- What are you using for a purge line?
- How much can i spray on stock fuel pump with svo 30#
- New Web Site
- Flaring tool recommendation...
- Are ngk's gapped right.......
- Time for the Spray?
- New best on motor and Spray!
- Wiring a Basic Wet Kit?
- Purge question
- Purge request
- NX dry downgrade
- Wow how plans change...
- OKAY which fogger nozzle ????
- what is THE BEST kit for 700-$$ (wet)
- Who the hell? POL!!!
- can svo 30's support 600 rwhp......
- blowdown needed for trunk mount?
- weird one
- I had a nitrous backfire last night and...
- Zex wet kit + NOS window switch wiring?
- tach imput on c5 for window switch
- Questions for N2O for intake air cooling only.
- Nitrous Oxide
- NEWB to Nitrous
- 75 shot ok need to know asap
- First time out on the juice
- spray+mahle pistons=?
- Shark Nozzle + Fernco Mod?
- stand alone time
- My pile-o-parts
- Another New Part NX is offering to our customers.
- What will 150hp shot do to my MPH????
- Questions about shifting six speeds with nitrous
- MSD Digital 7 programable with 250+ shot
- Can a larger nitrous line actually give you more power?
- Injector Question
- Do I Need More Fuel Pressure??/
- what timming on a 125-150 shot
- LT1 with nitrous.......
- Bottle location
- Buying Nitrous on a Budget, Need Advice
- Next Upgrade...Cam or Nitrous?
- Dry shot/weather/performance
- Problems with my new NXL fogger kit
- Is DP worth the extra 600$
- need nitrous cam help
- how can i tell if i am getting a signal from my wire tap on?
- My cam with nitrous
- Dave's LS1 Nitros Plate for sale
- More progress pics
- looking for fpss
- NX iceman solenoids
- N2O and tuning?
- What size will it take?
- my new dry set-up
- How old is this?
- Diect port vs Fogger?
- Nitrous gets the nod!
- Installed my Zex Wet Kit
- Water Temp Guage (mechanical) Question
- 200 shot
- opinions on how i setup my dual stage wiring...
- starter ket
- Nitro Dave's customer service!
- Bottle mounting
- bogging down at launch. why
- Nitrous Gallery
- Negative Effects of PCV Delete with N2O?
- plugs ??
- New to Nitrous
- NEED JETS for a noszle kit anyone
- I want dry nitrous, but just a little !
- BMN controller..how does it lock out 1st gear of 6-spd?
- cam okay for small shot....
- Dry vs Wet, Bog Launch Videos, and tech talk
- Dry Kit Questions...
- Stand Alone Fuel Pressure Question/Discussion:
- msd digital w/s help
- flaring tools
- which heads are better for nitrous
- What kit for a dual quad carbs??
- Heres the done deal install pic what you think?
- How much mph did you gain in the 1/4 w/nitrous?
- Robert 56 come inside please
- !!! Super Cool !!! Photos: Nitrous Outlet Stand Alone!!!
- Why pull timing?
- Fuel?
- safe 250 shot possible?
- Reverse Split Cams
- How much vaccum does a bung welded onto a collect pull?
- going from 125 shot to 250+
- 2 stage dry
- Window Switch Settings????
- questions about my new kit and 200 shot
- Anyone got a car for sale.?
- Nx Maf -dual Feed Single Stage
- nozzle shootout
- anyone looking for a stand-a-lone fuel setup?
- Problems with wot switch!
- looking for some msd pills
- NOS 5115 kit *pics* is this how i would hook it up?
- Need help with some fittings
- sprayed for the first time!
- Nitrous Vending/race car trailer
- Nitrous Outlet is Moving!!!
- hooking up kit and now car wont start!
- Outlaws Custom Direct Port Plummbing (Pics)
- I need a few things...
- Made a tubing bender last night...
- Why not a progressive controller single stage?
- Flames?
- Puddle-ing?... how to prevent it???
- Best way to hook up Mech. N2O guage
- 02 Z06 Nitrous Setups
- Nitro Dave's Nitrous Outlet
- need to find "ignition on"
- Whats nitrous?
- Cam thats works well with N20
- NX LT1 jet sizes
- harris speed works nitrous???
- Custom distribution blocks...
- nitrous questions
- Direct Port 4 noids or 2
- zex wet kit???
