- VATS! very weird.
- left turn signal is broken
- where to find replacement IAC o-ring?
- How do you pull the window wiper arms off
- Issues with A4 shifter
- How do i use an AC recharge kit?
- 96 camaro 3.8 with oil in antifreeze
- AC questions
- Throwing code P0420A
- No smoke normal with MCCC?
- HVAC position changes on throttle
- why is my z28 overheating ?
- Tps bad?
- Coolant level sensor advice
- weird idle problem
- air fuel spark
- FYI 20% Off Race Ramps
- Rear end vibration due to exhaust?
- average f-body LS1 battery draw or drain when car off
- knocking noise at 2200-3000 rpms can't figure it out
- Leaking from everywhere
- 93 lt1 z28 camaro won,t start
- Replaced AC system Saturday, purple fluid all over engine bay today
- had 4 codes come up today in the 00 formula. help.
- Sound like fuel pump? Maybe crank sensor?
- Loose/Broken Side Mirror
- weird camaro question
- 96 LT1 leaky fuel filter
- T-top rubber seal for front and rear of center rib
- Fuel ?
- seatbelts dont lock
- 2000 C5 tank system with siphoning pump
- Bad pulleys?
- trans cable keeps popping off lever (94 lt1 a4)
- oil leak somwhere
- Will this plug work? NGK SR5- 1VX ???
- LT1 Bogs after hard throttle, low oil pressure, help me
- weird head light issue with trans am
- did I jack my oil pressure sensor....
- Anyone have window regulator replacement instructions?
- Tire Sensors--Can they cause a car to run faulty?
- Weird, sudden high idle, bad TPS sensor?
- VIDEO! LS1 Camaro issue
- Fan/Hot&Cold/Heater Settings Not Lit
- Dash lights not working now
- electrical issues...
- Misfire/back fire/vail system issue
- ls1 overheating.
- Window part help. Need Part number
- High idle sometimes with A/C on?
- a/c comp problem
- Alternator Issue - Car Stranded Me Last Night
- Got water in my horn today.. where is it located?
- Rough idle and backfire in tailpipe
- 93 Formula Start up problem
- Problem with air vents
- rubbing noise from turning
- LS1 engine shut off!!
- Water on Drivers side floor
- Anyone rebuild their rack and pinion?
- Can't Diagnose Problem On Car
- 02 TA WS6 - Oil Pan Leak
- RPM Problem
- 02 TA Problems
- Is it tire shake or something else
- car does not start sometimes
- Alt not charging???? 98 Z28
- Ticking
- WOT causes voltage dip?
- key fob question
- spark plug wire not connecting to plug
- Blowing Dip Stick
- lq4 full throttle cuts out
- Car died completely last night
- A/C turning on and off
- HELP! Vacuum, MAF, MAP Problems!
- Overheating engine LS1
- please help
- well my issue is back....and worse then before
- MAF keeps popping out of lid
- random multiple misfire only when its raining
- Blowing up my turn signal
- a.i.r. pump question
- Need help with loud whistling noise
- problems with my a/c
- 2002 Camaro Stalls/Low Voltage
- Belt squeek help
- What is the name of this A/C part?
- Lound banging noise from under rear of car during acceleration?
- Car has no electrical
- Overheating LS1
- "TCS off" light randomly comes on?
- Brake light stuck on, not the switch?
- Can't hunt down A/C leak
- loses power/stumbles between 2500-3000 rpm
- fuel level guage stopped working
- A/C stopped blowing through my vents???
- Blew o-rings on fuel pump line...
- Brake light help
- car wont start
- Daily Driver
- Very odd problem
- Signal lights won't work. Some advice please.
- ls1 tapping
- A/C Compressor took a crap!!!
- Rivet broke off of headlight
- AC Compressor
- Replacing window motor right now, quick question!
- Where the fuel filter on a 2000 z28??
- instrument cluster
- Power Seat Wiring
- 99 TA Headlite only powers down:(
- alarm remote
- No Spark After Oil Pan Gasket Replacement
- Puzzling coolant leak
- Broke something...
- 99 TA D/S headlite goes down but not up?
- G spot on power window motor
- power steering
- Creak noise turning left?
- Power window motor Q
- Idle going up and down when stoped at red lights
- ABS INOP/TCS OFF lights
- 2002 T/A Won't Hold Idle.
