View Full Version : Nitrous Oxide
  1. What Crankshaft Pulley do you guys run?
  2. wire running...
  3. How much can the stock fuel rails handle? Dry shot.
  4. Plz Help me. Banging limiter after No2.
  5. 200-300 shot?
  6. Izz It Zafe? Used Mustang 75 shot
  7. TNT F-1 Installed-Good Story Inside!
  8. Why don't many people use Zex?
  9. And The Free 860 Heater goes to!!!!
  10. doe's this sound right for nitrous
  11. Free fuel pump?
  12. question about the gas
  13. making an NX remote bottle opener work on TNT bottle...
  14. Help With Bottle Warmer
  15. Giving away Free 860Heater tommorrow!!!
  16. Is this tune safe for a 75 tnt shot? Need help b4 I run a supra
  17. Easy NOS kit to fit on LS6
  18. Looking for donor motor!!
  19. NX "FIRE AND ICE" question.....
  20. 200 shot with NX kit?
  21. Hp tuners as window switch?
  22. Advertised NX ratings vs.TNT
  23. what size is the NX electric bottle pressure guage?
  24. GM 454 H.O. How much?
  25. Missing sparkplug tip?
  26. tr224/227
  27. Single Cab truck bottle location
  28. Remote Bottle opener 4 TNT Bottle
  29. Injectors Question
  30. MSD window switch?
  31. *For Sale* My entire nitrous setup
  32. Direct Port for LT-1
  33. Nitrous on Stock motor
  34. Dynotune Nitrous Christmas Specials!!!!!
  35. Invatory Reduction sell!!!
  36. Nitrous Guys: Why did you go with spray?
  37. Broke my nitrous bottle?
  38. NX Jets
  39. Pics of our Nitrous Outlet Street Car!!
  40. Got my NitroDaves 90mm ring this weekend!!!
  41. !! NX Maf kit for SALE !!
  42. Hey Nitro Dave>
  43. how to hook up a fpss
  44. keyed/ignition source
  45. Having Problem
  46. Nitrogen Push Guys, question for you
  47. Jets for NOS 5177 kit
  48. nitrous/a/f ratio wirring
  49. What cam are you running with your..
  50. Odd Nitrous Question, Nitrogen push....
  51. Edelbrock Nozzle (what jets?)
  52. tnt solenoid mounting bracket????
  53. 120,000 Can I Spray??
  54. Where can I get a nice electric (not mechanical) nitrous gauge?
  55. wiring with relays for N2o and etc.
  56. nitrous measurement
  57. edelbrock bottle warmer wiring schematic
  58. TNT Bottle w/NX Opener-HELP ASAP
  59. Hidden WOT switch
  60. NX problem
  61. ZO6 NX Direct Port Install PICS!
  62. Questions about tnt jets
  63. 2 5/8 Elect. N20 Press. Gauge
  64. Help with purge install
  65. Jets and Tuning?
  66. Bottle Valve to rear or car?
  67. PICS!!! Of the 90mm collar!!!
  68. Nitrous Express "NXL", yes or no?
  69. Pics of installed TNT F1 PLEASE
  70. getting into nitrous?
  71. Some help with install . . . Quick Please!!
  72. LS2 Direct port Pictures
  73. spray on a 70,000 mile motor???
  74. TNT F1 Kit
  75. 30.00 Off Nitrous Express Bottle Blankets!!
  76. 100-125shot and Gears???
  77. Anyone Useing a Harlan Window Switch?
  78. Nozel position?
  79. anyone running the cold fusion direct port?
  80. 860 heated brackets...
  81. spray to what rpm??
  82. Purge Line
  83. Gear ?
  84. New toy for the '69! NX MAF kit....
  85. Fuel Line
  86. question about the Nitrous express Maximizer
  87. In need of some nitrous accesories..
  88. Finally got my Nitrous working
  89. nitrous experation?
  90. nitrous for my raptor
  91. Full Throttle Activation Switch?
  92. Best place for sender on electric nitrous press. gauge?
  93. Nitro Dave's Is Now carring a full line!!!
  94. Purge blows my gauge fuse
  95. Install Guide Needed
  96. size injecters
  97. what combo is best for nitrous?
  98. purge before shutting down?
  99. Nitrous and 140=MPH trap's
  100. washer fluid can it be used for fuel?
  101. New To Nitrous
  102. spark plugs
  103. Anyone upgraded nitrous solenoid line to -4 over -3??
  104. Nitrous on a Tahoe Z71
  105. Nx wet kit vs tnt powerr ring kit
  106. Progressive Controller question
  107. NX fuel accumulator - can I use it with aftermarket fuel rails?
  108. Which Way...
  109. Timing Tuner guys in here,please...
  110. max purge kits u can run
  111. Think this Bottle will Fit????
  112. Dry shot ????
  113. Pill chart??? low press. vs. high press. fuel system
  114. opinons in the NXL NX kit
  115. Need opinions hidden or not
  116. Iron Block and NOS
  117. Who has the cheapest direct port kit?
  118. nx maf kit guys in here please
  119. what has to be done to an MSD window switch to make it work?
  120. Christmas Sale!!!!!!
  121. Got My New Nitrous Kit
  122. quick ? on NOS dual jetting sizes
  123. wiring up heater
  124. bmn controller ???
