View Full Version : General Maintenance & Repairs
  1. air only blows hot... vac problem ?
  2. Misfire
  3. Brakes????
  4. Power Steering Leak, HELP
  5. Squeal ONLY at idle
  6. Workin On My Dash, Need Tips
  7. Need help with driver side window
  8. Gutting Cats
  9. Occasional Vibrations During Driving
  10. very weird idle
  11. Car missing/sputtering question?
  12. No Heat at the Floor Vents
  13. need help identifyng a sensor!!!
  14. tune up question
  15. Chirping brakes?
  16. knocking from drivers side front end
  17. Squeaky Suspension
  18. LT1 Mystery Problem
  19. Weird window sound.. not the motor though wth is going on?
  20. Some Random Questions!
  21. Cold startup noise. (Vid)
  22. fuel pump dieing??? help please
  23. Thermostat Q
  24. 2002 rear hatch opening problem
  25. p0102 and p1153
  26. SES Light from Sea Foam?
  27. could engine cleaner ruin my belt?
  28. steering column
  29. car problem etc.
  30. bad fuel mileage
  31. 99 TA LS1 wont start, battery charged what to check?
  32. Seat belt buckle plastic trim
  33. Nasty power steering fluid
  34. wont idle!!
  35. Is my ls1 nonfixable?
  36. click/grind coming from back left wheel
  37. Broken ignition?
  38. Clean engine bay?
  39. Power Window Motor ?
  40. Engine stalling and not responding to throttle
  41. surges at idle???
  42. 100k miles
  43. How to test MAF off an 87' IROC camaro?
  44. engine removal question..
  45. OIL sending unit.....how do you remove that sucker..........
  46. Seafoam Deep Creep
  47. Coolant Capacity
  48. Yes, Another Rear Main Seal Thread
  49. Leak at front of vehicle
  50. Water pump help please.
  51. Replaced cats, now vibration?
  52. Whats the fuel line connected into the intake....
  53. need help ,The battery does not charging
  54. timing
  55. Car Shifting Hard
  56. running hot
  57. How hard to replace stock cats?
  58. My car is acting up ;(
  59. Where To Buy Knock Sensors
  60. Powesteering pump overflowing out the top of resivor HELP
  61. Car shut off and won't stay running
  62. Service vehicle, ABS inop
  63. 98 TA, M6, idle issue.
  64. What is my car doing??
  65. Engine Install Question
  66. Problem with the Oil
  67. A/C pressure problem, help me figure this out!!!
  68. dead in the water
  69. Ok so...
  70. Easiest way to check for bad coils........
  71. exhaust/hole in floorboard problem
  72. My 98 camaro 5.7 lit is overheating!!
  73. Gates brand ls1 water pump, anyone tried them???
  74. Dead Battery
  75. What is this hose? (pic attached)
  76. Starter Relay? Second Problem?
  77. engine noise??
  78. weird oil pressure problem
  79. Clutch problems
  80. Overheating Issues
  81. Could this be causing my front end clunking over bumps?
  82. Loud Squeeling Noise
  83. oh my god, not another broken part!
  84. oil change light?
  85. oil leaking from driver side exhaust manifold(Please help i love my baby)
  86. i need your help!
  87. Ants and a leaking spoiler!! Oh my!!
  88. no heat
  89. Electrical issues
  90. Will the fuel line assembly from a 3.8 work for an ls1? Theres one on ebay
  91. Weird Popping sound
  92. bad alternator? I NEED HELP!
  93. P0412!
  94. Tailpipe Expander???
  95. Why is my carpet wet!?
  96. somebody help me! Vacuum leak?!
  97. Trunk wont stay up?
  98. Exhaust brackets
  99. Left side blinker SOLID LIGHT!!
  100. Speedometer Woes
  101. Key stopped working to start car
  102. Got Power steering leak fixed now belt squeal
  103. need a noise diagnosed
  104. Brake Grinding Noise on Left Turns
  105. suspension squeaks alot in cold..
  106. keep blowing PS pumps
  107. ABS LIGHT and/or WHEEL SPEED SENSORS
  108. How to change valve springs?
  109. Trunk rattle?
  110. Radiator leak
  111. pulley problems
  112. loud rattling when WOT engaged
  113. which driveshaft loop??
  114. Car stalls in wet weather!!!!
  115. 4L60E problem
  116. Crappy heat???? Help me out!
  117. LSx Trans Am A/C Vents
  118. Best drive shaft loop
  119. Car running hot
  120. Heads up for anyone doing their MAP sensor
  121. need help with power steering problem...
  122. So I got my SES light code read at Autozone. What is it?
  123. P/S Return Hose Replacement
  124. Auto Trans Problem
  125. Windsheild weather stripping
  126. Looking for brighter replacement headlights.
  127. heater core problems
  128. reputable machine shops in az?
