View Full Version : General Maintenance & Repairs
  1. AC Not Cooling & Low Pressure reading seems high?
  2. trans am idleing problems
  3. chevy vortec 350 delay in oil pressure on startup
  4. broke pvc line near front of intake
  5. Who offers new leather seat covers for a 98-02 camaro?
  6. PCV valve leaking oil
  7. Outter Door skin, separating, wut do?
  8. 98 T/A headlight motor grinding?
  9. P0171: System too Lean (Bank 1) need help
  10. where is my coolant going?!?!
  11. hard starting
  12. Weird overheating problem.
  13. Whats the deal with this alternator "vent"
  14. sputtering and bucking.
  15. No torque, misfires, exhaust popping....
  16. steady belt squeal
  17. over heating at idle.
  18. i get aloud bang in tranny area when i engage the clutch before i shift need help bad
  19. Car Still want start! Please help
  20. Halo headlights worth the money?
  21. window motor fuse?
  22. not sure whats wrong
  23. Needle Stuck
  24. hesitation and backfire after rain
  25. help please
  26. why cant i get a good seal onto my y pipe?!!!
  27. 95 z28 wont start all the time help plz??
  28. Blowing horn fuses. Is there a difference between Camaro/Firebird horn?
  29. Resetting oil light and capacity?
  30. Looking for Seat Covers
  31. anyone have any ideas????
  32. T-Tops Leaking
  33. clunk/grinding sound and feeling
  34. DRL/Blinker bulb - Is it 3157 or 3457?????????????
  35. my old 96 Z28 seemed faster then my 2000 Z28
  36. A/C Blower intermittent
  37. Cam or Crank sensor???
  38. VSS install trouble
  39. Electrical Issue - Popup Lights/Alarm?
  40. stuck window regulator due attempted replace of window motor
  41. Leaking Antifreeze
  42. Headlight Lens Repair Question
  43. Where to get water pump...
  44. 2000 trans am will not start?? VATS issue?
  45. havc vent control question
  46. Stubborn Oil Change Light
  47. Leaking fluid above driveshaft
  48. Dirtiest power steering fluid you've ever seen.
  49. changing doors. Door lock ?
  50. starter signal wire
  51. Wierd Headlight problem (Trans am)
  52. Most recommended o2 sensors?
  53. Lost keys... got new keys but won't open hatch. Possible to re-key?
  54. pully noise?
  55. oil pan leak, few questions inside
  56. random dash lights
  57. Can't get pass. window lined up
  58. Both Headlights Out (please help!!)
  59. a/c help
  60. Brake pad,caliper & rotor replacement
  61. Replacement power window motor didn't come with hardware - size of nuts&bolts to use?
  62. 99 z28 camaro wont start
  63. P1416 OBD2 Code Help
  64. Using aluminum or tin foil to block engine and transmission heat ??
  65. Another Headlight Issue
  66. Anti freeze coming out of my exhaust, and car starts pretty hard, what can this be?!
  67. Where can i buy an aftermarket Vehicle speed sensor?
  68. crack in lower dash
  69. PCV Valve Tube Identification
  70. Shifted into reverse while traveling forward!!!
  71. 2000 C5 won't start. Battery is good but keep hearing relays clicking in fuse panel
  72. ls1 low oil light.. even after oil change
  73. Can someone tell me the size of this 6 point bolt?!
  74. Removed stat, found bits of black seal
  75. Whole car shakes at 60mph+
  76. Where can I buy Gatorback belts?
  77. p0131 and p0151
  78. Rear Main Seal/Clutch
  79. 150psi, low-side AC?
  80. PO300 Code! Let me explain.
  81. Royal Purple and Shell gas BAD?? False Rumor??
  82. Help with a problem.
  83. NO power to fuel pump...few question and need advice
  84. Finally found that loose change noise...
  85. oil leak , oil pan or sumthing else ?
  86. Belt falling off in rain
  87. Power steering weak/stiff
  88. Serpentine Belt won't stay on...
  89. Have a weird issue, help appreciated
  90. SES light is on cat issue .
  91. Location of wiper switch
  92. Smoke or steam coming from A/C vents..
  93. Plastic thing around the starter
  94. Mobil 1 5w30
  95. whining sound after 60 mph??
  96. Need Help Diagnosing Oil Leak
  97. A/C Refrigerant Leak
  98. Free Play In Steering Wheel?
  99. Seafoam question??
  100. Rear swap now car wont stay running?
  101. A/C Problem
  102. Knock
  103. turn signal circuit/fuse issuse
  104. Split cigarette lighter accessory power?
  105. Erratic idle
  106. shifter knob problem
  107. New Window motor? ACI or Dorman?
  108. Squeaky shocks?
  109. P0300 random misfire and alt trouble
  110. P0118 (ECT) and Low oil light came on same time
  111. Car starts only sometimes?
  112. Power Windows Not working Help with Electrical
  113. F*cking window motor
  114. Car kills optispark's
  115. Car makes some strange sounds
  116. Sputters at WOT
  117. New car , ASR BRAKE ABS lights are on .
  118. Crazy rattle when revving
  119. Help with clunking
  120. Waterpump
  121. Transmission Y-pipe hanger / mount question
  122. Anybody know what this is/does?
  123. weird thumping noise. This is a good one...
