View Full Version : Nitrous Oxide
  1. Fuel Pump
  2. Anyone use nx #60040?
  3. Dual stage direct port kits
  4. How much do u think i can spray 250+?
  5. Anyone use Champion S57C plugs?
  6. I know Ive asked this before...but i lost the thread
  7. Nitrous tune vs. NA tune ?
  8. Wideband gauge
  9. Can you fit...
  10. Does N20 go bad with age?
  11. Anti Pre-ignition Additives
  12. C5 Install Pics
  13. Does this progressive controller exist?
  14. How much do you pay for nitrous?
  15. Recomendations On NX Amount ?
  16. Can I spray a 150 shot with my NOS 5177?
  17. refill help please.
  18. Innovate Wide Band With Gauge --- $249!!!!!
  19. best N20 kits
  20. 4.30 gear and Nitrous?????
  21. removing nitrous kit to sell it...and i cracked the fuel rail..kinda.
  22. MSD Digital Window Switch
  23. Nitrous, bad idea?
  24. Over heating after nitous run!!
  25. top gun solenoids
  26. Cold Fusion Nitrous
  27. Anyone have a Speed Eng. Switch panel
  28. Dynotune - great cust service! THANKS
  29. A/F ratio-double check my wire before i cut please :)
  30. Anybody with a forged 408's spraying?
  31. New plate systems,Have some questions...
  32. MSD Digital Install, guide me on the wiring....
  33. autos and spray
  34. Will the CFN-1100 kit work with LS1s?
  35. Confirm NX Jets for NX DUAL NOZZLE 100 Shot
  36. any way to hide a shark nozzle? <wet kit>
  37. Is this everything i need. Geting NX w/Extras
  38. Is it a bad to run more fuel?
  39. NX Maximizer II dyno tests inside with dyno graph
  40. ash tray switch panel on ebay?
  41. POLL: Bottle Warmer Color, Speak up!
  42. Nitrous for Lt1
  43. Just installed my mega blaster purge
  44. Nitrous Install is underway OBSERVATIONS (The BANDIT)
  45. Ordered my NX kit today
  46. Directport Time!!!!
  47. how to delay a shot on an M6 till 3rd
  48. N2O Newbie needs advice.
  49. Zex Kit in stock motor. need info
  50. question about 2 stage?
  51. Look!!!
  52. will nitrous work with this cam
  53. Does NX make a twin nozzle kit??
  54. Question For Nitrous Users
  55. possible issues with NX fill station. help!!!
  56. Clever ways to hide nitrous
  57. Basic Nitrous Oxide N20 Information
  58. Hurricane Rita
  59. Anyone hear that Hard lining Nitorus eliminates Lag of N20 Hit?
  60. Tune your WET Kit by adding more fuel pills?
  61. MSD Dig Window switch Tach wire
  62. nitrous backfire
  63. Dry people. What bottle pressure do you use?
  64. NX "WARRANTY"????????????
  65. I'm going nitrous!!!
  66. bad bottle???
  67. question about a set up
  68. Flow differences: -4 / -6
  69. What The Hell?
  70. 175 shot, 93 octane, timing?
  71. car died mid run. Please help.
  72. Which Setup Should I Use
  73. why does the air box pop loosewhen I spray in 1st gear?
  74. why use a stand alone fuel??
  75. scanmaster ?
  76. best price for NOS 15384 Progressive Controller
  77. Stand alone fuel cell.
  78. Here's a dumb question..
  79. Fuel needs
  80. New Toy
  81. what should i run
  82. Setting up new direct port...
  83. FPSS, fuel pressure gauge, and wet kit all at once???
  84. N20 leak?
  85. Got some good results with the wet/dry 225 shot.
  86. Cold fusion users
  87. 1/4 miles time with all stock motor 200 shot
  88. N2o help - wiring..
  89. Just read TNT Power Ring in CHP. I now think i am hooked. Questions tho..
  90. C5 and Predator getting Nitrous
  91. what to do???
  92. Here it is.Plate system Pricing...
  93. Problems spraying for 1st time
  94. The Video of one hell of a race NOS vs Turbo
  95. Pulsing 'noids...HOW BAD IS IT REALLY?
  96. Check out this awesome Nitrous Garage Sale
  97. pictures of DIRECTPORTS and dual stages
  98. help with first spray!
  99. dip stick popping out
  100. First nitrous pass
  101. NX Direct Port kit: Need tube flare and bender
  102. hey nx ricky
  103. Has anyone seen this mustang blow up on dyno?
  104. NX QUALITY....Top Notch!
  105. Alternative to Thunder Shootout --- Need Input
  106. KR with NOS tune
  107. Sheet Metal intake and Nitrous
  108. nitrous tune
  109. SPY Picks of new Solenoids..
  110. New 346 nitrous combo....PICS
  111. How much will it handle?
  112. Nitrous Car takes out the Twin Turbo
  113. Progressive Controllers - Which one?
  114. 5 Nitrous Sponsors on 1 site gots to be a record.
  115. nitrous newbie here....
  116. Let me know what you think
  117. guys with tr 224/224 cams ! look !!!!!!!!
