- has anyone used this?
- c5 steering wheel in 98 camaro.....possible?
- how do i put 2001-2002 steering wheel controls into a 1998
- wont start
- No Headlights, high or low beams
- spark plugs
- Headlight won't open sometimes (passenger side)
- Auto vs manual?
- Clutch safety switch question.....
- Stealership service trying to screw me! Help!
- Alternator problems Please Help!!!!!
- My engine is hissing at me
- urgent electrical problem!
- 2002 Camaro 3800 v6 starts but wont stay running
- Air bag light on....how to dissable
- Car wont start after Re-installing transmission
- Water coming into 4G F-body
- power steering whine......
- Tach stopped working- new PCM
- drivers side headlight only works when its on highbeam.?
- Low voltage in the radio fuse??
- Need help with LS2 swap Coolent Temps
- Alternator Wire Broke
- How does oil get on the knock sensors?
- Low idle/power
- Turn signal not flashing
- pics of my window problem
- FYI...A blown GAUGE fuse will prevent the car from starting!
- Antenna wont go down?
- Another "what window part broke" thread
- clutch sticking
- Fixed My Loose Door Handle
- For those with P0102 code, MAF circuit input low
- non ls cooling question
- High Speed fans wont kick on..any help?
- Oil Change Light
- misfire with no codes
- Holy Fu%^$*( Crap......
- Drivetrain Noise
- Overheating problem
- Air Intake Sensor..
- Random Misfire???????
- Unidentified warning light
- PCV Valve Replacement (in a 97 LT1)
- Air Conditioning Issue
- Hood flutters at highway speeds
- 96 bird 3.8 l, intake gasket leak possibility and valve gaskets?? piks need sum input
- Change Oil Light is on....
- P0300 misfire HELP!
- Car restarted during WOT pull
- Faulty headlight motors??
- engine temp question
- A/C help
- HELP car won't start
- Another damn window regulator/motor thread
- No charge to battery
- no voltage from knock sensor harness
- **Changed my differential oil today... PICS
- Trans oil leak
- Alarm keeps going off
- Battery Cable
- Are These Normal Sounds
- Dip Stick length?????
- Photo request: steering shaft boot/cover
- How to vacuum test an LS1
- Speedo not working right 2000 SS
- Misfiring
- ls1 Sway Bar
- Car raise idle when put in gear WHY!!!!!
- is anyone else amazed with the ls1 motor?
- My maintenance list...
- Starts Then Dies Immediately - Intermittent
- PCV Hose question?
- engine wine
- Truck Alternator
- running rich in both banks, live data
- Taillight has me completely perplexed.
- a/c problem
- LS1 sputter
- please HELP electric/harness issue?
- Restarting car that has been out of commission
- camaro shuts down?
- oh my GOD!!! another breakdown in my v6 bird help for the love of God Please!!!
- Going insane over ticking tire....
- I need this part (picture incliuded)
- Strange shuttering
- A cling noise from the rear passenger tire
- rounded off oil drain bolt
- *URGENT* Clutch/Hydraulics issue
- Power Steering Issue
- what a/c compressor to get?
- '01 WS-6 intermittent stalling and power loss
- Found the source of my rattle, how can i fix?
- clutch fluid
- LT1 starting problems
- Firebird headlight.
- mysterious rattling/vibrating sound
- URGENT PLEASE HELP!!! no power when ignition on
- Temp gauge going up and down with loss of engine power
- radio and clock wont turn off
- A/C help please?
- lights dimming out
- Vibration, lack of power, bad mpg's, SES, etc...
- Cant disconnect fuel line!
- a buttload of codes
- 02 TA headlights not going down until minutes after
- Need a PIC of where to drill for PSide window motor replacement
- Fluids help!
- How hard to swap PCM? ?
- C5 AC Problem
- Hesitation between 2500 - 3500rpm
- Officially utterly bamboozled (electrical)
- knock in a turbo lt1
- Lesson Learned but I'm Pissed
- Oil weight for Oklahoma summer?
- motor mount help!
- Anyone Use Green Grease?
- M6 Getting Hard to Shift
- Need help asap!!! car really acting up!!!!
- A/C smell
- Wierd Electrical Problem
- Hit a bump.. crazy rattling sound that grows with speed coming from console/tranny no
- Stupid f***ing coolant light....
- Oil Pressure Guage
- low level oil light on
- 2000 corvette, broken door lock mechanism
- Radio/Window Problem
- a/c spitting out not so conditioned air. help?
