View Full Version : Nitrous Oxide
  1. Car won't idle with BR7EF's?
  2. Another lnc-2000 question..
  3. injectors
  4. Nitrous breaking up PROBLEMS NEED HELP
  5. 75-100 hp dry kit , info please
  6. lnc2000/twister/whatever placement
  7. 2 stage shots
  8. low hp #'s on 75 shot
  9. Ok... Lots of searching, no answer. Plugs...
  10. Cam and 75 shot
  11. Frost tune w/ nitrous
  12. Help with trick perfrormance controller
  13. Lingenfelter LNC2000 Diodes
  14. FS:L92 Victor Jr. With Spray Bars SOLD
  15. got bored, made a switch panel.
  16. Nitrous Plate Location
  17. Anyone running a n.o.s ls2 plate on a low pressure sand alone?
  18. Can u port out a n.o.s ls2 nitrous plate to fit 95mm intake combo
  19. Pushing Water
  20. about to spray
  21. Am I going to have a problem with the stock bellow?
  22. 300 shot on Stock Forged Block Question
  23. The Rebuild of the Nitrous Outlet Drag Radial Car
  24. Stock Cube ls2 build ideas
  25. NX fuel line ?'s
  26. HSW Nozzle with NOS jets?
  27. Help me read my plugs
  28. NA 402 c16 in the Fuel cell with no timing pulled Safe?
  29. Coil Pack Signal wire? for MSD Window Switch
  30. FJO Progressive NEED HELP
  31. Stock short block LS3 Goes 5.58 with a Puck System
  32. "the famous DynoTune high flow bottle valve"
  33. Plug reading debate. Who is right?
  34. few detail questions..
  35. Hotcam with nitrous?
  36. Help in Plug Reading please!
  37. Will the nitrous outlet window switch reset
  38. plesae help me out!! need diagram!!
  39. For the guys wanting to plumb a LS1 Fast 102
  40. place to fill near OCMD
  41. Air flow
  42. maf screen, remove for n20??
  43. nozzle location pics..
  44. How often need to swap br7's on a shot?
  45. biggest shot on my motor
  46. how many mph do you pick up on a 100shot?
  47. Bottle heaters
  48. New to Nitrous
  49. Looking to get wet plate kit... Quick question!
  50. MSD 8969 Issue, question for the nitrous guys
  51. 120 Volt Heater In Car
  52. FPSS Users
  53. Done with nitrous
  54. joining the nitrous world
  55. Diamond Dome Nitrous Pistons...
  56. nitrous and n/a timing 110 octane
  57. Fastest Stock Bottom Nitrous LS?
  58. Is 18 deg timing low for a H/C 130 shot?
  59. First time out with nitrous on new combo 5.73@122
  60. Installing FPSS on 2 Fuel Solenoids
  61. Slew based timing controller.
  62. help with nitrous!
  63. nitrous power loss on dyno
  64. Nitrous Help!
  65. Crazy question....
  66. nitrous question
  67. Spark Plugs Help
  68. victor jr intake nitrous setup help
  69. Would you need to change fuel pump ???
  70. Nos Cheater1600 noid good for 150plus shot?
  71. Should I rebuild solenoids?
  72. Does anybody make a timing and progressive controller in one?
  73. converted from NX single nozzle to 92mm plate
  74. What parts to replace on 8 year old NX kit?
  75. How much extra timing to pull for every 10 degrees temperature increase
  76. Digital Nitrous Gauge
  77. Announcement from Nitrous Outlet
  78. what progressive, window switch ect....
  79. can different solenoids effect horsepower?
  80. tuning and spraying a dry shot using an IAT resistor and momentary switch
  81. Bottle mount
  82. Information On Nano Kit Dealers
  83. Need nano kits
  84. DO i need more timing adjustment?
  85. Mounting the Nitrous Bottle Side ways???
  86. Another Launching M6 Question
  87. nitrous filter
  88. 4.8L e85+150 wet shot...Questions
  89. 93 octane and nitrous
  90. NX and NOS jet compatability
  91. fast 95/95 with 92mm plate
  92. best nitrous setup for 408 stroker????
  93. Wet or Dry? H/C/I Stroker 100 shot
  94. My NitrousXpress install so far
  95. Small shot with my set up?
  96. H/C/I LS1 going N2O: My kit/parts, YOUR input. (updated parts list pg2)
  97. low hp gain on a 150 shot at the dyno
  98. Z06 cam and springs with spray?
  99. show me your nozzle and smooth bellow install
  100. NX Lightning Valve Not Happy
  101. What can i change?
  102. Lingenfelter RPM-002 window switch blowout deal!
  103. Project JUICE 2
  104. So I'm not sure if I'm hitting or not...
  105. help with mounting 15# bottle
  106. Spraying a dry shot through a "Wet" plate
  107. 300 shot what gears?
  108. Need advice on a 200 shot?
  109. timing retarder
  110. WhiteLTone update
  111. TPS switch or WOT switch?
  112. Chevyhardcore.com, check this out!
  113. Newbie to nitrous
  114. Surging, low voltage, weird N/F reading? Check this out.
  115. who has sprayed a stock bottom LQ4?
  116. Timing and RPM
  117. Looking for some help with my nitrous wiring.
  118. Check my 2 step/Line Lock Wiring
  119. Need fuel regulator?
  120. timing twister users come in
  121. NX Maximizer 4 + Lingenfelter Launch Control (LNC-003) Wiring Diagram
  122. Noobie to Nitrous, need some reccomendations
  123. G8 Switch Panel
  124. Nitrous Outlet Direct Port pics
  125. plug readings
  126. Too much gas off the line?
  127. Please help with nitrous question!!!
  128. Want to reinstall nitrous.
  129. Since HSW is gone, does anyone make something like "The Interface"?
  130. Nitrous System Help *Popping my Cherry*
  131. First time at the track on spray, now bad misfire
  132. what shot noid are hsw , asap
  133. Pick my kit! Suggetions please!
  134. Using nos as a intercooler on turbo charged ls1
  135. Fuel pressure guage with nitrous outlet kit
  136. nitrous tune, Need Help!!
