View Full Version : Nitrous Oxide
  1. Coming soon project.....
  2. Will a zex style (mechanical) bottle opener fit my venom bottle?
  3. WTF is going on here? (long)
  4. Spraying out the hole!
  5. nitrous express install on 2000 z
  6. need nitrous engine bay pics
  7. Not enough?
  8. Dynotune Purge having issues
  9. What fuel pump for 650rwhp?
  10. How do you know when to spray more, or sooner?
  11. dyno tune nitrous switch center...blue wire confusion?
  12. Mounting bottle ?????
  13. need diagram of MSD digital window switch
  14. Question about NOS kit
  15. Nitrous Bottle Blow Out!!!!!!
  16. finaly got the danm dry kit in...purge ?
  17. What's A good GTO kit
  18. *PERFECT No2 CAM*
  19. TNT jetting questions
  20. best nitrious kit for my LT1
  21. Hard line DP users/installers
  22. -3 hose and fittings
  23. Stupidity or Opinion
  24. nitrous issues.
  25. David@TNT and Dyno Tune guys please
  26. plugs for a 150 shot
  27. does anyone have NOSsle kit installed
  28. BMN tach input wire problem...
  29. Maximizer II... Questions & Comments
  30. Best DP for your $$$
  31. nx kit is bad ass
  32. Nitrous bottle opener opinions please...
  33. Psi gauge is ashtray
  34. nx tpas & bmn wiring please
  35. Sctratched Bottle Sale....
  36. New Nitrous Guy
  37. Dry NOS 1577 or TNT Wet shot??
  38. Cubic Inch / Nitrous ratio...
  39. Defensive Driving...
  40. 100 octane in my car. Make a difference??
  41. Where the hell do I get my bottle filled (SoCal)?
  42. Timing vs Race Gas on Spray
  43. nitrogen push
  44. nitrogen pushed fuel?
  45. Anyone interested in trading the NX MAF kit for a TNT Power ring kit :)
  46. NX direct port in summit??
  47. MSD 2 Step
  48. Does anyone have a preference in nitrous filling stations?
  49. 2 stage wiring on same wot and window switch.
  50. Mounting Bottle In Spare Tire Well?
  51. How do you keep the bottle temps down?
  52. Need a good 150+ shot setup for a G5X2 cammed car
  53. Tune with Nitrous=less Na?
  54. pics engine bay direct port
  55. Tuning ?
  56. Whats Better NX or TNT?
  57. ***attention*** Nitro Dave
  58. 100 tnt wet shot ??
  59. Does compressed air have weight?
  60. Nitrous mishaps
  61. Do bigger lines = a bigger purge
  62. fpss and filter for tnt kit
  63. What injectors should I go with?
  64. TNT kit not working... sprays, but
  65. Who makes....
  66. 100,000 mile car
  67. edelbrock bottle heater wiring diagram
  68. what is best
  69. Nitro Dave or Dyno Dean....
  70. [Nitrous Newbie] Why can't I see the nitrous when I purge?
  71. Safe psi
  72. New #s with NOS
  73. guys with sheet metal manifolds post pics of your direct port!!
  74. Anyone spray a FM11 cam?
  75. track results with nx dp kit!!
  76. My TR6 gapped .32...why?
  77. Problem with fuel..
  78. where to buy???
  79. ANyone know if NX and NOS jets are interchangable
  80. How many seperate circuits should I run??
  81. Does the line have to be under the car?
  82. Corvette TPS and Window switch wiring help!
  83. MSD Window Switch into shift light???
  84. Top Gun Solenoids?
  85. Dry Shot Injector ?????
  86. need pics of ur bottle mount in the spare tire area...
  87. Stealth Switches CUSTOM!! PICS
  88. wet/dry
  89. working on setting up 100dry shot on my new car
  90. Question about n2o critical pressure
  91. A bit irritated with my purge...
  92. ANY Changes to a NX WET GM #20920-10 it lately?
  93. Nitrous timing retard question
  94. where to mount my nitrous switches
  95. Post Bottle Setups!
  96. Direct port: Hard lines vs Braided lines...
  97. Bottle mount places???
  98. TNT Address?
  99. Timing Tuner users....Step inside.
  100. Spraying the Z for the first time this weekend...NERVOUS
  101. Anyone direct port users..
  102. Purge question
  103. WOT switch question
  104. How much spray are you getting away with on stock LS1 bottom ends?
  105. Was going NOS Dry 05177, now thinking Wet,,Opinions?
  106. jimmy jams panel mounting
  107. switches!
  108. Got TNT kit in mail 2day. Have ?s
  109. Nitrous Question
  110. Please Help-What TNT Noid Bracket?
  111. Propane and nitrous?
  112. Nitrous Dave special vs TNT f1 kit
  113. Anyone run a Dry kit on a Z06???
  114. Who has the best prices on the MSD Digital switch?
  115. I need some nitrous help!!!
  116. how much hp and tq with 100 shot?
  117. nitrous backfire
  118. Gains(?)of a 100 Shot on H/C/Bolt On M6
  119. TNT 100 shot
  120. N20 newbie... What kit is the best "bang for your $?"
  121. Question about fuel line
  122. Risk of buying used direct port kit?
  123. funnel vs flare jets?
  124. N.O.S. jet sizes - QUIZ
  125. Noid problem!!!!!
  126. do you think this switch panel ill work?
  127. 5% - 15% off Nitrous kits and accessories!!!
