View Full Version : General Maintenance & Repairs
  1. Question about the rear end (2002 NHRA TA)
  2. Window won't go down...any ideas?
  3. Dash panel popped up a little bit in the corner
  4. Blown head gasket, any other upgrades or maintence work I can do?
  5. Replacing Catalytic Converter
  6. Stopped leaking...WTF
  7. VATS Problem? Or starter?
  8. truck wont start
  9. what is this!?
  10. No power after starter install
  11. Trunk hatch release problem.
  12. Built 408 misfiring at WOT?
  13. EGR Code P1404--I have questions about EGR Delete and other options!
  14. marble noise when applying brakes
  15. What is this piece called that is missing?
  16. Need a new MAF
  17. High temp rtv sealant for exhaust leak?
  18. Pop! when starting
  19. no fuel psi and no power
  20. Non LS1 question for yall
  21. Car Acting Weird.
  22. Idler pully EXPLOSION
  23. Abs tcs brake light?????
  24. Front right DRL gone bad
  25. what gives? SES light blinking
  26. Squeaking belt/Idler pulley
  27. need window regulator help.
  28. Voltage drop when brakes are applied
  29. Denso Part # 2344025, can I run this for my front 02's?
  30. Dex-Cool or Green Antifreeze?
  31. Driver window is Bustn my Chops!
  32. Dexcool mixed with Antifreeze (green stuff)
  33. Anyone ever rebuilt thier alternator?
  34. Either I have something clogging my oil filter or I'm in serious trouble
  35. Water Leaking
  36. water pump questions
  37. do i need new spark plugs? **PICS**
  38. bought a new BCM.......now what
  39. Oil leak
  40. Idioling/Rpm problem
  41. PS pump issue
  42. Posessed Windshield wipers.
  43. Air conditioning compressor noise
  44. Cold weather fixes instrument lights... coincidence???????
  45. New Alternator??
  46. Another seat question. Help again plz
  47. Gas Pedal Sticks at 1/8th Pedal
  48. Car wont start and now the odometer wont display anything
  49. Top dead center
  50. Squeaky Hatch-Repair the hatch?
  51. How to take apart T-Tops? Due to Noise!!
  52. Seat problem. Help me plz!
  53. do this when taking car to the shop if you care!
  54. Loose Drivers Side Window!
  55. SS hood struts vs. z28 hood struts
  56. 'TCS Off' light comes on randomly
  57. dont know whats going on....
  58. Someone pleeeeease help me figure out this problem!
  59. v6 to LS1 swap...need help!
  60. 1998 Pontiac Firebird Check gages light.
  61. Starter relay going bad
  62. Car Jerking at cruising speed/ around 80mph
  63. unusual rev/crappy idle
  64. fog light help
  65. No code
  66. Driveshaft hitting bottom of car.
  67. Screeching brakes
  68. Window Motor Equal Voltage Mod
  69. Winter storeage opinions....
  70. Started, heard 3 dings, died, now nothing. ?
  71. Headlight Issue
  72. A4 guys
  73. only when its cold
  74. p0446??
  75. rebuilding an alternator? how much?$$
  76. Help! working on the car right now!
  77. Bought a fuel pump but never seen a in-line hose like this...
  78. A/C Suggestion didn't work
  79. time for new plugs!
  80. ignition stuck
  81. Strange build up
  82. Cant find gaskets
  83. Water getting into trunk?!?! WTF!!!
  84. Something is broke..
  85. Crraaappp
  86. window motors
  87. 02s not ready
  88. Wiper problem
  89. an air conditioning issue
  90. Recommended Power Steering Fluid
  91. Vacuum Line
  92. GTO Vibration issues
  93. p0300 and p0412
  94. Car squeals from belt area whenever cold
  95. Starting problem
  96. where to buy caliper slides only?
  97. HORRIBLE issue with t/a and the rain.
  98. A/c
  99. Ticking
  100. problem with reverse?
  101. ac problems please help someone!!!!!!
  102. headlight adjuster
  103. Struggling Upon Acceleration
  104. What's wrong?
  105. cruise control not working
  106. Bad bushings maybe?
  107. Gas pump shutting off while filling up?
  108. electrical issue
  109. no spark no fuel pressure
  110. Catalytic Converter advice
  111. Tail Light Harness (Camaro vs Firebird - LT1)
  112. Cheap way to fix your blinker issues.
  113. All you LT1 wizards....I need some advice on a rack and pinion
  114. optima battery tender?
  115. What to do
  116. Need help with 03 Bu.
  117. shifter problems
  118. Bad wheel bearing?
  119. pcv connection that goes into valve cover
  120. 02 sensor wiring help pleas!!
  121. Vibration at 70 mph, not consistant....
  122. Help! Car shakes at certain speeds
  123. Battery
  124. loud knocking coming from rear?
  125. Skip Shift Dash Light
  126. What is this part?
  127. P1071 & P1074 codes came up
  128. engine shakes just above
  129. Bad stutter, back fire..after header install
  130. coolant not draining????
