View Full Version : General Maintenance & Repairs
  1. Need help asap!
  2. Need you alls help !!!!
  3. A new radiator ls1 or lt1
  4. VATS help/lost keys
  5. T-Top Water Leak
  6. please help with knock retard.
  7. Headlights kill dashlights-wtf?
  8. thermostat area leak ?
  9. A/C cabin control question....fan motor resistors
  10. My arm does not between the bumper and the windsheild wiper fluid tank?
  11. Power Steering Leak
  12. ABS light and traction control Light .
  13. Question about Head Bolts
  14. Fuse box question
  15. engine vs gear vs diff vs water vs xxx coolers
  16. Whining on Cold Start, AIR pump?
  17. Popping under acceleration after bolt-ons
  18. Coolant Capacity?
  19. Wheel sensors
  20. Stupid Overheating problem, op needed
  21. is burn out hurt your car ?
  22. Help replacing window lock switch panel
  23. Fuel Pump Bad? Please Help..
  24. Bad Wheel hub vs. Bad ball joint
  25. Window guide broke...
  26. LT/ORY pics
  27. Zirgo fans??
  28. Driverside Door Issues
  29. Spring Mount!?
  30. need help 95 lt1 firebird 5.7
  31. Speedo issue?
  32. steering column
  33. Headlight from hell!
  34. P0122 Throttle Position Sensor/Switch A Circuit Low Input
  35. Rack and pinion leak
  36. horn?
  37. Grind on take off.
  38. vent tube? pic inside
  39. Digital Odometer & Tripodometer Not Working
  40. SES Diag/Symptoms Please
  41. NEW A/C Compressor
  42. Anything work as good as berkebile 2+2 gum cutter but cheaper?
  43. Throwing Codes (2000WS6)
  44. 2 Cycle Oil in My Gasoline? WTF?
  45. Random Misfiring Oil Fouled Plug Two SES Codes
  46. Giving the car I purchased the once over, and here is what I found. Questions inside.
  47. A/C compressor violently vented freon to atmosphere
  48. Could anyone tell me what the name of this part is???
  49. Opps! What is this?
  50. camaro front brake caliper question
  51. our window motors sux balls!!!!!!
  52. Possessed Firehawk: revisited!
  53. what weight
  54. Firebird Flip Up Lights
  55. clunking t56
  56. Help! My Camaro Won't Start!!!!!!!!!
  57. Water pump gasket question
  58. How to access front turn signal bulb?
  59. battery (lightweight)
  60. Anyone have Progressive Direct and had a windshield replaced in no fault glass state?
  61. help plz
  62. Rattling noise when accelerating at higher rpm - H/C LS1 '69 Camaro
  63. Unusual window motor failure
  64. Gear Pin bolt rounded off. How to get it out???
  65. Pic of MAF
  66. Cam sensor falure,ecu failure..some other questions.
  67. Serious Problem
  68. Oil leak gone bad
  69. Instrument cluster lights not working! isnt the fuse
  70. Changed Coolant....Funny Temp Problem
  71. LS3 damper
  72. gauge lights not working 98 T/A
  73. Car left in parking lot wont start
  74. chirping/squeaking
  75. A/C compressor oil
  76. Turn signal won't cancel, it's not the spring
  77. Help ASAP!!
  78. Mysterious Problem, Help me try to find it.
  79. Vats bypass resistor
  80. Slapping / Ticking engine noise? with sound clip
  81. Having no luck with tail lights....
  82. Help!!!
  83. clunking or banging noise under car
  84. Missed a shift and now car misfires
  85. P0171 and P0174 codes... Could it be the fuel pump?!?
  86. Power Window problem on 2001 Z28
  87. speedometer
  88. whining
  89. ticking noise sometimes
  90. airbag sencer
  91. I got another code!
  92. Weird Smell (lol)
  93. 01 Camaro Driver Side Power Window Problem
  94. Headlight problem
  95. Help on changine passenger side AIR check valve.
  96. major tune up
  97. Turn Signal Problem?
  98. Map sensor
  99. Backfire on start up...wtf over!?
  100. bad cat?
  101. Write up: How to make your own passenger window fix!
  102. Throwing codes (2002 SS)
  103. Headlight Issue
  104. Radio & Windows Losing Power
  105. ses light clutch switch?
  106. Blown Head gasket????
  107. Car stumbles
  108. LOL changed widow motor and now.......
  109. cam sensor
  110. Oil Pan gasket MINUS trans
  111. firebird lifting/jacking points???????
  112. Car starts but dies shortly after... Help please
  113. throwing code for high idle, 1600rpm in neutral?
  114. Replaced trans mount and...
  115. need help
  116. just did a couple of WOT runs..now oil on waterpump and belt?!?!
  117. What is causing surge?
  118. Only misfires when its raining or wet out. WTF!!
  119. Fun Speedo Issues....any ideas?
  120. Power Steering Failure in rain?
  121. Seized high pressure line bolt!
  122. Trans problems!!
  123. is there a certain type of engine oil flush i should use?