- Power Window Problem
- Driver's seat belt
- Gauges stopped working and now car won't turn over
- Weird Dash Lights Incident
- How hard is it to put your own freon in?
- Exhaust rattles like crazy after WOT run
- Ignition won't turn.
- Cooling system riddle...
- starter solenoid replacement DIY???
- Left turn signal always on and highbeams
- Air conditioning compressor
- No low end torque car feels slow
- a/c is not working
- Bad vibration when decelerating
- Windshield replacement...
- starting problems
- P0300 on Highway cruise
- Water pump advice needed..
- Window won't roll down?
- Chevy S10 pick up door glass question..............
- stalling shortly after startup
- Help 2000 Z28 Door sagging
- Help!!! Major turn signal problem!!!
- Over heating
- All warning lights came on for a few seconds?
- Gauge Light goes on and off
- Misfires with Humidity/Rain & Other Stories
- Camaro soundin weird
- Cabin Air Filter install 4th gen (if anyone cares lol)
- Electrical Problem????
- a/c dont work have some questions
- Dash lights help!!
- Loss of power
- Window rolls down but gets stuck an make a thumping sound when going up
- riddle me this
- 00 Trans Am almost dies when coming to a stop
- trouble when breaking
- engine light won't go away
- Runs like crap map sensor maybe?
- Radiator adapter
- power steering fluid mixing into my coolant help
- How accurate is the oil computer in 4th gens?
- Motor oil drip
- White residue Inside exhaust tips????
- Turning signal adjustment
- Problem w/Gauge/Radio Lighting
- Possible Short in Electrical System! HELP???
- Ls6 swap cranking with no pcm?????
- car turns off while running
- Right turn indicator light stays on in dash...
- lube job
- Window Won't Roll Up (window motor is working)
- Hard start, surging idle, and some times will not start
- ac pulley squeal
- firebird engine running too fast!
- a.c question
- 2000 trans am help
- Help...2002 TA will not fire...
- LS1 Rough Idle
- huge clunking noise help please
- mass air flow
- Freaking door won't stop creaking!!!
- need help with an AC vacuum line (where to get)
- How to check possibly bad pcm?
- non LSx question.....about octane and a Dodge Hemi truck....
- Gonna buy a new fuel pump for my 3.8L
- 98 vette ls1 swap into 02 z28
- So my headlight cover flew off on the highway
- car isnt starting???? clicks and new batt but nothiong...
- bad fuel pump or starter?
- driver's window rattle
- AC Issues
- Leaky pinion seal, made it worse
- Daytime running lights-possible deletion task
- My car feels loose after alignment
- Fuck the stealership. (motor mounts)
- annoying squeal under load
- Replacing window motors for the first time....
- Need help SES light on and Tach gauge not workin :/
- Belt tensioner again...
- Pop Pop caused by exhaust leak?
- Camaro 92 air conditioner problems,
- Help with DTC Codes.....
- my car is back firing at low rpm while accelerating
- I Have an electircal bug some where..
- 02 S10 4.3, misses under load
- 40+mph car shakes violently with light gas
- Ok, so how much engine "tick" is normal???
- need help with rsar main
- 2001 WS6 idling issue
- Rough idle at stop, dies. Ideas?
- Rear main or Oil pan?
- Rubbing/moaning noise
- Key in Ignition..No Warning Chime when door is open??
- Rear End Leak
- SES light flashing, no codes, and a low end miss
- fog light connector / harness
- I filled up my tank and 100 miles later it is on half empty/half full.
- Nice!!
- Window problem - not motor
- Fuel Neck/Cap Issue
- Idle RPM way too high
- Heater hose question
- Body Ground Strap
- Help diagnose mount problem
- air bag light
- ac compressor idler pulley
- Pinion seal parts?
- Is a prothane trans mount a must when doin prothane motor mounts?
- 1998 SS wierd PS leak into coolant?
- Bad coolant temp sensor cause the engine to die?
- Battery Disconnected long time
- Wiper go up when turned off!
- No Prime From Fuel Pump
- Pop when backing up
- Please help identify this noise on my 2000 SS
- Security Light / Car Not Starting
- Blazer is trying but just wont fire
- Got a weird one for you guys
- Electrical Problem!?
- Oil pressure and battery level
- Belt squealing after P/S pump install
- Rack and pinion
- Ls6 swap?
- starting car with EVAP solenoid unplugged?
- Battery issue.
