View Full Version : General Maintenance & Repairs
  1. Stealership wants $100+
  2. Starting problem???
  3. TCS problem
  4. water leak
  5. fixed my problem but need a part #
  6. Alarm Problem
  7. Missed a shift bad, freaking out.
  8. this a fuel pump problem??
  9. So I'm switching from r/p to mobil one.
  10. radiator help???
  11. Driver side window...
  12. Charging system issues: Car keeps dieing
  13. i'm flushing my complete a/c system and installing a new compressor and
  14. DRL problem - searched
  15. gas smell inside car, recently replaced opti n knock sen.
  16. Octane questions...
  17. coolant senser problem
  18. High idle problem
  19. Strange Cat Problem
  20. Park Brake Cable Adjustment
  21. need help one wire lt1
  22. 2001 TA M6 no crank, no start, cd player installed, help!
  23. Really Confused? Intake Manifold filled with water
  24. 96 T/A fans dont kick on. Only with AC on.
  25. F**K Power steering
  26. WS6 headlight issue (not gears)
  27. Cutting Out at High RPM.....weird one
  28. a/c trouble....
  29. Help resetting computer system
  30. Ls6 Intake
  31. Steering question
  32. Sluggish in lower RPMS after shifting
  33. can you guys help me out with this? 350ci
  34. Which Alternator to Get...
  35. ls1 to lt1
  36. Spark Plug Question
  37. After headers and ORY car is F'ed!!!
  38. Rattle from front of dash/engine compartment
  39. car barely starts then revs up
  40. Which fuse/relay controls the interior dome/rearview mirror lights?
  41. Hood wont open!!
  42. losing power
  43. Long Storage Time
  44. rear end chatter
  45. not your ordinary headlight problem
  46. Help, major smog problems!!!
  47. 2000 Z28 Preemptive Replacement
  48. Change Your Swaybar Endlinks
  49. Installing a front parking light bulb
  50. installing a front parking light bulb
  51. LT1 Belt tensioner replacement
  52. oil?
  53. Where to buy?
  54. where to buy good or stock o2 sensors ?
  55. Hatchback Struts
  56. need help with ac!
  57. Low oil Light?
  58. lt1..Low rpm bogg/buck...running rich..multiple cylinder missfire..PLEASE HELP
  59. Time for a new fuel pump. Which one is the best?
  60. help
  61. Fbody windsheilds Interchangeable.
  62. Clicking/clunking noise that increases with speed?
  63. window molding
  64. Hooker LT1 Cat-Back Exhaust System 1995-97 16825
  65. Hard to turn on high-beams. Have to pull the stick back hard!
  66. GM Repair Manual
  67. Camaro throwing code P0332?
  68. What Brand of oil, what weight, and filter shoud i use????
  69. trouble code help
  70. Rotor mess?
  71. how low?
  72. white smoke, random misfire?! no chk lights
  73. Vibration and rattling when engine braking...
  74. Check engine?
  75. Can you solve this blinker woe?
  76. help
  77. ABS/TCS off
  78. please help. i stomp on the gas and car doesnt go
  79. 94 Z28 randomly cuts out
  80. gauge problems after cluster swap
  81. Auburn or Torsen rear?
  82. When to change fuel filter?
  83. wet Crank postion sensor?
  84. Car is Stumbling at low rpm, seems like 4cyl, Help !!
  85. Scraping-squeak - Ideas appreciated!
  86. DAMMIT!!!!!! My car is messed up and i'm pissed
  87. EGR valve?
  88. Alternator
  89. radiator hose connections help
  90. easy fix for brights?
  91. Window Motor HELP
  92. Help quick after seafoam!!!!
  93. my wheels sound like a sprinkler
  94. Service engine soon light and trouble codes...
  95. Camaro Battery Tray
  96. WTF is wrong here?! im confused
  97. Power steering pulley loose?
  98. Voltage problem.
  99. Low Voltage in all 4 o2s?
  100. any pics of lift points on camaro
  101. HELP ASAP!!! Oil Pressure Sending Unit
  102. D.R.T...Done Right There. Help please!
  103. 2k RPM until the car stop at a light
  104. Problem
  105. Skip shift and security light either one
  106. The one thing that pisses me off about fbodys
  107. Power Loss - 01 WS6
  108. Stock Motor Knocking?
  109. Those with Red Top Optima Batteries, Come In!
  110. Dealer sell me wrong plugs? 41-110
  111. squeaking?
  112. Headlights keep blowing
  113. Weird Popping
  114. cooling system issues
  115. Burning oil?
  116. Broken window...not the motor.
  117. Radiator help
  118. Best Alternator
  119. Remove Stock Heat Shield On Hood?
  120. Trans Am Head lights
  121. Fuel Pressure Gauge Concerns
  122. Engine Lugging in 4th Gear at Low RPM
  123. After LTs and ORY install...
  124. Power Steering Problems Stacking Up
  125. Bright lights dont work
  126. What Tool Do I Need Block Plug???
  127. Where to get tail light sockets?
  128. another exhaust vibration question?
