View Full Version : General Maintenance & Repairs
  1. T-top repair
  2. Need help asap, car wont start
  3. Cheapeast place to get all this crap.......
  4. I need a shift tube ....
  5. Need bolt size for exhaust
  6. Turn Signal Problem...help!
  7. Intermittent AC compressor operation.
  8. Loud ass brakes
  9. if u ws6 pros could please chime in
  10. Oil, too much?
  11. A/C pressure sensor 5 Volt reference issues
  12. The 2 Rear Oil Pan Bolts?
  13. Car stalls when I make a hard left?
  14. low oil sensor wire
  15. how to stop ttops from leaking?
  16. WTF My stupid PITA belt keeps falling off in the rain!!!
  17. Power window adjustment?
  18. HVAC Selector issue
  19. 2000 z28 - Rear End Knocking with Acceleration
  20. Leaky t-tops
  21. Oil blowback
  22. Can't jump car through the battery?
  23. Is there a "how to" for the AC evap core?
  24. cat got so hot it burnt a hole in the carpet ????????
  25. Problem found- Camshaft sprocket bolt walking out
  26. PCV lines broken, any effect?
  27. My belt walked off ????
  28. Headlight Beams
  29. Driver side mirror housing
  30. A/C High-side vs. Low-Side
  31. Lean bank 1 and 2 codes (P0171, p0174)
  32. Help Diagnose my NEW problem
  33. Oil for 2001 VETTE
  34. Help my new to me camaro has a loose steering colum!
  35. interchangeable starter?
  36. bad alternator?
  37. shifting problems
  38. Throttle problems AGAIN!
  39. WTF Security light popped while driving wont go off...
  40. Window Motor possibly bad
  41. Performance with 'knock sensor low input'
  42. A.I.R. Pump
  43. Rear Wheel Studs
  44. Weird idle issues even after tuning with cam.
  45. hesitation after startup
  46. low voltage problem
  47. mystery leak?
  48. Cuts out and wont accelerate past 55
  49. Damn this *cruise control*
  50. Damn this *cruise control*
  51. C0035 and U1040 codes...
  52. sputtering issue
  53. Both power door locks stopped working
  54. door lock
  55. Help with starting problem
  56. Engine Crank Problem
  57. V6 Camaro Spark plug and wire help
  58. brake pad replacement question
  59. ~ Lots of U and C codes! Need direction ~
  60. Starter relay going bad?
  61. Drive train Vibration Question?
  62. LT1 idles at 2000rpm after going WOT
  63. Hesitation between 2k and 3k, and hesitation at idle
  64. Noise from rear of the car
  65. bout to put a brick through my window and call it a day
  66. 98 formula running rough.
  67. Help whats this sound!!??
  68. Stock oil filter was changed
  69. DRLight socket melted
  70. idle sometimes high sometimes low? only with ac on
  71. 2001 formula ls1 KNOCK SENSORS
  72. Help
  73. ~~ Added a ground. Still have flickering lights - low volt - INOP ABS BRAKE ~~
  74. Battery question
  75. Question for 98 guys
  76. Air pump re-route, or delete?
  77. disappearing coolant
  78. ac vents wont open
  79. water pump?
  80. Service Engine Soon Light is on
  81. best replacement window motors?
  82. 2002 b4c ping maybe?
  83. P0352.. passenger side coil packs are 'dead'
  84. Directional Lights Fuse Keeps Blowing!
  85. IAC noise
  86. Window motor or window switch??
  87. Clatter sound coming from rear HELP PLS!!
  88. Driver window fast as hell...now pass. window wont budge
  89. Ac compressor help
  90. another starter problem
  91. p0400 code help
  92. Gas meter broken/stupid
  93. Pulled 8 codes!!
  94. AC Repair
  95. Secondary/Air Check Valves.???
  96. Odd part request (3rd brake light)
  97. P0353 code thrown. Not a plug wire?
  98. AC Delco PF 46E filter?
  99. drivers side headlight not working
  100. Powersteering Pump Oring?
  101. Loose gas pedal. Any ideas?
  102. 93 z wont start
  103. '99 Z28 M6 - Low Oil Light?
  104. I installed pacesetter long tube headers and y pipe what do I do with the other sensr
  105. Name that problem
  106. ~~ Cant get Torx off of A/C pulley! ~~
  107. Lousy wiper motors/controller!
  108. V6 Evap Help
  109. ~~ Valve cover leak? Smoke from oil filler cap! ~~
  110. Alternator Heat Soak?
  111. Sounds like its cammed....but its not
  112. factory CD changer really pissing me off. How to fix?
  113. I can't find where this damn coolant leak is coming from! Help!
  114. exploded view of drivers side window
  115. Any ideas what happened? Do I need to worry about this?
  116. clunking from rear end.. please help!!!
