- signs of a bad alternator?
- Car Won't Start
- Cold Start Problem
- flushing the radiator, mixing coolants
- Squeeking LCA's
- Vent fan not working
- Noise from harmonic balancer?
- Help with codes
- Power Steering
- Chrysler Cirrus doesnt like the rain...
- having interior light problem on a 99 toyota camry...
- wierd "knock" near tranny
- turn signals acting screwy
- window motor
- Steering wheel and brake shake
- slow service from GMPartsDirect...
- how often do you change your fuel filter and O2 sensors?
- Stripped lugnut won't come off!
- Any idea of whining noise when turning?
- Idle Speed Question Need Advice
- Bleeding the radiator.
- How To Get Rid Of This
- How good are the A/C kits from Autozone??
- Battery leaked like crazy, Cleanup Options, Repainting?
- Iridium Spark Plugs (Tune Up)
- Exhaust system
- Daytime running lights
- Air Conditioner Servicing. How To:
- Oil pressure flutter
- AC Idle Pulley HELP!
- low oil pressure
- Trans Am headlight problems
- spark plug wires....
- truck rental
- Car dosent feel like starting sometimes
- Transmission Flex Plate Bolts For Crank
- Top Engine Cleaner
- no oil level sensor....
- Code P0420
- need some advice
- Really LOUD squeak coming from the rear of the car!
- Noise at start up.
- Light Part Numbers and how to replace?
- GC & Texas Summer
- Loss of electical power while driving?
- Running Hot??
- Extending O2 sensors.
- Firing order to injector order on ls1 each side
- chirping Breaks (ANNOYING!)
- WTF!? installed gears and now engine just turns over w/o starting
- cammed cars...what weight oil do you run?
- Unusual Window Issue
- wiper inch size??
- Good glue to use for third brake light on my 00 SS Camaro
- SES...o2 low volts???
- Grind into 4th? clutch?
- Squeaking sound under hood
- OEM power steering pump vs remaned...
- SES Light
- Please help unusual headlight problem
- Could 89 octane possibly set off the lean bank1 code?
- Battery problem?
- Water as coolant?
- Motor Noise
- headlight grind!!!
- Choosing the right oil. suggestions?
- Lifter stuck
- 1999 Chevy Malibu running very rough
- ford escape egr problem
- Abs Inop? What The Heck?
- Headlight motor part number
- Would this do anything helpful?
- Headlight making noise
- smoke from exhaust...
- Service Vehicle Light?
- lost my key to my TA
- Annoying vibration at 1200rpm
- Brake light issue
- Found it
- Help Strange Misfire!
- bad plugs? opti?
- AC/Heater Question..
- strange rattle please help!!!
- Strange rattle help please
- Console Cup Holder Rattle Fix
- HELP! my car is acting strange
- My car just died
- RH front blinker driving me nuts!
- normal for air pump to come off and on while driving?
- fuel additive
- Hardtop Weatherstipping....
- Power Steering Problems - Help!
- Torque Spec
- Maintenance manual for 04 GTO?
- odd problem... electrical (short?? starter??)
- car storing...sort of
- Flickering Headlights??
- a window question
- Rotella 5W40 synthetic?
- adding fuel takes 30 min??
- Air bag question
- No Gauges and nothing when I turn the key.
- drivetrain vibration
- Headlights acting up
- Which amsoil?
- Anyone know where to get.....?
- Hatch rattle
- Bleeding cooling system
- Are the wires that connect to the throttle body supposed to be tight?
- Should I use Mobil 1 10w30 in my 98 SS M6?
- 98 M6 SS, growling noise on start-up
- oil pressure issue
- Oil Pressure to high?
- High Pitch Squeek When Turning Right
- Cooling system flush...help!
- Control arm cost - does this sound right?
- fuel filter
- left blinker won't turn off by itself after turn
- somekind of valvetrain noise?
- Low Voltage! doesn't feel like it though...
- 40K mile service
- Couldn't believe this... ATF in manual transmission!?
- Re-Setting the Oil Change Light
- K&N air filter for 96 Camaro SS?
- High pitch noise emitting from car...
