View Full Version : Nitrous Oxide
  1. And the Free Plate Conversion Goes to...
  2. Is a relay required to run a purge solinoid?
  3. My Install
  4. 2 stages 1 wet 1 dry.
  5. Max HP with NOS 5177 Dry Kit?
  6. max rwhp from small nx noid
  7. 90mm TNT power ring
  8. Dynotune window switch w/TPS question
  9. 200+ shot guys, what gear?
  10. Pressure Regulators
  11. two way switch.....
  12. what kind of numbers?
  13. what about the zex dry system?
  14. Can you use a fuel noid as a purge noid?
  15. FJO Progressive questions
  16. Progressive Nitrous Controllers?
  17. We are Back and Its a new year!!!
  18. Accessory Guages?
  19. Timing?
  20. can someone please explain what happens when your run too lean
  21. Nitrous on a 100k motor
  22. Just oredered my Dynotune wet nitrous kit
  23. NX jetting ?
  24. Cold Fusion Nitrous Systems wet kit? Good Kits?
  25. Nitrous Setup (pics)
  26. 3lb. bottles? and manual sparay?
  27. wanting to go from dry to wet...
  28. NOS kit FS
  29. What makes a good Nitrous cam??
  30. can't find the hole
  31. Happy New Year
  32. Solnoid bottle opener???
  33. Burst Panel
  34. 2006 New Nitrous List....
  35. quick plug question
  36. NOS or not.
  37. What fuel & plugs are you high HP nitrous guys useing??
  38. whats a safe shot to use?
  39. TNT F1 wet kit? any good???
  40. How much power are you making on stock pistons?
  41. Those running dedicated fuel cells
  42. How to adjust pills in WS?
  43. Rwhp ?
  44. nitros quesiton
  45. Dry Shot/Nozzle Questions
  46. Could some one help me out (Spark Plug Issue)
  47. NX versus Ny-trex nozzle
  48. Nitrous wiring help
  49. Unsure about wire on MSD Window switch
  50. Wet system Nozzle mount question
  51. Wiring for Mini-Progressive, 2step, transbrake?
  52. fuel injectors for 200 shot
  53. will i need a re-tune?
  54. GM High Tech Performance-Jan issue
  55. 06 300C NX project
  56. MSD digital window switch?
  57. Bottle Mount Question
  58. nx dp kit?
  59. window switch
  60. Thanks Dynotune!
  61. Is it rice?
  62. Spraying my blower setup?
  63. Zex bottle warmer??
  64. Jet sizes??
  65. Nos Single Nozzle Pill Chart
  66. BIGGGG shot guys (400+)
  67. Thank You!!!!
  68. harlan 2-step wiring question
  69. Anyone have the HSW angle?
  70. Cold Fusion purge (pics)
  71. sorry for the newb question...
  72. Question for NX...
  73. MSD Digital Window Switch - Which wire to which pins on relay?
  74. Here's one you'd never expect...
  75. Which gears with a 100 shot 6 speed?
  76. Can i use a 150 shot?
  77. 150 shot?
  78. 200 shot ?
  79. My new CFN Nitrous Set-up
  80. Introducing the new Dynotune Premium Bottle Warmer!!!!
  81. Will 2 10lb bottles fit.......
  82. Nos 5176 questions
  83. Bottle warmer with pressure switch??
  84. lookin for install pics of dry dynotune kit...
  85. Whats too high of compression to run with nitrous?
  86. My mom kicks ass!!!!! x-mas gift!!!
  87. bottle?
  88. TNT Noid Bracket
  89. Single Stage Prog. Dyno Sheet???
  90. Biggest shot with a TNT ring?
  91. Help deciding between two NX kits
  92. Those with MSD window switch
  93. wiring for a two stage setup
  94. Quick solenoid question.....
  95. 250 on pump gas 502?
  96. NX TPS Switch Which wire..
  97. Nitrous Pressure / Bottle pressure discussion
  98. Critique My new Nitrous Plan
  99. How long is No2 good sitting in a bottle
  100. Would i need to upgrade fuel injectors if...
  101. spark plugs w/ a bad tune?
  102. NX CF bottle, need exact weight.
  103. Why not use aluminum for direct port -3AN?
  104. Fjo Clearence Products...
  105. 2 stage setup question
  106. Purge Kit
  107. wot switch install option, mounted
  108. Few N20 Install ?'s
  109. Directport
  110. Progressive Controller special!!!!
  111. spare 5-pin relays locally?
  112. Dry Nozzle From Nx... Thats Right Dry
  113. Best Wet kit?
  114. NX Dry Kit
  115. 100shot...results on bone stock ls1 no mods?
  116. MAF SPECIAL FOR NX MAF SYSTEM 100.00off
  117. FAST with 2 stages???
  118. Spray before air filter?
  119. wet or dry
  120. FUEL PURGING (next big thing)
  121. Does a blower cam make for a good nitrous cam?
  122. LS1 Nitrous Wet Kit
  123. Braided line
  124. How often do you change your spark plugs?
  125. Greg here is your intake...
  126. Personal Preference?
  127. Happy Holidays From Nitrousdirect
  128. Just got FJO Racing Progressive Controller
  129. pills
  130. How long?
  131. LT1 guys with AFR heads. What plugs for nitrous?
  132. Some questions about DynoTune controller and solenoids
  133. new spark plugs when juiced?
