View Full Version : General Maintenance & Repairs
  1. Umi torque arm and driveshaft issue or.. pics
  2. Engine knock at idle
  3. Air pump fuse question??
  4. Code P0443 - Can't put gas in tank!
  5. AC Delco oil filter?
  6. Can't fine ps return hose?
  7. storage in extreme cold
  8. Replacing Denso O2's..
  9. P0101 103 803 & o2 sensors
  10. need help - rear heat shield
  11. Hatch won't stay up, new struts needed?
  12. Steering wheel replacement
  13. routine oil change turned into guessing game
  14. Catalytic converter issue
  15. alternator keeps going bad after tune
  16. RPM Gauge not working
  17. white smoke at idle
  18. Alternative methods for Throttle Cable
  19. Radiator??
  20. oil leak issues
  21. oil consumption problem improved
  22. Needs ideas for misfire quick.
  23. Newbie from Monroe,La- Finally got me a 99z28
  24. Blinkers not blinking
  25. Another...my car won't start thread.
  26. Replacing motor mounts
  27. SLP Lid Plug Size
  28. Idle issues!!!
  29. Headlight grinding sound
  30. HELP Slave Cylinder/Clutch fork
  31. what is this hose???
  32. Door help
  33. terrible squeak
  34. Broke starter right of the block
  35. P0300
  36. 2002 Firebird dash and radio lights not working?
  37. Factory sized lower ball joints
  38. Serpentine belt options
  39. Hood latch lever doesnt return
  40. Installing the rear block cover?
  41. Broke my throttle cable tabs...
  42. Car loads up while cruising????
  43. Alignment issues
  44. oil leaking out of spark plug, see pic
  45. Oil pan removal question
  46. Another car shaking thread need advice, tires? Transmission? something I missed?
  47. Need help with leak on 2000 SS (pics)
  48. Rear vibration after engine/trans install
  49. got sick of it honestly
  50. vibration when wot in 6th gear
  51. 2001 pontiac firebird water leak
  52. Water in oil pan and oil in exhaust after 5 year nap
  53. Help flushing coolant during H/C/I swap...
  54. How to Grease LCA?
  55. right rear tire noise
  56. 2000 Formula no heat
  57. Water coming into passenger firewall grommet
  58. HELP! LS1 Trans am not starting
  59. sputter vibration in acceleration
  60. Driver headlight stuck, then worked again
  61. Car wont start, strange problem.
  62. Steering wheel not aligned
  63. 2002 Firebird, how long should the gear in a new headlight motor last?
  64. Help with Headlamp adjustment
  65. Intermittent shifter/ignition switch issue
  66. Cant stop the squeal of the belt.
  67. coolant reservoir hose
  68. missfire in cylinder 6 PLEASE HELP!!!
  69. LS7 stalls after crank
  70. Heater Always On
  71. LQ4 oil pressure questions?
  72. cam sensor question.
  73. Check Gauges light on, all gauges reading fine wtf
  74. Pcv valve 12572717
  75. P0102
  76. window track problems
  77. Torque arm clunk?
  78. Need new hood supports
  79. wierd problem.. any help?
  80. What tools i need?
  81. 5.3 Flooded
  82. Intermitten starting Problems
  83. 2000 Trans Am LS1 Idler pulley replacement.
  84. classic industries weatherstrip
  85. p0300 help
  86. I need a part number asap plz
  87. advice on starting up issue
  88. Gas Guage issues 01 Z28
  89. Need help diagnosing
  90. Late model Trans Am squeaks on passenger front side
  91. Window binding
  92. Really annoying!
  93. A bit unconventional
  94. Window Clunking. Video included, name that sound.
  95. 99' Z28 miss and backfire on acceleration What Could I DO?
