View Full Version : Nitrous Oxide
  1. What is the best FPSS & FTPS
  2. NX Genx2 kit purge line
  3. 550 RWHP and a Walbro 340 pump.
  4. Msd Window Switch Wiring????
  5. What else do I need ....
  6. Newbie Questions (used search)
  7. nitrous question
  8. Whats a good Nos cam?
  9. Dry kit jet locations
  10. 250shot no tuning
  11. dynotune phone number
  12. track results from the Compucar Bottle in a bag
  13. NX MAF Dyno Results
  14. What Dry Kit for my 5.3 gmc???
  15. nitrous fuel plumbing
  16. Looking for pics/info on hidden NOS systems
  17. how much can you spray
  18. Dynotune Bottle heater...
  19. how to mod ls1 zex wet kit for 200 shot??
  20. Purge wiring question
  21. Can I go with 150 shot?
  22. 346 + nitrous: 600-750rwhp questions..
  23. question on splicing timing tuner into N2O wiring. HELP!
  24. Anyone know updated NX jettings for 175, 200, 225, 250?
  25. NX Ford EFI Wet Kit....Will it work on LS1
  26. Nitrous Timing Tuner - cheapest place to buy?
  27. Timming tuner??
  28. Is it absolutely necessary to remove MAF screen for 100 dry shot?
  29. Diagnose my dyno
  30. vroomm WOT shhhhh BOOM
  31. newb trying to rig a dry kit
  32. Finally used n2o tonight and surprise!!!
  33. ZEX nitrous kit
  34. How much timing are you taking out ?
  35. MSD Digital Window Switch-PN#8969
  36. Nos Wet kit wiring
  37. Hobbs fuel pressure safety switch
  38. Nitrous w/ Methanol Injection...anyone tried it?
  39. How many passes?
  40. LSX 90mm TB & intake safe with TNT f2 kit?
  41. How do I wire my 2-step to deactivate N2O?
  42. Anybody intrested in a Dyno Tune A/F ratio switch & gauge?
  43. what to change or add to my fuel system?
  44. N/A performance w/ TR6s?
  45. 400rwhp+TNT 100 shot = ?hp/?tq ?et/mph
  46. Would the NX MAF kit spraying 200shot on a 402CI, lean out the back cylinders
  47. First Dyno #'s
  48. NX dry kit with Halo bar?????
  49. Do I have a nitrous leak?
  50. 1st run on Nitrous express kit
  51. Where to mount Switch and other ques.
  52. Nitrous Safe?
  53. 7.40s in A4 100 shot?
  54. Zex Nitrous 150 shot
  55. Anyone spray a 200 dry shot?
  56. Where to get fuel rail fitting for FPSS?
  57. Which is best and most reliable?
  58. Nitrous Express Incognito Kit
  59. Nitrous wet kit - how to make it safe and what is needed?
  60. Too rich with my jets
  61. Anyone run tr8 all time time.
  62. nitruos bottle pics
  63. 110 lsa
  64. Who makes bottle brackets for roll bars?
  65. Need nitrous!!!
  66. Can I zip tie my nitrous line to tranny coolant hard lines?
  67. Question on Shifting while spraying
  68. Getting ready to back out again!
  69. Spraying with medical grade N2O?
  70. Small dry shot
  71. low cost nitrous kits
  72. NOS Bottle Fitting VS. ZEX/OTHER Bottle Fittings...
  73. Everything i need to know to run N20?
  74. Bad nitrous fill??
  75. N2O refills in Austin TX???
  76. What can I expect
  77. Removing MAF screen for Dry Shot
  78. -6 nitrous filter???? who sells one?
  79. 237/242-595/595 lift
  80. gemini kit questions
  81. Got Most of my Nitrous Stuff
  82. What’s the best way to test solenoids?
  83. NX Maf Kit or Single Shark Nozzle
  84. Retard about to put nozzle before MAF on a dry kit!! Help me change his mind!!!!
  85. OMG this car launch's hard on spray
  86. Nitrous Installers in Md.?????
  87. Fuel Pump Question?
  88. Surging on a full bottle?
  89. FP blowing through regulator??? Need input
  90. What PSIG is needed on FPSS
  91. Fitting assembly questions
  92. Adding a resistor inplace of the IAT(nitrous - retard timing)
  93. What’s going to happen?
  94. Anyone relocated their TNT Wet Kit?
  95. Wa WO! Fuel pressure = GOOOO BYEBYE!
  96. How bad in nitrous on a T-56?
  97. Clutch ?
  98. Which size
  99. How much current through a window switch?
  100. HPE's new nitrous rings!
  101. NOS soft plume nozzle max flow?
  102. Car Dies after 125 NOS NOZZEL shot
  103. 100 shot=what et?
  104. Results: H/C 150 Shot M6 on 26" ET Streets
  105. New Best on a 200 shot and Good Weekend of Racing
  106. Dumb question about NX Filter
  107. Is this a good setup?
  108. low CR with n2o ?
  109. What nozzel for NOS dry kit for 100 shot?
  110. Found A Great Book on Nitrous
  111. NGK TR55 w/125
  112. new to nitrous
  113. Nitrous times vs. N/A times
  114. Dyno Graph-700HP
  115. NGK TR6 part #?
  116. What Causes the Lean Spike When Nitrous is Activated?
  117. My dyno numbers with NX MAF kit
  118. N2O with HPP3 tuning?
  119. Replacing my 5177 noids with...
  120. NX Gemini MAF kit… Need a little help…
  121. Nitrous feed line? (installing now)
  122. *pics* First time for everything: plumbing direct port
  123. NX Nitrous Backfire *Please Help*
  124. 100 Shot question.. New to Nitrous
  125. power sourse for Swicth needed?