  131. What to do?
  132. Help..Can't remove key, steering wheel / shifter won't lock.
  133. Spark Plug Wires for LQ4
  134. Power Steering Went Out D:
  135. Leak from the unknown
  136. Passenger headlights and single lights not working
  137. Squealing rattle noise coming from driver's side rear
  138. Having a problem with a 2nd gen iroc-z
  139. Check engine codes
  140. What are these wires?
  141. Please automotive masters I need your help"
  142. Painting Center Console Bezel To correct OEM Color
  143. Vats problem! Help!
  144. boging
  145. WS6 power steering cooler
  146. Washer Fluid Leak?
  147. Eletrical problems - Need your help!!
  148. Issue with rear defogger/seats
  149. wabbly unstable car at 55+mph
  150. Center Console Bezel Removal
  151. Help me out going to look at another firebird!
  152. Drivetrain Buckling?
  153. vacume leak
  154. Starter going out
  155. Heater core
  156. Does differential fluid smell linger??
  157. Scary Clicking Sounds w/ Performance Issues
  158. For those car stored with a BATTERY TENDER, come on in...
  159. Need help sealing firewall around a cable....
  160. car lugs when cruising in gear
  161. oil pan gasket
  162. Changing the power steering pump
  163. Getting Foreign objects out of the bellhousing.
  164. STARTER question for anyone........
  165. o2 sensor readings
  166. car wont turn over, lights are one and fuel pump primes fine.WTF
  167. A/c problem
  168. E-brake switch location?
  169. Where to buy new side view mirror glass?
  170. Car Cranks but wont start......
  171. 2000 Trans Am LS1 Stalls then Dies after WOT
  172. Oil Change Interval on Infrequently Driven Cars
  173. Blue heligon head light
  174. What does code P0430 mean?
  175. Front tires skip when in reverse
  176. Cold idle problem on a mazda tribute v6
  177. It Started! Then died... What happened? PLEASE HELP!
  178. Radio cuts off and windows wont work after
  179. P0356? Igniton coil #6
  180. No DRL's ?
  181. my lights flicker when i give the car gas
  182. Got gas now no crank....
  183. Problem with wheel shaking
  184. Help LT4 wont run!!!!
  185. power steering leak...common areas of failure??
  186. is the IAC valve supposed to have an o-ring?
  187. running like crap continues
  188. security light??
  189. Seafoam froze or shorted my fuel pump
  190. Guys who store your cars come in!!
  191. PWR Steering Cap - Question
  192. Tuning her up soon.
  193. T-top and door gasket sqweaks--
  194. Front Oil leak
  195. Heat Shield Vibration
  196. turn signal/ DRL bulb..
  197. A4 Shifter
  198. Hmm, pulled the carpet, what are all these?
  199. no front drl or turn.
  200. Exaust Question
  201. Headlight Problem - not the usual kind
  202. A couple power steering rack questions...
  203. EGT's on my 02 Camaro SS
  204. having brake issues
  205. 01 Camaro V6 running rough
  206. Stock valve covers/ 5.3L Heads
  207. Damn dash cracked today
  208. Hatch release
  209. Engine randomly cranks without firing
  210. Daily Driver Help!!!!!!
  211. map light (and dome light) wont turn off
  212. E-Brake light wont come on!
  213. All knowing peeps...and those who can do more reseach than me, please come in. (IDLE)
  214. checking for worn suspension components
  215. power steering issues
  216. Steering clunk
  217. this is a chassis question
  218. Courtesy Lights?
  219. poor idle
  220. 98-02 Camaro Borla Adjustable Plates
  221. bad stutter
  222. Squeaks coming from my passenger front wheel....
  223. HElp with this plastic clip, should i be safe?
  224. K&N Filter Cleaner and Oil
  225. Restartin Camaro project been sittin in garage for year
  226. oil pressure gauge dops to 0 when im braking
  227. lt1 sucks air
  228. How you take off windshield wiper arms?
  229. Stripped torx bit
  230. ABS INHOP and BRAKE light
  231. 3M fuel system treatment
  232. E-Brake "BRAKE" Light Stays On
  233. Cat getting plugged
  234. Do I need the little plastic piece in front of the ac condensor?
  235. Weather Stripping....
  236. Which battery is best for my specific needs?
  237. Headlight Issue
  238. bad front end shaking
  239. Re-location Brackets - Worth It?
  240. SES codes P0171 P0174 P0161
  241. idle
  242. Car shakes and lacks power randomly
  243. Hatch release
  244. Help! My wheels are all locked up and im stuck! Think its abs? Master cylinder? Etc.?
  245. 2000 C5 balancer or idler pulley?
  246. Okay really strange sounds. please read...
  247. will a 93 z28 fuel pump work in a 97 camaro 3.8?
  248. 99 Z28 dies immediately after firing
  249. Need your help! Clunking sound
  250. LM Performance Water Pump
