View Full Version : Nitrous Oxide
  1. anyone interested in 6 foggers?
  2. Bottle Fill Problems
  3. Purge through WS6 hood?
  4. MSD Adjustable Low RPM Module
  5. Stock Exhaust OK?
  6. wet or dry kit
  7. Halo system
  8. Do any wet nozzles have 4an fittings?
  9. Best Place for Nitrous
  10. nitrous newb
  11. Nitrous System Installation Complete!
  12. RAMCHARGER timing tuner users...inside please.
  13. Anyone interested in a nice NX Kit?
  14. from dry to wet
  15. Bottle Set Up Opinions C5 (Pics! Dial Up Beware)
  16. Magnacharger and Nitrous
  17. do I need anything else?
  18. v6 or v8? nitrous or no? today or tommorrow? you decide
  19. Nitrous rocks
  20. 860 Bottle Heater Wiring?
  21. NOS 05177 Dry Kit Wanted
  22. nitrous quality?
  23. Pinging...Help
  24. ALMOST Done My Nitrous System Installation!
  25. dry to wet conversion
  26. what size injectors??? help please
  27. Corvette (TPS or WOT Switch?)
  28. Dry shot at 2000 rpms?
  29. 408 + 200 shot, would an intank and inline supply enough fuel!!??
  30. difference between different forms of nitrous
  31. Purge solenoid smoking
  32. Nitro Daves "fuse box side" Stand Alone fuel system - Installed Pics!
  33. TNT jets (200, 250)
  34. zex n2o kit????
  35. timing tuner question?
  36. IAT sensor location using NOS and KN FIPK
  37. 91 Octane Fuel
  38. #28 and #30 pills for a DP=?
  39. Can my fuel pump take it??
  40. tr6 tr55 question
  41. stock ls1?
  42. note of thanks to NX
  43. Putting in 216-220 114lsa and wet nitrous kit.
  44. Jet size for NX 200 or 225 shot
  45. nitrous jet question where?
  46. what NX wet shot jet sizes for 125 and 150 shot
  47. my new N20 goodies:)
  48. Little Help Needed Ref. Console Switch Assembly
  49. Tach signal wire location, and is it MSD window switch compatable?
  50. FPSS Location
  51. NX Dual Nozzle Nozzles in Coupler, or TNT Power ring?
  52. BMN Windows Switch W/1st Gear L/O Questions
  53. hiden? help
  54. Nitrous Nozzle location
  55. Nitrous with supercharger?
  56. Should run what????
  57. Nitrous for a dummy
  58. WS6 nos install problems
  59. Been kicking myself over tuning for a dry setup../
  60. Pics of my new nitrous setup....(56k beware)
  61. help me with zex wiring
  62. What Nitrous for me?
  63. stock fuel pump with cam and 75 shot?
  64. steering wheel radio controls for NOS anyone do this???
  65. ? on how much i can spray
  66. So...who's running a dry direct port?
  67. Should I get a bigger stall if I spray?
  68. NOS NOSzel system
  69. where are you guys mounting your n.o.s switches for t/a?
  70. Nx Jets
  71. Installing BMN window switch
  72. Had a FPSS failure
  73. need opinions on my set-up
  74. NOS 05177 kit any poniters
  75. Dual Stage NOS Set up pics Please!
  76. Zex plug-in bottle heater
  77. nitrous wiring question
  78. timing tuner
  79. how to run a 150 DP
  80. which nitrous kit makes the best power ?
  81. Nitrous Question
  82. Torquer and NX??
  83. FS: Dynotune Auto Warmer
  84. 1-gallon cell dimensions?
  85. Small dry kit + 4000 stall?
  86. Race Gas and Nitrous
  87. Maximier 2 why it is the best.!
  88. Autometer Cobalt Nitrous Pressure Gauge
  89. Newbie to nitrous..
  90. nitrous A4 problem
  91. n20 leaning out 7 & 8
  92. BMN or MSD Digital? Which one should I use?
  93. bottle heater relay pinout
  94. Car tuned lean N/A.. Need help with jetting???
  95. Is my car leaning out because n2o?
  96. Fastest LSx nitrous Car in the world??
  97. Dry kit Lean spike ???
  98. need another bottle
  99. what size pills to use for wet 100 shot nos
  100. Rough Startup after N20?
  101. This guy has no clue!!!
  102. nitrous experts step in-->
  103. Do all NX nitrous solenoids have a port on the bottom?
  104. Installing Dynotune Purge Kit on TNT F1
  105. my n2o install coming up soon
  106. Took the plung and got the nitrous kit tuned in...
  107. trade nitrous bottle?
  108. Dedicated Fuel system SPECIAL!!!!!!
  109. Check Out this Bad Azz Set-up
  110. Which Fitting would be Better????
  111. TNT ring with NW TB?
  112. Andy...Here it is....
  113. Battery and 10lbs bottle in spare tire well?
  114. Nitrous for the Vette
  115. So I broke down
  116. Bottle heater question??
  117. Where are all the "purpose built" NOS race cars?
  118. Plumbing the intake ...
  119. I need help.
  120. Spraying into 5th gear?
  121. Timing ?? On Spray
  122. tuning for n2o
  123. Nos Pro race fogger Vs. NX Shark
  124. 860 heated Bracket
  125. Update 1 PIECE MAF KIT
  126. Any good stuff in store for us N2O guys???
  127. Switch panel install tip.
  128. 2-stage 250 shot..