- Nitrous questions
- nitrous converter...............
- Partial TPi nitrous kit??
- Problems !!!!
- New Dynotune dry results
- Question TNT Power Ring
- Contemplating nitrous ideas...
- Detailed dry install pics and instructions?
- Cold Fusion Nitrous
- just bought a noszle setup, have questions
- Propane parts help
- trex and nitrous
- LS1 Tech
- Help with a wiring diagram please?
- can I get a nut?
- wet kit and dual nitrous solonoid
- --New Product-- DynoTune Time Based Nitrous Controller
- ? about dynoing stuff. and dif. in rpm and mph.
- Anodized Color for new Plates
- Set Shift Points (A4) ; Extended
- Attention! Nitrous Forum Policy
- Polished Bottles!!!!!!
- Another sweet Custom Directport...
- Nothing Compares to our plate!!!
- Predator Dynos
- Upgrade injectors for 100 dry shot?
- perferred wall thickness on SS tubing for...
- 15 lb Bottle
- 5115 kit dilemma need some help, have quite a few questions...
- Spraying 150 wet shot...clutch and bottom end?
- Considering new setup...again
- post pics of the best lookin dry kit
- Inspecting Solenoids
- dual stage ?
- probs w/ a dry kit????
- stand alone question
- What happened...
- retarding my ingnition ????
- spark plug gap??
- Comapring pieces of a puzzle.
- Discussion: Nitrous nozzle design and is it important?
- Wiring Up My Bottle Heater...need Help Quick
- need fuel pressure safety switch for 99 camaro (HELP!)
- How do I remove the bottle valve?
- NX Ricky or Jeremy Help please. Fuse sizes?
- How much can stock bottom can take?
- Single plane Nitrous plate? (Nitrous Sponsors)
- The 'Big Brown Truck' came today...
- how cold does it get?
- Who makes a good N20 controller?
- Spark plugs
- hidden nos
- NOS sponsors inside please
- direct port or wet system
- NOS Noszle DP kit
- NX Kit
- largest dry-kit recomendations on a 402
- FJO wiring Diagram please
- The Stand Alone has arrived...
- help getting in touch with TNT
- Few pics of my dry setup
- TNT mounting bracket w/ NWTB
- Nitrous and road racing...
- ** Huge News ** Hot New Product!!
- wiring diagram
- Vendors need help....Y distribution blocks
- Need help with micro switch & fast/NW TB!!!!!
- Which tubing bender is this...
- wet or dry???
- IAT question
- mythbusters!
- Am I Safe?
- NX rail tech question
- timing dilema
- Nozzle Placement
- Check this out!!!!
- bottle mounting gauge question
- New Product
- High pressure fuel hose??
- Dry learning curve
- Looking for opinions/advice on how to finish my nitrous...
- TNT F1 kit
- Lots of nitrous questions
- First impressions 6061 T6 aircraft tubing
- switches
- Stand alone fuel options
- FPSS problems-
- Highest dp shot on pump
- Sonsers! do you have a plate that will fit....
- 3/16" SS tubing bender options
- Looking for pics of Nitrous set-ups
- hmmmm
- FJO questions
- Should I worry about this?
- Fuel pumps...one or two?
- Just when you thinks it's safe...
- pictures
- dual stage NOS kit?
- Here It Is Gto Guys !!!
- Dyno Tune dry kit results
- Congrats to Taner on pump gas drags
- Any regrets?
- Fuel cell with nitrous kit?
- time for me to spray
- Venturi = Boost?
- what plugs with FJO controller?
- New noids and nozzle installed,What you think
- bottles
- THANK YOU Cold Fusion Nitrous
- Nitrous Upgrades???
- Few more steps!!!!!!
- what wires are you using
- Advantages and Disadvantages if SS vs Aluminum lines
- What pills (NX maf kit)
- how much nitrous on stock 99 trans am
- new test:nx noid vs dynotune
- hidden system purge?
- tnt 2 stage ?
- nitrous for your speakers NX get in here
- My doesn't like nitrous anymore!
- Vette bottle mounting location?
- N20 Relay help
- Nitrous and cops. What kind of punishments?
- Parts to convert single stage wet into dual stage dry/wet?
- can a 15 lb bottle fit in spare tire area?
- distribution block question
