View Full Version : Nitrous Oxide
  1. Does a 10lb bottle actually get 10lbs of nitrous?
  2. Pic of your Bottle Set up
  3. would it be stupid?
  4. Remote Opener is stuck on???
  5. Can u put a nos jet there?
  6. How To Mount Bottle In Hatch Above Gas Tank?
  7. Merry Christmas to me!
  8. tnt problem
  9. Effect of too much retard
  10. Nitrous window switch controlled by factory pcm!
  11. nitrous help quick
  12. Wet vs. Dry: Effectivnes?
  13. Pics of TNT kit on a vette?
  14. Need help on tnt f1 kit wiring w/ BMN...
  15. Need a wiring diagram
  16. Got the N20 going today...
  17. TNT f1 kit
  18. Puddling?
  19. A/F on a 150 shot
  20. Im back..
  21. Best cam
  22. What is everybody running for timing at WOT with 100 or 150 Shot?
  23. 125 NX wet shot pill sizes??
  24. Nitrous V.S. Supercharger
  25. corvette NX kit work on my SS?
  26. edelbrock bottle heater wiring diagram
  27. Question on bottle heater...
  28. Best stealth kit for a forged motor?
  29. I need NX wet kit install pics.
  30. Is it still safe to spray?
  31. want pics of spray patter on fuel thru a nozzlw
  32. Wet system--Purge fuel line?
  33. First fill and bottle leaking.....
  34. An NX MAF kit running stock exhaust.
  35. Zex TPS Hook up help
  36. Installing on new cars w/warranty
  37. First passes with Dual Stage
  38. Maximizer Questions...
  39. Dynotech Power Plate?
  40. what angle nossles do i need for my DP kit
  41. nitrous ?? with headers tune???
  42. Wet or Dry?
  43. Off The Line??
  44. Anyone using this ebay window switch?
  45. Finally LSX is here
  46. Couple N2O setup questions..
  47. Pulling Timing
  48. Fuel injetors
  49. Help W/ Spark Plugs And Stock#s
  50. Cop and N20
  51. 1st gear lockout
  52. nitrous setup advice
  53. What is YOUR preferred Warmer setup and why?
  54. LQ9 motor takes a 300 shot easily.
  55. please need help fast! leaving in 30 min
  56. How many shoot off the line?
  57. Bad Idea To Spray My Car?
  58. Advice on a TNT F4 Direct Port 200 shot on stock block...yes, I am crazy.
  59. Spraying in 1st ?
  60. nitrous works pics
  61. N20 Newb
  62. Lookie what i got
  63. Bottle and torches NONO
  64. a bit of carnage
  65. nitrous
  66. Damnit!!
  67. Air in lines
  68. Plug gap for 300 shot.
  69. Spark plugs?
  70. Nitrous Prediction...
  71. MSD window switch modified for LS1
  72. Purging
  73. 90* fitting on nozzle?
  74. Pictures and Video of my Weekend with Nitrous
  75. Dry kit on lt1
  76. FPSS Question
  77. Tuning with NOS?
  78. 128k, to spray or no?
  79. How important is the nitros filter?
  80. Wet shot & Fast 90MM? Maximum safe shot?
  81. bottle opener
  82. Guys spraying a 150 wet shot...
  83. nitrous problems
  84. Nitrous users producing 550 rwhp
  85. Direct Port!
  86. Does anyone run a bottle heater and blanket at the same time?
  87. 100 shot hits week
  88. Help with BMN Nitro Controller
  89. nuB question... Can you have a seperate fuel tank for a wet system?
  90. Does Russell or Earl's make these?
  91. Very Important Question Please Answer
  92. tps switch which wire?
  93. Need education on converting to Dry....
  94. WET vrs DRY
  95. ok well nitrous still not working!!
  96. Nitrous ?'s
  97. Calling BMN !!
  98. Will this work on a 94z28???
  99. switches
  100. tnt f1 kit
  101. nitrous all the sudden doesnt spray anymore?
  102. fuel pump ?
  103. Anyone ever used a kit from the nitrous works
  104. N2O Help Please!!!
  105. Need Help
  106. Dry kit jet help
  107. How do I do a wet system on a LT1
  108. TNT Power ring for a LS1
  109. Help with desicion please
  110. Transbrake + Nitrous
  111. **In memory of Nitro Dave's Father **
  112. Need Help
  113. TNT dyno challenge
  114. calling NEXT!!!
  115. Hey guys...
  116. Nitrous List
  117. Progressive Controllers
  118. the biggest shot
  119. What heads for a car running nitrous
  120. Nitrous Problems! Please help!!!
  121. Ramcharger Timing Tuner...
  122. question about problem with my nitrous....
  123. Spark Plugs
  124. no jets
  125. What Plugs to run for 150 hit............
  126. f/s nx2stage new!
  127. Check out my intake for my TNT F4 kit, it was plumbed before painting...
  128. from dry to wet..
