View Full Version : General Maintenance & Repairs
  1. hard time turning engine on
  2. cant believe Im asking this....
  3. okay to re-use rear main seal?
  4. qhere to buy ex manifold hardware
  5. 3 headlights dim 1 bright?????? HELP
  6. Bad ignition?
  7. removing a/c "HELP"
  8. Wifes car not running right, need opinions!!!!!
  9. Window motor from Parts Taxi
  10. AC question
  11. Popped 10!!! codes!!
  12. Horn stopped working
  13. smoke out left side tail pipe
  14. Need some help please, my car is possessed
  15. BCM Removal
  16. Alernator: exciter wire... ???
  17. Cat inefficiency code, swapped cat, need help!
  18. Alternator/Battery Problems On 2000 LS1(Detailed story)
  19. Starting but not idleing...
  20. LS6 PCV mod / valve cover questions
  21. IAT Problem P0113
  22. HVAC Question Trans AM Need some heat!
  23. re using transmission fluid and oil?
  24. Speedo/odo doesn't work.
  25. using a quart of oil at about 1500 miles..?
  26. ws6 hood latch vs firehawk hood latch ls1 generation
  27. Rear Defroster: fffuuuuuuu
  28. weatherstriping & window gap
  29. Lower part of engine seperating?!
  30. car pulls to the left and clicking noise?
  31. Low Oil? Leaked about a quart in a month
  32. Royal Purple Oil Filter.... ???
  33. Clutch Pedal Squeak
  34. HIDs + wipers = annoying buzz. Really weird problem.
  35. Turn signal problem...
  36. 00 trans am dead soldier recieving no power
  37. Repair Manual Opinions
  38. Alarm and Stereo Problem
  39. ticking
  40. Fluid transfer pump?
  41. P0301 misfire...this is involved
  42. Factory Bose head unit - display flickering, volume level reacting to headlights ect?
  43. Battery or Starter?
  44. Just replaced my drivers side power window motor
  45. Can Wiper Arm Be Moved Upward Any
  46. new 2002 Z28 owner, with problems already!
  47. windows
  48. Electrical Issues-Car won't start!
  49. UUGGGHHH Window not moving!!
  50. Improving a/c performance, Variable orifice valve
  51. vibration?????
  52. Misfire question. P0300
  53. AHH broke a bolt :(. Help!
  54. Preventive Water pump R&R?
  55. 2000TA: Car won't idle at all just starts and dies, HELP PLEASE...
  56. ASR turns off when I release the clutch
  57. 94 camaro 3.4 spewing white smoke out the tailpipe and misfiring
  58. gauge cluster
  59. Wiper fluid pump
  60. 1998 OIL Pressure Sensor wiring
  61. 02 WS6 few issues!
  62. Oil leak! help plz :(
  63. Tapping sound w/ Random ses light
  64. Newbie needs LT1 help....
  65. Can you clean a belt??? Squeaky Vette
  66. water in oil cap of 2000 ta
  67. large amount of carbon build up on my rear bumper
  68. chunk in oil
  69. cleaning windsheild drains?
  70. Belt squeak squeak squeak...SOLVED!!!
  71. do I have a broken throttle cable?
  72. ls1 f-body wont stay running
  73. Heat problem
  74. Using a multimeter to troubleshoot charging
  75. Still stuck after VATS bypass NO START!
  76. vss leaking
  77. another powersteering thread
  78. Ls1 need new pistons, or should i rebuild the whole engine?
  79. wheel studs
  80. Replaced window motor, now none work!
  81. 98 camaro turn signal please help
  82. card in bike spoke sound on decel/closed throttle
  83. Battery bolt (-) is stripped why won't car stay started?
  84. HELP!! My security wont let me cranl my car!!
  85. Need help asap, sticky throttle/ rpm guage
  86. WTF is up with my idle? Update still need help though
  87. Random Misfire P0300 started today in the RAIN
  88. Power steering pump
  89. NEW Windshield installed for $155
  90. High Idle? Is it normal?
  91. car idles low then dies? help
  92. No heat! I'm stumped, help
  93. shift cable problems
  94. Still have a charging problem!!!!!!
  95. Wire hanging by trans mount
  96. gas attendent filled up my 98 ta with regular!
  97. blinker light failure
  98. Car Idles Rough When Cold (sometimes)
  99. Full tune up Advice wanted!
  100. battery tender ?'s.
  101. RPM Issues and Vibration under stress
  102. Water pump woes
  103. what does this sound like?
  104. Any alternative to K&N air filter?
  105. Car Dieing
  106. Need help chasing the breakdown gremlin
  107. lights dimming
  108. RPM problem
  109. Replacement glass windshields question
  110. Oil leak help!
  111. little squeeking sound when turning sharp
  112. asr off light stuck on
  113. Stock Headlight Bulb is?
  114. Need part #!!!
  115. GM 5.0 pullys squeaking
  116. Help with CEL code P1153
  117. BAD Steering Wheel Vibration
  118. Misaligned subframe??
  119. dies after start up???
