- Question about Timing and Nitrous..
- which cam for nitrous!?!?!
- TR6 plugs anyone have the part number??
- NOS main feed line size
- Who's running the NX Gemini twin MAF kit?
- Direct port dry kit...
- Can you run 150 TNT shot on a 99 ls1?
- TNT VS NX kit: Help me pick a kit.
- Nitrous Mastermind???
- what did i screw up?
- Optimum A/F ratio on spray???
- NX System
- who do you think makes best kit?
- Tough decision???
- Detonation on TNT 100 Shot-Help
- where the heck is the nxl???
- Any way to use 85 mm MAF and TNT power ring?
- MSD
- NX Direct Port Finished
- Wiring diagram??????
- Track Safety Requirements?
- What REALLY causes nitrous backfires
- 150 shot at 5800 feet?
- where to buy 100 shot jets??? and other products
- Do I need tuning with a WET kit before I spray?
- I think T.N.T ??
- A (not so) quick TNT wiring question
- Question about why purge isnt working right.
- NOZZLE DIRECTION QUES?
- Question about the TNT F1 Dry Kit
- What kit is best w/K&N FIPK?
- Bottle heater question...
- Pros/cons of NX Gemini (MAF) vs. NXL kits...
- How to acitvate 2nd stage???
- nos dry kit single nozzle?
- 03 cobra forced me to do it!!
- Where's the cheapest internet dealer for NGK TR6 plugs?
- 224/224 .563 114LSA Good for 100 shot?? and 3500 stall
- NOSzle Installed - Pics
- want NOS on 5.3 help
- TNT F1 kit...
- Wavy torque curve. Please help!!
- tried nx100 on a tp4400 3.23 geared car.
- Can you turn a dry kit into a wet&dry kit?
- 3600 Vig and NX wet kit?
- Read something maybe some of you might be interested in....
- Mallory 685 Ignition or just a window switch?
- which nitrous is better
- TNT wet shot users/ what's your maf? ends?
- HP limitations of stock 2002 Z06 fuel pump(s) nitrous related
- Trying to pick my next mod???
- C5 Nitrous problems
- Tony from TNT or anybody else????
- Any update on NXL's release?
- Window Switch RPM
- Baby nos
- Change from stg 1 to stg 2 dry setup?
- The safest kit?
- Times with a TNT 100 Kit and....
- F2 TNT anybody
- why N20?
- nos kit for a lt1 and ls1
- Nitrous Works Kit (WET)
- N2O questions
- Installing NOS
- Need to learn Everything about using GAS on a LS1 !!!!
- slp 85 maf work w/ tnt wet kit?
- Need Descriptions of two NOS Part Numbers
- ignition guys I could use help locating a couple of things
- Wet or Dry? ...That is the Qeustion!
- DRY KIT BOTTLE PRESSURE
- window switch?
- Can I do this
- Mounting a switch to the shifter
- bolt-on motor with a 200 shot dry
- Custom NOS dry kit, I need some things, where to get them?
- TNT Wet Kit
- Nitrous Setup
- Antone had problems like mine??
- stock times with 100 shot
- NX Wet Kit - Basic Install w/ Pics
- 382 and a 150 shot
- Interesting item for big shot dry guys
- 10-bolt + nitrous from a roll, safe??
- Having issues spraying 300!
- Am I missing anything?
- Can I run more nitrous with a progressive controller? move up to 300 rwhp
- TNT Purge Differences?
- Sprayin with a 4.56
- t.n.t or n.x system?
- TNT F2
- Please help me quick!
- How big to go on Injectors?
- What will I need to change the NOS Dry Kit to a wet kit???
- The long awaited NXL pic.....
- NX Fuel Pressure Safety Switch ?
- 500 RWHP..will my car be ok???? HELP HELP
- TNT Force 2 Kit or NOS Dry Kit witch is better
- SHOW ME YOUR SWITCHES !!! ! ! ! ! !! !!!! !
- is this too much?
- Would this work?
- zo6 slave and master fitting f-body
- WTF!! Nitrous Freeze!!
- Anyone hooked their bottle opener to their ASR?
- Safer than the Venom VCN2000
- NOS Brand jet sizes
- Can NX bottle warmer tap into defroster for power?
- help with timing tuner !!
- Looking for a GREAT Nitrous cam!
- Whats the difference in a TNT F1 kit and F2?? diff solenoids?
- intake?
- what do i need to run tnt kit?
- What is a good fuel pump for nitrous?
- Are TNT N20 jets different than NX jets?
- HP limit for a -4AN main feed line...
- MSD window. What wire do I cut into for TACH?
- Have direct port nitrous question?
- BOTTLE MOUNT QUES?
- Paging Diamond, and other N20 Internal Gurus!!!
- Got walked, ready to bottle feed ASAP, need help.
- the little v6 that could
- Best Nitrous kit for me? NXL or just the NX wet system
- Best Pistons and rods for N2O?