  129. single nozzle or direct port
  130. What the hell.....
  131. thermostat question
  132. my switch panel
  133. what is the acdelco #
  134. Dynotune bottle opener on NOS Hi-flow valve?
  135. I Hit the Juice and It is GOOD
  136. Wet kit Questions
  137. bmn switch, where i tach wire
  138. Question about lightweight flywheel and nitrous
  139. 150 shot picked up 2 tenths???what could it be?
  140. Gas Puddle?
  141. Upgraded Fuel System??
  142. Nitrous Guys: What *feels* faster? Spray or boost?
  143. time for a new engine...who do u suggest?
  144. dual nozzle pics
  145. NX peak pressure
  146. Should I go from 150 to 200 shot?
  147. wet to dry, two nitrous noids?
  148. NX Phase 3 Gemini Quad vs. NOS 2 Stage Double Cross Bar
  149. Check out the Altronics 8 egt datalogger graph
  150. Where can I find???/
  151. Went to the 1/8th can't wait to ADD my Bottle. What times with that?
  152. TNT Install
  153. Install $375+ !?!?!
  154. Zex Wet Kit Promble
  155. pressure drop during run
  156. Using hard lines from solenoid to nozzle
  157. best fuel pumps for a 150 shot
  158. window switch/spraying through shifts??
  159. dry/wet 2-stage pics??
  160. any M6 guys here spraying with stock 10 bolt?
  161. Robert56 - BMN timing pull diagram
  162. Standard bottle nuts fit on motorcycle bottle valves?
  163. 1st time running N20, diff, than expected
  164. Hmmm . . . Some help please ...
  165. Pics of TNT installs...
  166. August Nitrous Specials...
  167. BMN RPM Window Switch Questions!
  168. My hose busted :(
  169. harlan window switch
  170. What should my car run on a 150 shot?
  171. Jimmy jam micro switch???
  172. How much timing do you run on 200+ shot?
  173. Think my FPSS is broke?
  174. Please help
  175. Nitrous cam?
  176. Does anyone want 95deg thermostats for their heater?
  177. Dry shot a/f ratio
  178. Any one have any kits for sale?
  179. nx wet kit selenoids placement...pics possibly?
  180. Which NX dealers accept Paypal or Discover Card?
  181. Sneaky N20
  182. O2 sensors went bad?
  183. Nitrous Problem, PLEASE help me solve it
  184. NX shot leaning out a/f,do Ichange jet size?
  185. 2 nozzles duel stage questions
  186. It's august dave
  187. Does nitrous go bad?
  188. MSD Digital Window switches INSTOCK
  189. Spark plug after 75 shot popping out exhaust.
  190. There must be a big difference in wet to dry nozzles...
  191. Looking in to No2 and have a few qs
  192. jetting and plugs
  193. help me decide
  194. Had to blueprint my new NX remote opener.
  195. 3 New Bests this weekend!!!!!!!
  196. So with the Zex kit....?
  197. Gauge lights
  198. Nitrous tune
  199. Wet kit fuel line question
  200. problem with nitrous
  201. Nitrous cam
  202. TNT help quick.....
  203. Fuel Pressure Question
  204. what Kit to chose and not hurt the engine
  205. Tr6 Plugs!!??
  206. what size jets?
  207. Nitrous Causing Problems... Help!!!
  208. Valve Stem Again..
  209. leaks
  210. Checked my plugs today.....
  211. Dynotune Electric Nitrous Pressure Gauge Sale!!!!
  212. just got my nitrous hooked up!
  213. Remote Bottle Opener Control Module. NEW U can use a reg switch.
  214. feels like it is running out of nitrous?!?
  215. 427 into the 9's? Nitrous Question
  216. Nitrous with 11 or 11.5:1 compression?
  217. stock fuel?
  218. FS: NX Kit w/ Accessories
  219. 112 LOS on spray
  220. Can I hit the N20 before 3k RPM's with a Dry Shot?
  221. CR question...
  222. 28.8# injectors ok with 150 wet shot??
  223. 340RW but wanna shoot 100 dry....
  224. Nitrous and other goodies for sale!
  225. BMN Window Switch Wiring ?
  226. Who is using NX Maximizer with FJO Wideband?
  227. fog light electrical pins?
  228. NX/Nitrous Outlet EFI System Installation Help Needed!
  229. How much can rear handle?
  230. Help!! Tach wire on the C6 Auto!
  231. TNT F1 kit..
  232. A few pics of my bracket for solenoids...
  233. Should I do spray on my engine? Will it hurt it?
  234. Anyone using a TNT ring w/ smooth bellows?
  235. Cheap Dry nozzle...
  236. bellows for 85mm maf -> power ring
  237. old style NX maximizer, is it worth it to wire it up?
  238. "Wet" to "Dry" Trend...?
  239. finally got my nitrous working...
  240. Dave@tnt q's?
  241. #10 wire on a 2000 z28?
  242. relay wiring
  243. Some N20 ?s
  244. NOS Pressure Guage leaking...help
  245. how accurate are the shots??
  246. bottle refills
  247. Halo Kit Users
  248. dry nitrous
  249. 100 shot??
  250. nozzle drill
