View Full Version : Nitrous Oxide
  1. Texas Heat, How Much is TOO Much bottle Pressure?
  2. Possibley going TH400,vig 3200 ok for spray?
  3. Which plate do you like and why?
  4. blow down tube
  5. Will Stock Clutch Handle 100 Shot?
  6. Can I build a Dry Nitrous System from Parts?
  7. Best N02 kit for my setup
  8. Any one spraying 150 on stock fuel pump?
  9. Is 27 degrees of total advance too much for 150 shot?
  10. nitrous timing
  11. ATTN Nitro Dave!
  12. New member
  13. New N2O list! If you spray you must vote!
  14. 200 Shot recipe
  15. NOS brand bottle valve question.
  16. What kind of times to expect on a 125 shot?
  17. People who've installed DynoTune Two Stage RPM Window/TPS Switch PLEASE HELP...
  18. Just orderd some parts
  19. Do I need a fuel pressure regulator and FPSS? Where are they located?
  20. Opinions on best/fastest bottle heater
  21. wire clean up
  22. Nitrous/race parts for sale -
  23. Purge Help
  24. Good Nitrous Converter? Have SS4000/Getting New Tranny Perfect Time
  25. need help planning
  26. I sprayed 200 today and!!!
  27. Nitrous on 90,000 Highway Mile Car? Help!
  28. 9.3 video with hood ejection!
  29. NX bottle heater will not heat to over 800psi
  30. will an Lt1 nitrous kit fit an LS1?
  31. purging
  32. First Run
  33. what improvements did YOU guys see?
  34. Need a new thermostat for my bottle heater!
  35. Paging next!!!!!!
  36. finaly got some shake downs!!!!!!! new setup
  37. main feed line install
  38. piston in nitrous solenoid
  39. dry kits with 5lb bottles?
  40. Wrapped up on the Dyno 2 Stage Nitrous
  41. Lt1 Dual Nozzle Installation
  42. Diagram Request TB and Timing Tuner
  43. NX Bottle Question
  44. Pics of N2O setup
  45. Any place to hide a 10lbs bottle?
  46. Solenoids Noise
  47. Any tips on REMOVING the TNT power ring from tb?
  48. my wifes numbers
  49. edge or timing tuner
  50. nitrous not working????
  51. 90mm plate and stand alone questions
  52. Problems with tnt power ring?
  53. Why does my car Idle up 200rpms when my Window Switch is activated?
  54. Someone please check my wiring
  55. Bottle difficult to open/close
  56. Need help troublshooting NX 200shot on 408ci - low dyno numbers
  57. BIG shots on ls1 block
  58. I Hate the tnt power ring!
  59. Those with single gauge pods...
  60. Brain picking time...
  61. Dry Nitrous Kit Installation Tips?
  62. Set up for WOT?
  63. Window switch, tps, progressive programmer...IN ONE BOX!
  64. Do I need a Fuel Pump?
  65. Cam for 150 shot?
  66. How to mount the N/X (shark ) nozzle
  67. Where are you mounting your Full throttle switch?
  68. Nozzel holder?
  69. Solenoid problem
  70. Do you need a MSD window switch for a tune?
  71. FJO tuning
  72. Race Fuel with Nitrous
  73. test
  74. Sweet, Sweet Hardline
  75. N20 (300+) - what fuel are you using?
  76. How many runs down 1/4 on 10lb bottle
  77. why no lt1 guys using dry setup?
  78. Nos?
  79. Iridium plugs and Nitrous
  80. What else do I need???
  81. TNT Fuel solenoid sticking?Any one else?
  82. Question after MSD Digital Window Switch Install?
  83. Paging Nitro Dave
  84. To much gas
  85. NX Bottle weight
  86. Where to find switch panel.
  87. DynoTune Gauges Kick Ass!!!
  88. Plate System ?
  89. Any alternatives to TNT power ring?
  90. n20 help
  91. A little help please.
  92. switch panel
  93. Nitro Dave plate kit and 3500 2.5 str stall?
  94. N2O cam ?
  95. something went wrong
  96. Best Nitrous Kit for 98 Z28 DD (mostly stock)
  97. Nitrous and new Impalla SS
  98. anything like this ever happen to anyone.
  99. mallory 685 users...
  100. Beta Testing
  101. am i an idiot for going N20???
  102. Turn the bottle on and kill the motor instantly
  103. What to gap my plugs at?
  104. Thanks to Matt @ HSW...
  105. NOS controller 4 sale
  106. 400RWHP tired of getting beat by nitrous.
  107. HSW question
  108. Any good Nitrous Installers Near Northern Indiana?
  109. how many 1/4 runs on 15lb bottle..
  110. New NOS Controller for sale
  111. Msd Ignition
  112. ZEX or NX
  113. 5.62@120 with a 1.29 60ft on drag radials
  114. Need help with nitrous decision
  115. NX MAF question?
  116. Gonna get tuned
  117. a/f vs jet size?