  137. SBE 5.3L 4l80e 3.73 gear Mild cam, how much nitrous for 9 sec slip?
  138. Deck Clearance
  139. Stand Alone setup
  140. Launching on Nitrous with Manual Transmission
  141. Help with nitrous setup
  142. Another intake with dual stages by Alzilzil Racing
  143. Nitrous Outlet 102 Plate - Picture request
  144. NOS Sniper Wet Plate Kit
  145. First Stock Cubic Inch Nitrous in the 8's!!!
  146. Dedicated fuel systems for nitrous using race fuel
  147. need wiring help!!
  148. push button vs window switch
  149. How NOT to empty a NOS bottle!!!!-Video
  150. plug gap for 125 shot
  151. n2o outlet feedback
  152. 1st gear lockout
  153. Ramping Up Production @ Nitrous Outlet!
  154. Lsx ls3
  155. New Guy at Nitrous Outlet!!!
  156. NANO questions
  157. Mounting microswitch for nw tb
  158. Carb plate
  159. ADM built/ LPE powered CTS-V runs 192.4 mph at the Texas Mile!
  160. nitrous noob, advice please
  161. NX custom wiring harness for c5
  162. few nano kit questions
  163. Nitrous on my 98 Trans am
  164. nitrous illegal!
  165. Carter01 SBE Nitrous Update.....
  166. Is there a difference?
  167. Tuning Nitrous
  168. 88N 45F Plug Pics
  169. E85 tune and nitrous
  170. Help! Hsw interface spray light always on.
  171. How much can I spray on a 93 tune if I run race gas?
  172. How much gain spay to mph et 1/8th mile?
  173. BR6EF vs BR7EF for 100 shot stock engine?
  174. Can an hsw interface and timing tuner be installed at the same time?
  175. Spark plug reading
  176. N20 kit on a Edelbrock pro flo xt
  177. Nitrous Fuel Question
  178. plumbed intakes for this month
  179. lt1 nitrous questions
  180. Does Anyone Have the Install Instructions For the HSW 78mm Sudden Impact Kit
  181. stock rod bolts + wet shot
  182. What did your nitrious kit/and eveything that goes with it cost you?
  183. e85 fuel pump for nitrous
  184. safe to spray on these mods?
  185. tunnel mount fitment
  186. Plug Pics
  187. Is a 4.185 bore LSX block safe to spray a decent shot on?
  188. Cheap Direct Port
  189. What way to mount nitrous bottle
  190. To many miles for spray??
  191. seperate fuel system
  192. what psi do yall normally run on a low psi stand alone
  193. What are my options for running a tad lean with a Halo bar dry shot
  194. Options for pulling timing
  195. new to nitrous
  196. 7.40 Nitrous LS stock suspension
  197. Is this a good fuel pump for a cam/bolt-ons plus 150 shot?
  198. Worlds fastest stock ci 346 on nitrous
  199. Record has been broke!
  200. Past and present 102 plate users (200+) How's your experience?
  201. how much?
  202. wiring trick window switch with leash nitrous timer and controller
  203. Nitrous with a 6 speed
  204. Got my bottle painted....
  205. Stock bottom end LQ4. How much spray is safe?
  206. where is the best place to buy a stand alone
  207. Which Ngk plug to run on nitrous .
  208. safe amount of spray??
  209. Direct port setup for H/C Caprice .
  210. New Build Thanks to HKE, Nitrous Outlet and G Force
  211. what to choose for timing 2step and progressive
  212. Thank You Nitrous Express & Nitrous Outlet! (pics)
  213. Iron ls2 nitrous ring gap?
  214. new to 4150 set up, help me pick a plate please
  215. NOS 5168 plate system on low fuel pressure
  216. nitrous jet change ?
  217. Money Maker system for my 2002 bolt-ons/cam WS6
  218. Will it work?
  219. dual stage plate kit
  220. First runs on Nitrous Out Direct Port Sys
  221. new to nitros
  222. Recommended amount of spray?
  223. Just bought a kit...methanol injection?
  224. upgrading microedge to microedge +?
  225. new with nitrous help please!
  226. What is the best AFR with Nitrous built engine with 200 shot ?
  227. zex gage/nitrous in bottle
  228. Need advice for adding nitrous
  229. Solenoid bracket options for FAST 102?
  230. TFS 245 LSX heads
  231. Purge with a extended/sealed off hood?
  232. How many bottles have you put through your stock bottom end LS?
  233. Built a new control panel for my car.....
  234. VP Q16 racing fuel
  235. Plate kit?
  236. For just a 150 shot....what kit do you recommend.....?
  237. 20lbs bottle instead off 2X 10lbs ???
  238. Help me find a direct port system installer
  239. Nitrous Controller Options *****
  240. An Apology to our Money Maker Customers.
  241. High Compression 6.0 Build ?'s
  242. Fearmont info?
  243. Additional FPSS after fuel solenoid?
  244. WTB Carbon Fiber Nitrous bottle
  245. spraying out of the hole
  246. Can i do this??
  247. Strange Lean condition with plate kit
  248. Breakin 7's with nitrous vs. breakin 7's with a turbo
  249. mounting 10lb bottle
  250. 5.3 + 150 Shot =
