- fuel pressure problem
- Question on purge line
- What do you guys have against ZEX?
- AN Fittings and a Tap?
- Bottle Left open?
- Timing Tuner
- giggle juice and trex
- window switch setting?
- I few questions before I order the bottle
- jetting ?
- My new kit, your thoughts please
- What stand alone system?
- NX Dual Nozzle Jets
- I finally did it!
- If anyone is looking....
- new best 2 stages, 8's soooo close!!!
- Two stage. Wet/Dry which 1st?
- spark plug is powder white?????????
- ZEX Fuel Pressure Shut off
- Installing a Cold Fusion Wet Kit...
- Nitrous wiring questions.
- what do yall think about this kit
- Dynotune NOS KIT Question
- What's the deal with the new HPTuners dry nitrous enrichment feature...
- nos/ timing question please help
- lots n20 ?s any advice welcome
- Ok nitrous gurus.. i've been thinking
- wiring question NEED HELP ASAP!!!
- Thought some of you N20 gurus might want to get involved in this disscusion
- Nitrous Shift points
- why is it
- A directport for the Sand Dunes
- Killer priced direct port!!!!
- ls4, and the bottle
- WOT Switch Pics on Gas Pedal
- 18 gauge wires
- 4an Vs. 6an
- Nitrous question
- Need To Beat 01 Cobra W/kb!!
- Racetronix fuel pump kit?
- Purge quit working?
- TR6's ok on a 150 shit?
- LT1 dry
- What happens if I run low on n2o during a run
- Nos Installation
- Nx Nxl Kit??
- f14 & n02
- SuperRam Question
- FJO window switch, what do you set the tach signal to?
- New Guy Here!
- Happy 4th!
- hsw nitrous?
- New setup - something a little different
- solenoid help????
- argh!
- Am I getting a 300 shot?
- What do you gap your TR6's to?
- Hidden halo kit/switches *PICS*
- Problems with Solenoid?
- Help Please, Solenoid relay closing
- fuel pump and plugs
- spraying on forged 402???
- Where are you F body guys mounting your MSD window switches?
- Cam n Nitrous
- will I get pulled over
- how much n20 on stock drivetrain
- any one
- Q on nx jetting
- Bare bones kit?
- Just Ordered TNT F2
- Can I use low fuel pressure on the NX shark nozzle's?
- Wiring question..
- EFILive Custom Nitrous Tuning
- If you have Dave's plate system........come inside please!!
- Safe to run Nitrous with TR55's?
- Some one help
- Sick of debugging nitrous system - Need some help.
- SES light came on after spray HELP!
- Timing Tuner
- Dry kit all finished, but it just isn't working right.
- Blowing fuse on relay power wire
- Need C5 Bottle install advice!!
- First time spraying, have a problem now
- Problems with Timing Tuner
- fuel supply for wet 100 shot?
- Air Fuel Cutoff?
- Nitrous Outlet/ Vacation Time
- Opinions Needed PLEASE
- Wide Band with HP Tuner
- The 4th and the spray
- repairing braided line...?
- 100shot and longtubes?
- My Dyno results 100 shot NOS plate
- new nitrous addict. .
- converting to wet
- Nitrous Express Gen X2 kit FS: BRAND NEW!
- Install time
- Racetronix Fuel pump install questions!!!!!
- lt1 cold fusion dry kit results
- C-5 Panel with Built in N20 gauge
- what brand of nitrous system do you use?
- just a quick question
- Stupid question: How do you know when to refill your Nitrous?
- 150 shot ?
- Custom Wiring harness.
- NEW Product. GTO Bottle Mount
- New progressive controller...
- BMN 1st gear lockout
- Fuel
- i hate wiring
- NX wtf is this...
- Price Increases
- T-Rex and a 300 shot??
- Running rich with Nitrous?
- Z06 MS3 + 150 wet
- Stock LS1... have NX kit... Need Advice!
- looking to do low 11's on 100 shot. 3.89's or 4.11's
- Where To Buy Jets?
- MSD window switch or NOS window switch?
- Wet Or Dry?
- window switch choices
- 4150 Plate for Vic Jr.
- 50 to 100 dry shot?
- Moneymaker backfires HELP!!!
- Solenoids upside down?
- Finally got some baseline numbers - Car is DONE!
- LT1 WOT placement
- single or dual nozzle, that is the ?