  124. HELP Car only starts randomly
  125. Drained battery, help finding gremlin...
  126. Broken Head Bolt
  127. Help with starting 74 Corvette after 5 years of unplanned storage
  128. turn signal flasher
  129. SS instantly running like crap, no codes thrown!
  130. What is this sound?
  131. Starting at random!
  132. code po131 help
  133. Battery or Alternator
  134. Vibration in steering wheel when turning hard left, rough idle and bog after startup
  135. Overheating Issue
  136. Help! Where is the orifice tube located?
  137. What is my car doing?
  138. Cleaned my Throttle body an now i have like a 2100 rpm idle AHH!!
  139. Alternator removal help...
  140. car not running right
  141. Power Antenna Repair Kit?
  142. Foil in oil!
  143. NEED HELP! My car boils antifreeze out after shutting it off?
  144. Ignition Coils
  145. solenoid only clicks
  146. need help
  147. Rear end fells like it moves around, in a bad way Need Help
  148. Installed new window motor and found this rubber piece..what is it?
  149. 1 simple coolant question
  150. Burning oil?
  151. interior electrical damage?
  152. Drivers side window (not the motor)
  153. Need help asap! Lt1 engine has weird sound..
  154. Surging/missing at constant speed
  155. Frustrated with not starting issue Help!
  156. mobilone or castrol edge what oils in ur f-body
  157. tune up
  158. What temp should my car be running at?
  159. Help me fix my Cruise Control
  160. looking for a lift
  161. Clunk when turning in reverse
  162. Tranny Clunk
  163. tons of white smoke after head gasket job
  164. Where to get door panel screw insert?
  165. t56 transmission fluid
  166. Car Won't Start
  167. Loose steering column 2000 Z28
  168. whats this noise?
  169. HELP! AC condensation leaking from under dash!
  170. Drivers side Air check valve,where is it??
  171. Unknown Noise
  172. Coolant Gurgling Sound
  173. Drivers seat sagging.
  174. Where to buy OEM rubber exhaust bushing
  175. !HELP QUICK! PCV hose nightmare
  176. Ignition Cylinder problems...please help...
  177. Need Help Solving Electrical Gremlin! 03 Tahoe 5.3
  178. Disappearing hose!
  179. Driveshaft Clunking Damage... PICS
  180. stuttering problem
  181. Ignition Issue - Odd Issue. **Resolved**
  182. Whining from under the hood
  183. A few issues I'm having with my 2002 SS
  184. Starting problem. need help asap!
  185. Clanking?
  186. how do i fix broken ash tray door
  187. bogging out
  188. Sometimes leaning out @ WOT
  189. Gets hot with AC on
  190. Change ignition cylinder/key
  191. is this too close to the header? help me out here.
  192. How to remove the top bolt from AC compressor
  193. Window motor?
  194. 98 LS1 transmission lines
  195. No idea what's wrong. Help!
  196. rattling in shifter?
  197. HELP with my daily please. 97 park avenue passkey 3 issues
  198. clutch pedal squeaking
  199. So i'm fooling around under the hood today and..
  200. Need help with brake hoses near differential
  201. battery drains over couple day period of time
  202. What are some cheep lt1 mods
  203. More Opti Problems
  204. AC problem, need help guys. Thanks
  205. Problem with a big clunk sound
  206. what is that little cushion under intake
  207. Brake light stays on
  208. replaceing my window regulators...
  209. Total cooling capacity ls1
  210. Restore Firehawk Centercaps??? Tabs Broke
  211. Wierd squeaking..sounds like a bearing
  212. How do i remove the console ?? MGW short shifter install...
  213. Soft ticking noise from engine
  214. What's the piece in the t-top that keeps the lock from falling out?
  215. stupid question
  216. I need help yall * video *
  217. P0113
  218. random misfire code
  219. Power Steering Pully Wining + Smell Help
  220. OEM WS6 hood install issues
  221. im an idiot. please help
  222. GMC SBC will not start
  223. a/c wont blow out of top vents
  224. Window acting up.
  225. a few questions...
  226. So...
  227. Ignition coils Question
  228. When did NGK made plug for Ac Delco ? is this true ?
  229. AC blows cold but not hard enough to cool down the car what gives?
  230. AC/Heater motor blower starting/stopping issue
  231. Why Is My Engine Pinging???
  232. Car wont charge
  233. Low oil pressure from 5w-30 mobil 1
  234. Do I need new front struts?
  235. Can't enable factory alarm
  236. Stupid quesion about spark plug change
  237. 20W-50 Oil to slow down oil leak
  238. new lt1 crank, no start issues.
  239. Steering linkage bolt size
  240. !!Filler Tube!!
  241. Some trouble starting, dont' know where to look
  242. need help finding a part....
  243. Head lights come up when i turn on indicator lights
  244. smoking between a seats console camaro z28
  245. Low Voltage O2 Sensors
  246. 98 buick regal air intake sensor code
  247. AC install
  248. Everything compatible Premixed coolant ok with dex cool?
  249. is it time to change my "new" clutch
  250. how to place the 9284pt head gaskets