  125. Trade In program in affect..
  126. What kind of gains with an NX150 shot?
  127. Anyone spraying through shifts on an auto?
  128. Huge!!!christmas Sale!!! 10lb Bottle Sale
  129. Time's Question
  130. Direct Port Install Pics
  131. Where to fill tanks in CT
  132. What Settings For Window Switch?
  133. How much timing you guys been spraying with on race gas (300 shot 26 deg here)
  134. Nx Maf Question
  135. Safe And Reliable N2o...
  136. What cam are you guys happy with.
  137. Where Do I Mount The Bottle???
  138. Nitro Dave
  139. LSA and nitrous
  140. 3.73's 100wet shot M6
  141. TNT Power Ring
  142. Best nitrous solenoid for current draw?
  143. T/activation microswitch or NX TPAS?
  144. Mostly want to stay n/a but have nitrous on the side, help
  145. Nitro Dave: need jets for tnt kit please!!!
  146. questions on Nitrous Express MAF plate system..
  147. 200 shot of nitrous?
  148. Help! wiring switchs
  149. Car won’t idle after changing intake, PLZ HELP!
  150. Which pump and regulator?
  151. Question for Nito Dave's
  152. spraying thru shift on a 4l60e.. please help quick
  153. What Else For 150 shot?
  154. How much HP through 3an lines from solenoid to fogger?
  155. Wow TNT Rocks ... 6.44 @ 99.51
  156. NX isntall..???
  157. Decided not to bother w/ dry. converting to wet..
  158. engine problems with Nos?
  159. 2 ?'s--N20 leve; gauge & bottle blanket
  160. How long is a filled bottle good for?
  161. fred nitrous controller ?'s, help please
  162. New numbers with 150 shot!
  163. Maximizer noid pulse frequency
  164. NX 100 shot jet size??
  165. NGK TR8 plugs
  166. Dyno Tune NOS
  167. Nitrous 5177
  168. Would anyone LEASE me flaring tool?
  169. Head/cam o2 Z06 with 150 NX wet fuel system?
  170. help me hook up msd window switches wiring.
  171. blow down tube
  172. NX kit on M6
  173. I can't get my MSD Digital Window switch to work.....HELP
  174. dual purge kit, GREAT deal!
  175. what do i need!!!!!!!!!!
  176. !!!N/X Wet Kit For Sale!!!
  177. Cold fusion nitrous
  178. Free..860 Performance Heated Bottle Bracket!!
  179. Insurance and Warranty
  180. Gained only .4 tenths on 100 dry shot. Is that about right?
  181. Thanksgiving Nitrous Super Sale 22 - 24 And On The 26th
  182. multiple misfires in cylinder one!!
  183. System bottlenecks and limitations
  184. Hawk Spencer is back in town
  185. Window Switch Or RPM Switch?
  186. What RPM Switch and FPSS Switch...
  187. intake manifold question
  188. Not Having My Car Is Dangerous
  189. what hp do stock fuel lines max out
  190. spark plug selection/ timing retard
  191. How much HP do the little NX Piranha nozzles flow?
  192. How much is this Nitrous setup?
  193. Forged 408
  194. Diamond Nitrous Pistons FS
  195. 408ci motor ?
  196. Damn it, I maxed out the 4AN nitrous line.... 680RWHP & 770RWTQ.
  197. Closed November 23,24,25
  198. Hard line plumbing?
  199. 4 degree retard "feelable"
  200. TNT 150 shot!
  201. Most HP possible from a 350-400 ci nitrous small block??
  202. Nitrous install write up
  203. How much tq with a 100 wet shot???
  204. You won't believe what I was quoted to fill a 15# Bottle!!!
  205. NX Maf Plate...
  206. Timing Tuner Question ???
  207. What are some good head gaskets.
  208. Gauge Pod
  209. How can you build a standalone fuel system...
  210. Nitrous for the only mod?
  211. What Switches/Bezel Do You Have?
  212. Who here is running a NX Maximizer
  213. Nitrogen push pass tech?
  214. I need your input..
  215. Anybody have the Purge LED cloud illuminator?
  216. "Q" on what size oj inj.
  217. Anyone else done a purge like this before?
  218. Compucar "pills"?
  219. Anyone need any nitrous/fuel hoses?
  220. Picked up a partial kit...what else do I need? (Dave?)
  221. Need help hooking up fuel pressure guage
  222. do's and not do's of the nxl kit?
  223. Blow Down Requirements to pass Tech?
  224. Safest/Best wet kit for stock engine.
  225. NX-Cam Shaft Clearence Sell!!!!
  226. N/X wet kit for sale or trade!!
  227. Problems - Need advice
  228. Source for the cheapest FPSS
  229. NOS Pill sizing for a single Nozzle dry kit
  230. 5177 wiring ?? (Pic)
  231. Bolt On Motor. Dry Or Wet?
  232. Are Air Fuel Gauges that hook to the stock o2s "close enough"
  233. Introducing the DynoTune Time Delay Switch!!!!
  234. does n20 go bad if it sits too long?
  235. Solinoid Maintenace
  236. tr-6 question..
  237. Need some opinions on DP
  238. Question about wet vs. dry.....
  239. Winter Storage
  240. Rather safe than sorry!
  241. Wiring 2 Stage Kit to Work with 6-Speed.
  242. Nitrous question....can't find an answer
  243. Cold Fusion Kit Questions.
  244. NX Purge kit(pn#15600) tube
  245. Question about using tubing from 'noids to jets
  246. Wet conversion (shopping list)
  247. High Pressure or Low Pressure for DP
  248. hell fire rings
  249. Fuel system questions on wet shot in the S10
  250. TR6 is .040 cold enough?
