- n20 backfire
- NX's "NXL" System
- High Compression and a 200 shot
- Nitrous Help
- New Noyzee racing mascott!!!!!!!
- Nitrous System Help Please
- How important is bottle angle?
- For The racers!!!
- FJO to Tune out Lean Spikes
- Nitrous on the way!! Couple questions...
- >Nitrous spark plug experts in here<
- bottle opener
- when to spray
- 224 581 cam and 5.3 heads....how much nos can?
- FJO WB Single vs Dual Channel System
- Ready for an upgrade 75 to 125...
- New FJO installation and new bottle pics :)-
- TNT ring ?
- sc ws6 question.
- Help on new NO2 system
- Will the Tranny Hold Up?
- How do I remove the siphon tube from a NOS 15 lb
- LT1 switch panel
- What should I be expecting?
- gonna let the 150 shot rip soon....
- Blowdown tube help
- Nitrous kit need help finding.............
- hey guys new to ls1 tech have a question
- NOS and My tranny?
- how much nitrous can go in a 2 stage?
- does nitrous go bad over time
- Fuel questions
- Bottle Jackets
- Wow!!!
- wet? dry?
- How to??
- Any dry kits rated @ wheels?
- I want to spray but....
- Remote bottle opener decision
- Can't find the fitting I need
- 50 shot?
- Bottle Blanket
- Lt1 Fpss?
- Solenoid "ON" status LED
- Need a Good NOS System
- thinking
- help with 2 stage dry kit (diagram inside)
- NOS 125 Dry questions
- OK back to the dry problems
- How to hook up a FPSS
- DP almost finished
- Bottle Heater Wiring Question
- Why Doesn't EVERYBODY Run One?
- Finally found out Why the Dyno Mule DIED.props to GM.
- NOS 5177 question
- What Can I do
- Dry guys which way do you have your nozzle pointed?
- picked up 1.3 seconds and 12 mph with NX 100 shot
- cam with 125 shot?
- Anyone running a Zex kit w/a digital window switch?
- This is gonna sound crazy, but....
- My Plate Install pic's
- rpm question
- bottle mounting on driveshaft hump
- NGK TR6 Plugs ok for N/A?
- Nitrous Air/Fuel?
- gunna get bottle heater
- You can say "NOS" now.
- sponsors I need some jets
- Need Some Analysis Help
- Any switch besides the BMN have 1st gear lockout?
- need wiring help
- What is a good basic window switch?
- Need fitting to mount fpps&guage off fuel rail
- NGK TR55 or TR6
- AWESOME Nitrous Bottle Sale!! - WOW!
- 10LB Nitrous Bottle Sale !!!
- 1/8 allen head plug ^ oil filter ok 2----
- help???
- What is the window switch for in a nitrous kit??
- anyone know where to get a 2-5 shot of nitrous
- Nitro daves plate Dyno #'s
- Which cam would be better for a 100 dry shot?
- FAST 90mm with TNT Kit *Pics
- how safe is a 50 shot????????????????????
- What fuel pump?
- N20 Question
- Flycut pistons VS N2O
- First time with nitrous... check my tenative setup...
- Used N2O kit, new wiring?
- just a few ?s
- Tuning for nitrous w/ only HPtuners and larger injectors?
- Tuning with nitrous ?'s
- intake teaser shot!!!!!!!
- First time I melted
- Project 1 Sweet Goat..
- Move update info.
- 2 stage controller
- Should i throw in a two stage for the hell of it?
- FJO Wiring Diagram
- i need some help
- Nitrous Controls
- Why does a wet kit hit harder?
- Nitrous Dave's Trick Window Switch Wiring
- multi stage.. poor mans first gear lockout?
- FJO wiring questions
- Gained 12mph with a 150shot :)
- Where can I get replacement t-stats for my NOS heater
- A4 + stock rearend vs. 100 dry shot
- where's the thread with the progressive controller comparisons?
- New Best E.T Boltons/Nitrous
- I need a little more help fellas!
- Routing of nitrous lines
- Nitrous install question, pics inside, please help.
- Rumor has it!!!!!!!!!!
- TNT 150 hit on stock tune- discussion
- Nitrous scale?
- Dry Kits Users Please Step In…
- Is 4.30 gears too much for 28" tires and spray?
- Stock Clutch vs. Nitrous
- ZEX POWER RACER plugs
- 90mm Ring? Where can you get one?
- Need A New Bottle- Zex Bottle Is The Worst!
- What fuel pump for a Wet Kit?
