- Phew..Running Nitrous is a Wire Mess!!!
- Nitrous question
- need help finding a part
- Want More
- whats the biggest shot i can run with 91 pump gas?
- Dry shot doing crazy stuff, big hit thru single nozzle
- Wet vs Dry
- Purge Momentary Switch
- z06 pics - nitrous MELTDOWN
- Stock Rod vs after market question
- Need #57 nitrous jet
- Bought an f2 kit...question
- FPSS...Off Fuel Rail..or After Nitrous Noid?
- 346-347 on spray????
- Purging Questions
- 5177 Dry Kit Open Line HP???
- Lean Spike on Activation
- Installed new Walbro FP, car still detonates 100 shot?
- TNT 100 shot seems soft out of the hole??
- Dry kits doo hit hard....
- Nitro Dave Quick Question!
- Harlen Window Switch Users
- What brand of fogger system
- What kind of gains from 100 to 150 shot?
- Great customer service from dyno tune...
- Ran 12.5@115 on the juice today...
- What jets
- FYI: Nitrous and plugs...
- 12 compression + nos = safe or boom???
- wired right
- TNT 150shot question...
- NXRicky and Nitro Dave
- Dry Nitrous kit
- What flare tool for DP lines?
- Relay necessary for dynotune purge valve?
- New to the N2o scene....need some help
- Help me find a n20 solenoid......
- Nitrous Filter Sale!!!
- Safe Shot
- Need some help(rough idle, o2's)
- Need Cold Fusion Nitrous Jet Settings
- NOS vs. TNT solinoids
- Where do i get a new oring for the power ring
- Power ring porting!!
- Any other window switch good besides MSD?
- Bottle heater Question?
- dry-to-wet suggestions...?
- NO2 choices...HELP
- Oh My Dear Lord!!!!!!
- Fuel Pressure Regulator
- 150 Wet Kit
- Im gonna do it open noid
- power drop off on my 100 shot! bottle pressure
- ZEX Direct Port issue after going up in jets. Any clue?
- tnt power ring nozzle dumping extra fuel
- NOS with catalytic convertors in place?
- Spraying 125 shot questions.
- Nitrous Switch
- cheap way to remove timing
- Purge Lines?
- What are the jets for a 175 shot?
- Direct port help again pic inside
- window switch to a switch
- Jet Size with open Solenoid
- My NX Install w/pics
- Anyone know the part # for the 5177 Nozzles?
- bottle valve stuck
- part number for nos 5177 solenoid bracket?
- (ADvise Please.) sTILL Confused after searching
- sprayed today and............
- Fuel Pump ????????
- Fuel Pressure Regulator or not??
- Can an Eagle 408 hold a 200 shot safely?
- nitrous solenoid problem =(
- 20 lbs ... 20 lb bottle?
- nitrous press gauge
- 800+RWHP with a 346 & Nitrous
- TNT f4 kit, wiring q?
- I did it!! Finally :)
- how many bottle have you used safely
- Another nitrous video pass
- Is my intake plumbed wrong??
- whats a good nitrous filter
- 12v ignition source??
- mix and match HELP!
- 3 install questions???
- Switch panel????
- Is this real.... any pros for these??
- has anyone turned the horn buttons on steering wheel into momentary n2o switch?
- newbe nitrous question
- Whats needed to run 200-300 all dry shot with single nossle?
- NOS instructions
- fast shift on nos
- Fuel pressure safety switch question
- Can i bump up my shot????
- 408 owners please chime in
- NX TPAS switch with Timing tuner wiring?
- Launching with big convertor?
- msd window switch with no loops wont work?
- N2O in a Car Wreck
- probably a stupid question about n2o
- 150NOS wet shot ok with flycut pistons?
- TNT 150 gave me alot more..:)
- A/F Ratio shut-down switch or FPSS?
- Time analysis
- wasting time ???
- Help...Engine revving out of control :(
- up it or not????
- how to test to see if solenoid?
- Dyno results w/ TNT wet (100)
- people with the TIMING TUNER come in.
- Your perfect kit.
- Too much stall and gear?
- Which way to face
- Mounting nozzles in LSX?
- Mounting Harlen Window switch
- where to mount msd rpm box ?
- Angry nitrous user
- nozzle mounting
- Nxricky
- How far in does nozzle need to be on TNT power ring?
- Nitrous Bottle Question...
- Nx single nozzel kit owners?
- Install pics; custom switch panel, DIY purge LEDs...
- Which window switch pills to run?
- where are you guy mounting your rectangle dynotune nitrous gauges?
- Nitrous and Hypertech PPIII?
