View Full Version : Nitrous Oxide
  1. Looking to start a "Spare Bottle" Group Purchase
  2. Looking for a switched 12v under the hood...
  3. purge tube ?
  4. i only gained .5 from a t.n.t 100 shot,is somethind wrong?
  5. 12 volt source in console??..cigarette lighter?
  6. For those who are not electronically challenged:
  7. something is very wrong
  8. 5177 Noid
  9. NOS 8301 DP kit, who`s using it?
  10. car is tuned to spray a 100shot but i want to spray a 150 shot??
  11. New times with 100 dry shot!
  12. Timing Tuner's Window Switch Function
  13. Anyone with dedicated fuel system in the rear?
  14. NX jetting question
  15. 300 Wet shot?
  16. nozzle placement
  17. Building 402 for nitrous, do I want high or low compression?
  18. how important is fuel pressure safety switch
  19. Stand Alone Fuel System?
  20. timing tuner/ nitrous wiring help!
  21. Hong long does it take to install TNT Wet kit?
  22. What HP level is a #67 jet on a NOS dry system?
  23. And The Free Nitrous Kit Goes To......
  24. Does anyone know where I can buy only NX MAF ends?
  25. Would a dry shot + rich tuning be = wet shot?
  26. DPI and jetting Q
  27. Safe to shoot with my setup?
  28. Help! Want to run nitrous on my mercedes.
  29. lost compression
  30. What's Safe
  31. purge button question, please help..
  32. dynoed with nitrous ??????????
  33. nitrous a/f ??? on a stock motor
  34. 2 Step
  35. wont spray
  36. The best defeat (BEST FRIEND FINALLY GOES DOWN HARD!)
  37. Nitrous Plates I started making
  38. An old idea but perhaps interesting
  39. Need a 28 Fuel Jet
  40. 11:1 cr and a 50 or 100 shot.
  41. How much timing do I really need to pull?Need some help from the NOS guys
  42. How Loose can I go ?
  43. TNT Direct Port kit or NOS Noszle kit?
  44. custom dry shot help needed
  45. ok I am disapointed
  46. Very happy with my new set up!!!
  47. got my first 3 N2O passes!!!!!!!!!!!
  48. Anyone wire up a trans brake and nitrous inline together?
  49. All 9 second daily drivin N2O powered cars come in here.
  50. Bottle temp vs. Bottle pressure?
  51. Wiring Two step with Timing Tuner?
  52. How do you install an rpm window switch?
  53. BMR 4000lb GTO runs 10's - stock internals
  54. Dry vs Wet
  55. universal NX dry kit $200 good deal?
  56. Hey Nitrous Guys, You need to see this
  57. NGK TR55's vs TR6's or a one step colder plug
  58. How long should a 10lb bottle last on a 200 shot?
  59. Slotcar plate spaces out TB too far, cruise cable won't work
  60. Co2 fake purge
  61. What nitrous kit for a 427ci?
  62. Custom NXL (pic inside)
  63. Open or Closed?
  64. LOOK: Special on 860 Bottle Heater/Bracket
  65. 3 switch panel by TCS switch
  66. FPSS Which one is everybody using
  67. Who Is Running A Nitrogen Push.
  68. A4 with Nitrous
  69. 400rwhp+100shot tnt
  70. Making as Direct Port from TNT Kit?
  71. I would like some feed back on ?
  72. where did you put your bottles, switches and purges?
  73. which pills to use for a 250 shot in a NX shark nozzle.
  74. nx n20 pressure guage no worky!
  75. Fire & Ice controller?
  76. Window switch vs. rev limiter
  77. TNT Nitrous Kit SPECIALS
  78. Got my pocket bike N2O From Dave!!!
  79. newbie here..who sells the most affordable 100 wet kit?
  80. What jets to use for a 125 shot!?
  81. Anyone running Zex wet kit???
  82. What do you use to retard your timing?
  83. TNT F2 users!
  84. Fuel system for 800+rwhp?
  85. 100-125Dry and 100-150wet systems
  86. TNT wiring ? PLEASE!!!!
  87. just to make sure...
  88. nitrous dont spray? i dont know
  89. Motivation: your opinion on nitrous results
  90. Reminder..FREE KIT!!!
  91. 5177 and split the noids?
  92. My first N2O experiance!!
  93. NXL Jetting
  94. Nitrous -- Spark Plug Question
  95. ANyone use breathers (PCV issues) with nitrous to vent pressure???
  96. Jet pattern & Big Shot Questions
  97. Is there potential problems spraying through the LS1 intake?
  98. At what temp is a n2o bottle unsafe?
  99. Jet Question??
  100. H & C + 150 shot...exhaust popping under...
  101. 150 shot w/ low bottle pressure
  102. Does the TNT F-1 come with n20 filter?
  103. question about the ZEX sparkplugs
  104. Plug question
  105. How to hook a Fuel Pressure Gauge up to NXL?
  106. opinions on cold fusion
  107. question about the bottle
  108. New to the LS1/6, few questions about N20 DPI setups on these motors...
  109. 860 Bottle Nut
  110. Walbro Pumps!
  111. bottle valves?
  112. need help installing, did search.
  113. Jetting the NX MAF kit?
  114. Those with Timing Tuner, please chime in...
  115. Nxl Re-testing Complete
  116. venom kit
  117. Power Ring or NX MAF kit
  118. OOPS I left my bottle open.
  119. Any tips on buying...
  120. How to protect an engine from missed shifts
  121. Anyone put their bottle on the trans tunnel?
  122. nitrous location????
