View Full Version : General Maintenance & Repairs
  1. need help with 2000 camaro
  2. Why did my battery melt?
  3. Overflow tank seems to be leaking
  4. Performance on Hold, Car Needs Some TLC
  5. Heat and A/C problem
  6. Is my cat going bad?
  7. C5 Corvette Oil Pan Gasket or Front Crank Seal?
  8. HELP! Why do I keep ripping belts in half? Pics
  9. temp gauge
  10. Plastic/Rubber Screw Hood Rests On
  11. Rattling inside hood!
  12. What's wrong with my power seat?
  13. How to tell if my car is running rich?
  14. How to access and replace H/L Horns?
  15. Rear passenger, passenger side speaker removal help!
  16. Engine coolant light
  17. What is this part??
  18. Clunking In rear passenger side PLEASE HELP!!
  19. changing oil and found coolant ?!?!?!?
  20. 2001 Chevy camaro doesn't always start
  21. Seat Belt Light problem in dash
  22. misfire? (video inside)
  23. ac and heat only blows out defrost vent now
  24. Licence plate light
  25. Gas gauge problems
  26. eng fan prob.
  27. Mouse and Chipmunks inside car.Success stories???
  28. No brakes! I hate no brakes!
  29. Rear Driver's Side Rattle Located
  30. Zero heat
  31. headlight motor gear again!!
  32. 02 TA Air Bag lite on
  33. weird vibration in brake pedal
  34. *****Electrical Flickering.***
  35. collant temp gauge
  36. turning signal lights burning out over and over
  37. Save or Scrap?
  38. Gauges go dead then return on restart
  39. battery draining
  40. Aftermarket drive belts or GM Belts?
  41. 2005 dodge neon
  42. Can you look at something on your car for me?
  43. !air now no start
  44. car surges or bounces how every you wanna say it on throttle
  45. Window speed
  46. Wiring schematic
  47. Winding sound on my T/A *WITH VIDEO* Please help!
  48. Winking Firebird
  49. what could it be?? Car dies instantly when I turn the lights on.
  50. Belt Replacement
  51. air bag light came on
  52. alt pigtail connector issue
  53. Coolant Question
  54. Power Steering Leaking from Cap
  55. squeeky belts after ls6 manifold swap
  56. Throwing a p0306 check it out
  57. head lights
  58. Carb cleaner=check vacuum?
  59. Throwing a p0306 check it out
  60. Factory Service Manual \ Parts Manual Question
  61. Oil Leaks
  62. mystery coolant leak
  63. 01 z28 power loss
  64. Weekend Warriors: Oil change intervals?
  65. PCV line broke
  66. 2000 Pontiac Sunfire won't start
  67. Lighting issue in a 99 camaro
  68. crazy idle
  69. first ls1 oil change..
  70. '02 TA won't start -- common culprits?
  71. trans overheating on f250
  72. Replacing my O2 sensors, Spark plugs and wires
  73. At a loss with what to do next.
  74. Door skin
  75. Locating a ground wire...............
  76. oil change light help
  77. Puzzling LT1 problem
  78. no fire coming out my coils ????????
  79. Turn signal AHHHH!
  80. 03 2500 hd overheating. Need help ASAP please
  81. aftermarket steering wheel.....help.
  82. Need help putting pulley back on!
  83. Right turn signal no power
  84. Random starting issue
  85. Acceleration problems going uphill
  86. Whole car vibrates at 70-up
  87. coolant smell
  88. New Magnaflow exhaust. Vibration at 2k & 3k RPM's
  89. sudden power steering fluid leak
  90. Inspection w/o heater box
  91. Another A/C not cold question
  92. Changing oil (3k miles or 6mth??)
  93. Right front turn signal issue
  94. TBSS Gremlin
  95. 3800 coolant leak
  96. noob misfire problem. done search but, nothing like my problem. please help...
  97. Help, knowledge needed! Smoooke!!
  98. check engine codes
  99. turnsignal shananagans
  100. Embarrasing but I gotta ask....radiator cap removal.
  101. Spark knock
  102. multiple issues! please help!
  103. Doesn't want to turnover? Help?
  104. headlight problems
  105. steering wheel shakes at 55mph
  106. Running a little warm
  107. 2 wires going to Ignition switch
  108. Misfire code now car will not start?!?!
  109. storage for my garage
  110. Squeaky Brakes..even after replacing pads!!!
  111. A/C Vacuum problem
  112. Changing rear differential fluid
  113. Idle issues, and few codes pulled
  114. Idle issues, and few codes
  115. Noob Q: SES-knock sensor code and coolant related?
  116. LS1 Camaro stalling from stop > go
  117. 99 Z28 Trans NOISE???
  118. Electrical gremlins
  119. Oil leak timing cover
  120. Water coming from AC normal?
  121. headers rattling?
  122. RPM's drop weirdly
  123. Great charging power at first startup then sucks after
  124. Having a hard time getting inspected.
  125. headlight fuse.. where is it?