  129. C16 in fuel cell=WAY rich.
  130. nos help
  131. Largest bottle in spare tire well?
  132. Where to purge?
  133. how are you 150-200 shot guys comming out of the hole? m6 cars only.
  134. MSD or Kenne Bell boost-a-pump for N2O???
  135. Colder Plugs = .2-.3 ET loss N/A
  136. ZEX direct port LSX intake kit
  137. First hit on the juice
  138. oil dipstick pops out every time nos is sprayed,why?
  139. Test fit my HPE Ring today...
  140. Have a problem with nitrous!
  141. Best window switch?
  142. Relay Question. Anyone know how much amperage...
  143. Fuel spray w/o N20 pressure during testing
  144. 150 shot no a stock car?
  145. Zex No2??
  146. Welcome our newest Nitrous mod Robert56
  147. best bellow to mount nozzles w/85mm maf, 90mm tb
  148. Which motors compression would work better for n2o
  149. Small Dry shot on ls2
  150. Harlan window switch.
  151. Gauges?
  152. Bad Azz N2O Video
  153. Nitrous and fuel Pressure
  154. Stand Alone Fuel System and a few other Q's
  155. Nitrous Outlets Dry Kits..
  156. New Maximizer 2 release software.
  157. Whats our fuel pressure?
  158. Methanol Injection
  159. A sneak peek 4 you guys...
  160. Is this ok and safe???
  161. Double check my system for me
  162. Safe to run a 50 or 75 shot without a dyno tune?
  163. Purge Question
  164. NX kit Fuel Line
  165. Ramchargers timing tuner question
  166. steal on new in the box wet kit
  167. Does TNT have a fitting like NX to hold nozzle
  168. DYNO TUNE great products & cust. service
  169. my R6 with nitrous
  170. How many passes on a 150 shot?
  171. Nx/fjo Tps?????
  172. What causes a Nitrous backfire?
  173. Sorry, i couldnt find anything. m6 and wetkits
  174. Teflon Paste?
  175. an sizing
  176. Stand Alone fuel system question.
  177. A4 Nitrous Guys Inside
  178. Would you spray?
  179. dynotune vs. cold fusion dry kits
  180. how much will a 100-150 shot drop my 60
  181. 860 Bottle Bracket Heater SAVE NOW!!!!
  182. Ummmm
  183. Need help. Harlan window switch w/ TNT F1
  184. Another Dry shots hit hard ....(with video)
  185. Fuel fitting question
  186. Another Nitrous/Fuel pump question
  187. Inline Pumps No Good For N20?
  188. How much N02 with heads/cam?
  189. Nothing is working right!
  190. Decent article on bottle heating
  191. Jet question???
  192. inline nitrous gauge
  193. nitrous bottle painted
  194. Nitrous hp peak
  195. finally sprayed my truck: got questions
  196. Windows switch?
  197. Ok try this again.. WHAT PILLS FOR 100-150 SHOT
  198. NX Jets Needed
  199. Attn. Nitrous geniuses!!
  200. Newb questions - Help me out w/ my setup please! (TNT)
  201. Full Throttle Tuner?
  202. Certifiicate needed to buy nitrous? New Law?
  203. Anybody running the NOS Universal Wet Kit?
  204. How much for a used NX gemini Kit?
  205. NOS on 10.8:1 comp
  206. New nx setup - clean...
  207. nitrous downshift?
  208. Killing 03'Cobra's with NOS?
  209. How Many Runs
  210. 100,000MIles; Should I spray?
  211. Should I use a purge system?
  212. Medical Grade Nitrous
  213. Install Is Happening As We Speak!
  214. Shooting in first!
  215. What happended at 4400rpms
  216. NX Radio Controlled Cars Nitrous Systems
  217. Is this NOS 5177 kit complete?
  218. nozzles in stock maf housing?
  219. Small N2O bottels
  220. Fuel rail fitting
  221. what WOT timming?
  222. NX 125 jets?
  223. What pressure is everyone spraying there wet kit at...?
  224. nx & 4L60-E question
  225. Voice activation and verification?
  226. fogger pics
  227. Where to put the purge!!
  228. tnt noid the same as a cold fusion?
  229. LS1 Tech Dual Nozzle Special!!!
  230. New/old style NX Maf kits??
  231. Thanks DynoTune!
  232. NX Maf jetting? Dave, Ricky?
  233. FAQ and Guide To NOS
  234. 85mm Prtotype Done and in house.
  235. got a few ?s for you guys
  236. Could I use a zex wet kit from a VW?
  237. finaly a few pics of my setup.
  238. Gas vs. Metal
  239. Anyone from wisconsin give a helping hand?
  240. help me get all the parts needed
  241. Can i spray with out a window switch and be safe.
  242. N2o numbers
  243. Spraying on TR55's?
  244. *pics* New Direct Port
  245. NX MAF kit???
  246. convince me...nitrous VS FI
  247. TNT vs. NX
  248. new track times after intake install
  249. Installing a wet kit
  250. HELP!!! In need of funnel jets for the cold fusion direct port