- PART # FOR tr6'S PLUGS?
- Direct port install question?
- Anyone with a direct port need 250hp jets??
- Check out my DynoTune Nitrous gauge
- Just sprayed the 150rwhp shot- Need advice.
- Spraying Stocker
- Alright, stupid question time!!!
- Wire diagram for the NX switch panel.
- safety first!
- Is there a prefered kit??
- Just installed my NX wet kit
- Nitrous Failure problem?
- Nitrous wet shot with no 02 sensors
- New custom nitrous switches installed (pics)
- Wiring help
- Dual stage or single big shot?
- Looking For FPSS Install Pics
- cam/150 and under shot..what fuel mods?
- TNT Ring? what color are they?
- Quick Jetting Question
- I need a JET CHART
- heat range question
- Whats the cheapest price...
- Mounting Bottle
- nitrous gurus please shine in ?????
- How much of a shot?
- Questions about LS1 NXL wet kit
- Nitrous worries
- Stressed please tell me. AHHH
- Nitrous ?
- N2O+Stock short block@5500ft
- Does anyone know how long it's safe to use the same N2O Noid?
- NOS5177 purge?
- Ready to purchase N20, What else would I need.......
- nxricky thanks for you help
- what should i use?
- Wet Shot on LS1 won't make it threw intake??
- Z06 W/ TNT 100 Shot!
- Spraying in 4th gear a4?
- how do you install a nitrous guage from the pillar pod?
- first nitrous casulity
- Solenoids in trunk??? No heater on dry setup?
- Anyone want to swap my flexible dp lines for hard?
- Piston questions
- Could my plugs being gapped at .30 cause this??
- Mounted bottle
- Bottle opener switch needed please!!!
- need to know if this is the right part?
- Average DD some spray/mostly n/a cam???
- Where to Get NX MAF Plate?
- What guages do i need for nitrous?
- nitro switch panel
- Pull timing with Cam only, 125 shot?
- Nitro Dave....
- What plugs for me?
- Okay to run two solenoids for dry shot?
- fuel pressure and jetting question
- New to Nitrous
- Running a NX wet 100 shot....power?
- The last of Nitrous Outlets 90mm collar!!
- tps switch
- Suggestions on Nitrous Setup for 408
- Harlan Window Switch Wiring Question...
- Here's What I Got.
- Which timing tuner are most people using?
- Where to get the cheapest universal dry kit?
- NX shark nozzle – what sized nut / thread type and washer to use?
- Alternative to a Blown down tube
- got an idea
- HELP: wet or dry shot for my supercharged Mercedes
- Nitrous fitting question, identify this part (PIC)
- HELP NX wet kit install
- Disadvantages of nitrous fuel cell in rear?
- what are yalls opinions on MSD digital Window Switch?
- Tech Tip "Pusher systems"
- what would happen if i sprayed a fm14 112
- quick jet ?
- Building 408 For N/A Now/Nitrous Later?'s
- *dynograph* am i safe to run nitrous?
- WTT: Sport Comp Nitrous Pressure Guage
- Noid question
- .093 inch N2O Jet in NX?
- Got the window switch working, but I have another problem.
- Purge Question
- Nitrous Problem
- good nitrous cam?
- Speed Density Mode and Dry kits
- Routing Nitrous Line
- What ever happened to the NX 85mm LS1 intake?
- Can I spray 100 shot with this NGK spark plug
- For a friend
- Edelbrock Bottle Mount
- Opinions PLS: NX MAF vs TNT
- Noid Pictures
- Quick Question
- How big of shot before you had to start pulling timing?
- Dry 100 shot, what else should i do to be safe
- Nitrous Question
- Need an All In One Box....
- Best NOS Install Shop
- 200 Shot
- Nozzle placement
- Who makes a 120 Volt AC bottle heater to plug into my house outlet
- a way to pull timeing without a controller
- 8-second nitrous lt1 rumors
- Mercedes superchrgd ?
- nos 5177 jet placement
- anyone spraying with a Vig????
- anyone need a smooth bellow for your nozzle?
- jet ???????????
- NEW window switch from FJO.
- DynoTune Fully Automatic Nitrous Bottle Warmer Kit – $119!!!!
- Nitrous kit help
- Looking for a tuner
- unusual check engine light after using N20 on 2004 GTO...
- Another "where do I mount this" question???
- These pictures might help convince someone that Nitrous is safe, done properly.
- How can I change NOS heater on/off temps.
- Which bottle heater will stay around 1100psi?
- wiring the FPSS on a LT1?
- NX MAF kit question?
- Which kit?
