View Full Version : General Maintenance & Repairs
  1. cant pump gas??
  2. Got a quick question about our power windows.
  3. Are the buttons on out doors supposed to light up?
  4. Grr.. turn signals not working
  5. heater valve??
  6. Headlight qeustion
  7. hooker exhaust and cutout pipe
  8. Horrible Noise trying to Start - Starter Bad?
  9. Window out. Need help
  10. A/C took a shit on me...now wondering Ls1 in Lt1 parts??
  11. First Post -Just bought 02 T/A Problem Already
  12. !!HELP!! electrical problem
  13. 01 Camaro not cranking...still
  14. wont idle
  15. Car died...
  16. where is the HVAC blower motor and how do i get it out
  17. headlight brass gear question
  18. Starting Problem
  19. Quick engine question.
  20. Car won't start intermittently
  21. Rear end looks weird...
  22. Low Coolant Light.
  23. WHAT'S this?
  24. How to fix Cruise Control?
  25. upper dash plastic panel replacement how to needed:
  26. Oil Blow-By?
  27. lt1 plug wires.....need help
  28. Having problems cranking
  29. HELP: Ls1 Misfire problem(READ ME)
  30. storage question
  31. LS1 Fans
  32. HELP:powersteering problems
  33. NAPA alternators?
  34. Window will go up but not down, just makes funny sound
  35. missing after over rev ?
  36. Air conditioner belt squealing. I'm going insane!!!
  37. Fuel gauge stuck @ 3/4, and trip meter not working
  38. Lt1 knocking
  39. Water-temp guage coolent spill!
  40. Clutch slipping or rearend?
  41. Why doesn't the car work???
  42. Think oil pumps bad
  43. More Power steering issues
  44. oil change??
  45. WEIRD-O sound coming from the engine bay
  46. Bad tilt column?
  47. bad sounding chatter
  48. Rattling heatshields
  49. 2002 Ws6 Map Lights won't click on.
  50. Dead battery
  51. eratic idleing problem. HELP!
  52. Did not know where to post this but......
  53. no throttle response
  54. Which OIL will leak LESS 5W-30 or 10W-40??
  55. bought this window regulator and motor, good deal?
  56. Battery died, who sells delco green light battery
  57. will not crank even with vats turned off
  58. Lovely Door Crack
  59. Battery works but car wont turn on
  60. odd whining coming from engine
  61. Air leak
  62. 1996 LT1 Camaro knocking!!!!
  63. need help with a cooling fan problem
  64. ???PCV Line???
  65. "ASR OFF" - Not wanted
  66. Engine cutting out, temp gauge goin crazy
  67. Need help - alarm/key fobs stopped working
  68. low oil light
  69. 1998 Camaro, possible VATS problem, not starting!!!
  70. What to do after Seafoam?
  71. oil consumption
  72. A lot of moisture in tailpipes
  73. Brake booster replaced = INSANE stopping power
  74. Bad gas mileage
  75. Blinkers aren't blinking - HELP
  76. Odd problem...
  77. Anyone ever had a fender crack on them?
  78. Hatch lock seized up?
  79. a ta headlight question i havent read.
  80. Turn signal doesn't work...
  81. No P/S and no Brakes
  82. Ok guys, have a gauge problem...
  83. Reason for vented opti?!
  84. Won't fire up?
  85. Lowered car, now it squeaks....WTF!!!!!!!!
  86. possibly clutch or something else??
  87. window tint getting scratched
  88. Ta drl question
  89. 02 z28
  90. HVAC tank question
  91. did my fuel pump take a dump??
  92. Adjusting window height
  93. Rpm gauge stuck at 6k. Help needed
  94. 98 ws6 auto headlights
  95. Window problem
  96. need alittle help on my idle ?
  97. Low coolant light...lots of coolant... ??????
  98. Mr. Gasket head gasket bad out the packaging
  99. broken windshield question?