- Oil Change Overfill
- Car won't hold idle
- Need help with 98 T/A Headlamps and Alarm
- Parking brake loose/tight?
- Steering colum squeak
- Knock sensor question
- High rev, then wants to Stall!???!
- Quick Question? HELP!!!!
- Squeaking noise from t-tops
- Help please
- Where can I find..
- idle problem
- rattling noise when getting on the gas
- Strange High Idle Problem with my 98 TA
- Strange idiot light
- Driver side window motor goin out..
- Bad timing chain?
- Pics of engine bay and a/c line
- check "guages" flashing driving me nutz
- Cooling problem
- low oil, rough idle
- power antenna on a 1990 corvette broke
- Gatorback Belts?
- engine noise
- Just popped my hood and.....
- Need a new radiator
- ABS question..
- Calling all A/C Experts!
- very strange electrical problem......drivers side brake light
- car wont start
- bad knock sensor?
- parking my ls1 for a few months
- i have a rattle
- Need Help Bad
- Still having problems!
- something wrong with my car
- Cheapest Car lnsurance Quote
- p0412 trouble code
- not the fuel pump?
- Center Console Lose as ???
- Water in passenger side?
- Different oil pressure sensors between years?
- Rear end leak
- Temp Sensor?
- Bad lifter? Need opnion
- non-synthetic oil choice ?
- Ticking
- Want to go back to black face gauges
- Windows won't go up? WTF?!?
- Rattle - could it be IN my Y pipe?
- Power Window Motor Template?
- Squeak by the passenger door over bumps, stops when my friends holds it...
- Help with high beams
- Front end creak
- is my Z28 water logged? please help.
- rear end noise
- t-top frame
- Missfire under hard acceleration. Please hellp!!!!
- Oil Pressure?!
- How are my fluid Choices.
- Lightweight battery
- Sensor Question
- Trans smoothness diff between years or gears?
- Another stupid turn signal thread
- Need Help!!!
- Coolant sensor issue ... maybe?
- Spark Plug Recommendation
- anyone else burn alot of oil?
- driver-side power window rattles
- where to get a new wiper arm?
- LT1 running Slugish!!! HELP!!!
- Smoke on plug change
- Door sag
- Did the LT1 come with a popcorn maker?
- Strange engine noise
- Leave jack and spare tire in or not?
- belt squeking
- P0440 Evaporative Emission Control System Malfunction
- car switches off for a second or two
- Spoiler brakelight(3rd) bulb #
- keys locked in car
- Where'd You Guys Get New Headlights At?
- Removing Thermostat
- how useful is this piece?
- overheat
- seat help pleas read
- Speedometer light
- car keeps stalling - mechanic claims it needs a new computer chip??
- what's the deal with my headlights??
- i-pipe stuck to muffler
- Detonation.....caused by not having knock sensor?!?!
- Rattling under 3,000 RPM with 1/2 throttle or 3/4
- Oil pan seal replacement
- Engine cranks, but no go.
- Lifter Problems?
- Turn Signal Bulb
- How do you get the sun visors off???
- Fail Safe Thermostat
- Adjusting the headlights
- Window Motor Help
- Roof Bubbling
- Car didnt wanna start after work?
- how much does a water pump cost?
- Bad Coil Pack?
- ridiculous gas gauge on my 96 Camaro SS
- Scheduled Maintenance Q's
- Turn signal flasher
- Shift Boot Retainer
- help w/ recharging A/C please?
- Distributor/Timing Belt NON-FBODY (Sorry) Girlfriend's Car
- Car won't start.. battery is fine, no gauges?
- HELP: Brake lights WON'T turn off
- Transmission repair HHEEELLLLPPP!!!
- Power window motor took a dump
- Missfire under hard acceleration? Please help!!!
- Rear end noise / diagnosis help requested
- How do you know when a cat is bad?
- DexCool question?
- A/C is pissing me off
- Now what??
- what should i do... 53k 8 yrs old...
- valve cover gaskets replacement????
- My drivers mirror on my c5 is loose, easy fix?
- how to replace the windsheild wiper blade arms, and window motors?
- Clicking noise after a few WOT pulls