- Long list of things that dont make me happy.
- Roaring Noise in the Rear
- 00 Formula wants to bogg down
- Hesitation 2,000-3,000 RPM Confused!!
- Rack and Pinion Replacements
- A/C not working on cold start
- '02 3800 coolant leak..help **PROBLEM SOLVED!**
- 200 Miles/Tank
- Z28 LS1 Radiator Replacement - extra fitting!
- Question about AC compressors, having some issues
- Mystery oil leak
- a/c compressor noise, LOUD
- Help Identify Parts & Pieces LS1 AC Compressor
- For those of you who have codes P0131 & P0151 only
- 98 ls1 bogs...help plz...
- A/c turns on , car dies ?
- o2 sensors
- problem starting help
- A/C Low Side Service Port Leaking
- Horn intermittently stops working
- Heater Core Hoses
- clunking over bumps , when letting clutch out quick , or drivetrain shocked
- overheating
- cruise control doesn't work after clutch change
- Issue with starter after swap in 76 Camaro
- Hatch back wont close
- an't find a cat converter for my SUV so , thinking of swapping one ..
- LS1 strange "putting" exhaust note
- My OE fuel pump is loud..
- Bell housing leak and pushing through the converter!
- brake problems
- Link to Identify Bolts
- Window Motor Issue
- cruise control no worky
- New Belt, New tensioner, or manual tensioner
- new power steering pump whine
- Is my a/c compressor done?
- Shaved Inner Rear Fender Lip???
- removed air pump but whats this?
- URGENT: wire delete mod makes transmission malfunction?
- ummmm, what is this random switch?
- engine scanner
- Annoying rattling noise from rear of car
- $12000 to $2000 in the corse of a day.
- Diagnosing and fixing my ls1
- Squealing noise back again...
- Electrical System Issues
- P0420, changed cat & rear 02, CEL still come on
- Bouncing fuel guage
- idler pulley dust shield?
- Camaro keeps missing
- crazy shit
- '99 Z28 M6 - Radiator Mounted Sensor
- asr abs inop brake light
- Cooling issue?
- little help please!!!
- 1997 Ponitac Fire Bird Won't Start!
- AC - O-ring question 99 - F-body
- Necessary to change all fluids?
- fuel gauge question
- 02WS6 (heating to 260* only on highway?)
- Slight hesitation?
- No fuel problems
- Cruise control not working HELP
- Carwash killed my car....
- A/C box is cracked! Water leaking in floor!
- car will only start on second try
- Help fixing backup lights
- Water pump help
- How much gas is actually left in the tank when the check gauges light comes on?
- Exhaust Rattle
- Need Some Assistance After Mirror Damaged
- I am selling a new ls1 camaro door and other parts.
- Egr problems P0401 and P0405
- What size are my nuts?
- ac help
- drive belt too tight
- throwing codes..need some advice
- Location-A/C expansion valve 99 Camaro
- gas pump clicks off early
- Car won't start, multiple times
- stripped allen head torx bolt
- wtf is wrong with my buddys car?
- steering issues
- Low Coolant Light Keeps coming on.
- Steering pump pullery walking off shaft???
- Rattle/Grinding noise from rearend on deceleration
- Car Experts Needed, Recharging AC
- 98 T/A - Hard starting EXCEPT when gas tank is full
- small crack on starter flange
- stock ls1 only get 200 miles to the tank... WTF??
- Overheating at normal temps?
- Searching for idle; HIGH idle
- what battery to buy?
- Loud clanking noise
- Window Question
- Hard to steer
- Coolant Leak after car was in Sun all day...Bad gasket/WP?
- Side mirror glass
- Is all ORANGE/RED coolant Dex-cool?
- Weird ping noise + Service engine soon on
- ANOTHER window issue... Starting to see a trend
- The case of the moving coolant leak and boiling coolant...
- Main Brake Lights Not Working Consistently
- Throwing enginue codes P0101, P0131, & P0151...HELP!
- Epoxy sealant around EGR and AIR block off plates?
- Rattle heard coming from rear during idle
- 6 speed for auto
- AC Pulley Noise. HELP!!!
- a/c clutch or tensioner? help diagnose
- Window problem
- stock 1993 Camaro Live data
- Air Conditioning Woes
- a/c "Shop" says
- Car sputters in rain?
- car died while driving...
- another CEL code? what is this one about?
- need help identifying the source to this CEL light?
- My car is slow..
- window motor problem.
- Temp Guage acting erratic when car stalls