  129. Security light ON?
  130. New Power Steering Pump?
  131. first startup issues
  132. Spark from ground wire
  133. Stock Exhaust Vibration?
  134. 2000 Z28 groaning sound in reverse!!!
  135. One crazy SES light...
  136. Missing bushing on the rear end?
  137. Tach wiring question
  138. DRL module bad?
  139. dbw problems tps percentage is 20 at idle.
  140. Iacv
  141. over heating problems
  142. Has this Happened to anyone before?
  143. what oil came in our cars from the factory
  144. Cant find signal flasher....
  145. Shift light problems
  146. Need help asap!
  147. Need you alls help !!!!
  148. A new radiator ls1 or lt1
  149. VATS help/lost keys
  150. T-Top Water Leak
  151. please help with knock retard.
  152. Headlights kill dashlights-wtf?
  153. thermostat area leak ?
  154. A/C cabin control question....fan motor resistors
  155. My arm does not between the bumper and the windsheild wiper fluid tank?
  156. Power Steering Leak
  157. ABS light and traction control Light .
  158. Question about Head Bolts
  159. Fuse box question
  160. engine vs gear vs diff vs water vs xxx coolers
  161. Whining on Cold Start, AIR pump?
  162. Popping under acceleration after bolt-ons
  163. Coolant Capacity?
  164. Wheel sensors
  165. Stupid Overheating problem, op needed
  166. is burn out hurt your car ?
  167. Help replacing window lock switch panel
  168. Fuel Pump Bad? Please Help..
  169. Bad Wheel hub vs. Bad ball joint
  170. Window guide broke...
  171. LT/ORY pics
  172. Zirgo fans??
  173. Driverside Door Issues
  174. Spring Mount!?
  175. need help 95 lt1 firebird 5.7
  176. Speedo issue?
  177. steering column
  178. Headlight from hell!
  179. P0122 Throttle Position Sensor/Switch A Circuit Low Input
  180. Rack and pinion leak
  181. horn?
  182. Grind on take off.
  183. vent tube? pic inside
  184. Digital Odometer & Tripodometer Not Working
  185. SES Diag/Symptoms Please
  186. NEW A/C Compressor
  187. Anything work as good as berkebile 2+2 gum cutter but cheaper?
  188. Throwing Codes (2000WS6)
  189. 2 Cycle Oil in My Gasoline? WTF?
  190. Random Misfiring Oil Fouled Plug Two SES Codes
  191. Giving the car I purchased the once over, and here is what I found. Questions inside.
  192. A/C compressor violently vented freon to atmosphere
  193. Could anyone tell me what the name of this part is???
  194. Opps! What is this?
  195. camaro front brake caliper question
  196. our window motors sux balls!!!!!!
  197. Possessed Firehawk: revisited!
  198. what weight
  199. Firebird Flip Up Lights
  200. clunking t56
  201. Help! My Camaro Won't Start!!!!!!!!!
  202. Water pump gasket question
  203. How to access front turn signal bulb?
  204. battery (lightweight)
  205. Anyone have Progressive Direct and had a windshield replaced in no fault glass state?
  206. help plz
  207. Rattling noise when accelerating at higher rpm - H/C LS1 '69 Camaro
  208. Unusual window motor failure
  209. Gear Pin bolt rounded off. How to get it out???
  210. Pic of MAF
  211. Cam sensor falure,ecu failure..some other questions.
  212. Serious Problem
  213. Oil leak gone bad
  214. Instrument cluster lights not working! isnt the fuse
  215. Changed Coolant....Funny Temp Problem
  216. LS3 damper
  217. gauge lights not working 98 T/A
  218. Car left in parking lot wont start
  219. chirping/squeaking
  220. A/C compressor oil
  221. Turn signal won't cancel, it's not the spring
  222. Help ASAP!!
  223. Mysterious Problem, Help me try to find it.
  224. Vats bypass resistor
  225. Slapping / Ticking engine noise? with sound clip
  226. Having no luck with tail lights....
  227. Help!!!
  228. clunking or banging noise under car
  229. Missed a shift and now car misfires
  230. P0171 and P0174 codes... Could it be the fuel pump?!?
  231. Power Window problem on 2001 Z28
  232. speedometer
  233. whining
  234. ticking noise sometimes
  235. airbag sencer
  236. I got another code!
  237. Weird Smell (lol)
  238. 01 Camaro Driver Side Power Window Problem
  239. Headlight problem
  240. Help on changine passenger side AIR check valve.
  241. major tune up
  242. Turn Signal Problem?
  243. Map sensor
  244. Backfire on start up...wtf over!?
  245. bad cat?
  246. Write up: How to make your own passenger window fix!
  247. Throwing codes (2002 SS)
  248. Headlight Issue
  249. Radio & Windows Losing Power
  250. ses light clutch switch?
