View Full Version : General Maintenance & Repairs
  1. exciter wire voltage fluctuating why?
  2. Mobil 1 0W-40 good for summer?
  3. cooling problems
  4. Engine throwing a code
  5. Radiator leak (99 SS)
  6. Annoying T-Top Rattle over bumps, fix?
  7. any fuel stories?
  8. Picture Request for A/C only blowing through Defroster/Floor problem
  9. trans cross member bolt stripped!
  10. best way to remove motor from bottum without lift
  11. Need Help No Headlights
  12. Chirping??
  13. how much freon should my 2k camaro z28 should have ?
  14. trans mount/rear and vibrating sound
  15. Having some issues
  16. 3000GT Ignition Control Module location
  17. Spark plugs done! But what did I break?
  18. other car not starting?
  19. My car makes a noise whenever I...just watch the video.
  20. power steering pulley install
  21. Bad o2 with no ses light
  22. Motor mounts SUCK !!!!
  23. P0442 Evaporative Emissons Control Leak
  24. Power Seat won't move all the way forward?
  25. speedo not working??
  26. starting problem
  27. AC pressure on 02 T/A
  28. Has anyone else had this prob. advice please
  29. Mystery coolant leak...
  30. Multiple Misfires
  31. Steering rack - replace or adjust?
  32. Ac compressor replacement
  33. Anti-Theft Code
  34. Windshield wipers not retracting
  35. antifreeze question
  36. Car was hesitating Around 3K
  37. Cluster issue
  38. TCS,Brake,ABS
  39. My lady Camaro v6 3.8
  40. signal light switch replacement
  41. Replaced battery now several things don't work...
  42. Power steering return hose
  43. problem with ls6
  44. p1404
  45. odd "rattle" sound coming from intake or head
  46. Whining Noise Narrowed Down
  47. acceleration issue
  48. How to change coolant..
  49. Is my fuel pump about to go out?
  50. Need Help. SES P0418 and P0412
  51. guage cluster problems/ DRL switchbacks...
  52. a/c problem..need advice
  53. Radiator Cap
  54. Dealership problems
  55. car shakes more then is suppose to???
  56. received wrong hotwire kit? pics inside
  57. '99 Z28 M6 - Electrical Gremlin
  58. Need help few check engine codes on..
  59. Best way to fix tired slow windows?
  60. Air likd A.I.R. extension tube NEEDED!
  61. Springs go bad?
  62. Air bag help
  63. Security Light
  64. Oil Leak!!!
  65. had a question about spider gears.
  66. spider gears
  67. Noise under car over bumps etc..
  68. HELP! Leaking under clutch pedal...
  69. Hard acceleration = Air bag light. WHY?
  70. Power Steering Help
  71. sway bar bushing bracket broken
  72. changing maf
  73. Airbag question
  74. Leaking coolant from overflow tank
  75. service vehical light?
  76. ac problem
  77. AC issue
  78. Aligning window motor gears with regulator gears? Help PLEASE!
  79. drilling a hardened bolt in a junkyard
  80. Losing fuel pressure, but only dies in idle(runs bad otherwise once warm)
  81. 2001 camaro steering column assembly
  82. lt1 runs when it whants to
  83. Very difficult to explain...
  84. Overcharged battery - Can I start it?
  85. 1999 Camaro Z28 Backfires when starting after EGR/AIR Delete
  86. hood strut bolt size?
  87. random cylinder misfire, have questions
  88. Gears are gone? Idk
  89. major grinding
  90. Two things: Brakes and steering?
  91. needing help on a 93 cadillac
  92. V6 Beater ac compressor shot
  93. destroyed part, what is it?
  94. Buying fenders question.
  95. 99 Trans am hiccup/sputter
  96. powersteering rack lines
  97. battery drain problem-help
  98. Engine not cranking!!! Replaced ign switch??
  99. P0332 Knock Sensors
  100. grrr this squeal is pissng me off!
  101. What is this noise? Vid inside
  102. 93 harness swap to a 94. need help befor i buy
  103. Need diagnosis on 99 sierra 5.3 issue
  104. Bang..bang..bang!!!!
  105. Ran out of gas- now wont start
  106. Leak at radiator coolant level sensor, ideas?
  107. Seat Bolster Split
  108. Help ! Lots of bucking and jerking cruising In 6th!!!!!!!
  109. Smoking and running rough, not head gasket.
  110. car feels like its about to stall
  111. precat 02 sensor needed?
  112. so I saw some smoke coming from my front end...
  113. Blinking check engine light!
  114. power window question
  115. P0171 P0174 and P0332 need HELP
  116. Vibration
  117. Help me!!!!
  118. CTS V P0305 Engine Misfire Code, can't find problem
  119. oil filter upgrade
  120. What kinds of maintenance do you do?
  121. 2002 ls1 issues, vibrating bad, need expert advice.
  122. wheel bearing
  123. Thud while after shifting certain gears
  124. idle surge after stomping on brake
  125. Odd idle after clutch is pushed in.
  126. dash vents not working, need more detail.