  117. Hatch alignment
  118. alternator harness for ls1
  119. ac belt tensioner noise
  120. replacing oil pan gasket
  121. Maybe axle bearings?
  122. AC issue
  123. Anyone have this Hatch Strut problem?
  124. Drowsy Engine During Idle
  125. AC Compressor FAIL! Now what?
  126. trans install issue
  127. Possible fuel pump problem.
  128. not in right forums but maybe u can help
  129. Squeaking coming from the front of the car
  130. Getting pissed off!!! (video added)
  131. AC and cruise control quit working???? any ideas...
  132. I need new 02 sensor and to replace my alt...have no idea..
  133. weird noise
  134. keep blowing fuses
  135. What does this sound like?
  136. Car stumples / loses power at part throttle!
  137. coolant odor
  138. Back right brake leaking...
  139. Noise from pully, ac unit, or tensioner?
  140. **PROBLEM** with lights operate with key fob
  141. A/C Questions
  142. new seats?
  143. Problem with low beams
  144. question about gutting cats/affect of a warranty
  145. 98 TA wont start
  146. AC wont work
  147. Burnt DRL pigtail
  148. Speedo is off , How do I fix it ?
  149. Ignition relay in 2000 LSI Camaro, did this site ever find the fix?
  150. SUPER WEIRD car won't start... 2002 Incon T/A
  151. air filter
  152. Brake lights dont work, then they do work, then why dont...wtf!
  153. How hard to swap drivers window?
  154. Key feels like it is in a bind
  155. how to install an air filter in your camaro
  156. window motor
  157. 2000 SS Wont Start
  158. i need help with annoying problem
  159. Weak spark
  160. Help!!!
  161. crank position sensor broke off
  162. ac filter # please
  163. HELP! found needle bearings in oil pan
  164. Loud ticking/clicking noise after wot...
  165. Changing out spark plugs... Need some advice!
  166. AC Compressor Issue? HELP!!
  167. Help...
  168. Help with lights!
  169. blinkers and steering
  170. thrush catalytic??
  171. Ls1 dies after warming up.
  172. Power steering hoses
  173. LS1 running terrible
  174. Fuel Pump Relay help! 2003 Olds Alero
  175. car shakes at 80mph
  176. Major Squeal.. Cant find it...
  177. Under headlight control - what is it?
  178. noise from injectors
  179. belt tensioner assembly
  180. power steering not smooth as it should be
  181. Downstream (after cat) O2 sensor ?
  182. Any way to wire in a battery shutoff!?
  183. Wiring Diagram Help
  184. Help Car wont start...need ideas
  185. Water pump question
  186. How to get gas smell out of carpet.
  187. DESTROTED Oil Filter STUCK!!! !!!!!HELP!!!!!!!PICS!!!!
  188. Oil change light
  189. 2001 engine wiring harness issues
  190. A/C and Heater both blow outside air temp
  191. Power steering leak....??
  192. Permanent fix to bent fender tab problem
  193. Security light on LS1 Camaro
  194. Security light please help!
  195. New Computer, No AC
  196. Opti replacement gone wrong
  197. so im stranded in a parking lot
  198. Cracked sway bar
  199. Easy question
  200. battery or alternator?
  201. Trouble turning over engine
  202. weird sound coming from engine (video inside)
  203. my lt1 is shaking back an forth.
  204. weird pulsing vibration
  205. Skip when coming to a stop?
  206. Parked car now No Power … HELP!!
  207. Knock sensors replace but problems help please
  208. Fog Lights Dont Work
  209. Bad O2's,,, again!!
  210. rattle noise when accelerating, what can it be?
  211. chevy express
  212. cricket in my engine bay! video inside
  213. egr ?
  214. my 3.8 camaro Conversion to ls1 >>>help me
  215. Car has cataracts - WTF?
  216. Power steering still on the fritz after pump replacement...
  217. A little help with a couple issues.
  218. 2000 Trans Am
  219. Air condition
  220. ~~Anyone using cheapo AZ/Advance wire set? Did I get the right Plugs?~~
  221. Under car clunk on decel *searched*
  222. cabin air filter?
  223. Thermostat Question
  224. 3800 6cyl?
  225. idle issues, burning oil, surging.
  226. HUGE backfire...
  227. How do I adjust my t top weatherstripping?
  228. Bypassing stock computer & ignition
  229. Door lock, and trunk release actuator question.
  230. Help me KILL my low oil light.
  231. Idling high in park
  232. 200a alternator installed, no flickering, still questions
  233. Could this be my PCM?
  234. car wont start ugh stupid vats I think!
  235. i think i have bcm problems
  236. Replaced A/C tensioner - Squeak is worse!!!
  237. t/a headlights
  238. HELP!!!! Rear End Buckling...
  239. frustrating horn
  240. My 01 z28 radiator bubbles for about 10minutes after I shot it off... WTF is goin on?
  241. turn signal flashers location
  242. 99 Camaro Cluster Help!!
  243. Misfire at idle and PO442
  244. how do you swap the alternator?
  245. TA Headlights possessed by satan
  246. Catastrophic Fail.
  247. Annoying pulley chattering!
  248. Fix for rear hatch ball joint mounting plates?
  249. Factory electronic antenna won't go down...
  250. Car Stopped Today While Driving In a Flooded Street
