View Full Version : Nitrous Oxide
  1. Choices in window switches!!!!
  2. How will a car run....
  3. LT1 Electronic Nitrous TPS Switch
  4. Carb NOS microswitch
  5. Nitrous kick out idea
  6. Any of you guys........
  7. Bottle Heaters
  8. Window switch ???
  9. putting WOT switch under dash (gas pedal)
  10. before or after?
  11. Who sells variety packs off jets?
  12. i think i mounted my FPSS on the wrong side?
  13. mounting the WOT switch?
  14. stock 10 bolt on the juice
  15. Harlen Window switch
  16. Can someone explain this setup to me?
  17. Nitrous Gauge
  18. Help on nos tune.
  19. dyno numbers on a 100 dry shot?
  20. Quick Wiring Question
  21. zex nitrous system
  22. Tech Tip "Fuel flow Test"
  23. Dynotune bottle heater
  24. Optimum engine temp for nitrous?
  25. Switch location??
  26. Tech Tip: Fpss Reposted
  27. How much does a full 15lb NOS bottle weigh?
  28. Racing classes
  29. 20 Shot????
  30. Vararam with nozzles Problems?
  31. NIB NX direct port for sale
  32. nitrous
  33. where can I buy these switches?
  34. sprayed 150 shot on 04 GTO tonight, interesting results
  35. Bottle Mounting
  36. Easy way to retard timing for spray?
  37. Dumb ?, Where are the jets on my Gemini kit?
  38. Nitrous bottle exploded. Why?
  39. How sensitive are noids to heat??
  40. cam+forged internals+150 shot+timing tuner HELP NEEDED
  41. Jet size dry shot
  42. what octane to run for 150 shot
  43. Direct port nitrous
  44. Will I be okay for now?
  45. Z06 and TNT kit Install HELP
  46. How Much Does Your PREMAF Shot Peak...??
  47. Need some help
  48. Need some Tech Ideas.
  49. Ordered my kit from Dave
  50. Would running SVO 30# injectors hurt me in any way?
  51. a dumb question maybe
  52. I need wiring help / MSD adjustable (pill) window switch and NX FPSS.
  53. Completed Sx2 Direct Port on Sheetmetal Intake...Finally
  54. what is the best rear end for N2o?
  55. Got alot of nitrous questions, TNT guys please help
  56. A ? about direct port with inject spacer.
  57. is a 250 shot too much???? for stock bottem end
  58. ok new to n20, need tips on install?
  59. Ramcharger nitrous controller
  60. Need help with cam spec on built N20 402
  61. What shot causes head lifting
  62. nitrous trouble help...
  63. Who sells 1/8" nozzles
  64. injectors on 5177/ dyno results
  65. Accel Digital Nitrous Processor
  66. searched...and left hanging. how to get 100 shot on TNT wet kit?
  67. NX Ricky 90mm Update??
  68. Going to do it
  69. plumbing fuel line
  70. Billet fuel rails and mounting fuel solenoid
  71. Question about the billet mount...
  72. Nitrous Question
  73. looking for a 97 ss black with ttops thanks
  74. TNT wiring Q.
  75. Spark plugs
  76. 5177 vs. Halo Ring
  77. When should I cut off the spray?
  78. Stand Alone Fuel System...LOOK!!!
  79. Nitrous feed line and wiring
  80. Part Number: NX-20109-10 (NX @ nitro Dave's)
  81. fuel pump question
  82. Where Are You Running Your Lines/wires
  83. Timing Tuner question....upper rpm limit....
  84. i need instructions for a dynotune remote opener to an NX switch panel
  85. NX Maximizer Q
  86. Tech Tip "Testing your electrical with all Safety intact.
  87. TNT f1 kit for sale
  88. Anyone with a nos brand remote opener I have a question for ya.
  89. Nitrous Refill Station
  90. Trying to decide on Nitrous Kit
  91. Different MSD window switch pills?
  92. Plugs for Nitrous??
  93. What Gap to Run on a 2003 Silverado??
  94. Plug gap NEEDED ASAP
  95. 150 shot- advantages of DP over wet kit?
  96. Question about wet kits??
  97. Just got my 5177
  98. Does any one know how to set up a LT1 intake for direct nitrious?
  99. Full Bolt ons + heads and cam... Dry shot? or not worth the trouble?
  100. Timing tuner
  101. Harlan window switch
  102. how long did it take to hook up your full nitrous kit?
  103. Went to the dyno...Need advice?
  104. FPSS and rev limiter?
  105. Spraying tnt 100 should I move up to 150?
  106. Purge Kit?????
  107. Pics and a vid
  108. Wiring MSD Window (pill)Switch
  109. Best wet nozzle setup?
  110. In case you missed it....FOR SALE: 12# carbon fiber bottle
  111. factoring in my cost.....
  112. some no2 stuff for sale
  113. More power: No2 vs. timing
  114. My newfound philosophy...agree?
  115. Newb to nitrous, have some questions.
  116. heater wiring question
  117. Can a nitrous bottle blow up?
  118. what is a good nitrous cam?
  119. LS2 Direct Port Pics
  120. How did you mount your solenoids?
  121. Replacing Blowdown tube with ss braided hose, size?
  122. Harlan 2-step Plan of attack
  123. is my cam good for a small shot???
  124. N20 install help!!!!!!
  125. M6 Owners please...
  126. no2 ?
