View Full Version : Nitrous Oxide
  1. Latest on the new NX progressive controller???
  2. Stock set-up
  3. Propane and N2O. Im still a little fuzzy
  4. NX Console Switches Question
  5. Pictures of my new Direct Port setup
  6. How long does your nitrous last?
  7. NX install help!
  8. NX jet size info needed
  9. C2 Cam good for 100hp shot?
  10. NOZZLE PICS?
  11. New Best on the bottle.
  12. Cost per pound?
  13. Sparkplug question....
  14. Texas lid and NOS dry shot setup??
  15. Fogger nozzle limits???
  16. Nitrous Cams...????
  17. Can someone please tell me whats wrong with my car??
  18. 100 Shot Plug Question
  19. Will this bracket work for mounting the bottle in the spare?
  20. NX price increase and upcoming new products!
  21. Best nitrous setup for FI
  22. Any ideas on what it will run?
  23. Q's about the NXL kit...
  24. Uh oh, what did I break?
  25. Paging Big Mike....
  26. Timing Tuner
  27. Heads Cam Guys what Nitrous kit are you using?
  28. sheetmetal better than "plastic" intake for N20?
  29. Small Wet Shot on my car
  30. NX Noid Leak????
  31. Possible problems with Ram Chargers timing tuner
  32. Your opinions PLEASE!
  33. ? 100 shot what's better wet or dry?
  34. Nitrous Kit Question
  35. What is Nitrous?
  36. Any suggestions?
  37. Anyone have a good videos of LS1's spraying out of the hole
  38. rev limiter sprayn'
  39. Need a good cam?
  40. Nitrous switch panel for automatic ashtray?
  41. Jet sizes
  42. A direct port jetting technique question
  43. Wet Kit
  44. How much can you spray a stock '99 LS1 (NX wet)?
  45. Thoughts on TNT 250 shot for LT4
  46. 10.750 @ 128
  47. new noszle kit and fuel system f/s
  48. Nitrous List
  49. Will this work?
  50. Will this work?
  51. Propane and Nitrous?
  52. Where to tap into the fuel line?
  53. How long would my motor would last with a 175 shot?
  54. Dry to wet
  55. How much n20 per cylinder before TB would = 300 direct port?
  56. How big of shot?
  57. where can i buy 2 125 shot jets and 2 150 jets for 5177 dry
  58. Nitrous refills in South Bend, Indiana
  59. How much timing?
  60. Help deciding on a Nitrous System
  61. Nitrous experts inside please, need ideas..
  62. Purge Nozzle
  63. thicker oil for N20?
  64. Modified MSD Window Switches now available!
  65. Question on a purge system
  66. FS: 5177 kit & Purge kit & 2LB bottle.
  67. Dumb Question
  68. Stupid question.
  69. Help with Jet sizes please
  70. Will the TR230 on a 111 lsa work with juice
  71. I'm a rookie, but I have a question about juice?????????????
  72. Running 75-100 wet without retarding timing?
  73. nx switch pannel
  74. wet kit on heads and cam cars........
  75. Upper and lower RPM's?
  76. what timing should i run
  77. nitrious ?
  78. nitrous kit wiring help
  79. How do I post up pictures
  80. NOS 5177 Single Fogger
  81. Air Fuel
  82. do i need new fuel system
  83. Finally got some N20 Dyno's :(
  84. Big Mike and Cartek do it again!!!!!!
  85. 100hp "dry" and TR6... What gap??
  86. Need install pics of NX GM-MAF kits on F-bodies please....
  87. newbe
  88. WOT switch and BBK throttle body where do i mount it?
  89. questions about direct port
  90. What Spark Plug Is 1 Step Cooler Than Stock-- TR55IX?
  91. making a NOS 150 shot.....?'s
  92. fuel question ????
  93. NOS 5177 setup
  94. any reason you cant run a BIG shot dry?
  95. Wideband guage
  96. TNT kit comin on late
  97. New Dyno Numbers with 100 shot
  98. NX Twin Gemini Kit
  99. Lookin to get spray (newbie), got some ?'s
  100. Question for guys running over a 300 shot...
  101. QUESTION ON THE MSD WINDOW SWITCH INSTALL
  102. IS ANY ONE RUNING A 200HP SHOT ON A STOCK LS1 ???????
  103. huge shot limit??
  104. Need help. Injectors hitting direct port nozzle
  105. newbie!
  106. Anybody runnig NOS with Procharger
  107. Brand new TNT kit for sale
  108. Any update on NXL progress?
  109. Hitting a barrier Spraying, need help...
  110. pics of setups and switches
  111. Anyone using Iridium plugs with nitrous?
  112. headers and 150 shot ...123 mph
  113. TR-6 GAP WITH MY MODS
  114. what size jets for 125 shot { nitrous express}
  115. NOS Switch
  116. Flycutt pistons and N2O???
  117. Wiring Schematic Question! *4wd switch for Nitrous*
  118. anybody use the timing tuner?
  119. Direct Ports and smaller HP shots
  120. GMS MAFS + 100 shot= ??????????
  121. Experimental Nitrous, Timing controller
  122. Need help on building a 10 sec SS
  123. How long can a motor be sprayed?????
  124. good stall for auto and nitrous off the line?
