View Full Version : General Maintenance & Repairs
  1. Long list of things that dont make me happy.
  2. Roaring Noise in the Rear
  3. 00 Formula wants to bogg down
  4. Hesitation 2,000-3,000 RPM Confused!!
  5. Rack and Pinion Replacements
  6. A/C not working on cold start
  7. '02 3800 coolant leak..help **PROBLEM SOLVED!**
  8. 200 Miles/Tank
  9. Z28 LS1 Radiator Replacement - extra fitting!
  10. Question about AC compressors, having some issues
  11. Mystery oil leak
  12. a/c compressor noise, LOUD
  13. Help Identify Parts & Pieces LS1 AC Compressor
  14. For those of you who have codes P0131 & P0151 only
  15. 98 ls1 bogs...help plz...
  16. A/c turns on , car dies ?
  17. o2 sensors
  18. problem starting help
  19. A/C Low Side Service Port Leaking
  20. Horn intermittently stops working
  21. Heater Core Hoses
  22. clunking over bumps , when letting clutch out quick , or drivetrain shocked
  23. overheating
  24. cruise control doesn't work after clutch change
  25. cruise control doesn't work after clutch change
  26. Issue with starter after swap in 76 Camaro
  27. Hatch back wont close
  28. an't find a cat converter for my SUV so , thinking of swapping one ..
  29. LS1 strange "putting" exhaust note
  30. My OE fuel pump is loud..
  31. Bell housing leak and pushing through the converter!
  32. brake problems
  33. Link to Identify Bolts
  34. Window Motor Issue
  35. cruise control no worky
  36. New Belt, New tensioner, or manual tensioner
  37. new power steering pump whine
  38. Is my a/c compressor done?
  39. Shaved Inner Rear Fender Lip???
  40. removed air pump but whats this?
  41. URGENT: wire delete mod makes transmission malfunction?
  42. ummmm, what is this random switch?
  43. engine scanner
  44. Annoying rattling noise from rear of car
  45. $12000 to $2000 in the corse of a day.
  46. Diagnosing and fixing my ls1
  47. Squealing noise back again...
  48. Electrical System Issues
  49. P0420, changed cat & rear 02, CEL still come on
  50. Bouncing fuel guage
  51. idler pulley dust shield?
  52. Camaro keeps missing
  53. crazy shit
  54. '99 Z28 M6 - Radiator Mounted Sensor
  55. asr abs inop brake light
  56. Cooling issue?
  57. little help please!!!
  58. 1997 Ponitac Fire Bird Won't Start!
  59. AC - O-ring question 99 - F-body
  60. Necessary to change all fluids?
  61. fuel gauge question
  62. 02WS6 (heating to 260* only on highway?)
  63. Slight hesitation?
  64. No fuel problems
  65. Cruise control not working HELP
  66. Carwash killed my car....
  67. A/C box is cracked! Water leaking in floor!
  68. car will only start on second try
  69. Help fixing backup lights
  70. Water pump help
  71. How much gas is actually left in the tank when the check gauges light comes on?
  72. Exhaust Rattle
  73. Need Some Assistance After Mirror Damaged
  74. I am selling a new ls1 camaro door and other parts.
  75. Egr problems P0401 and P0405
  76. What size are my nuts?
  77. ac help
  78. drive belt too tight
  79. throwing codes..need some advice
  80. Location-A/C expansion valve 99 Camaro
  81. gas pump clicks off early
  82. Car won't start, multiple times
  83. stripped allen head torx bolt
  84. wtf is wrong with my buddys car?
  85. steering issues
  86. Low Coolant Light Keeps coming on.
  87. Steering pump pullery walking off shaft???
  88. Rattle/Grinding noise from rearend on deceleration
  89. Car Experts Needed, Recharging AC
  90. 98 T/A - Hard starting EXCEPT when gas tank is full
  91. small crack on starter flange
  92. stock ls1 only get 200 miles to the tank... WTF??
  93. Overheating at normal temps?
  94. Searching for idle; HIGH idle
  95. what battery to buy?
  96. Loud clanking noise
  97. Window Question
  98. Hard to steer
  99. Coolant Leak after car was in Sun all day...Bad gasket/WP?
  100. Side mirror glass
  101. Is all ORANGE/RED coolant Dex-cool?
  102. Weird ping noise + Service engine soon on
  103. ANOTHER window issue... Starting to see a trend
  104. The case of the moving coolant leak and boiling coolant...
  105. Main Brake Lights Not Working Consistently
  106. Throwing enginue codes P0101, P0131, & P0151...HELP!
  107. Epoxy sealant around EGR and AIR block off plates?
  108. Rattle heard coming from rear during idle
  109. 6 speed for auto
  110. AC Pulley Noise. HELP!!!
  111. a/c clutch or tensioner? help diagnose
  112. Window problem
  113. stock 1993 Camaro Live data
  114. Air Conditioning Woes
  115. a/c "Shop" says
  116. Car sputters in rain?
  117. car died while driving...
  118. another CEL code? what is this one about?
  119. need help identifying the source to this CEL light?
  120. My car is slow..
  121. window motor problem.