- Need help with fitting selection
- NEW CAM, WILL IT BE SAFE TO SQUEEZE ON IT?
- MSD RPM Window switch c5 corvette
- Should I replace my head gaskets for a 125 shot?
- Do i need to change anything with 100 shot "wet" ??
- Nitrous pressure gauge stopped working, where's the best place to get NX stuff?
- Wet Kit or Dry Kit??????
- QUESTION ON TNT POWER RING
- TNT F1/2 users 200 RWHP Shot questions.
- I NEED A 1.5" PRESSURE GAUGE!!
- Dual stage or progressive controller, which is better?
- Need Help with jets sizes
- LS6 Intake w/ TNT Wet Kit
- wondering where to get a bottle warmer for 15# bottle??
- PLZ post pics of ur purge
- Air Temp And MAF ???
- 50 shot wet?
- anyone ever run nos with 1 super powershot noid?
- Kenne Bell Boost-a-Pump?
- Q on when to hit NOS with stock rear?
- Plugs for big shot?
- Spraying over 200, need input...
- HOT: NX kit relay wiring... which wire is which???
- The life of my motor will depend on your responses!
- How much timing with 150-200 shot?
- Nitrous Works
- any of you NX guys wanna make some money?
- E.T. Questions ? ? ? ? ? ?
- 4.10 or 3.73 when spraying???
- Hey Guys....
- Conveting a TNT F1 kit for a LS1 to work on a LT1
- How have you hid your nitrous?
- what to expect?
- Stock 2001 fuel system enough to support heads/cam and a 100 wet shot?
- Max Compression for a 200-300 Shot
- Nitrous Express LS1 NXL w/Rail
- Spraying in 5th gear??
- Compilation of Nitrous Direct port photos within
- Paging TONY TNT
- Best Mixture Distribution Dry or Wet
- Safe to spray TNT 250 RWHP (310HP) shot on forged pistons, stock rods/crank??
- Track and NO2 questions
- HPP3 Tuning with N2O??
- At what RWHP level do you guys change the stock intank pump?
- Who had the NOSzel DP pics?
- Time for WB.
- Best dry kit setup?
- TNT Conversion kit & some questions
- TNT kit without the power ring
- 2 soleniod, 1 relay
- Spark Plug Question
- Progressive Controller
- can I spray this setup?
- NX remote openers back in stock!!!
- New 5177
- help w/ nitrous!
- Custom H-11 Head Stud Kits F/S
- can i use nitrous on a road race course?
- honda ?
- MSD vs Harlan window switch
- possible to convert carb system to FI?
- 200 shot questions
- NX MAF install PICS ...
- 100 shot hurting my tranny?
- NX remote opener?
- Fuel Volume to Support Direct Port System
- N20 slowing me down?
- anyone spray witha 3600 converter
- ? about timing tuner
- Simple NOS 5177 Question
- Any word on when the NX NXL system will be available for the LS1?
- QUICK QUESTION ASAP >>
- New Dyno with a 382 and 100 Shot!
- 150 pills 62,33 or 62,35
- For those of you that spray through the shifts........
- need help with window switch
- H/C and spraying fuel pump question?
- Purge problem...
- I WANT NITROUS....but
- Any of you N20 users check your compression before and after?
- Tapping the LS6 intake for Direct port?
- Is anyone spraying the C2 cam?
- wiring diagram for wet kit with purge needed
- Difference between wet and dry shot???
- where to buy mounting brackets for 15lb bottle
- dry nos with slp meter
- bosch inline pump part #s
- TNT F1 jet question
- dry shot parts
- FINALLY doing it...??What parts for wet kit...???
- Bottle and fuel pressure gauge
- Timing Tuner
- Where To Put The Nozzle?
- Plug ?'s w/ 5.3L heads and nitrous
- seperate fuel system for nitrous.
- Can stock fuel pump and injectors support a 100 shot?
- Where to install my purge?
- NX Direct Port Install Update
- who makes the best DP kit?
- Where to run bottle line?
- NX maf kit question.
- hot cam and a kit
- NX Window Switch
- Need help from you BIG shot dry users
- Has anyone run multiple window switches?
- Dry kit tuning issues....
- WTB NX shark nozzle
- NOS website?
- where did you mount your bottle in your vette
- Nx wet kit jetting chart
- Newbie install Q.
- Considering dual stage setup
- Mounting in a spare tire compartment
- Would a 4400 stall + nitrous be okay w/ a progressive controller?
- Timing and fuel question??
- Can I use Granatelli maf with NX maf kit?
- Difference in solenoid sizes and nozzles?
- 175+ shot...
- Spraying a 4.56 bolt-on LS1 :)
- Does anyone have a 224/230, .550 lift, 114 grind for nitrous?
- safe to spray NEW 422?
- Dry to wet conversion?
- Question about NOS jets...
- How did you mount your gauges?
- speedshop nitrous gauge