  125. NOS 5177 bottle heater thermostat
  126. tnt jet sizes
  127. tr6's good for my setup
  128. anyone sell pills so that i dont have to buy 2 sets
  129. need 100 shot on top of my powerdyne *DELETED*
  130. Does TNT have a 5# or 6# Bottle?
  131. 4 SALE: Nos 05177 Kit with Bottle Warmer & Whisper Lid
  132. How much RWHP on a bolton ls1 with NOS 5177 and 125 jets?
  133. What is the biggest shot i can run on a dry kit???
  134. NEW NOS NOZZLE SYSTEM FOR SALE (CHEAP)
  135. Reading Spark Plugs..need some help
  136. Backfire ?
  137. Does anyone answer at TNT anymore??
  138. Selling NX Wet Kit
  139. ls6 or lingefelter intake for DP nitrous
  140. running a T off the fuel rail for a dual stage?
  141. Spark Plugs
  142. TNT F4 Kit
  143. i need assistance with nos
  144. Noszle kit
  145. Well explain these dyno #'s with the TR 224/.563/112LS runs
  146. What should the Air Fuel ratio be?
  147. Late nitrous
  148. What plug to go with for a dry 100 shot?
  149. newbie nitrous ??
  150. The making of a low 10 second street car.
  151. NX anyone with a pill chart???
  152. Selling brand new noszle kit
  153. N2O install basic questions
  154. Nitrous Express NXL system delayed until the end of August
  155. Went to the track last night :)
  156. Who sells the Noszle system? (Direct port)
  157. How to run a gauge inside cabin?
  158. Whats needed for Dry shot?
  159. 11.41 at 124MPH w/TNT 100shot and TR 224/112LS cam!
  160. Think I'll have enough power?
  161. Mallory VS. MSD?
  162. RPM based Progressive Controller ... Who makes them?
  163. MAF plate NOS VS Lid injection
  164. TNT Direct Port
  165. Big cubic inch guys! What are you spraying?
  166. NX Twin Nozzle System- Need help!!
  167. Could my bottle have a leak??
  168. Need opinion--What is best Nos for 02 Z06?
  169. dont guess anyone can answer my question
  170. Can a Stock Clutch Hold Nitrous From a Roll
  171. NAWS
  172. ?? on a dry shot
  173. ForSale: 2LB NOS brand nitrous bottle
  174. Need to cover this darned bottle!
  175. How many of you have been running N20 for 2 years +
  176. Attn:WS6 Owners W/Power Ring
  177. Never had nitrous before... want it now!!
  178. Spraying through shifts?
  179. NOS Programmable Nitrous Controller
  180. Will NX automatic bottle heater work w/ the TNT bottle?
  181. What converter for a TH400
  182. Aluminum Nitrous Feed Line
  183. hpp3 ok for gears and nos
  184. new to ls1's
  185. Any updates on NXL kit ?
  186. can i safely spray with these mods?
  187. Nitrous Supply Line Question
  188. TR 224 cam with N2o
  189. Good Idea to spray or not
  190. rev limit
  191. pics of dual stage or single MAF nx kits
  192. Stepping up to a direct port!
  193. I need colors
  194. nos or no nos?
  195. is anyone running dry kit w/out jets
  196. cam for nitrous?
  197. NX on stock engine how much,,,?
  198. wanting to put TNT on the Z..help
  199. Nitrous works jet card
  200. NXL direct port kit
  201. Newbie needs some NOS help
  202. question on the NX kit
  203. Newbie needs help
  204. Is NX really a bad company?
  205. NOS EFI LS1 kit
  206. Dry Shots and Hidden Solenoids....
  207. is there a special jet for a dry kit to move u to 150?
  208. TNT or NX???
  209. Looking for info on direct port fuel system
  210. Question about new Maximizer
  211. install the NOS system&dont hit hard
  212. First run...What do i spray?
  213. Would it work *DELETED* *DELETED*
  214. Fuel Punp and Injectors
  215. anyone spraying a cam like this
  216. New NOS GM Truck Kit for 4.8, 5.3, 6.0
  217. How to setup large dry shot to pull timing when you use n20
  218. why mount 'noids in engine bay?
  219. do N20 bottles go bad?
  220. first post...nitrous ?
  221. NX bottle heater fuse?
  222. New Dyno Numbers Inside...Thanks East Side
  223. Quick purge wiring question
  224. What should i run with my sig set-up
  225. Which to buy....NX Maf kit or TNT F1?
  226. Iridium & N20
  227. when to stop using hpp3?
  228. Need Help! How to mount the WOT switch
  229. TnT power ring still have fitment problems?
  230. How big of a shot with my new H/C setup?
  231. Dual Stage button-M6
  232. how to adj timming after NOS
  233. MSD Window switch?
  234. Where to wire window switch in 5177 kit
  235. Where to put the NOS 2 spay nozzles with KIPK
  236. Where to buy teflon paste?
  237. Interest in a digital knock guage with memory recall?
  238. Adapter size on NX bottle
  239. Can I safely do this? (fuel requirements)
  240. What is the difference between TNT Pro purge and normal one?
  241. Any brave souls w/ bottle between seats?
  242. 396 Lunati Stroker.
  243. Has anyone mixed and matched TNT jets?
  244. confused??
  245. Anyone need a holley 255 in tank fuel pump..
  246. Thinking of hooking up a heater.
  247. TR5 spark plugs
  248. cam question
  249. Timing control on large shot via PCM
  250. N2O coupling problems