  129. Good Seats
  130. Suggestions on rattling center console
  131. Wiring question..
  132. gas guage inaccuracy
  133. changin oil pan gasket and rear mail seal
  134. No blinking
  135. Need HELP! Keep breaking starters.
  136. can you rethread a battery terminal
  137. Need help asap please!!!!!
  138. Question about the rear end (2002 NHRA TA)
  139. Window won't go down...any ideas?
  140. Dash panel popped up a little bit in the corner
  141. Blown head gasket, any other upgrades or maintence work I can do?
  142. Replacing Catalytic Converter
  143. Stopped leaking...WTF
  144. VATS Problem? Or starter?
  145. truck wont start
  146. what is this!?
  147. No power after starter install
  148. Trunk hatch release problem.
  149. Built 408 misfiring at WOT?
  150. EGR Code P1404--I have questions about EGR Delete and other options!
  151. marble noise when applying brakes
  152. What is this piece called that is missing?
  153. Need a new MAF
  154. High temp rtv sealant for exhaust leak?
  155. Pop! when starting
  156. no fuel psi and no power
  157. Non LS1 question for yall
  158. Car Acting Weird.
  159. Idler pully EXPLOSION
  160. Abs tcs brake light?????
  161. Front right DRL gone bad
  162. what gives? SES light blinking
  163. Squeaking belt/Idler pulley
  164. need window regulator help.
  165. Voltage drop when brakes are applied
  166. Denso Part # 2344025, can I run this for my front 02's?
  167. Dex-Cool or Green Antifreeze?
  168. Driver window is Bustn my Chops!
  169. Dexcool mixed with Antifreeze (green stuff)
  170. Anyone ever rebuilt thier alternator?
  171. Either I have something clogging my oil filter or I'm in serious trouble
  172. Water Leaking
  173. water pump questions
  174. do i need new spark plugs? **PICS**
  175. bought a new BCM.......now what
  176. Oil leak
  177. Idioling/Rpm problem
  178. PS pump issue
  179. Posessed Windshield wipers.
  180. Air conditioning compressor noise
  181. Cold weather fixes instrument lights... coincidence???????
  182. New Alternator??
  183. Another seat question. Help again plz
  184. Gas Pedal Sticks at 1/8th Pedal
  185. Car wont start and now the odometer wont display anything
  186. Top dead center
  187. Squeaky Hatch-Repair the hatch?
  188. How to take apart T-Tops? Due to Noise!!
  189. Seat problem. Help me plz!
  190. do this when taking car to the shop if you care!
  191. Loose Drivers Side Window!
  192. SS hood struts vs. z28 hood struts
  193. 'TCS Off' light comes on randomly
  194. dont know whats going on....
  195. Someone pleeeeease help me figure out this problem!
  196. v6 to LS1 swap...need help!
  197. 1998 Pontiac Firebird Check gages light.
  198. Starter relay going bad
  199. Car Jerking at cruising speed/ around 80mph
  200. unusual rev/crappy idle
  201. fog light help
  202. No code
  203. Driveshaft hitting bottom of car.
  204. Screeching brakes
  205. Window Motor Equal Voltage Mod
  206. Winter storeage opinions....
  207. Started, heard 3 dings, died, now nothing. ?
  208. Headlight Issue
  209. A4 guys
  210. only when its cold
  211. p0446??
  212. rebuilding an alternator? how much?$$
  213. Help! working on the car right now!
  214. Bought a fuel pump but never seen a in-line hose like this...
  215. A/C Suggestion didn't work
  216. time for new plugs!
  217. ignition stuck
  218. Strange build up
  219. Cant find gaskets
  220. Water getting into trunk?!?! WTF!!!
  221. Something is broke..
  222. Crraaappp
  223. window motors
  224. 02s not ready
  225. Wiper problem
  226. an air conditioning issue
  227. Recommended Power Steering Fluid
  228. Vacuum Line
  229. GTO Vibration issues
  230. p0300 and p0412
  231. Car squeals from belt area whenever cold
  232. Starting problem
  233. where to buy caliper slides only?
  234. HORRIBLE issue with t/a and the rain.
  235. A/c
  236. Ticking
  237. problem with reverse?
  238. ac problems please help someone!!!!!!
  239. headlight adjuster
  240. Struggling Upon Acceleration
  241. What's wrong?
  242. cruise control not working
  243. Bad bushings maybe?
  244. Gas pump shutting off while filling up?
  245. electrical issue
  246. no spark no fuel pressure
  247. Catalytic Converter advice
  248. Tail Light Harness (Camaro vs Firebird - LT1)
  249. Cheap way to fix your blinker issues.
  250. All you LT1 wizards....I need some advice on a rack and pinion
