View Full Version : Nitrous Oxide
  1. Time For A Spare Bottle!!!!!
  2. FREE.... Stage One EFI Nitrous KIT!!!!!!!
  3. 5117 and stock lid?
  4. New engine... Should I keep my dry kit or go wet?
  5. Hiding My Nitro
  6. Opinions On Proper Engine Parts For 250+ Shot?
  7. Need Nitrous controller recommendation..
  8. Best way to check fuel solenoid
  9. Info on propane injection? links?
  10. NOS on truck... a few questions
  11. What causes a nitrous backfire???
  12. 10.88 at norwalk S.I. dry shot, full weight
  13. Tunning for nitrous
  14. Dry Nitrous on stock 2000 Trans Am
  15. NX relay wiring question
  16. timing tuner ?????????
  17. New Nos Nozzle System
  18. Nitrous Pistons? Nitrous Convertrs? Nitrous Cams?
  19. Dyno w/ Cold Fusion Kit
  20. Not so hidden nos pic!
  21. Kr
  22. Can I sand down my n2o bottle?
  23. Need Help Decideing
  24. NX DP kit w/flexible lines...how to brace rails
  25. Help Me Set Up a N20 System...
  26. what kind of kit should I go with.
  27. Pics Of My Nxl With Braided Lines
  28. anyone have experience with the adjustable RPM chip
  29. detonation,detonation,detonation...
  30. What kit do i use with a custom fuel rail with vacume regulator
  31. estimated E.T.s
  32. Anyone have a F.R.E.D. controller
  33. Window switch
  34. MSD Digital "Pill-Less" Window Switch
  35. 853 castings how much juice?
  36. Nxl Kit Going To Nx For Testing
  37. Decided to polish my bottle today...
  38. show me where you mounted your n2o bottles...
  39. Where are the N20 spray bar plates?
  40. Colonels write up
  41. Stupid question just out of curiosity
  42. Nitrous kits on C5s
  43. squeaking,rattling??
  44. Nxl Dyno Results 7-27-04
  45. where to get injectors?
  46. Monster Nitrous Sale
  47. If i run bottle pressure at 800-900, can i maintain topend HP throughout run?
  48. How to get more than 30-40lbs out of 60lb mother n20 bottle?
  49. Fuel Slut Nitrous Kit Raffle - save our site!
  50. window switch question?????
  51. Whats Better?
  52. 2 gas 2 nitrous solenoids
  53. anytone here usung a version 1.1 timing tuner?
  54. Nitrous n00B...few questions
  55. people with the nos noszel kit help please.
  56. Huge Nitrous Sell!!!
  57. 150 Shot on Stock Timing?
  58. Nxl Problems Only,in Here
  59. On juice then traction control came on
  60. nitrous purge
  61. how much nos can i pump my engin ??
  62. Nxl Line Breakage
  63. Does Anyones Nxl System Work?????
  64. Compucar Kit??
  65. nxl rails
  66. All NXL owners inside please . . .
  67. Where did you mount your bottle?
  68. Direct port questions.
  69. Nitrous 4 sale?
  70. got a new best on the home made 150 shot
  71. how much gas
  72. Hiding The Nitrous System
  73. TNT F1 Kit w/purge
  74. 75 shot on cam and bolt ons ls1 ?
  75. New member here...
  76. NXL fuel solenoid problem?
  77. best safeest wet kit for stock ls1
  78. How much to have Solenoids rebuilt...
  79. Things to ask when comparing Nitrous Systems
  80. Which switch panel do you like more?
  81. Tr55's with 80 shot nxl?
  82. Filling station owners
  83. Nitrous Backfire
  84. Super Sale On Nitrous Refill Station Today Only $599.95 Fill Your Own Bottles And Sav
  85. Using a low fuel pressure pump for n20?
  86. Anyone have experience with plate systems?
  87. distance from solenoid to jet
  88. proper jet size
  89. Yank SS3800 and Nitrous!
  90. Would the tsp 231/237 cam work well with nitrous?
  91. 10% Off Any Bottle Today Only
  92. Give me your NX MAF kit impressions?
  93. Is spraying out of the whole any harder on the motor?
  94. Need opinion on N2O and cam, etc
  95. NOS remote bottle opener owners come in
  96. what size shot with a non anti balloning plate converter?
  97. Anyone heard of this progressive controller ?
  98. Anyone using a Cold Fusion Nitrous Kit?
  99. Nitrous laws
  100. Nitro Dave's is now carrying Timing tuners!!
  101. NOS Noszle system
  102. Nitrous Plugs?
  103. do i need a regulator to run the Walbro 340lph pump
  104. q? for NX-Maximizer users (new version)
  105. C5 guys with a TNT kit----->>
  106. Did I hurt anything?
  107. 1st 10 second run on a 100 shot
  108. DP setup -- major q?
  109. Digital window switch?
  110. Zex import kit on LS1????
  111. Why do my lights blink on my Timing tuner?
  112. New to the Nitrous side
  113. NXL track results
  114. ET Database
  115. MAF kit distnace from intake?
  116. Nitro Dave, Digi-max questions
  117. Wet kit or direct port??
  118. "Brown" coloration to TR6's on 175 shot...
  119. step by step detailed NOS 5177 installtion guide
  120. Purge as a dry shot?????????
  121. replace rearend even with just a 100 dry shot?
