View Full Version : General Maintenance & Repairs
  1. Different starter for 2002?
  2. What is this???
  3. EVAP system expert needed.....
  4. Car "rattles" every-time i drive over uneven ground
  5. loud squealing noise
  6. Studdering (Long)
  7. lower shift boot part #????
  8. Fans Stopped Working
  9. Headlight problem when releasing E-BRAKE
  10. Help!! Noise from the rear-end..
  11. Help,Help
  12. 74K Mile/Winter Maintenance for New Season.
  13. My car bogs down after first ~15 seconds after start up...
  14. nose support
  15. Help T-Top Lock Fix
  16. Oil Pressure- Drops under hard acceleration
  17. P0803 Scan code
  18. Clunk under the car
  19. Fog lights
  20. New prob, bad backfire
  21. Vibration on 02 WS6
  22. 2000 camaro vacuum line diagram
  23. replacing fan shroud
  24. What is wrong with my 2002 Camaro Z28 ?
  25. Ignition switch?
  26. rear bump stops
  27. Drivetrain groaning when turning
  28. Low Coolant Light
  29. Replaced Idler pulley & still squealing and chirping!!!!!
  30. DRL module bad? Let me know what you think!
  31. Long Term Storage - Start Up Time
  32. car goes lean and stumbles
  33. Auto headlight problem
  34. SES light and weird idle
  35. Starting issue:twice EVERY time?
  36. AC and Heat Help!!!!
  37. need new window motorrr quick question
  38. Best way to flush a smell out of A/C
  39. How Long does stock alternator and LS1 coils last?
  40. Temperature Sensor
  41. need a little help
  42. exhaust smell when WOT?
  43. Coolant Temp and Oil Pressure question
  44. Can you replace the bolts in the battery cable?
  45. Rear defroster install, need wiring diagrams for switch
  46. When I run the AC water(not coolant) leaks onto the floorboard 2001 camaro
  47. Read end!! Help!
  48. Car dies after running for a while.
  49. What is this? (vacuum line?)
  50. O2 Sensor or Catalytic Converter?
  51. Hatch won't close.The opposite problem as the other "hatch won't close" thread.
  52. Power steering rack and hoses
  53. Car acting crazy!! Electrical Help!!!!
  54. Misfire, loss of power. Where to go from here?
  55. Intake Backfire
  56. how bad is this?
  57. T-Top Kits?
  58. widow motor out.. but how do you lower window to fix
  59. 2002 window motor
  60. car wont start, no fuel pressure please help
  61. preventing aftermarket intake from sucking in water?!
  62. Speedometer/ rpms shaking while starting
  63. Hatch won't close!!
  64. HELP!!!! Misfire!! HELP!!!
  65. fuse box?
  66. 1997 LT1 radiator swap
  67. Fuel line question
  68. Original Heater Hoses
  69. my steering
  70. help
  71. Need help guys!!!
  72. what usually dies on turn signal switch that kills the brake lights?
  73. AAGH stupid coolant leak! Bad water pump?
  74. transmission dipstick seal where to get one
  75. Pulling to the left?
  76. A/c blows warm + coolant smell in interior?
  77. Weird DRL problem, '00 TA
  78. Complete LS2 Engine Overahaul Gasket Set?
  79. Problem with the DD, ideas?
  80. help!!!!
  81. which of these 3 o2 sensor lengths do I need
  82. ABS INOP & Brake Light On
  83. b4c 2002 camaro
  84. Custom guages help
  85. Iac problems.
  86. Changing out the water pump
  87. AC recharge question, just refill and good to go??
  88. no brake lights?
  89. Blower Fan Issue
  90. oil leak
  91. HELP car won't start
  92. Idle problems
  93. charging issue
  94. Leaking Coolant, all of a sudden!
  95. MOPAR Combustion Chamber Cleaner Alternative
  96. i need some advice
  97. are LT1 and LS1 starters interchangeable?
  98. Moisture in Engine
  99. I've got a problem
  100. Brake lights stuck on please help!
  101. p1635????
  102. voltage problem?
  103. '99 Z28 - Drivers Side Power Window Issue
  104. SES light
  105. brake fluid
  106. weard brake light
  107. LS1 Bogging down and loosing power under load
  108. Water spots under the floor mat
  109. Silly lift question
  110. passenger seat
  111. The One eyed beast =)
  112. Oil Leak?
  113. Best place to get power antenna motor?
  114. windshield replacement
  115. oil pump specs
  116. service vehicle light???