  124. Help loud noise
  125. Have questions about some problems.
  126. 2000 Camaro Z28 DYING!! HELP please with driveability issue!!!
  127. Leaking transmission fluid
  128. Not your normal A/C problem
  129. Running Lean
  130. Leak in Airbox Lid
  131. Squeaking noise from hatchback
  132. ABS and BRAKE light on,and shifting super hard
  133. missfire.
  134. Left turn signal/brake not working?
  135. Replacing AC Idler Pulley
  136. a good classic mustang forum?
  137. Fuel Flooding
  138. belt squeek help
  139. Blinking SES light after plug change
  140. Finally got to seafoam it.
  141. anybody recharged the refrigerant of their car?
  142. Sweeping Gauges
  143. HELP!! removing steering linkage
  144. 92 Convert. Top?
  145. What gap on plugs?
  146. salvage title be insured for full price?
  147. car won't start...
  148. Oil smell but can't find a leak
  149. How to question
  150. WTF!!! water leaking on passenger side
  151. dash lights
  152. a/c blew up
  153. replace front turn signal sockets - how to pull them clear?
  154. 01 z28
  155. Ebays fatmat Rattletrap sound deadener rocks!
  156. tachometer problem!
  157. I need help 911 Pep Boys Murdered my 01 SOM Trans AM
  158. trans am door panels in a camaro
  159. airbag question
  160. Turn Signal Problems
  161. Headlight PROBLEM!!!! YAY!!!!
  162. Turn signals are really slow!
  163. Studdering issue @ idle
  164. 01 v6 camaro not starting...help!
  165. New engine, NO crank NO start....
  166. My '98 Camaro wont start after wither storage.
  167. I think my headlight's ate some shrooms..
  168. Need Tech advise
  169. Changing a bad IAC motor
  170. Need help on strange noise ASAP!! *vid included*
  171. Buzzing noise in the back end (not bees trying to enter the honeycomb taillights :P)
  172. air condition clutch bearing
  173. Random Misfire
  174. so my cars throwing knock sensors
  175. Hey guys, with bolts ons, whats your gas mileage?
  176. Motor Mount Swap
  177. Window Motor is going
  178. Frustrating electrical problem
  179. Air Conditioner Noise
  180. Engine stalls when returning to idle.
  181. i know its gotta be on here but i cant find it so im going to ask it
  182. ABS inop light is on???
  183. Radiator cap squirting out water
  184. Window Wipers Are Freaking Out!
  185. Question about LT1 Radiator Conversion
  186. help me out here
  187. A/C Question...
  188. Glovebox Question.....
  189. Oil level
  190. Where is the flasher?
  191. losing volts
  192. A/C compressor oil
  193. Squeak over bumps in front left
  194. Any ideas what could be wrong? No power.
  195. Wheel feels loose on WOT and turns
  196. Wrecked LS1 T56 Z28 - what do you think? Look..!
  197. Question about O2 sensors...
  198. Replaceing Oil Pan Gasket?
  199. Radiator Issues
  200. problems, help.
  201. Alternator problem
  202. Checked out a 2000 z-28 today and.......
  203. pcv question
  204. bottem end
  205. Suddle Rattle in motion
  206. water pump
  207. HELP!!! 95 Z28 LT1 Stoped firing ???
  208. Rod Knock on 05 C6?
  209. Autozone PCV valve...?
  210. Flashing SES Light???
  211. NEED HELP ASAP w/ clutch, gears, rough idle???
  212. lights
  213. A/C in LT1 car..
  214. Z28 is becoming Harder to start...Starter?
  215. Need help about headlight
  216. Emergency Brake Light
  217. powerstering issues?
  218. need help!
  219. Part number for M6 trans mount on 02 camaro
  220. Alternator problems
  221. Need some Spark Plug Help please!
  222. 2000 WS6 Service manual PN #'s
  223. Damn POS P0300 code
  224. how to and part number for T/A front turnsignal sockets?
  225. how do i get window motors out of doors without sawzalling the doors?
  226. clutch squeaking??? HELP!
  227. A/C Compressor will not turn on unless jumped at the Relay
  228. Car's possessed
  229. Blown Head Gasket! Need Help!!!
  230. Battery keeps dieing someone HELP
  231. Alternator wire
  232. help
  233. Ticking/Jumping oil pressure
  234. Need some help with airbag (pics)
  235. Replacing Motor Mounts
  236. low alternator ampage
  237. fuel injectors
  238. Cool Fan relay position
  239. Rear main write up
  240. 99 gmc sierra 5.3 vortec questions?
  241. Heater problems!
  242. Wheel Bearings
  243. byunspeed card, were can you use it?
  244. M6 shifter issue (hurst billet plus)
  245. having problems with every light on the car
  246. Heat Wave!!!
  247. Oil Pan gasket
  248. Clicking noise...
  249. INS&SUPT Bracket...
  250. Turn signal woes