  122. NXL kit and 3°KR
  123. A Newbie Nitrous How to do question?
  124. Ntirous and Propane anyone???
  125. timing tuner issues??
  126. running power tuning with nitrous
  127. How to hook up a 700rwhp F-body?????
  128. Sputtering After Spray....
  129. new dyno numbers today
  130. How much do the NXL nozzles cost? without a kit
  131. How Many of you Guys are Spraying 100-150 on TR55 Plugs?
  132. how can i test the system when using a window switch..
  133. nos 5177 kit problem
  134. Questions about a NX kit
  135. timing tuner tuning question?
  136. nitrous on a stock 02 Z28??
  137. bottle questions?
  138. NX MAF kit track results
  139. where is the damn crank trigger??
  140. Holley Red work for dedicated fuel system?
  141. NOS and daily driving?
  142. NX Chemical X
  143. NOS 5177 or NX dry?
  144. Just got the call on my nitrous solenoids..
  145. Anyone used NX's two stage nozzle?
  146. My master switch....
  147. Cam selection advice need help
  148. Myth or fact? Nitrous vs. LT's
  149. NXL Jetting Problem, HELP!
  150. Just picked up an NOS Opener
  151. Can you just leave the bottle open?
  152. TNT Power ring + FIPK2 for truck!!!!!!!
  153. Purge Question
  154. Looking for guages
  155. Car Pinging like crazy
  156. Nitrous Blew Intake To Shreds....
  157. Nitrous Fuel System (Rear Mounted)
  158. You see I have this "friend"......
  159. used N2O bottles?
  160. How to polish nitrous bottle
  161. nitro dave's halo kit questions
  162. are the autometer Phantom gauges Lit?
  163. NX MAF kit, couple observations..
  164. Timing Tuner Works ok Now
  165. Ramcharger tuner vs.Imperformance tune! Difference?
  166. Jimmy Jams Micro Switch (blue) and new.
  167. Cheap/good nitrous
  168. n2o limiting factors
  169. N20 engine build
  170. Jet size questions?
  171. which purge kit is better?
  172. Anyone spray with the new TSP 225?
  173. Wet Nitrous Systems For 389.00!!!!
  174. Any Help For A Newbie to N2O??
  175. stock injectors?
  176. 10% sale at www.coldfusionnitrous.com
  177. got my TNT kit and TPS....what now?
  178. Anyone need a new NX N2O Maximizer?
  179. TNT installed
  180. Where can I get......
  181. How Do I set the Window Switch on the Timing Tuner?
  182. NXL Kit Questions?
  183. Guys that spray on the street...
  184. TNT v/s NX
  185. Question about NX purge and hardline..
  186. ls1 nitrous question
  187. What do i need besides basic nitrous kit?
  188. What Is a n2o Pilot Relay Coil?Please Help!
  189. purge line question..
  190. Help,How do I hook Up Nitrous Tuner to NX System?
  191. anyone spray on a 231/237?
  192. New Nozzle System Cheap
  193. N20 with 4.10's and Transgo--PLEASE HELP!!
  194. Link on Nitrous Outlets Dry kits
  195. How many passes can you get...
  196. bottle heater
  197. Frankenstiens Nitrous Monster
  198. Zex kit results..
  199. Does anyone have Jet sizes for LS1 Fuel Pressures?
  200. Using TNT Power Ring w/ FIPK?
  201. Who to check out solenoids...
  202. Anyone who needs N2O stuff!!!!!**
  203. Pluming for wet set-up
  204. TNT power ring w/ a 90 mm throttle body????
  205. Blow Down Tube Install ? Need Help ASAP
  206. what shot jets do I have?
  207. TNT came through on customer service
  208. will this work?
  209. how many seconds can you spray nitrous?
  210. What else do I need?
  211. n20 fittings
  212. nitrous noid is not opening
  213. Purge Picture!
  214. timing tuner...comments?
  215. Need some feed back on the NX- NXL kit
  216. fuel pump for 150 shot
  217. Nitrous and PCM Scanners
  218. TR6 or TR6-IX
  219. LS1 TNT jet sizes?
  220. Add this to my list of new mods!!
  221. Can you purge on your tranny cooler?
  222. New TNT bottle valve full of metal shaving
  223. Had to put 350 n20 pill with 250 fuel pill to get 250hp TNT kit
  224. TNT Solenoid sticks closed new, then sticks open
  225. Spraying with the LSX
  226. How much timing should I be running
  227. F#$%!mounted My Bottle In Back Seat Hump...
  228. Have you guys seen this?
  229. Installing fuel pressure guage with NX Wet kit..
  230. Fuel solenoid died and I didn't even know it.
  231. Nitrous on a M6
  232. autometer pills on an MSD window switch?!?
  233. TNT F1 mounting??
  234. Nitrious fittings
  235. spare tire bottle mounting.
  236. good n2o cam for m6?
  237. anyone else running a wet/ dry 2 stage through the intake?
  238. TNT Power ring question
  239. Where the heck are your window switches?
  240. msd distributorless window switch problems
  241. Ack, im a ricer, ordered "Purge light"
  242. 10lb vs. 15 bottle?
  243. NX MAF kit guys - do you have problems getting A/F tuned
  244. Hidden / Stealth 5177 Site Link?
  245. C5 Corvette guys in here.
  246. making a 5177 kit a wet kit need some info
  247. Installing a DP in a plastic intake.
  248. Digital Window Switch
  249. Master Switch
  250. spraying it out