  118. Nitrous Plug Size?
  119. Should I bump the jets?
  120. Why does a wet kit make more torque than dry?
  121. Hitting the dyno tomorrow morning..
  122. A Question for nitro daves stand alone fuel cell.
  123. Thanx Dave new lines are awesome!!
  124. Quick Operational Check
  125. Plugs
  126. Burst disc went off....couple ?s
  127. GTO Custom Switch Panels.
  128. Synergy All in One product line....
  129. Some LUV 4 LT1 Directport!!!
  130. Problems with my 5177 kit - need help
  131. C6 Z06 Video on the giggle gas, Bad Azz
  132. Nitrous works jets
  133. Need connector for harness...
  134. times on the dual stage
  135. Kudos to Ricky at NX
  136. Dyno tune A/F nitrous cutoff switch Q's
  137. Nitrous Heavy hitters.....PCM/EFI managment systems?
  138. N2O clean wiring pics
  139. Kicking around the idea of a DRY kit. Step inside.
  140. Nitro Dave' Customers Inside!!!
  141. NOS bottle safe on the trunk?
  142. Timing Tetard
  143. newb - dry 2 wet - mix & match zex & nx
  144. Guys with H/C motors and advanced timin
  145. Best Piston for Nitrous
  146. Few questions about the "Edge" from Harris Speed Works.
  147. Injector Spacer Nitrous Systems
  148. Bottle valve opener
  149. First time nitrous, need advice.
  150. Time for Nitrous!?
  151. how much?
  152. Is progressive controller good idea for 150 shot or less?
  153. Sneak Peak at a New HSW Plate Kit
  154. Where to buy new Nitrous jets for TNT kit?
  155. NOS Mini-Progressive controller FYI
  156. anyone know anything about ZEX? please help
  157. Who Makes The Best...
  158. Noyzee, Next, ESP, chef and many more in GMHTP
  159. Where is the filter on NOS 5177 kit? Should I have a seondary filter?
  160. 3qt fuel cell how quick out of gas
  161. New track Problem!
  162. Will I max out stock 75mm MAF?
  163. Nitrous Direct! Scott, pm clean out.
  164. Wet kit on carb... without plate..
  165. Wet or Dry
  166. stand alone fuel cell
  167. is it safe to run spray
  168. Spring Nitrous Kit Specials!!!
  169. Quick wiring question MSD WS box.
  170. Zo6 On Nos
  171. Install is almost there (pics)
  172. Jacobs mastermind?
  173. Anyone spraying on a yank 4400??
  174. Help me with the rest of my setup
  175. Tons of nitrous stuff for sale
  176. Purge Install Question - Do you need to drill?
  177. best dry kit???
  178. Removing a stuck fitting?
  179. /help me choose
  180. First Gear Lockout--Robert?
  181. Engine Build up
  182. Want to see the Zex kit innards?
  183. 11's capable with 100 shot?
  184. With my mods and a 100 shot, what kind of 1/4 mile times am I capable of?
  185. yaaaaaaaaaaaaaaaaaaa sprayed the 120 tonight
  186. quick question on the fuel side of wet kit.
  187. Rev limiter and window switch
  188. lean a/f
  189. First time nitrous installtion BIG!!!PICTURESS
  190. Nitrodave Help
  191. need help. FJO bogging
  192. Need TnT jetting asap
  193. 200 shot on stock 2001 z28
  194. Safe Memorial Day Weekend!!
  195. LSX w/ DP
  196. want pricing for..
  197. Nitrous (high miles LT-1)
  198. Hidden Purge?
  199. system will only work w/ jumper wire in on side of window switch?
  200. Wiring diagrams for Dynotune TPSWS and Wot switch?
  201. Nitrous Not used all the time, What to look for/Maintence
  202. Daily Driver Bottle Question
  203. 175 or 200 shot safe or not?
  204. High Mileage N2O...
  205. purge ?'s
  206. Anyone use the cold fusion plate?
  207. Polish TNT Bottle
  208. Wideband
  209. Yank Pt4000 with 100 shot?
  210. Wondering about #7.
  211. Preparing for 300 shot.
  212. times w/ and w/o nos
  213. threads on nozzles
  214. another newbe no2 ?
  215. Purge kit
  216. C5 install??
  217. Pro Shot & Sportsman Fogger ??'s
  218. Opinions on best Nitrous system for LS1 GTO
  219. Stock Bottom End + 200 Shot = Carnage Pics/Video
  220. no jets ok?
  221. Can I do a 200 shot?
  222. I've been busy this week!!!!
  223. Who has the fastest nos.
  224. Adjust FPSS or bigger fuel pump
  225. discovered my problem
  226. Another Directport for a Vette...
  227. Viton is holding up.
  228. Blow down tube for bottle between rear seats
  229. Safe to run 28* timing on 50 shot
  230. Odd electrical problem raised idel when armed
  231. LT1 plate system?
  232. Paging Nitrous Dave
  233. Dyno Tune Nitrous
  234. Z06 with Nitrous guys come in (and C5's)
  235. ? about halo kit
  236. Nitrous Outlet Track Truck
  237. Spark Plug Question
  238. Brand new dry kit
  239. NX Max 2: bare mininum to turn on
  240. purge not working
  241. solenoid fittings
  242. Nitrous today!
  243. Cost per pound of nitrous?
  244. check out my A/F on 200 shot.
  245. pulling timing-how much power loss?
  246. The white Z is alive!!!!!!! ls2 fired up!
  247. Just left the dyno. No more nitrous for me
  248. Lots of 250 wet shot questions.
  249. stick with the NX nozzle or get a Nitro Dave's plate
  250. Need help with jet size!!!