  118. Question about sprayin a 150 shot on a C5 ???
  119. Spray Activation
  120. Just ordered a F13 and....
  121. RPM Module Range
  122. Fpss
  123. New Site Sponsor
  124. how do you hook up to your fuel system
  125. dry/wet a4 car rwhp???
  126. How much timing to pull w/a 200shot
  127. Can anyone tell me why I keep burning up the #7 spark plug?
  128. 5177 & k&n cai
  129. spray and traction.
  130. TR6 Plugs
  131. wet or dry
  132. Would a narrow band work decently enough with an A/F gauge?
  133. what to do next?
  134. hiden nos
  135. what needed to run a 5177 kit?
  136. NX install help
  137. bottle weight
  138. got mods...how big of a dry shot?
  139. Thinking about a Nitrous Outlet kit for stock WS6...
  140. Will I be safe to spray with this setup?
  141. Finicky bottle opener
  142. MAF Gemini System...???
  143. D1SC on C6 8 pounds of boost
  144. lowest A/F ration on dry kit?
  145. Unique place to hide a NOS kit....
  146. Aeromotive fuel pump/Injectors
  147. too lean?
  148. Will this work? trying to install dynotune gauge..
  149. Spray through shifts
  150. Single NX Jets
  151. Purge Install and Braided Line Question (Big Show Purge). Vette
  152. Nitrous w/ an M6, need advice
  153. Nitrous on an auto
  154. dynotune nitrous kit
  155. 125 shot on 5177 dry kit??
  156. can nitrous leak cause high idle?
  157. .022 fuel jet instead of nitrous jet
  158. 10lb Bottle Question...
  159. What size injectors?
  160. PM'S will be behind
  161. How critical is it toadd TR6's with a 100 shot wet?
  162. Z06 needs nitrous help
  163. In car 12 volt switched power
  164. Just an observation (wideband results, stock fuel WS6)
  165. Is there a timing retard box available for a C5 on N20?
  166. Is there a timing retard box available for a C5 on N20?
  167. "BIG DOGS" inside please
  168. need help with timing tuner settings
  169. timing tuner activation
  170. Thread Sealer Question.
  171. bottle pressure too high??
  172. quick question guys before we spray the car
  173. Dumb question for nitrous Experts
  174. NOSzle question
  175. Dry kit
  176. not working?
  177. TNT nitrous tuning question
  178. NX jetting?
  179. Just installed my 5177 kit, red relay wire fell out
  180. Nos fogger nozzle jet size?
  181. ZEX or NX express
  182. Advise me: best setup for my 04 Vette
  183. largest shot out of NX
  184. NX heater wireing diagram
  185. n00b w/ dry kit question..
  186. which gauges?
  187. Fuel Pressure Guages
  188. Another newb question...
  189. 4cyl kit on ls1
  190. nitrous works??? is it any good
  191. Any good pages on how to plumb a direct port
  192. NX wet kit or TNT wetkit??
  193. nitrous for and lt1
  194. how much nitrous
  195. Please help guys! In the middle!
  196. What should air fuel ratios be when spraying.
  197. New TPS switch, The Trigger!
  198. NX Remote Bottle Opener
  199. Need help installing purge kit..
  200. What will a 26lb inj and stock pump support
  201. Trouble shooting a NOS dry kit.
  202. NX Dealers...
  203. NOS line getting new ends????
  204. spark plug gap
  205. msd digital window switch?
  206. 175hp TNT jets?
  207. Need help installing Nitrous Express Bottle Opener...
  208. Maximizer II issues
  209. Just ordered the LS1 125 Dry Kit,
  210. Question for DYNOTUNE or maybe someelse can help....
  211. 5177 kit still not working...
  212. Fittings clogged
  213. Problems...
  214. Can I use a single TNT nozzle for 100 shot?
  215. Dry users, a mech pressure regulator for consistant runs
  216. Switch questions
  217. nitrooo dave, 90/90 DP?
  218. 5177 kit jetting
  219. TNT kit = IMPRESSED
  220. Solenoid/line Selection (help)...
  221. Should I go with a bigger shot?
  222. Check out this knucklehead nitrous install
  223. paging 383LQ4SS
  224. what kit are you LS6 guys running ?
  225. Race challenge
  226. Sources of switched power
  227. NEW Nitrous Progressive.... MULTI-POINT RAMP
  228. Darton blocks and NO2
  229. Sneak peek at the LS1 plate.
  230. halo kit
  231. NX Jetting Chart Question
  232. How many runs?
  233. nitrous quality
  234. Testing new system
  235. 15lbs bottle between rear seats, ooo yes. Pics inside.
  236. max effort cam for nitrous
  237. stall
  238. denso iridium plugs
  239. Question about NX switch panel..
  240. TNT Nitrous Filter??
  241. The Mark! Digital nitrous bottle contents indicator!
  242. Twisted Sanity Nitrous Controllers
  243. cam + nitrous question
  244. What makes the best street car Nitrous, Supercharger, Turbo?
  245. Why not direct port?
  246. Wiring help
  247. Want to build a low 10/ high 9 street car
  248. C6 10.96@128 on spray
  249. window switch
  250. ANOTHER Bmn Window Switch Problem
