View Full Version : Nitrous Oxide
  1. HELP WITH NX BOTTLE HEATER!!! Quick!!!
  2. Changing my nitrous system around...
  3. just installed kit . i have a few questions
  4. Some Pics of my Custom Fuel System... pics big
  5. head/cam car and a 100 shot + stock fuel system
  6. 35 gap hurts n/a performance
  7. Finally going to hit the bottle.
  8. 200 Shot Whats NEEDED???
  9. timing tuner questions...
  10. Better Delivery Systems, Any Out There?
  11. Nitrous sale!
  12. MAF translater on dry shot
  13. Need a little help
  14. NitroDave's Is Moving!!!
  15. How Much NOS is to much????
  16. Can you run this reliably
  17. NX Wet Kit
  18. Nitrous + boost?
  19. Can I run nitrous with my car without BOOM?
  20. NGKs Tr-55s
  21. Nitro Dave!
  22. Can I repair my nitrous line???
  23. What NOT to do with nitrous?
  24. Did anyone try
  25. nos dry kit please help
  26. Spraying?
  27. MSD window turnoff???
  28. mallory window switch please help on wiring
  29. Sprayed the 150 shot tonight for the first time!
  30. New NOS wet system
  31. Question after TNT install (power ring)
  32. NX MAF Ends
  33. anyone with NOS 5177 Kit come in
  34. Jacobs Nitrous Mastermind?
  35. 6000 MSD Window pill?
  36. question about a/f gauge connection
  37. Spraying a supercharged truck
  38. What rpm does your window switch go off?
  39. spark plug 100 shot
  40. Need Help ASAP with NOS Dry Kit
  41. Low mph with 150 wet shot
  42. Wiring a Harlan window switch w/ NX kit
  43. How hard will this be to drive?
  44. new system
  45. TNT bottle pressure?
  46. how safe is nitrous equipment in vehicle ?
  47. ?nitrous buttons hooked up threw steering wheel?
  48. Eastside New Stock location suspensoin record.9.14
  49. nitrous plug colder than TR6???
  50. fuel safety
  51. **New best with new setup - Oh So Close!!**
  52. how long will a stock motor last on the juice?
  53. Wolfe Roll cage & 15lb bottle/spare tire location
  54. EASY QUESTION ====== PURGE VALVE
  55. cheapest and easiest direct port
  56. how long should i purge??
  57. Where to power switches from???
  58. As promised..Pics of my setup
  59. Prototype Nitrous set up in the works!
  60. Remote openers...
  61. Looking for line
  62. Why retard timing?
  63. What size injectors for a 200 shot on a 422
  64. Fan nozzle placement
  65. Max direct port shot
  66. Car stalls when coming to a stop after NX install
  67. Nitrous / Propane Injection
  68. Anyone spraying on stock GM plugs?
  69. pic of how you mounted your WOT switch???
  70. Building first switch panel
  71. Jets, to richen/lean
  72. Wet kit jet size question
  73. How much fuel do you go through??
  74. Dual Stage vs. DP on a programmable controller???
  75. NXL Where are you????
  76. Backfire takes out the crappy ls1 intake for me.
  77. Window Switches?
  78. a newbie and nitrous
  79. NX Gemini Kit
  80. Dual Stage 300 Shot...wet or dry..direct or MAF
  81. Direct Port DynoToday (544/540 on 150-shot)
  82. Seperate fuel cell
  83. Timing retard with nitrous?
  84. LS1 NX Gemini Kit
  85. Wet Kit Users Inside Please
  86. How much fatter?
  87. TEST forum 8
  88. Possible Timing Tuner Problem?
  89. Disassembling bottle for powder coating?
  90. NX Jet sizes?
  91. Timing setups for spray, I have a slight problem possibly
  92. wtb wet kit
  93. Do the NOS brand kits come with a WOT switch?
  94. anybody with a wet kit accidentally spray with an empty bottle
  95. What gears with Spray..
  96. i need help
  97. will race gas kill 02's if just used with the nitrous?
  98. For thoes of you that manually engage you N2O
  99. I need pics of your WHOLE Nitrous setup!!
  100. Need NX Maximizer wiring/install PDF
  101. 5177 problems
  102. Need Wiring Help please
  103. question sell price for an lt1 dry kit?
  104. 2002 ls6 cam w/....
  105. Direct Port for sale
  106. spray at low rpm w/ 2 stage
  107. need help installing NX wet kit w/ genx 2 upgrade
  108. Will a wet kit make more power than dry with same n20 jet?
  109. Nitrous question and backfiring problem!
  110. Where can I get individual NX jets?
  111. Nitrous efficiency problem?
  112. Can we post the NOS 5117 install pics.
  113. Pls post your contact user in AOL, ICQ, MSN...
  114. 100 dry shot, 4400 and TR55`s??
  115. LS6 Cam And Nitrous?
  116. Recomended Kit?
  117. Quick help us! Where to ground toggle switches.....
  118. WTF, my gauges won't be legal?
  119. LS 1 edit
  120. jet size question again?
  121. Nitrous kit almost complete
  122. Get on the list for the New NX NXL Kit.
  123. nos 100 dry kit please help
  124. NX MAF system questions....
  125. where do you got tnt?