  128. NitroDave/NX Ricky....which is better idea to lean out AF ratio??
  129. 5177 kit
  130. questions on a nos kit
  131. -4AN FEMALE x 1/8 NPT MALE Adapter
  132. Tune with 100 shot dry?
  133. Will NGK plugs fit on my car?
  134. How will i do??
  135. Redynoed the NX Dual stage controller on RevX 408
  136. This readings safe for a 150 shot?....
  137. What if my bottle isn't installed angled up?
  138. Ok heres my dyno sheet from my nitrous runs. Critiques?
  139. Nitrous install on Horsepower TV
  140. Z06 '4', Mod/Cobra '0' and BFG DR/N2O update
  141. Nitros Steel Braid Lines
  142. 150hp Shot On Bone Stock Ls1
  143. Vette w/ SS4000 & wanting DRY Shot. How bad is my TC?
  144. Jets!!!
  145. Need cheap "front" of a dry kit
  146. nitrous dyno help
  147. User Vs Wet kits! CAR GOES BOOOM
  148. major ZEX kit problem
  149. Props to Nitro Dave!!!
  150. CONGRATS Harris Speed Works!!!!!
  151. Want Nitrous DRY SHOT on my A4,,,Help.
  152. Dyno #'s with PRC heads and FM-8 and 225 shot
  153. LT1 Nitrous Express MAF System?
  154. Tell me what you think
  155. Called NOS and this what they told me...
  156. N2O and 'Big Meat'
  157. TNT F1 kit????? help fast!
  158. Nos with 6speed questions.
  159. 300 shot on 408??
  160. My newest N2O project!!!!!!!!! SWEET!!
  161. Timing and AFR readings from Tech 2 scanner
  162. Questions about my set up...
  163. Nitro Dave Need info please
  164. Thanks Dave!
  165. My custom dynotune setup!!!! pic
  166. Basice jet chart?? Nitro dave maybe?
  167. NICK What do you think!!!!!!
  168. 200 Shot
  169. FS **Complete direct port setup, FAST 90TB, more**
  170. 5177 Kit Questions
  171. complete set up questions
  172. Is it dangerous to spray in first gear?
  173. What fuel pump and brand of remote bottle opener?
  174. newbie question
  175. Help find me this TNT noid bracket
  176. BMN rpm nitrous switch
  177. First spray...
  178. Direct port NX question
  179. What else do i need????
  180. Carbon Fiber Bottle Knob...
  181. Few quick questions...
  182. Anyone have pic of Vette with Power Ring?
  183. Please help! Need to get Noids Checked
  184. Using the Maximizer w/ four solenoids
  185. ?'s on 100 dry shot
  186. Relay mounting
  187. TPS or switch?
  188. Fuel Pressure Safty Switch.
  189. BEST gauges-digital?
  190. Refill Station?
  191. Best Nitrous?
  192. Nitrous Outlet Garage Sale...
  193. bottle install bracket pictures for tire well area
  194. venom on lt1
  195. what's a good a/f to be at when spraying?
  196. Converting LT1 nitrous system to LS6 nitrous system
  197. throttle position sensor question?
  198. What Nitrous kit for C5Z06 with 11.5 compression?
  199. Nitrous bumper drag.
  200. Nitrous Issue, no one knows what to do!
  201. Dip in nitrous dyno caused by what?
  202. spraying on a n/a tune with racegas.
  203. BMN window switch
  204. nitrous works....
  205. MSD WS Pill question
  206. Looking for 2 stage setup advice
  207. Anyone have pics of switches w/cheetah shifter
  208. Pill size help!
  209. Nitrous + Blower
  210. Nitrous and Timing
  211. Nitrous putting me in the 11's
  212. Plug Gaps and Brand?????
  213. First Timer and Happy!
  214. Zex Machine Gun Purge
  215. NX MAF vs. Single Nozzle Wet Kit?
  216. Sparyed the 408 with TNT F-1
  217. Master Blaster Purge System?
  218. Nitrous issues.
  219. Full throttle switch??
  220. Highest CR on forged 383, 200-300 DP
  221. Just ran my 150s last night and I like em!!
  222. Where to buy another Nipple and Nut for a Nitrous Express bottle
  223. how many miles are you guys getting from tr6's?
  224. Nitrous not working right??
  225. dry shot timing pulled automaticly?
  226. Jetting Size Needed
  227. Does Nitrous eliminates altitude?
  228. Got my LT-4 Direct port back
  229. anyone spray more with a tnt F1 kit then 150 with just upping jets
  230. Nx Maf Kit
  231. MSD Digital window switch?
  232. 100dry + 150wet what all is needed?
  233. Timing ?....
  234. M6 nitrous users: Advice needed!
  235. Kit Nos 5177
  236. should i spray a dry 100 shot before or after the maf
  237. Lsx ?????
  238. What fuel system for 250 wet shot?
  239. The Corvette Fuel system!!!!
  240. Bottle Pressure on HOT vs COLD days?
  241. Nitrous Junkies *help reading plugs
  242. Does a 10lb bottle actually get 10lbs of nitrous?
  243. Pic of your Bottle Set up
  244. would it be stupid?
  245. Remote Opener is stuck on???
  246. Can u put a nos jet there?
  247. How To Mount Bottle In Hatch Above Gas Tank?
  248. Merry Christmas to me!
  249. tnt problem
  250. Effect of too much retard