  126. Custom dry setup questions
  127. How an $80 part can ruin your night at the race track
  128. Nitrous Sale
  129. IconAutoSports Direct Port Nitrous Package
  130. Mounting of noids
  131. Weight of 5177 15lbs....
  132. N2O Q's for a new guy
  133. N.O. used to cool a forced induction intake?
  134. NX wireing diogram,.
  135. fuel tap?
  136. Highest Shot To Run On Stock Motor
  137. Nitrous Outlet Rocks!
  138. 150 wet shot /stock tuning?
  139. Couple quick nitrous questions
  140. Question about SX2 Nozzles...
  141. Launching a H/C 150 Shot M6??
  142. NA peformance of tr-6s
  143. Direct proportion between shot size and A/F points?
  144. need kit for '00 silverado 5.3l
  145. Nitrous bottle EXP date??????????
  146. Best complete kit? couple Q's too.
  147. IS my NHRA blow down Legal??
  148. Nitrous Question
  149. Well Edlebrock NOS jets work with my NX...?
  150. Got my home built nitrous kit working today
  151. questions with a ZEX dry kit
  152. Direct port fuel system
  153. Dynotunes a/f ratio switch with timing tuner
  154. Stuck on hooking up Timing Tuner to NX system
  155. 150 shot and 5th gear?
  156. Bottle pressure after refill
  157. Who is using NX EFI direct port???
  158. NOS remote valve...this is driving me nuts!
  159. nx wet kit with nos jets?
  160. Question about Timing Tuner and Solenoid Testing
  161. Any 15lb bottles in C5's?
  162. How to run Direct port off stock rails?
  163. Going to hardline my NOS Nozzel System, What are the injector nozzel's worth.$$$
  164. How much pressure loss down the track?
  165. will shot size change with more cubic inches?
  166. NXL On the 180 Pills
  167. Manual cars and Nitrous.
  168. considering N20
  169. Designing my own bottle bracket, suggestions?
  170. small 50 shot do i need to bother with plugs?
  171. nitrous on camed ls1.
  172. washing steel braided lines?
  173. NO2 explosion in my friends car @ strip
  174. What Jets to run in the HP settings for NX wet kit??
  175. Nitrous on top of a Mangnuson?
  176. nos ideas
  177. Relay question on bottle heater.
  178. Is this cam OK for 125 dry shot?
  179. Popping (backfire?) after letting off...
  180. ok lets get this straight
  181. Name that nitrous kit...
  182. TNT users-how many out there with no return fuel line?
  183. Hiding N2O from Insurance inspector & DAD
  184. what jets do i need?
  185. All those running an Electric Fuel Pressure Gauge
  186. Will a 15lb bottle fit in the spare tire/jack area?
  187. Questions on TNT nitrous solenoid
  188. To all the nitrous supply sponsors...
  189. TSP lid and NOS 5177 kit??? Jet Placement
  190. Anyone have their stock bellow collapse under WOT???
  191. ANy one use NGK -7 plugs with nitrous??
  192. Jets sizes for cold fusion kit
  193. Have to cut lid for TNT power ring?
  194. Timing Tuner questions...
  195. stupid NOS question
  196. Nitrous Wiring Help Needed
  197. Doing nitrous w/95k on the odometer?
  198. Who uses the DynoTune A/F switch?
  199. 'small’ nitrous question…
  200. Few questions?
  201. Gained
  202. Gotta ?
  203. Nitrous Cam?
  204. Low fuel pressure DP jet sizes?
  205. Pocket Bike N2O, long term!!! thanks Dave!
  206. rpm pill question
  207. Best looking A-Pillar Pods?
  208. I have 4:10s what do I do?
  209. Colder than stock spark plugs and their affect on N/A performance discussion....
  210. September Nitrous Specials!!!
  211. Question for Accel Gen 7 and FAST users
  212. knock retard and questions.
  213. 120 shot what gains at the track
  214. Can someone point me in the right direction?
  215. Just an Idea need opinions
  216. safe???
  217. Need Advice on the PE for Nitrous Car
  218. What will it run on the hose?
  219. Jets with the NX MAF kit?
  220. Very cool new tuning/datalogging product: wideband, egt, nitrous pressure,etc
  221. jet sizes
  222. Timing Tuner and plugs.
  223. Nxl Customers Time Critical
  224. New Member with Nitrous Questions
  225. spray & 04 Z06
  226. Which dry to wet kit to go with???
  227. Anyone know a site to locate nitrous fill stations?
  228. How much RWHP?
  229. Newbie nitrous ?'s
  230. Added a FPSS and a window switch and got probs
  231. Will all brands of bottle fit my 5177 kit??
  232. Any need for PCV mods (i.e., breather) with 200 shot on LS1???
  233. How much will I have to spray to get 700rwhp?
  234. I installed my TNT kit....Now I'm having window switch problems!?
  235. TNT F1-can I spray more than 150 with it?
  236. Got a dyno sheet for you guys to look at.
  237. Questions for Nitro Dave
  238. Hide Nitrous or not?
  239. Wet vs. Dry.
  240. N20 System Reconditions? Few questions…
  241. Looking to start a "Spare Bottle" Group Purchase
  242. Looking for a switched 12v under the hood...
  243. purge tube ?
  244. i only gained .5 from a t.n.t 100 shot,is somethind wrong?
  245. 12 volt source in console??..cigarette lighter?
  246. For those who are not electronically challenged:
  247. something is very wrong
  248. 5177 Noid
  249. NOS 8301 DP kit, who`s using it?
  250. car is tuned to spray a 100shot but i want to spray a 150 shot??