  126. oil smell in car
  127. HELP! low idle and misfire
  128. *Need help* Sqeak & Creak
  129. Lil help with A/c
  130. PS fluid cooler temps......and coolant temps.....Finally checked them
  131. ignition cylinder
  132. 98 formula allergic to throttle
  133. what is this for???? Under driver side headlight
  134. LS Longevity?
  135. replacing front oxygen sensors, should I replace rears ?
  136. Coolant flush question / recommendations
  137. Belts squeaking? or what do you guys think?
  138. Pulley gone bad? not sure
  139. Headlight Question *I read the sticky*
  140. misfiring like a mofo!! help?
  141. Vats
  142. Who "side-gaps sparkplugs"? and why?
  143. Troubleshooting overheating 2003 Impala.
  144. P0175 Engine code
  145. Cleaned engine bay, now regulator issue.. fml
  146. Power Window Motor/Regulator Rivets
  147. Turn Signal issue with 2000 Camaro
  148. Can Someone Identify This??
  149. fuel pressure drops after shutdown
  150. Misfire without SES light?
  151. Could use some help please
  152. my moms 99 z28 is in jeoprady of being sold! help me fix it!
  153. Temperature Readout: XXX
  154. NEED HELP WITH BRAKES... All caliper pins seized!!!!!
  155. Rebuilding steering column
  156. 93 z28 hach help
  157. Interior Lights
  158. Major Oil Leak from Filter Housing - Really Need Help
  159. Misfiring - Please help
  160. LS1 with stripped Starter Bolt Holes..
  161. Well my original 10 yr. old battery finally died!
  162. oxygen sensor
  163. window stops ???
  164. lt4 Wont stay running ?? STUMPED !
  165. Power steering bleeding issue
  166. Chirp chirp chirp
  167. need help asap 5.3 wont start
  168. temperature gauge
  169. How to change blinker housing?
  170. Gas pedal ? And exhaust smell ?
  171. hesitation and lack of power and awkward moments
  172. Power Steering Rack Issues
  173. Dead Speedometer
  174. Car wont start!!! Big issue!!1
  175. turn signal and break light
  176. Battery relocation woes :(
  177. Vibration near trans...
  178. Car taking longer to start
  179. center console and gear shifter removal
  180. squeaky ac
  181. Headlight problems
  182. Long Cranking to start
  183. Short curcuited?
  184. Still slight misfire after cleaning maf
  185. Trottle body grind mod help
  186. Tach jumps around
  187. Car not starting and idle issues
  188. Fuel Gauge Fluctuation?
  189. brake problem
  190. Best place to get a drivers side door bezel and are they all the same?
  191. Knocking in motor?
  192. Running rich, gas in oil!! Help!
  193. BEST GM parts prices????
  194. Headlight problem
  195. 1993 Trans AM LOOSE STEERING WHeel..Up and DOWN. WHy?
  196. How far up the creek am I?
  197. Fuel Pump life ?
  198. Dome light problem
  199. Loud Pop
  200. What part is this?
  201. 6LE dash pad...
  202. What oil are you running
  203. advice on heater hose restrictor valve
  204. P0650
  205. How-to PVC valve leak
  206. Fuel Pressure Regulator.....Bad?
  207. spaztic oil pressure gauge
  208. Front Blinker is Corroded. Need Help Fixing Please
  209. Leaking oil, not 100% sure if it's coming from behind intake.....
  210. Need help!
  211. 04 Corvette electrical issiues
  212. Brake / Clutch OEM pads
  213. Oil leak on engine
  214. I can hear my truck spark knocking.
  215. Water spilling out of reservoir
  216. Flashing "Service Engine" light after fillup?
  217. smoke out of dipstick tube
  218. Rear hatch weatherstrip?
  219. is my starter going?
  220. White box with springs and stuff on steering column
  221. Stock Rad Questions...
  222. Car hopping from 1st to 2nd shift
  223. Best directions I've seen for window regulator removal
  224. po152 code - which o2 do i need?
  225. Need Help Asap!
  226. T-top corner bulging
  227. Trouble getting exhaust y pipe off
  228. High Idle on Electronic Throttle Body
  229. Car does not start, does not turn over
  230. Schrader Valve Stuck
  231. weird thing happened with my car today.
  232. Will not start sometimes
  233. Exhaust leak
  234. Good Shop in Tulsa OK???
  235. Pcv question
  236. HVAC: Unable to turn on blower
  237. Torn MAP sensor seal, where to buy??
  238. crank no start please help
  239. A/C blows only through defrost and floor. help
  240. turn signal issue *update*
  241. steering wheel pin out
  242. Weird A/C compressor issues
  243. car doesn't want to crank sometimes
  244. Brakes suck!
  245. rattleing/bad bearing noise... waterpump?
  246. crank no start please help
  247. Bad motor mounts?
  248. Bad coil or injector, WOT exhaust popping
  249. Windows not up all the way?
  250. Flashed HIDs and lost the ignition relay?