- nozzle placement ?
- Correct NX jetting for dual nozzel 200shot for a 408ci
- NX bottle opener part needed
- First Plumbing job ever. Pics
- Gonna spray it with the new DP kit this weekend.
- dual nozzle question
- attn: nitro dave
- converting to dual nozzle
- What's wrong with my wiring??
- Stroker N2O comp ratio
- Nitrious Line too short, Can I run a extension?
- conversion car NOS setup
- LSx Top 10 all time nitrous cars
- Nitrous cutting in and out.HELP
- Dynotune adjustable pressure switch...
- Fuel Safety switch
- Wanna go bigger on cam HELP!
- DynoTune A/F cutoff switch triggers with positive voltage.
- Fueling Question (nitrous realated)
- What shot on a stock motor?
- FJO Question
- Newb Help
- Smoke Help
- Should I be okay on a 100 shot?
- Picture of Nitrous Dave's Mounting Bracket?
- Setting up a front mounted FP Regulator...
- Switch panels pics
- how long does your 10 pound bottle last
- nozzle fitment
- scratch and dent kit
- How much is this spraying???
- PICS: my Nitrous Install---- 99% STEALTH =) ZEX Wet kit.... wheres the lines??
- Help with my wiring please!
- Which kit for an LS1?
- 2 stage?
- n2o question with H/C setup
- Double checking wiring
- Nx noids wiring
- My Nitrous Car For Sale
- Is this possible?
- C5-r Head Gaskets?
- Which Progressive controller do you guys like?
- thanks to chris @nitro daves
- So how do you know when you need a boost-a-pump?
- Who's spraying a 150 shot on SI?
- Standalone fuel system guys...
- New Product..Switch panel
- 75 or 100 shot??
- anyone use nitrous pro flow?
- Which jet with dry setup
- Fuel 'noid rebuild steps
- Last chance
- ****What fuel pumps do you recommend?****
- NX nitrous solenoid stuck closed (NX Boys/ Nitro Dave please have a look)
- Used TNT or Nitrous Direct
- How Often Do You Spray Poll
- Which window swich / controller?
- How high RPM can you safely spray?
- 6AN 45 degree Bottle Fitting
- Spray questions??
- Car "Bucks" when I Spray
- dynotune wet kit results on lt1
- purging onto radiator(or other ideas?)
- Is my fuel systen enough for a DRY shot?
- Installing a wet kit on an LT1
- Almost Time!
- Dry kit
- What else do I need?
- dry and wet shot at same time
- 150 shot/KB on 02 GT
- How much of a hit to go with?
- Purge line
- Average time drop from 150 shot?
- How do you hook up a blowdown tube?
- MSD Digital Window Switch
- NX Customer service is great
- Nitrous gains at the track??
- What heat range plugs are you guys running...
- 5177, MSD WS, & Dynotune TPS + Purge Wiring Schematic?
- Innovate Wideband
- next racing - nitrous update
- C6 vs Sprayed SS... need advice
- Nitrous gurus come inside please
- Which dry kit to use?
- What fuel system 402/n2o!!!!
- Too small of an rpm range?
- Anyone Looking for some Nitrous Stuff
- HSW Sudden impact wet dyno results
- Will emmisions matter with NOS?
- sprayin ga small dry shot through shifts?
- 125 Shot in the 5.3L S-10 good for 11's (Vid inside)
- Got me a new best today!!!!!!!!!!
- whos runnin a dry kit on a OBD1 lt1??
- Who wants this switch panel
- 150 shot safe with stock monifolds?
- Happy Fathers Day...
- bad bottle valve?
- NX pressure switch gone bad?
- BMN Window Switch problems...
- Custom bottle bracket fabirication begins. LARGE pictures
- Window switch rpm question
- New to Nitrous
- exhaust smoke on the juice
- Switch panel harness
- Custom switch panel (pics)
- what sponsors have the IC spray bar?
- BURST PANELS how to on FAST
- someone please explain
- HSW wet kits...
- Will it work?
- Wide bands
- nitrous and car insurance
- how to mount the bottle?
- Autolite AR93 Nitrous Plug
- need help with rotating assembly selection
- Intoducing.. The Black Widow!!!
- solenoid trouble
- Who has Nitrous Injection Rail
- Selling my NX bottle opener
- First N20 Pass of the year.... & ever! (Pics)
- Venom nitrous kit????