  127. Speedometer not working?
  128. Best place to get ls6 intake seals?
  129. miss problem
  130. Window Regulator Issues - Fiberglass Worn Out- Alternate Mounting Location ??
  131. Badly missing
  132. 2 stroke oil in the fuel?
  133. Reinstalling AC... diagrams
  134. Where to buy power steerng pump AND reservoir besides dealer
  135. heater not working well
  136. Desperate for help (any advice would go a long way)
  137. security light
  138. '00 Firebird Driver window problem--help please
  139. Oil Leak need some info.
  140. Ac problems and noises
  141. No start please help! Thanks
  142. A/C issues
  143. TA wheels on a Firebird, lug nuts are coming off?!?!
  144. hot motor
  145. Help..
  146. Squeaking Noise (Water pump?) and sounds like it's supercharged (Video)
  147. Where is a place to buy new old stock parts?
  148. steering wheel shaking Weird situtation though
  149. What are the signs of a bad EGR valve
  150. Mobil 1
  151. What plug does this go to?
  152. BAnk 2 catylis system code thrown.. what could be wrong
  153. what is this? (engine bay)
  154. My car won't budge
  155. Chirp when driving?
  156. Another IAT sensor Thread p0113,p0452,p1111
  157. Hoe can I test my fans?
  158. Harmonic Balancer - Want Come Off!
  159. what tool did you guys use to get the torx
  160. HELP!!! OIL pan issues
  161. No heat AGAIN.....HELP!!!
  162. About that reverse light fogging on the inside
  163. oil gage ?
  164. Throttle cable install?
  165. ZERO oil pressure?
  166. Changed my Fuel Filter Today
  167. In P/N, better idle w/ IAC disconnected
  168. I learned a new thing - need an A/C delete plate
  169. loses spark. help!
  170. a/c not cold
  171. Hit a Curb, FML
  172. LS1 power lost when hot
  173. Headlights Come up when i turn on the park lights
  174. gas problem
  175. Gas Hand
  176. Replacing front crank seal
  177. Reverse light condinsation/fogging problem
  178. Bad o2 with no ses light
  179. Coolant Leak
  180. PCM not turning alternator on?
  181. need help or ideas. ac clutch squeeling? 2001 ls1
  182. Window motor
  183. Name that sensor
  184. Steam coming from thermostat housing/lower hose
  185. Need some help! lights in gauge cluster wont come on at all
  186. Where can I find these parts?
  187. o2 help...
  188. problem bleeding brakes
  189. WS-6 Power Seat Harness
  190. Help me lol!!!! Headlights open seperately out of sequence!!!!!
  191. Need help with oil pan gasket
  192. water pump install question-urgent!
  193. Idler pulley question
  194. Fuel Guage pegged and car running like poopy
  195. ac compressor
  196. mystery noise and hesitation @WOT
  197. Car cranks, but won't always fire on first key turn.
  198. Elusive Voltage Draw
  199. Lean Condition
  200. Day Time Running Lights
  201. 02 sensor problems - 04 ZR2 Blazer
  202. Finding a AC leak
  203. Flashing SES after Header install....
  204. Wont shift into 3rd
  205. car acting up during start up
  206. coolant leak around heater hose and block
  207. steering wheel removal
  208. Any 1 know where to get screws for the headlight covers
  209. 93 Z-LT1 Cutting out and slight misfire
  210. vacum leak ,bad professional products???
  211. Drivers rear wheel locking up help!
  212. Alternator Question
  213. Please help identify this part
  214. mounts- what type?
  215. Replacing oil pressure sensor.. Advice
  216. troubleshooting missing
  217. Noise from rear end after oil flush normal?
  218. Rebuilt LS1 overheating, new to LS1's. Need advice and help!
  219. LOw idle and chasing throatle coming to a stop help!
  220. Brake, abs inop, asr off all came on at once !
  221. Mopar Combustion Cleaner Picture
  222. HELP ... Rear end noise 99 Camaro
  223. jump the wire?
  224. Ls1 low rpm squeal on warmup??
  225. ticking on cold start?
  226. seafoam double check
  227. Fluid types and capacities
  228. moisture coming through pcv
  229. ses code disappeared after wire mod
  230. failed inspection because of loose tilt wheel??
  231. AC Flush
  232. The Unshakable Shake in the Front of My DD
  233. window slider
  234. Need a tune-up for Lt1....Atlanta Area
  235. Weird smell under hood
  236. Squeaky ac idler
  237. Switched to amsoil.. Ok to mix 5/10w-30?
  238. Uneven tire wear
  239. Idle problem
  240. Alternator Issues!
  241. Wtf? That was weird. (lights)
  242. jerky weak acceleration but no codes
  243. 02 Trans Am Rear Bumper
  244. Need help guys!!!
  245. Octane Rating - what do you use?
  246. driving/blinkers not working on 02 ws6
  247. G-Oil Green Earth Technolgies, has anyone tried
  248. Traction Control won't stay on.
  249. SES light while on vacation!
  250. Hood adjustment (see pic)