  120. Check out the many leaks my car has!!
  121. Part Number for center compartment latch
  122. im stumped, please help
  123. Windshield wiper issues - Only work with washer button
  124. Headlight goes half way up and grinds
  125. TCS problem please help
  126. White chrystally fluid under car
  127. Discount Tire/Screw
  128. Car is acting up.. (sputtering)
  129. gauges sweep after starter installation
  130. Broken clip on throttle cable
  131. All three brake lights out '98 Camaro
  132. A/C dilemma
  133. A/C blows a fuse when turned on?
  134. weaird problem
  135. misfiring? anybody?
  136. Rain=Sqeaking pulley?
  137. oil in tail pipes? WTF?
  138. Horrible LT1 Problem
  139. A full dyno tune JUST for no cats?
  140. Lifters or Rockers?
  141. Lack of running/Parking Lights
  142. Overheating (ls1) question
  143. Help...Car doesn't start. Later does.
  144. Help...my car IS starting.
  145. Pwr Windows & Locks to Manually
  146. Bad window motor or wires gone bad?
  147. Driver's side mirror glass missing - what parts do I need to get it replaced?
  148. Need two connectors identified....
  149. I was drifting and then..."Whinning Sound"
  150. Advice Please
  151. Headlights are always on
  152. AC compressor
  153. Balancing the Rotating Assembly
  154. Bucking at low rpms and load (stock)
  155. Smog and o2 sensor (P0137)
  156. flashing check engine soon light
  157. DTC Codes pulled from 2000 Z28.
  158. Upgrading to Truck Alternator
  159. Ok need some advice
  160. underdash wiring harness through firewall connector.
  161. continuous clicking noise?
  162. alternator not charging
  163. alternator not charging
  164. 98-02 T/A & camaro clusters. interchangeable?
  165. Fuel smell...when I get out of the car every time now.......
  166. Blown fuseable link
  167. Hesitation problem
  168. Help with 85 IROC
  169. Filling up with water.
  170. 1998 WS6 OBD Code 0442
  171. Why is my car vibrating?
  172. Bad front wheel bearings
  173. Passenger side window woes
  174. Help: Need Part Number
  175. Refresh and Cleaning (Intake, Mods, Deletes) Help Please!
  176. Grind in 3rd and 4th with clutch disengaged
  177. Overheating and lifters
  178. need gauge bulb replacement guide
  179. Breaking in new engine-need help asap!
  180. spinning nosise, cold start only, above 3krpm..
  181. Any ideas??
  182. How to remove shifter knob
  183. P0430 code!
  184. Installing O2 Sensor?
  185. check engene soon light
  186. magical disappearing coolant
  187. Power Steering Cooling Success
  188. Went to tranny shop to get a flush...
  189. HID headlights not working help please!
  190. ses light
  191. Help With adjusting the headlight cover
  192. window motor and regulator
  193. Power steering fluid leak
  194. How to quiet interior plastic rattles and vibes
  195. Blinkers Just Turn On But Won't Flash. WTF?
  196. bad air idle control vavle?
  197. 1995 LT1 Long Crank Time Consistent
  198. Headlight problems, but not motors this time...
  199. Series of strange debilitating issues (Help!)
  200. Help with random shut off problem?
  201. MAP Sensor ?
  202. ignition prob
  203. power antenna won't go down
  204. passenger window wont go down
  205. Help me Diagnose my AC problem
  206. What is this on my roof?? Curious
  207. power steering pump help
  208. Low idle, dies with gas
  209. Replace Seat Belt Buckle
  210. Car wont start!...No its not VATS(bypassed)
  211. motor hesitates....still
  212. Leaking oil from top rear of block, help pinpoint please!
  213. knock retart
  214. weird thing happened when I flushed my radiator/engine
  215. How to replace rack and pinion?
  216. starter question
  217. Blinker flasher and tail lamp repair
  218. Crappy headlights on my bird...
  219. Where can you find aftermarket or OEM parts such as these?
  220. z28 on its way out the door
  221. Window Part Questions
  222. What can I wedge between my exhaust and body?
  223. 99 ls1 camaro MAJOR ISSUES
  224. Speedo stopped working Z28
  225. Windshield wiperblade problem
  226. headlight motor noise?
  227. rear end question?
  228. No heat
  229. Help!!! Washed my LS1!!
  230. knock while braking
  231. Need help finding coolant tank
  232. Crappy door and side window design
  233. horrified... question...
  234. 01 Trans Am dying
  235. acting funny after header install...
  236. power steering pump locked up?
  237. 1992 grand marquis
  238. Clunk while braking
  239. Slapping noise
  240. Cleaned Maf, Now car idles high/weird
  241. This is driving me crazy! High RPM breakup, funny idle!
  242. Clutch Pedal Sticking.. Clutch Master Cylinder the cause?
  243. Fuel issues
  244. drl or something else?
  245. FAST 90 complete hardware kit.....not complete :(
  246. Please help... Car troubles..
  247. High beams will not come on
  248. is this a window motor problem?
  249. Another Windshield Wiper Issue
  250. Low oil pressure