  134. new spark plugs for n20?
  135. 250 shot on hyperutectic pistons????
  136. Is this a fair price (Labor)
  137. new christmas ornament
  138. Looking for a #$*&@ rocker switch
  139. Timing Tuner with FJO?
  140. Used NX KIt 4 Sale..
  141. how many times
  142. What's the easiest/cheapest way to upgrade to dual stage?
  143. What Switches
  144. 860 bottle heater
  145. Fuel and Nitrous Supply questions
  146. I think I have the final answer to my thurst for juice.
  147. help with gauges
  148. 125rwhp shot safe on a 100k w/boltons tranny?
  149. NX wet kit ?
  150. Aux fuel cell
  151. Tune Revealed Problems
  152. Can I run 100 wet shot on my stock motor with no problems?
  153. High pressure test results
  154. Bigger injectors
  155. MERRY CHRISTMAS!!!Holliday Hours!!
  156. I made it into a magazine!!! : )
  157. Heater on while spraying?
  158. Best kit to buy
  159. 150 rwhp shot safe on stock LS1?
  160. Who sells the ash tray switch panel?
  161. 98 Injectors
  162. anyone have a 5800rpm pill for msd...
  163. Zex Dry Kit Question
  164. nitrous on ls1 in the long run? damage/wear in the future?
  165. NOS plate system Vs. ZEX system for LS1, opinions needed!!!
  166. question for N20 pro. . .
  167. What Spec On Cam To Look For
  168. braided vs nylon lines...
  169. Question on mounting of solenoids
  170. Sheetmetal intake and DP
  171. Spark Plugs
  172. Dry Kit Question
  173. Need Help - NX MAF kit...
  174. 2 MSD Window Switches $70
  175. Nx MAF for sale...$250 obo
  176. Purge Line Question
  177. what times should I get with this kit
  178. Nx Whp Gains?
  179. First Nitros kit!.......
  180. Nitrous Tuning ?
  181. Question About NX Jets...See Dyno.
  182. NX Jets
  183. new to NOS need a little help
  184. hose seperators
  185. 150 jets
  186. Wideband Upgrade new release for FJO.
  187. Help me find a nitrous friendly cam>>
  188. nos shots
  189. Got bored
  190. Few more noob questions.
  191. Nitrous/Propane Dyno
  192. 150 dry shot, how can i hide it?
  193. MAF for dry NOS kit
  194. Its a Sad Day
  195. Almost became a thief today...
  196. Lightning winners needed....
  197. Nxrickey I Need Help Again !!!!!
  198. next nitrous breakthrough
  199. Opinions on my nitrous set up
  200. Possible New idea for wet kit placement
  201. Can we get an agreement?.....OR ELSE
  202. You guys Ready for the kicker?
  203. Need some Christmas cheer Here!!!
  204. How about a 50 dollar credit!!!
  205. Dry Jet coversions from motor to wheels?
  206. Max dry shot on stock fuel system with 28lb injectors?
  207. Nitrous Outlet Now Carrys NOS Products..
  208. ashtray switch panels....
  209. why products cost more, NXRicky rambleing.
  210. Race Gas And Nitrous
  211. NXRicky I have a Mastermind II app question...
  212. Stupid question... need answer quick
  213. Is there a progressive controller that allows you to control flow based on SPEED?
  214. NX progressive controller?
  215. Solenoid openers
  216. Who is this???????????
  217. Nitrous Discussion Concerning Chemical Makeup
  218. What is the fastest dry shot LS or LT?
  219. Can someone set me straight?
  220. Looking for a good Nitrous read........
  221. I need a 90mm ring for a new NW TRB.
  222. can I put 175 jets in a TNT F1?
  223. Hidden Nitrous System?
  224. NX Mainline
  225. Who sells the complete stand alone fuel kit....
  226. Nxrackey Need Help
  227. Nitrous mounting setup..
  228. LT1 Plate+nozzle 2 stage questions
  229. NX progressive controller info?
  230. conventional play with gmmp single plane and carb styler TB?
  231. Anyone purgeing through a dry nozzle????
  232. NX Heater blanket kit...
  233. How much gain with 125 dry shot
  234. A New Sticky Idea
  235. Dry Shot: IATs
  236. NX Shark Nozzle ?
  237. Nitrous Pressure Discussion.
  238. Dyno #'s
  239. Missing purge parts?
  240. LT1 Switch ideas
  241. Post up your nitrous dyno graphs
  242. who all has the timming tuner??
  243. Paging Dynotune nitrous
  244. whats a good setup for me
  245. Zex dry kit on LS1???
  246. 6.0 liter intake
  247. OH YEAH A4 175 shot 1/4 mile times
  248. Couple cam/nitrous questions
  249. DynoTune bottle opener ?
  250. Logged: Lean A/F: Small Dry shot
