View Full Version : Nitrous Oxide
  1. A/F METER Frozen, Boiled, AND Ran Over
  2. newbee to nitrous what do i need
  3. So who else makes a window switch OTHER than MSD?
  4. Alcohol Injection & Nitrous? Help
  5. What HP Can I get out of a Fogger Nozzle
  6. Throttle body nitrous plate
  7. what can i do with this.
  8. Tnt Users Help
  9. Well i need better than pump gas?
  10. Free beer/money
  11. What size jets for 100 shot wet?
  12. Need some advice. Extreme n00b
  13. Nitrous filters?
  14. NX full kit + extras for sale..
  15. 2 5/8 gauges
  16. Question about plugs with N2O
  17. simple question
  18. msd digital window switch wiring
  19. What is the proper way to test my n20 system?
  20. pictures of stand alone fuel systems?
  21. Where can I find nitrous jetting charts?
  22. Progressive Nitrous Units...
  23. Gen I SBC Nitrous Usage Question
  24. 75 shot ok w/o pulling timing?
  25. Spraying in 4th with an A4 and 3.23's?
  26. Nitrous for 87,000 mile motor? Etc.
  27. What kind of hose end should I buy for a nitrous hose?
  28. Looking for a specific video...
  29. Those running inline fuel pumps
  30. Spraying thru a powershift?
  31. nitrous jets?
  32. Where to mount the bottle?
  33. its almost time for..
  34. Venom VCN-10000
  35. FM13 + 100 wet shot?
  36. Nitrous Bottle Brackets?
  37. What does a NX Maximizer do?
  38. N X problem please help
  39. Which is safer 100 Shot Wet or Dry
  40. setting up a wet kit,need some help please
  41. Thinking Of Going To Nitrous
  42. Where can I find a 15" 4AN nitrous line?
  43. Tech Tip "Fuel Puddle Something to think about"
  44. fellas need your help!!
  45. Timing
  46. Direct ports better than a nozzle right?
  47. Nitro Dave's - Nitrous Outlet Gone??????
  48. Continued discussion: Injector size and MAF flow rate with dry shots.
  49. n2o in non other places
  50. 36-lb./hr. @ 3 BAR ok for 600 rwhp?
  51. upgrading nitrous system?
  52. Hello all, Please enlighten a future nitrous user.
  53. Using Nitrous for droping inlet air temps and added power gain.
  54. 100 + 100 WET...Questions!
  55. Testing TNT f1 w/ window switch
  56. TNT F1/F2 users, any of you have a ported tb?
  57. opinions on compucar nitrous in a bag
  58. Power loss N/A with TR6?
  59. bottle between rear seats?
  60. Pressure regulated bottle heaters
  61. Tr6/Platinum plugs
  62. Nitrous and compression question
  63. Irridium plugs IT20
  64. NX Pressure Gauge Wont Work...Any Ideas?
  65. nitrous help
  66. Solenoid Power Ratings?
  67. cutting back the ground strap on tr6's.
  68. NX Bottle Heater Question
  69. Fogger Nozzle discussion.....
  70. Building custom dry kit need some help??
  71. Nitrous Works
  72. un-opened bottle strikes again.....
  73. How much PSI are you using?
  74. what gear ratio should i use?
  75. on a stock ls1
  76. Do it Yourself nitrous kit...
  77. License passes (video)
  78. DynoTune Nitrous Switch Center ?
  79. Two Stage DRY questions....
  80. Purge From Nostrils?
  81. FPSS why?
  82. Gauge and Filter Install Question. Pics...
  83. New best
  84. Nobody has ever had this much troble with a f**kn' window switch...HELP
  85. Hot Rod Pump gas drags
  86. 42 pound injectors for a dry shot and a cam?
  87. fuel solenoid instead of nitrous seloniod?
  88. N2O kit recommendation
  89. Best Off-Shelf Nitrous cam??
  90. Motor is getting closer **progress pics**
  91. Msd Window Switch On Ls1
  92. anyone ever use a slot car plate N20
  93. What am I missing, guys?
  94. Got Board UPDATE: Nitrous for your RC car.
  95. Anyone have pics of a TNT F4 kit intalled?
  96. Will this hurt the flow?
  97. Thoughts on Cold Fusion Bottle Opener(discussion)
  98. NGK TR-6s are not being discontinued.
  99. what do i need for my 5.3L Silvy
  100. What cam for big shot?
  101. 723 hp ls1 in Chevy High Performance Mag
  102. nx ricky or nitro dave or anybody else
  103. TECH TIP: Nitrous Soelnoids exploded view.
  104. Custom TNT F2 pics
  105. Just a little FYI
  106. new cam for the SPRAY...
  107. Nitrous Bottle Super Sale
  108. Dean at dynotune
  109. Sparying threw shifts Gains?
  110. Polished 10lb bottles.
  111. C6 Nitrous, June issue of Vette Magizine
  112. Corvette and installing a TNT kit ???
  113. How should I trigger my dual stage kit?
  114. TNT 100 shot only made 65 rwhp at 950psi?
  115. 860 bottle bracket FS
  116. NX Fill Station help
  117. stand alone fuel system but alky
  118. Looking for pics of nitrous bottle in spare tire well
  119. Question...
  120. How large of a wet shot do you think a stock bottom end ls1 will handle?
  121. Dynotune Bottle Warmer
  122. NGK-One or Two Steps Colder???
  123. Jimmy Jams
  124. N20 help needed (nitro dave)
  125. retarding for a 75 shot
  126. ok so, who's gone 8's on nitrous?