  126. How long does 1 lb. of nitrous last?
  127. nitrous activation
  128. Will a dual stage 250 Dry shot work correctly?
  129. BOTTLE HEATER
  130. Converting a wet kit to direct port?
  131. mti clear lid
  132. New dyno #s Yay me :)
  133. Help?
  134. Fitting connections... teflon tape or paste?
  135. Glidden Nozzles
  136. window switch settings???
  137. Installation
  138. newbie to n20....tnt f1 or nx maf?
  139. Which head gaskets for H/C with 100-150 shot?
  140. Quick question on bottle pressure
  141. Installing EGT question?
  142. spraying supercharger
  143. Who has the best price on NX system
  144. Sprayed 1st Time!
  145. Last day at TNT
  146. More than a 150 shot?
  147. Cheap bottle blankets on ebay
  148. beat a 911 with stock ls1 and N20?
  149. Hard to wire a window switch???
  150. Quick question on mounting NOS on a K&N FIPK kit
  151. How much for N2O install???
  152. Automatics with window switches
  153. TNT bottle
  154. Is a 25 shot worth it?
  155. Best cam for NA AND N20?
  156. Rails vs. Distribution Blocks
  157. life span?
  158. dual stage 250 shot dry
  159. What went wrong... ???
  160. Has anyone had their purge refuse to close?
  161. purge kit & paint
  162. Wet Shot manifold pooling?
  163. can nos get bad?
  164. pic of new switch panel
  165. NOS Bottle Warmer Install Q
  166. Will this wiring schematic work for a nos 5177 kit?
  167. Who has the Nitrous Oxide Systems 05177 kit?
  168. TNT People...
  169. I won NX...Now what
  170. Air fuel and 100/125 hp Dry shots
  171. N20 Filter and Flow
  172. Can spraying a lot......
  173. NOS Pro Race Fogger DP Q's?
  174. Pics of TNT Direct Port on LT1?
  175. Spraying 4.10s
  176. ??? FOGGER SYSTEM FOR LS1?????
  177. Sprayed it for the first time
  178. Well, I did it.
  179. when to cut off MSD switch?
  180. HELP ME DECIDE WHEN TO CUT OFF NITROUS WITH WINDOW SWITCH!
  181. Well, its April . . . any word on the NXL system yet?
  182. NXL vs. "standard" DP
  183. Oil Dipstick pops up after nitrous run
  184. NITROUS QUESTIONS
  185. Anyone have their FPSS wired this way?
  186. harlan window switch wiring
  187. Bad day at the dyno with a 5177
  188. NOS vs NX Kits?
  189. Car is hard to start after nitrous run. Have ?
  190. Have great pictures of my new TNT kit installed!
  191. Direct port not necessary for only 100 shot?
  192. Dyno with TNT 100wetshot, after 12bolt installed
  193. 30# or 36 # injectors ??
  194. fuel pressure cut off switch?
  195. changed my mind, i want some N20, but i need help
  196. Wet or Dry on a 1998 SS
  197. mounting bottle in spare tire area
  198. help wire window switch
  199. 9.21 @ 146 at ATCO.
  200. Do i need to use blow down tube???
  201. Please help this nitrous and ls1 newbie
  202. where did you run wiring???
  203. Xylene and Toluene
  204. TNT POWER RING
  205. Did I get ripped off?
  206. purge tubing/hose question
  207. Bottle size question
  208. how big of a shot with factory fuel sysytem?
  209. TNT or NX gauges
  210. TR6 @ .039 N/A
  211. MSD Window Switch Wiring
  212. Questions on 5177 100 shot kit?
  213. Problems with grommet?
  214. Safest Nitrous Setup
  215. DO i need to change timing??
  216. nos 5177 kit.. What purge? -4 or -6??
  217. Is anyone using -4an lines on there TNT wet kit?
  218. what's wrong with my second gear?
  219. low dyno numbers on spray...
  220. My nitrous filter is leaking??
  221. VENOM nitrous owners please
  222. Dry kit jets question
  223. Dry kit jets question
  224. TNT owners inside
  225. Where to get the cheapest accessories?
  226. Have question reguarding TNT kit?
  227. Question about NX nitrous relay
  228. Dual Purge Set Up Questions
  229. Tuned for N/A-But want to run a 100 shot?
  230. Where can I get ~8' of tubing for NOS purge
  231. Auto cars with 3.73s running nitrous
  232. Which dry kit??
  233. Bottle Heater Question
  234. all NOS and NX direct port users come inside
  235. Would you rather be blown or inhale the laughing gas....
  236. Anyone have vid of exploding dry dyno run
  237. Getting bottle filled in Pittsburgh Pa area
  238. Before/ After MAFS?
  239. Do i need fuel pressure gauge with juice??
  240. nx wet kit pill size
  241. is a dry kit easy to hide? Also.......
  242. NX Wiring Question
  243. NOS 5177 and Ramchargers Timing Tuner
  244. TNT F1 and 85 mm MAF
  245. Bottle Mount
  246. Iridium plugs
  247. Need Data on Spray
  248. Ever order from Ultimate F body??
  249. MSD window switch on 98 Trans AM
  250. Hidden Nitrous System (C5)
