View Full Version : General Maintenance & Repairs
  1. Rear Main Seal Change Question
  2. important pcm question
  3. Starting/idle issues after tune.
  4. no heat in the front seat
  5. Creaking upon acceleration Engine/Tranny mounts inspected found to be good
  6. Removing plastic steering wheel cover?
  7. A/C gurus-need evaporator advice!
  8. Oil filter/stripped threads: easy fix or no?
  9. not another vats question
  10. Fog light problem
  11. a/c causes car to stutter/ smoke ???
  12. Oil in cold side piping
  13. Car Vibrations 55+mph
  14. vacuum question, P0507 is killing me!!
  15. Turn signal Flasher question
  16. truck trouble
  17. loud ticking
  18. Aftermarket Oil Pressure Sending Unit Inaccurate?
  19. 2001 camaro Service Manual
  20. P0135, P0155? Why?
  21. Whiny power steering pump
  22. The A/C belt
  23. Power seats will not move...
  24. Key won't turn
  25. guys with home single car garages...
  26. Window regulator and glass removal
  27. How do i remove the driver/passenger windows
  28. Misfire help
  29. Need help asap
  30. no brake lights!!!!!!!!!!!!
  31. trouble with brake lights
  32. need help, oiling issue!!
  33. Help!!! P2101, p1516 on TBSS
  34. Do They Still Sell Lubra Additive?
  35. Car dies after 10-15 minutes of driving, never on highway.
  36. Got A code P0174 on 2002 firebird v6
  37. bleed air from cooling system?
  38. Keeps Leaking Oil
  39. Help!
  40. X-pipe placement
  41. Fuel Sender Problem
  42. Vibration
  43. Rattling under the car?
  44. misses bad in the RAIN !!!!
  45. Got a knock sensor low voltage code after Washing the enginge.
  46. problem please help
  47. spider gears went out:|
  48. Whatcha guys think?? **Updated with pics**
  49. What is that annoying squeak???
  50. thermostat do i need to buy the housing (neck)
  51. wheel bearing problems
  52. How do I keep the front tires from rubbing the plastic part in the wheel well?
  53. Idle Question?
  54. Engine cracks starter Why?
  55. Different Valve Cover?
  56. Alternator chatter
  57. loose door handles
  58. Half my gauges not working, half the warning lights lit up. WTF
  59. oil in radiator! help!
  60. code p1152 02 sensor location
  61. Possibly buying 2000 Firebird t/a
  62. engine bay smelling funny
  63. to all the v6's out there
  64. Rear sway bar
  65. security light on
  66. sarting problems need help!
  67. Window Regulator Assembly
  68. P0102 code not going away help!!!
  69. buzzing sound coming from driver side
  70. Getting water in computer, how do I prevent this and replace plug pin connectors?
  71. Where is there a O-ring in the power steering pump set-up?
  72. Exhaust R*A*T*T*L*E!!!!
  73. Driver's side window won't go down
  74. 2002 camaro z28 bumping noise
  75. GM Top Engine Cleaner vs. Seafoam vs. ???
  76. Oil Pan Leak
  77. Tick on fuel rail
  78. 2000 Z28 Behind dash fuel gauge wiring HELP!
  79. P0332 probably due to computer pin connectors?
  80. Car wont crank
  81. Name That sound
  82. water coolant
  83. Car spins but wont crank unless you jump
  84. ignition/starting problems!!
  85. Blinking SES light
  86. headlight motor
  87. Hood cable
  88. looks like oil in power steering fluid but I don't have a power steering cooler..
  89. Manual idler/tensioner pulley. New Belt. Whine when cold.
  90. Quick simple question
  91. Any Ideas???
  92. Need part number for side marker socket!
  93. Help!!
  94. car makes a thud noise
  95. ac isnt cold!!!
  96. Knock sensor code P0322
  97. battery wiring routing
  98. window issue
  99. horn
  100. Heating Up!
  101. Getting a Difficult Wheel Cover Off
  102. 799 heads
  103. Tough starting cold
  104. How does the oil monitor sensor work?
  105. Really loud squeking and chirping noises.
  106. HVAC not blowing!
  107. Fog lamps!
  108. Mice in the vents
  109. Water in Computer PIN connector
  110. racks
  111. Multiple things going on with car....
  112. NEED HELP: Passanger Side Headlight Stuck Up!
  113. P0300 code please help!!!
  114. small clicking noise?
  115. Bent Chassis?
  116. Help with dead spot
  117. Need Ideas. Electrical issues
  118. wobbly grinding sound
  119. Lt1 Backfires need help asap
  120. overheating issues.
  121. Antifreeze in oil or just condensation! Help!
  122. Possible Wheel Bearing Problem on my DD
  123. electrical problems
  124. Metal shavings after ls6 valley install
  125. HELP wheel lock/stud stuck
  126. Looking for some input concerning anti theft system.
  127. Need help locating this part/part number
  128. Help , brake problem
  129. abs and traction lights - solved!