  96. Possible BCM Issue??
  97. Need help
  98. F-body driver side rack bolt
  99. rear defrost not working
  100. Bosch Spark Plugs???
  101. PS pump Leaking?
  102. Need smaller drive belt what size?
  103. Intermittent no start but cranks
  104. Torn rubber thing by the T-Top separator
  105. Who's tried this weatherstripping fix?
  106. Mass air flow question???
  107. Something wrong?
  108. Washer pump
  109. Engine chugs at 40% throttle.
  110. Car over heating
  111. airbag question
  112. Problem code P0410
  113. Head gasket leak?
  114. Shudder at low iddle
  115. Need help finding a fix thread
  116. Can this be fixed? (Underside frame?) PIC!
  117. vette service active handling issue
  118. P0440 Code Help
  119. Windshield Seal Broken - It's supposed to rain tomorrow!!
  120. Problems w/ my mechanic, opinions wanted what would YOU do in this situation
  121. Loose Steering wheel after header install
  122. 1998 Camaro LS1 rear wheel bearing change
  123. Wheres this oil leak coming from?
  124. Check Gauges Light On???
  125. wont crank- no security light tho
  126. Bad Misfire
  127. vats problem????? wont crank
  128. Moaning/wining all times, worse when clutch depressed.
  129. abs codes
  130. Temperature issues...
  131. How long should a replacement headlight gear last?
  132. I dont know where to start..
  133. LS1 barely runs, unusual circumstances. Need serious wisdom here. Where do I start?
  134. Motor Mounts
  135. VATS Bypassed- Car Still Won't Start. Need Help!
  136. A/C Blower motor fan
  137. Emissions stuff makes my car act weird
  138. Having electrical problems car wont start and cluster dies while driving please help!
  139. OBD 2 coneector not working
  140. Gauge Light Extremely Dim. Help
  141. Help! Serpentine belt seems to be coming off?!
  142. Grinding Brakes
  143. Strange clunk...
  144. ticking noise driving me nuts
  145. What is this noise? (video)
  146. Windshield Wiper motor
  147. Security Light Problem
  148. Hazard Light Problem
  149. Water Pump Leaking From Front
  150. such a strange problem
  151. Side mirror fix
  152. low coolant light
  153. Need help with p0440 code car shakes in idle...
  154. Moisture in fuel
  155. Studder help
  156. turn sigal fuse blows
  157. Can someone point to me where the secondary air pump is
  158. Few problems 98 T.A
  159. 98 camaro won't start, odometer doesn't show anything, and gauges aren't working
  160. Changed thermostat now car won't start, Help?
  161. Help, Car is dying while driving.
  162. Places to look for vaccum leak????
  163. fixed rear torsen unit noise
  164. picked up 1999 firehawk
  165. Error Codes P0155 and P0135
  166. solved p0300 issue with random misfire
  167. Pretty Happy Today, 2 Problems Resolved.....
  168. Another CAR WONT START thread. Please help.
  169. Window regulator problems?
  170. Car wash gone bad
  171. Help with brake line
  172. Squeaking Serpentine
  173. Emissions Help...
  174. Sending unit ohms for 97 Z28
  175. replaced bad alternator and now no charge at all!!!
  176. Catalytic Converter replace Help!
  177. Car won't start randomly
  178. 02 trans am Backfiring and sputtering
  179. interior blower motor noise
  180. Crankshaft position sensor?????
  181. Door hinge creaks
  182. A solution to that major leak you see under your rear floor mats
  183. GMMG banging on floor near axle
  184. 98 Corolla - Brief Stumble at Idle
  185. fuel pressure wont hold
  186. Interior Fan Whining
  187. Pointers on flushing engine and trans
  188. Exhaust hot and jerking
  189. Anyone use a Bosch starter p/n:SR8581N?
  190. Preventive Maintenance
  191. CODE 121 TPS after top end rebuild cant figure it out!!!!!
  192. Hissing noise front passenger wheel well
  193. Hissing Wind Noise from Rear
  194. P0102 code, how do i fix it?
  195. LS6 intake swap, found this.
  196. I need a pic of where to hook the r 134a hose
  197. What's this noise?? (video) Engine knocking!
  198. ls1 rode hard put away wet..what do i check for?
  199. purge valve canister replacement help
  200. Trying to recharge my AC. recharge hose won't fit
  201. Camaro ls1 Running Hot HELP PLEASE
  202. Check engine light
  203. 2002 firebird catilytic converter
  204. Spark plugs
  205. wierd light/electrical problem help!!!!!
  206. inefficient CAT code
  207. Dead leaves blocking wiper drain
  208. oil leak question
  209. Can new O2 sensors improve gas mileage?
  210. 2002 Firebird Winshield fluid
  211. 2002 Pontiac Trans Am carpet replacement
  212. How long to install cam sensor/r&r intake??
  213. Turn on vents, exhaust smell in car?
  214. new fuel pump and now... it only idles?
  215. I keep blowing hyrdo slave cylinders during bleeding....
  216. Power window motors the same?
  217. '97 Firebird throwing service engine light
  218. Cammed 01 Weird Issue... Stumped
  219. Plz HELP!!!!!!!!! Random Misfire code still
  220. Coolant temp sensor
  221. 2002 Firehawk Heat Issue
  222. clutch pedal wont come all the way back up
  223. car won't start
  224. Issue with oil change light coming on...
  225. some kind of electrical issue
  226. Grinding noise 1st to 2nd gear
  227. Oil leak now?!
  228. ECT sensor bad
  229. 4th Gen Bolt and Fastener List
  230. opti sprak grounded out lt1
  231. How to coolant flush
  232. lost all coolant somehow.
  233. Help with stumble
  234. changed spark plugs, now what
  235. Wierd Ticking Noise ws6
  236. Heater core hose assembly fix.........pics
  237. oil light
  238. headlight problem
  239. this is a follow up on the aggravating rear noise posted on 11/13/12
  240. 94 z28 Camaro need help misfiring and back firing
  241. 2000 z28 starter issue
  242. Express Down not working
  243. '99 Z28 - Headlight Switch Replacement Bulb
  244. starter issue in 2000 z28
  245. Heater not blowing hot
  246. camaro z28 99
  247. LS1 Slave cylinder
  248. 02' Squeaky Clutch pedal
  249. help 1998 corvette LS1 engine
  250. Battery recommendations?