- results...eastside shortblock and tuning on the squeeze
- Solenoid clicking but not spraying?
- Flowing nozzles...tech question for the manufacturers
- Plate kit
- Msd Digital Window Switch
- What's a 100 DS feel like?
- Blow down tube for zex bottle?
- Powerblock
- Pro charger and nitrous a good idea??
- NOS 5177 questions
- Probable injector size?
- nitrous gap, compression, and size of shot?
- How much Nitris can a stock LS1 handle
- nitrous trouble shooting
- lt1 dry kit
- Speedtech Manifold Pressure Relief Panel...
- Does the FJO have a timing retard function?
- Bye-Bye Nitrous; hello Turbos
- Help install ZEX Nitrous Kit w/Purge
- Does your NX bottle opener get stuck?
- is my guage good?
- LT1 ZEX nitours kit?!?!?!
- 110 octane and spray?
- INSTALLTION INSTRUCTIONS FOR...NOS LS1 Dry Kit NOS05177
- need help!
- need complete bottle valve assembly
- C5 Direct Port Take 2.....
- Setting up for 5177 Questions
- Tuning for N2O Questions..
- Bottle Mount Bracket?
- Fill station pump question
- more progress last night!!! pics!
- More progress pics of the stang
- spraying 175 or 200 shot on LS1?
- Rail to Noid Question
- WS/WOT question?
- NX Fuel Solenoid Problem
- momentary contact switches
- NOS Blowdown fitting?
- does anyone make a tb plate for fast 90?
- 100-75 shot safe on my h/c setup?
- Stand alone guys: Using alternative fuel?
- Anyone runnig a full throttle Timing Tuner?
- Wet kit for Camaro
- Closed Friday/ 03-10-06
- Hiding the FPSS on a DRY Kit?
- got some work done!! progress!
- is nitrous worth it?
- What do I need to do??
- How to wire 2 stages of dry and 1 NX Wet???
- My Fjo Ordered! NEED SOME HELP FROM coldfusion -
- Nitrous Help!!
- Nitrous Stall Help?
- bottle size.
- Nitrous tuning with IAT
- Terminoligy Question.
- Dry plus wet?
- Dynotune purge MALFUNCTION!
- when is 860 gonna make...
- Need New Valve For Zex Bottle
- 2 step w/ clutch switch
- would it be dumnb to spray again ?
- Stand Alone Fuel Setup.. what kind of fuel pressure??
- 1st Spray and Some Feedback
- nitro dave, looking for pics
- wiring help please
- Need pics of........
- Am I doing OK?
- Fuel octane requirements for TNT F1 150 shot
- Window switch wiring help
- NX Maf Kit
- Nitrous Bottle Mount spots.
- ----Learn to speak Nitrous:-------
- Big Dry Shot?
- Intake is done!! now to the n2o guy!!!
- dry kit questions
- Purge question
- Zex Bottle Leaking
- What are you using for a purge line?
- How much can i spray on stock fuel pump with svo 30#
- New Web Site
- Flaring tool recommendation...
- Are ngk's gapped right.......
- Time for the Spray?
- New best on motor and Spray!
- Wiring a Basic Wet Kit?
- Purge question
- Purge request
- NX dry downgrade
- Wow how plans change...
- OKAY which fogger nozzle ????
- what is THE BEST kit for 700-$$ (wet)
- Who the hell? POL!!!
- can svo 30's support 600 rwhp......
- blowdown needed for trunk mount?
- weird one
- I had a nitrous backfire last night and...
- Zex wet kit + NOS window switch wiring?
- tach imput on c5 for window switch
- Questions for N2O for intake air cooling only.
- Nitrous Oxide
- NEWB to Nitrous
- 75 shot ok need to know asap
- First time out on the juice
- spray+mahle pistons=?
- Shark Nozzle + Fernco Mod?
- stand alone time
- My pile-o-parts
- Another New Part NX is offering to our customers.
- What will 150hp shot do to my MPH????
- Questions about shifting six speeds with nitrous
- MSD Digital 7 programable with 250+ shot
- Can a larger nitrous line actually give you more power?
- Injector Question
- Do I Need More Fuel Pressure??/
- what timming on a 125-150 shot
- LT1 with nitrous.......
- Bottle location
- Buying Nitrous on a Budget, Need Advice
- Next Upgrade...Cam or Nitrous?
- Dry shot/weather/performance
- Problems with my new NXL fogger kit
- Is DP worth the extra 600$
- need nitrous cam help
- how can i tell if i am getting a signal from my wire tap on?
- My cam with nitrous