  123. who is redLS12003 ??
  124. Nitrous Solenoids Question
  125. 10% sale at www.coldfusionnitrous.com
  126. F.Y.I. Black NX bottles
  127. 860 performance in GMHTP!!!!
  128. question about when to spray
  129. Wet? Dry? Or Direct?
  130. Nitrous Outlets Wet Nitrous Systems.....
  131. NEED HELP Goin to the track on friday
  132. Racenet EFI Wet Nitrous Kit?
  133. Bypass question
  134. Converting Dry to Wet
  135. Nitrous Experts - Does my wiring diagram look right??
  136. Methanol Injection With Nitrous?
  137. "nitrous john" gossen dies
  138. N2o Solenoid leaks?
  139. NOS 5177 kit conversion?
  140. Heads/Cam + All Bolt Ons Nitrous Noob.
  141. M6 Guys, How much hp = your ET
  142. nx wont warrenty brand new solenoid
  143. what should i jet for? need some help.
  144. Problems with sensors and NX MAF KIT
  145. NX Rail upgrade for DP kits
  146. How does your system know when...
  147. Selling my TNT kit
  148. NX jet sizes please.
  149. NX accumulator questions.
  150. LT1 Kit
  151. What are some typical numbers for these setups?
  152. Court Is Over
  153. Nitrous Converion Kit From Card To Ls1
  154. Hooked!
  155. 5177 question???
  156. timing tuner????
  157. How bad for the motor is it?
  158. Plug Color???
  159. Direct Port -- TNT Ring?
  160. 10.41 @ 130 with 125 shot NX MAF kit
  161. NX Tpas wiring question
  162. Where to get a good LS1 Window Switch
  163. Mutt wet kit
  164. Nitrous PROBLEMS!!
  165. Need Nitrous Help
  166. plug gap on NGK TR6???
  167. direct port ?s
  168. Newbie here with some questions
  169. What else for an A4?
  170. 5177 People Inside...
  171. hot rod april 2004 page 84
  172. two staging it how to
  173. Direct port problems, help.
  174. NEED Help!!
  175. Nitrous refills in Minnesota??
  176. Would spraying through ONE TNT nozzle be = to spraying through an NX shark?
  177. <PIC> What happens when you leave a bottle cracked open
  178. TNT F1 directions
  179. nitrous sponsors
  180. Anybody fouled up a plug before?
  181. TR6 Gapping
  182. What to upgrade before a f1 tnt kit?
  183. Solenoid Exchange Program Is Active!
  184. Pocket Bike Nitrous Systems! We have them too! $189.95 free shipping
  185. Beginner Kit: 5177 or Halo Kit
  186. n2o noob, have NX Gemini questions, any experience with?
  187. Tuning Question
  188. 100 dry shot?
  189. What jets for a 125 shot on an NX kit?
  190. Progressive Nitrous controllers bad for solenoids?
  191. quick fuel system question
  192. What nitrous kit to look for?
  193. NX EFI Kit - Nozzle Location??
  194. two questions about line size...TNT and 5177
  195. Nitrous question
  196. nx maf vs. tnt wet f1. (pros,cons,opinions)
  197. Anyone run straight methanol or mix with a big shot?
  198. nitrous and timing questions???
  199. NX direct port intake manifold
  200. Pocket Bike Nittrous Systems!!!
  201. Where are all of the BIG power N20 setups?
  202. Plug wires?
  203. Nxl Kit Testing Update
  204. High Pressure Nitrous Fuel System Questions
  205. new dyno #'s but have a question
  206. 42 lbs to much for my application?
  207. N20 Activation
  208. Propane injection meanderings
  209. DynoTune Fully Automatic Nitrous Bottle Warmer Kit – $99!!!!
  210. What window switch to buy?
  211. $1200 kit+$600 maximizer+$200 accumulator+$1000 extras=0 horsepower priceless!
  212. New Track Best with a 150 shot - 10.56 at 125mph
  213. Stock bottom end
  214. Cartek 3x cam and NITROUS.
  215. Where to buy misc N2O parts?? Sponsors please look!!!
  216. fernco smooth bellow??
  217. How to properly purge with no purge valve?
  218. Inline fuel pump and TNT kit
  219. Dry Shot limitations
  220. who sprays with a small cam?
  221. TnT power ring
  222. Mounting the blow down tube question
  223. TNT 75 wet = dry 100?
  224. NX MAF kit results, with traction this time :)
  225. Is TR224 good for nitrous?
  226. Alternative to nitrogen push?
  227. 10lb Nitrous Bottle W/gauge $140 Free Ship To Lower 48 States
  228. spraying a pt4400??
  229. what lid w/ power ring? what do you have?
  230. WOT switch problem
  231. what wire si used for window switch?
  232. Need NOS direct port jetting sizes
  233. Building own wet kit?
  234. guys with 100-150 shots, what cam are you running?
  235. Could I use...?
  236. low pres. fuel system info?
  237. How to mount the bottle in the spare tire well??
  238. What can my car handle on the bottle?
  239. Difference in purge kits...
  240. FS Billet Bottle Brackets
  241. help!!!
  242. Where do I get the bracket to mount bottle between rear seats?
  243. Dynotune A/F gauge
  244. NXL Lag Fix
  245. Nitrous problem
  246. NX setup question.
  247. Fuel Pump Fix NXL Lag problem??
  248. anyone spraying 250shot through a single NX shark nozzle.
  249. Blow off valve in the intake.
  250. Opinion on dealing with NX and Maximizer please...