  130. Don't know what to do falling apart
  131. H/C ls1 hesitation BAD!!!!!!!!
  132. Car wont fire up on first try
  133. About to lose my mind
  134. 2 issues, low rpm & high rpm
  135. Water Pump Repairs
  136. 01 T/A pwr steering res. that will work?
  137. Headlights not working
  138. Steering issues and lots of "play" in the wheel...
  139. What is this and why would it be cut in half (pic)
  140. Car alarm problem
  141. Car won't warm up.
  142. tune up
  143. Car misses at Idle in drive, but drives fine?
  144. Car idleing low! (Gas milage cut in half!)
  145. Creaking when releasing clutch?
  146. WHISTLE, not Whine or Squeek....
  147. Seafoamed the car a few days ago.... :)
  148. Car wont Start
  149. Drivetrain noise
  150. Need help
  151. sould i be shiting bricks?
  152. Wierd stuff happening.
  153. Disturbing rattle on 01 Grand Prix
  154. Hood Struts Blew up tonight :(
  155. Can you tell if an O2 sensor is bad with an OBD-II log? (log inside)
  156. Not that I think anyone cares...
  157. all you people in COLD climates.........
  158. Leak
  159. 01 Malibu P1626/P0230
  160. p1637 and voltage surge.
  161. Dash Lights
  162. O2 sensor
  163. leaking coolant from overflow tank's cap & banging noise
  164. Blown Head Gasket Or What?
  165. Iac question
  166. 2001 Will not turn over
  167. Installed rack and pinion
  168. Problem-removed alternator and forgot about exciter wire
  169. Heater Problems.
  170. 3rd Brake light help
  171. How-To; Steering Column Repair
  172. HELP NEEDED with window replacement
  173. LS1 99 Camaro Sputtering
  174. Is the junkyard the only place to find this part?
  175. No PWR steering and all looks well?!?!
  176. Not an LS car but need help
  177. Car needs a major tune up. What exactly does that entail?
  178. Crank pulley tabs broke during removal, how do I get it off?
  179. 02 TA window replacement help
  180. Windshield Wiper Relays?
  181. Steering wheel misaligned
  182. Clutch sticking to floor?
  183. Engine misfiring
  184. Bad Water Pump?
  185. Fog lights
  186. Possibly starter going out?
  187. Can Front Wheel Studs Be Replaced?
  188. Emergency Brake
  189. Question about exhaust leak and header flange
  190. Who makes a good catch can for a good price?
  191. Fix for loose passenger seat back?
  192. ABS Light always on even when disconnecting battery then reconnecting
  193. Airbag Connection. Pics needed
  194. Need Help!
  195. Bank One too lean (P0171)
  196. Voltage high
  197. part# for the rubber wiper bumper
  198. Do I have a short, dead battery, or bad alternator?
  199. Cracked Hose - What is it? Picture
  200. rattle coming from rear speaker panel cover
  201. symptoms of a starter/flywheel going bad?**UPDATE NOW CAR WONT START!!**
  202. Service Vehicle Light
  203. Tuning out o2s
  204. 96 TA Panel between windshield and dash cracked
  205. CODE P0174 and Insanely high oil pressure (120!) Need help Please
  206. Cruise and TCS quit at the same time
  207. Water disappearing, no leaks, not overheating
  208. My car was stolen. How do I prevent this from happening AGAIN?
  209. where to buy steering rack and pinion?
  210. SeaFoam? your take?
  211. Need to find this part
  212. 1996 WS6 Smells Like gas inside and outside of car.
  213. door/t-top weatherstrip ?
  214. starting trouble: clicking noise, dry "grinding" noise...
  215. Can't believe it
  216. No dash lights & no courtesy lamps
  217. battery keeps dying. need advice.
  218. no spark and no fuel presure
  219. weird chirping noise after installing ps pump
  220. Gm part number help please
  221. Wanted: Wiring harness
  222. Idle Problems Please Help
  223. Problem with Power Steering?
  224. Pressure leak in AC system..
  225. New brakes 911!!!
  226. Squealing A/C Compressor
  227. Having trouble finding correct acdelco thermostat
  228. problem with horn.
  229. power window problems (not the motor)
  230. Key Fob help please!
  231. Broken steerung shaft bolt
  232. ac leak
  233. Are 1998 valve covers different?
  234. Weird noise at idle...
  235. Fuel Filter Change (Urgent)
  236. strange vibration from gfs new trans am.
  237. Vibration problem
  238. bad problems:(, cant figure it out, help please
  239. Misfire & Light Cloudy Smoke
  240. Oil Change light?
  241. Something drawing power
  242. Are O2 Simulators prone to failure?
  243. Exhaust hitting axle..
  244. Removing stuck on exhaust tips
  245. My headlights shake
  246. Attention VATS experts!
  247. Need help please
  248. Tokico HP ("BLUES") coil-overs
  249. ABS Issues Please HELP!
  250. When i break to stop, my headlights come up? Why