  122. Temp Guage acting erratic when car stalls
  123. Want to test a/c compressor , need input on jumping switch
  124. Hard brake pedal after car sits awhile.....
  125. A/C not working and its HOT in AZ!!!! HELP!!
  126. Power steering fluid in coolant
  127. Start car without key?
  128. New spark plugs?
  129. Broken thread on temperature sensor :(
  130. takes to long to turn over
  131. Changed mount/bushings now vibration through rpm range
  132. Coolant leak + cooling fans issue
  133. Bosch oxygen sensors bad after a year?
  134. power steering leak
  135. what does this mean? help please
  136. Best way to raise the rear end for exhaust clearance
  137. What's holding the center console?? Plastic push pins??
  138. Fuel Treatment- Is it worth it?
  139. Trembling in 4th gear ?
  140. should i be scared
  141. Transmission or shift kit? New owner seeking help..
  142. Coolant leaking out of refill cap??
  143. So, is this VATS??? :(
  144. O2 Sensor voltage readings, bad?
  145. Tapping sound
  146. Backfire help
  147. Properly storing a car
  148. intermittent power steering pump
  149. no power
  150. 02 z28 hard start
  151. 02 z28 hard start
  152. Power Steering failure
  153. window problems
  154. help
  155. Smog issues.
  156. Cruise Control Module.. 2000 z28 A4... where the hell is it???
  157. Need Some help
  158. bosch 5.3 wave springs installation
  159. LS1 Ground Strap Location
  160. HELP!!!!!!!! my door is shot
  161. Car idles like crap after hitting bump
  162. TA 98+ Lights
  163. Broke a rocker arm
  164. 4th gen Fbody GM part number for LS1 upper radiator hose W/OUT P/S cooler?
  165. I'm sure we've all thought about doing it ...
  166. HELP : Veteran in the GAME but rookie to GHOST ISSUES 1996 Camaro 3.8L Vats issue or?
  167. Went from LS1 to LS3 418... Oil filter help please
  168. Transmission shifting problems
  169. Circuit check engine light codes
  170. Oil Change light
  171. Headlight only flips down?????
  172. Loss of power when accelerating
  173. Oil pressure gauge acting wierd WTF???
  174. Ac hot in traffic, ice cold at night and startup
  175. strange sound ,,, please help
  176. service vehicle light
  177. ticking noise
  178. Pop/misfire at full throttle
  179. AC sqweek driving me nuts
  180. What am I experiencing? Wheel hop or something else?
  181. trans am headlight problem
  182. Part Number Needed - DRL bulb
  183. LS1 jerks right before complete stop. Help
  184. driveshaft tunnel clunk
  185. Rear end noise - Hard slamming on hard shifts - Slams on bumps
  186. LED bulbs?
  187. once cool a/c stops cooling???? on z71
  188. Rear end looks as if it were leaking?
  189. 1997 trans am, Where are the o2 sensors located??
  190. Parts Request
  191. Find when my car was made
  192. Check gauges!!
  193. My ls1 won't start up!! HELP!!
  194. Lq9 or ls1
  195. ABS/TCS issues possibly something else?? Need help.
  196. Passenger door water leak
  197. 02 sensor codes??
  198. With TPS unplugged how does car know throttle position?
  199. Overvoltage on start-up???
  200. TA sputtering while driving???
  201. car wonk crank when security light is steady on????
  202. 1998 gauge cluster Q
  203. A/C noise
  204. wiper motor replacement?
  205. Keyless Entry Problems....
  206. AC blowing hot air. Front end wreck in late February
  207. Ticking During Acceleration at Low RPM's - M6
  208. Aiming Headlights (Firebird)
  209. Air Conditioner not working
  210. Window rattle
  211. What causes O2 insufficient switching?
  212. Wiring problem
  213. Headlight Replacement Issues
  214. Removing Headlight Motor Question?
  215. I need some advice on loosing coolant
  216. synthetic oil in high mile car
  217. Upstream or Downstream O2 Sensors
  218. LS1 sputter/skip
  219. 98 t/a front passenger side blinker
  220. turn signals & reverse lights dont work
  221. cutting the kmember
  222. Service Manuals
  223. How much could this cost me ?:(
  224. Trunk Latch Problems?
  225. air compressor leaking from case
  226. ticking sound from pass side
  227. New Oil Pressure Sensor - Pressure way higher?
  228. Missfire after 4k miles?!
  229. A/C took a !@#$ on me!!
  230. help with valve cover to throttle body hose
  231. Headlight Bracket Adjuster Broken.....
  232. question about buying a power steering pump
  233. ac help
  234. Symptoms of a bad 02
  235. TA Window Motor
  236. Wiper Arm Assembly
  237. DIY Relay Puller tip
  238. Squeal with the AC turned OFF?
  239. Cruise control repair
  240. if your a member of law enforcement than i have a question for you
  241. Boiling sound from radiator
  242. no start, some help plz.
  243. Issues with new '99 Formula
  244. ls1 help lol
  245. Scared
  246. Glue for console lid?
  247. Problems Continue!! Help. Stuttering, missing, Idle dropping
  248. How to install carpet jute?
  249. Speedo problems
  250. HelP!!! MY ALTERNATOR WONT WORK
