View Full Version : General Maintenance & Repairs
  1. maintainance for a Camaro ss at 100,000!!!
  2. general question
  3. Clean K&N Air Filter
  4. Doing clutc. Should I Replace Rear Main Seal?
  5. Front Passenger Side Brake Fluid Leak Between Line and Caliper...
  6. motor mount/k-member help
  7. Hatch Rattles Over Every Little Crack ???
  8. A/C problem!! QUICK HELP PLEASE
  9. burning oil smell after stop and go traffic
  10. High revs at start
  11. Cats below threshold?
  12. LS1 Questions + concerns :(
  13. Car won't start
  14. Motor mount replacement ?
  15. blinker light help..
  16. bypassing clutch cycling switch?
  17. Rebuilt motor, cant make good power
  18. A/c blows cold, then stops! WTF?!?!
  19. Got a confusing problem on my hands
  20. IAC sensor
  21. Oil Pressure sensor tool
  22. AC top/main vents wont blow air
  23. No oil in the car? please help
  24. more heating problems
  25. Car stutters at WOT...why?
  26. AC Problems
  27. Drive Shaft U-joints bad?
  28. help i think rearend or brake problems
  29. Cost of replacing lifters?
  30. Air Vents will only blow hot air
  31. Help! Battery or ?
  32. A/C compressors and dryer question
  33. Whats the problem ?
  34. Relay
  35. Shift Boot?
  36. alternator issues in 01' LS1!!!!!
  37. Remvong striped alan head...
  38. window goes opposite
  39. Grinding noise coming from power steering pump
  40. Leak
  41. how do you change trans am headlight bulbs, need help never done it
  42. anyone familiar with chevy 4.8
  43. low beams out...
  44. Torn Seat - Repair Kit
  45. Vacuum Hoses Question
  46. Air Bag Clock Spring
  47. Power Steering Pump?
  48. Wiper Misc. Issues
  49. changing PS pump, advices are welcome!
  50. Bad vibration from 80-110
  51. WTF My Low beam wont turn on??
  52. Power Delay( Inside car )
  53. my suspension is squeeking please help
  54. Electrical problem. TPS IAC I don't know.
  55. Tranny Seal
  56. Hydrocarbon way too high
  57. Crazy bent pushrod need some advice.......
  58. ok so im a little overdue on my oil change woops!...
  59. HELP.Whats This Knocking Sound (Video)
  60. Battery tests good, but no current to starter or interior
  61. would WOT brake my A/C
  62. I cant open my hood
  63. Front Seals are spunt ;.;
  64. I need help on my car?
  65. Did my dealership sabotage my trans-am?
  66. Engine loping/misfiring, lost power, stuttering. HELP please.
  67. How important is the Tunnel Brace?
  68. Bad PS pump or pulley?
  69. 1992 Firebird Gas Fumes
  70. Vats Key
  71. Radiator Fan Motor(s)
  72. Driver's side clunk..?
  73. Passenger side oil leak
  74. new A/C compressor replacement?
  75. Spark Plug replacement
  76. Truck won't start...WTF
  77. New problem...
  78. head gasket kit?
  79. Heater hose rant
  80. Books for Working on Car (not lsx related)
  81. Year One Battery Strap
  82. Another A/c Problem
  83. Can anyone tell me what the hell this tick is?
  84. Oil Pressure guage bouncing and shaking?
  85. continuing headlight issue (read stickies/searched everything)
  86. blower motor door problem
  87. is this good deal for labor ?
  88. New Waterpump installed: Do I need a tune?
  89. Running temp
  90. Steerting Wobble at highway speeds
  91. Cant get clutch return spring in!!!
  92. How do you
  93. what do you think
  94. Squeaking noise from engine when i accelerate??
  95. Lt1 service engine light coming on
  96. Car dies on highway
  97. Replace Alternator
  98. Help me please! Car won't start!
  99. ?? Anyone know of a lightweight windshield for 98-02 camaros ??
  100. Window motor issue
  101. Rear Taillight housing
  102. A/C problem... need help!
  103. This car is haunted
  104. Why does my temp keep changing to XXX?
  105. i need help
  106. auto steering column in stick car.will it work?
  107. Why does my battery keep going dead?
  108. A/C Question
  109. Looking for a dealer parts guy
  110. Car won't crank over..
  111. Rear main seal?
  112. question about convertable tops
  113. oil leak?
  114. pulse board GRRRRRRRR
  115. What is causing this?
  116. Brakes R bled. Pedal still goes to the floor...wtf??
  117. How to: T-Top lock swap
  118. shudders and shakes
  119. Alternator problems
  120. TSB 05513 letter?
  121. hvac fans??