  117. Headlight motor
  118. Z28 revving on its own while in park
  119. Floor board vibration
  120. car starts but something isnt right
  121. Codes but no SES
  122. 95 lt1 not running like it should
  123. rear main seal
  124. ABS,ASR,and brake light
  125. Radiator Help
  126. Help read end swaying... LCA Adjustable bolt pulled out on one end..
  127. cleaning engine block during headgasket fix
  128. check gauges light on for some unknown reason
  129. Headgaskets?
  130. brake install problems
  131. Excitor Wire...
  132. car is goingcrazy
  133. engine problem helppppp
  134. Bloomfield Compressor?
  135. 99" camaro ACDelco Purge Valve? reliable or no
  136. Window rolls up half way and stops ?
  137. Belt chirp/squeal
  138. electrical issue/ exhaust help
  139. 2000 Camaro Brake light and Blinker problem... Help
  140. Trying MCCC!
  141. hands on help with engine mod anyone?
  142. What Alternator Should I Buy For Replacing My OEM Alternator?
  143. Blinkers not working at all
  144. Vibration at 70 (not tire balance issue)
  145. rear wheel grinding noise
  146. Possible Water Pump Leak
  147. puddle on passenger side floor
  148. Safe to drive with bad cats?
  149. radiator
  150. Electric Locks going crazy.
  151. Window Problem
  152. Safe to leave Seafoam in Oil?
  153. Gauge lights went out while driving
  154. wooshing noise..
  155. Rear End Squek - Fixed
  156. Blowing my fuse
  157. Car throwing P0420 code and oil pressure above normal
  158. Coolant Leaking Help
  159. Engine Drop and maintenance
  160. BCM Problems
  161. Walbro 255Lpr Hi-flow Fuel Pump getting loud!
  162. steering wheel becomes VERY loose when you hit a bump.
  163. need help with other issue
  164. Radiator question
  165. AC question
  166. My 2000 WS6 wont start??PLEASE HELP!!!
  167. autozone alternator
  168. Traction Question?
  169. hesitation/bogging
  170. new car/bad leak
  171. someone SOMEONE HELP ON A P0133 CODE
  172. Noise from rear of car
  173. Car wont start!! help please!!
  174. Spark plugs
  175. Drivers Side Door Handle is Wobbly
  176. hesitation when under torque
  177. Vibrations while braking
  178. c5 shift kit
  179. Can someone help me on my wiring?
  180. Sticking Lifter!
  181. look what I found
  182. Iac no. is 0
  183. Vibration
  184. Oil pressure gauge
  185. Oil pressure gauge
  186. window starts clicking at 1 inch before being rolled up
  187. Brake Pedal Squeak
  188. E-Brake cable the same for A4 vs M6?
  189. low volts- bad alt??
  190. AMs OIL???
  191. Blown Fog Lights!!
  192. removing front bumper, scared of airbags deploying...
  193. Car running VERY rich
  194. Replaced 4 tie rods still getting clunking
  195. P0440 Code, need help. Do not know exactly what it means.
  196. gauges reseting...
  197. vacuum leak
  198. help with these codes
  199. SEE light on and flashing!!!!
  200. Grinding noise from rear end
  201. info on getting an old car running again
  202. something weird i cant find an answer to!vid!
  203. Help Removing 1996 TA Trunk Struts
  204. Lighting problems... seems to be random
  205. Squeal help!
  206. I am sure other drivers HATE MY GUTS!
  207. PO 420 help
  208. Turn the ignition, sometimes nothing happens
  209. This is why you do your own work. (Transmission Mount)
  210. Why is my car so loud?
  211. WHAT THE HECK IS THIS? Found In My 2000 Toyota Tundra Oil Pan
  212. Wipers park straight up when off -- work fine otherwise
  213. Rear transmission leak
  214. How do I replace the heater fan?
  215. Codes thrown after injector swap
  216. 2000 SS low rpm hesitation.
  217. Just replaced DRL, bulb is good but it wont turn on??
  218. Alternator & U.D. crank pulley question.
  219. cut wires
  220. recent engine swap, battery dies after a week
  221. A/C belt
  222. Fuel pressure drops after pump primes lines
  223. air only blows hot... vac problem ?
  224. Misfire
  225. Brakes????
  226. Power Steering Leak, HELP
  227. Squeal ONLY at idle
  228. Workin On My Dash, Need Tips
  229. Need help with driver side window
  230. Gutting Cats
  231. Occasional Vibrations During Driving
  232. very weird idle
  233. Car missing/sputtering question?
  234. No Heat at the Floor Vents
  235. need help identifyng a sensor!!!
  236. tune up question
  237. Chirping brakes?
  238. knocking from drivers side front end
  239. Squeaky Suspension
  240. LT1 Mystery Problem
  241. Weird window sound.. not the motor though wth is going on?
  242. Some Random Questions!
  243. Cold startup noise. (Vid)
  244. fuel pump dieing??? help please
  245. Thermostat Q
  246. 2002 rear hatch opening problem
  247. p0102 and p1153
  248. SES Light from Sea Foam?
  249. could engine cleaner ruin my belt?
  250. steering column