  127. snapped a few pics of my NX MAF kit today
  128. Do I need an inline fuse??
  129. What all do I need for a dry kit?
  130. Why does the dry kit have 2 solenoids?
  131. Whats the fasted 346 cam/n2o automatic LS1
  132. How to flare hard line
  133. where do you mount your N20..pics???
  134. 150 Shot!!!
  135. TNT question for an LT1
  136. TNT Nitrous kit?
  137. LS1 NX full kit for sale!
  138. F.A.S.T-nitrous
  139. NX Solenoid
  140. Taping fuel line
  141. nos 5150
  142. Nitrous Special..
  143. Wiring 2 FPSS to help lean spikes.
  144. ZEX kit
  145. injector bungs or fogger nozzle
  146. 10# vs. 15# Bottle Dimensions
  147. Cold Fusion Kit
  148. TNT Kit and Lid Fitment
  149. Whats the highest hp nitrous stock ls1
  150. Question about Nitrous & Purging
  151. **FOR SALE** NOS 125 Dry Shot Complete System
  152. nitrous pros and cons?
  153. Nitrous Pics????
  154. ???'s about jimmy-jams
  155. Those of you running dry kits...
  156. hypethetically, if a car made 525rwhp on a 11:1 comp. ratio,how would it do on a 9:1?
  157. Here's what I've got... How should I set it up?
  158. Retarding timing w/o ignition box?
  159. Tell me what clutch to run and why
  160. stealth nitrous
  161. bottle mounting IN A FIREBIRD!
  162. Finally got this thing installed....
  163. problems to steer clear of
  164. dave or ricky
  165. Electronic WOT switch for nitrous?
  166. New homemade NX avatar
  167. Stand alone fuel system but different
  168. NX MAF Kit for Z06
  169. Anyone make a "power-ring"
  170. Soleniod rebuild & custom bracket Q?
  171. nitrous additives
  172. best "kit" for a beginner??
  173. timing chain and n20
  174. 5177 conversion??
  175. Tech Tip:FPSS (how to adjust & "Y" Have).
  176. Bottle heater???
  177. is it safe to spray with over 100,000 miles
  178. quick bottle mounting question
  179. Brisk Plugs
  180. Diving bottle useable??
  181. 75 shot WET or DRY?
  182. will i be good with a 150 shot?
  183. new to nitrous
  184. z06 and nitrous suggestions
  185. NOZzle kit???
  186. RPM Window Switches, Who makes the best?
  187. 10's ?
  188. Is it safe to ?
  189. spraying with an m6
  190. Pics of my TNT F1
  191. What heads for nitrous setup?
  192. Painting my bottle
  193. s/c vs nitrous
  194. What kind of power do you guys forcast for my vette w/a 408
  195. anyone have a direct port install how-to?
  196. lt1 install complete w/ pics
  197. Pls advise, wet or dry shot on MP112?
  198. Lets get this whole spark plug gap and temp issue straight for us nitrous newbies.
  199. How to hook up MSD Digital Window Switch
  200. -7 plugs for nitrous
  201. dave some info
  202. Purge noid didnt work when purchased
  203. NX MAF kit with a 90mm TB/Intake
  204. Need some new Nitrous parts...DAVE
  205. bottle fitment
  206. NX Nitrous Express set up FOR SALE!!!!
  207. Can someone help me with a electric N20 guage
  208. Looking For a cam
  209. Hang time video
  210. Question about mounting nozzle
  211. Timing Tuner..Or BMN Window Switch?
  212. Mounting the Shark Nozzle
  213. any one hace PIC's of spark plugs?
  214. Yes Boys And Girls This Is Why You Get The Right Spark Plugs
  215. New Rapid Fire Purge!!
  216. Dry Vs. Wet
  217. Help w/ nitrous setup for street car please...
  218. Safe to spray?
  219. 2 stage upgrade
  220. Dry to wet conversion ... TNT LS1 Conversion all I need?
  221. Price of NOS in Northern VA???
  222. For you guys running nitrous on stock motors...
  223. MTI G1 make a good N20 cam??
  224. 150 Shot
  225. nx heater adjustment?
  226. cheapest tnt f1 kit-new?
  227. ok guys i tried search and not much where to mount NX wet solenoids ?
  228. Nitrous with my cam
  229. 175 shot?
  230. Spraying with gas gage on E
  231. Largest shots used on 346/347???
  232. Nitrous Pump Question
  233. Removing MAF SCREEN for dry shot..
  234. Got Board: Nitrous for your RC car.
  235. TECH TIP: Blow off fitting. Why it’s important.
  236. 10lb bottle or 15?
  237. differen't oil for nitrous?
  238. 250 shot on a stock block with a progressive controller?
  239. looked everywhere.. diff b/t tnt f1 and f2 is?
  240. What type of plugs?
  241. Help tuning nitrous
  242. Single stage 250 shot or 100 NOS "Dry" & 150 TNT "Wet" 2 stage
  243. What jets and what timing with F2 TNT?
  244. supercharge w/ nitrous?
  245. Dynotune Gauges - Custom Applications!!!!
  246. How does the MAF compensate for the dry shot?
  247. can i get a 2 port accessory for 2 pressure sensors?
  248. cant decide on plugs
  249. Direct port pros and cons?
  250. NOS LS1 Kit