  127. TTP Equalizer v3 cam, how is it on spray?
  128. A4 spraying through shifts...
  129. Does anyone have.....
  130. Aluminum cage bottle mounting brackets?
  131. Nitrous Instructions??!?!?!
  132. jimmy jams controllers???
  133. Tech Tip "Heaters yes or no"
  134. Easiest way to retard timing? Other Q's too
  135. what do you think?
  136. High Octane leaded - O2 sensor Q?
  137. LS1 based nitrous record
  138. NX Rickey
  139. Gotta a question to all nitrous users, curious on how many use safety equipment
  140. When tuning wet kit AFR with fuel jets...
  141. New to Nitrous
  142. Question for N2O people
  143. SES light on nitrous?
  144. Nitrous Express MAF plate system??
  145. March Nitrous Madness Sell!!!!
  146. G5x3 or TTP Equalizer v3.
  147. Mounting Question
  148. G5x3 on a 112 or 114 for best n/a and spray setup?
  149. how safe
  150. who sprays 150 on stock axle and tranny?
  151. Mounting bottle
  152. is it dumb to run 150 shot without checkin your air fuel ratio?
  153. Should I use a Fuse with an NX Bottle Opener??
  154. Best pump for a 150 shot
  155. dumb to run 150 shot without checkin your air fuel ratio?
  156. Pics of my bottle setup
  157. NX Remote Opener
  158. Spark Plug
  159. Where to get jets????
  160. Question on TNT Power Ring
  161. timing in a box... let me make sure i get this straight
  162. Where do I inject nitrous on Z06, K&N FIPK & 5177?
  163. FM9 with a direct port- 150-200 shot
  164. What exactly does a blow down tube do?
  165. nitrous
  166. Timing Retard with NOS
  167. Anyone above 700rwhp/800rwtq?
  168. Help with NX bottle heater
  169. Fuel Pump with nitrous??
  170. Question About Mounting Solenoids
  171. First Spray...Nervous?
  172. are air/fuel gauge worthless?
  173. will nx pills work on the msd window switch?
  174. Fast Set Up And Full Throddle Switch
  175. Sorry Guys
  176. how to improve your nitrous efficiency ten-fold...
  177. Nice pic of main cap (hit with some serious nitrous)
  178. 550rwhp via n20 vs 550rwhp via supercharger ... which is quicker?
  179. Nx kit
  180. Cold Fusion Nitrous Kits...
  181. About to order a n2o kit
  182. Dry kit and LS1
  183. new to n2o
  184. NX Kit cutting out at higher RPM's!!!!
  185. zz-409 cam vs. nitrous
  186. Will a nx bottle opener fit on a .............
  187. Just finished my NX dual stage - Pics inside *56k warning*
  188. Question about TR6 spark plugs for nitrous
  189. any nitrous for newbies? Also want to buy a wet kit, anyone have one f/s?
  190. Nitrous Through the EGR?
  191. Air/Fuel Gauge
  192. Who makes remote bottle opener compatable with TNT?
  193. Couple more ?'s, Thanks!
  194. Spraying a 11.5:1 CR motor - is it safe for 93 octane?
  195. How much will a 4an
  196. help with gear selection
  197. Got in an Argument with machine shop guy
  198. quick wiring question
  199. N20 newb? How do you know when bottle is empty?
  200. Nitrous Parts for Sale
  201. Buying n2o... Making sure I have everything... Help/Advice Welcomed!
  202. Tank Dimensions and bottle pressure?????
  203. NX MAF kit with a 90mm tb/intake
  204. I'm pumped Halo kit gets here today
  205. nx question
  206. Nitrous Questions
  207. 125 shot what else do i need to be safe
  208. First time to spray the 5.3L was today!!!
  209. Low Compression engine and N2O questions..
  210. Nitrous on Carb Setup
  211. Maf vs Direct Port
  212. What nx or tnt kit to go with?
  213. How much HP will this fuel system support??
  214. Hey guys check this out...
  215. filling station ?'s
  216. NX MAF for C5.....when?
  217. Nitrous Pressure Gauge and 4AN to 6AN fitting
  218. NX 150 fuel pump?
  219. Question about chroming some nitrous parts, also a guage Q.
  220. Has anyone seen the new NOS plate for the c6's?
  221. bogging ?'s
  222. How big is the TNT F1 power ring in millimeters???
  223. NX 150 shot question
  224. what do you think of this et and mph
  225. hp gains on nx wet kit???
  226. LT1 ac delco plugs
  227. Do you have to pull timing if you have a stand alone fuel cell?
  228. Routing the Nitrous feed line
  229. Difference between Dynotune's time delay switches?
  230. Anybody running AR472's?
  231. Nitrous Properties & Data For you
  232. Automatic Timing Retard with N2O
  233. nitrous and high compression 11.1
  234. New to NOS
  235. Spraying T-rex Help!!!
  236. thunder 224/224 with my 125 shot
  237. Opinions please....
  238. running out of gear?
  239. getting there
  240. pics of nx fogger with showerhead dist blocks?
  241. If anyone needs a 37 degree flaring tool...
  242. 100+ N2O setup with no problems ... how long?
  243. Controls for nitrous
  244. This sound right?
  245. A/F METER Frozen, Boiled, AND Ran Over
  246. newbee to nitrous what do i need
  247. So who else makes a window switch OTHER than MSD?
  248. Alcohol Injection & Nitrous? Help
  249. What HP Can I get out of a Fogger Nozzle
  250. Throttle body nitrous plate