  122. battery wiped! new battery wiped out too, and NEW alternator wont charge
  123. AC clutch clicking like crazy
  124. Won't start
  125. Superchips Cortex programmer?
  126. Tail lights and park lights wont come on?
  127. My mesh grill fell off my firehawk hood...
  128. Security light keeps coming on
  129. Squeak in Passenger side Seat
  130. Removing Fog Light Housing
  131. Cleaning your alternator?
  132. Oil leak
  133. Where to find gasket?
  134. SES P0118 Engine Coolant Temperature [ECT] Sensor Circuit High Voltage..?
  135. PITA Idle problem & Oil Pressure problem
  136. Starter chatter
  137. Clutch return Bushing #'s?Dealership cant figure it out
  138. Car died while driving, won't start.
  139. Coolant flush without engine running
  140. Hvac vents not switching??
  141. 3rd Brake Light Is on
  142. Every now and then car dies but cranks back...
  143. window motor keeps burning up wtf??
  144. car dies when I give it throttle
  145. Service Engine light on, Pep boys code 1193, Air/fuel regulator?
  146. Intake manifold bolt
  147. low idle help!
  148. T/A doesn't rev past 4500 rpms in 1st & 2nd Gear
  149. bad rear main seal??
  150. Bad Cats or O2 sensor?
  151. Brights turn themselves off
  152. speedometer is dead
  153. Car RPM zero and then working again
  154. 99 SS need a how to replace alternator thread PLEASE!
  155. Reverse Light Gasket
  156. Seat belt bracket off of the headrest broke!
  157. 1996 Formula 6-speed, wont run is 2,3,4,5,or 6th gear
  158. Noise and smell coming from engine
  159. reman alternators
  160. Losing coolant but no smoke
  161. rough and hunting closed loop idle
  162. Why is my car overheating?
  163. Complete DIY's on starting, charging, engines, trannys, etc.
  164. A/c recharge
  165. What are these bolts for???
  166. Clunking noise in reverse!!
  167. compression test
  168. oil presure switch
  169. Timing question
  170. Oil in exhaust
  171. blinker/drl issue! help please
  172. A/C blower motor issue: loss of air volume
  173. Fuel Filter, Which one do you use?
  174. How to Remove Seatback Plastic Knob?
  175. high beam switch...replaceing it?
  176. Dim headlights and no brights?
  177. A/C compressor??
  178. Oil Leak.
  179. Going down the check list...??
  180. another dumb question...how to open the petcock on radiator?
  181. #2 and #7 cylinders are misfiring
  182. Installed A/C...can NOT get compressor to kick on...
  183. how to take out seat belt ?
  184. A/C experts, freon/ oil question
  185. Free Diagnosis?!
  186. Burned out bulb in Dash.
  187. Whats That Whistle???
  188. Problems with coil #7
  189. who sells after market oil pressure gauge for fbody?
  190. Driver's window
  191. Breaks up when its cold but it fine after it is warmed up
  192. High Idle Problem
  193. gas pedal not responding
  194. How to change out side marker bulb ?
  195. Dealer doesn't know!
  196. What is normal load on alt. with all accessories on?
  197. My Camaro hesitates and looses power
  198. Low coolant and low oil lights
  199. low oil
  200. Need some advice
  201. Coincidence,vats , tuning other problem with car starting and dieing sometimes
  202. Car is shuddering in low rpms.
  203. Hey anyone have a link to the autotrix window mod
  204. Not a chev but i need help on the work truck
  205. Damn knock sensors, keep getting code.
  206. Parking brake handle rattle?
  207. Factory "air pump" on F-Body's............
  208. No turn signals! Help!
  209. Car hits "early" rev limiter?
  210. engine wants to die, after stepping on it
  211. Both Banks Lean.. Generator L Terminal Circiut, Random Multiple Misfire
  212. Any ideas what may have happened?
  213. What stops the fuel from coming for a filter change.
  214. Damn Voltage issue.
  215. Spare key with VATS??
  216. what do u guys have
  217. Front turning lamp sockets...
  218. A/C problems...
  219. Cooling Issue
  220. eng cooling fan problems
  221. Ok need some help!!
  222. Idle Gremlins...
  223. What is a P1415 code?
  224. No driver side cooling fan
  225. car studdering at low rpm
  226. s-10 manual steering box lube?
  227. Replacing hatch glass and door windows
  228. Chittering sound coming from rear
  229. knocking/clunking sound from front of car.
  230. o2 sensor question
  231. coolant on the ac compressor???
  232. Coolant/Radiator Question
  233. Rear view mirror
  234. Turn Signal issue can find a fix
  235. Please help, not an LSX ?
  236. New PCV experiment......
  237. how to check voltage to coil packs
  238. how check voltage to coil packs
  239. out the top,
  240. 99 SS vacuum leak help!!!!!!
  241. Auto Zone window motor users, step in please!
  242. Fuel pressure problem. need help!!
  243. lower ball joints which way to press them?
  244. 98 ta ws6,spun bearing 5.7,anyone know how swap for a lq4 6.0?
  245. drove through water now car is overcharging
  246. Temp needle jumpy and no fans?
  247. EGR question
  248. lifter noise
  249. Some newbie questions
  250. P0103. Unplugged MAF, no difference. Is it bad?