  100. 98 Z28 Starter Replacement
  101. window sitting to high up
  102. Loud Whine...
  103. Removing Power Steering Pump
  104. Need help with fuel gauge!!!!!
  105. Power Steering Cooler Change
  106. spark plug/wire ?
  107. is my oil pump bad?
  108. pcv valve on a 1998 t/a
  109. Help! Possible serious transmission issue!
  110. Wide Open throttle....nothing happends
  111. Extended Warranty question
  112. Started Again!
  113. ac clutch
  114. KEY Issue
  115. Body control module: Light on when door handle pulled up/key in ingnition reminder
  116. missfire getting worse.
  117. Oooh god, car's dead, please help
  118. Can't open driver door from outside.
  119. car sat 14 months, now what?
  120. Window Motor..Thermal Bypass Mod
  121. Leaking Coolant... Help.
  122. windshield wipers acting wierd
  123. Spark Plug Change Question!
  124. A/C went from ICE cold to not at all
  125. help bleeding clutch...
  126. Help Z28 wont start
  127. Car won't start
  128. AC belt tensioner and idler pulley.....
  129. Headlight adjustor question
  130. ~~HELP! No headlights ~~
  131. cam position sensor replacement?
  132. How the heck to you crack a plug???
  133. Can't get car to start!
  134. oil leak, rear main seal or no?
  135. car wont harldy start, and temp gauge quit working
  136. IAC motor malfunctioning?
  137. defroster
  138. Steering is loose?
  139. coolant leak after shut down?
  140. Help!!!! Im burning!!!
  141. Help out mom
  142. 02 camaro wont start sometimes possible pass key problem??
  143. Charging/Battery Issues?
  144. do it yourself tuneup
  145. clogged injectors?
  146. Is this a fair price for a tune up?
  147. 98 Cavalier Z24 part 2 engine dies at any moment when driving
  148. Mirrors interchangable?
  149. Tie rod end?
  150. Problem?
  151. Starter Help
  152. New Plugs and Wires...loss of power.
  153. build date of my 02 z28
  154. coil harness check engine light
  155. who killed cylinder 6?
  156. Water under back seat (drivers side).
  157. Clutch Disengaging By Itself
  158. faint tick after oil change?
  159. power steering??
  160. fuses hot all the time? help!!!!!!!
  161. Clunk in Steering
  162. Idle Problem
  163. spring like sound?
  164. Which water pump?
  165. I can't turn TCS on.
  166. What goes here?
  167. power steering return line
  168. Is my clutch going?
  169. Headlight conversion question
  170. weird electrical issues
  171. question about 2nd gear
  172. internal squealing/knocking?
  173. what happens when these fail
  174. Name this part... cause I broke it...
  175. Water Pump Rattle
  176. odd electrical problem
  177. Window Motor (gear slipping?)
  178. replacing heater core
  179. heater motor question?
  180. wierd issue with my z06
  181. Vacume line from pass side tb to pcv
  182. Car Jerks While Decelerating
  183. Pissed off! Keep blowing headlights!
  184. Car died maybe alternator?
  185. how can i search for my codes
  186. Top Overhaul
  187. cam position sensor?
  188. valve cover gaskets
  189. water pump leak
  190. WOT not shifting/backfiring
  191. Odd tick
  192. Throttle sticks when engine is running
  193. Tranny and Rear End fluid change.
  194. no ignition power??? Help
  195. what flex plate to run? and parts
  196. 2000 Chevy Blazer "Clicks"
  197. Air Bag Light....
  198. Reverse Light not working
  199. steering shaft removal?
  200. Broken Windshield Question???
  201. I think my SS is running like sh*t!!! Any advice?
  202. Not sure whats wrong with my bird.
  203. frigid weather
  204. reverse lights not working
  205. coughing, sputtering... full throttle...
  206. Car turns over for a while before starting
  207. need new windows motor ? suggestions
  208. Air Pump
  209. problems with drl's
  210. OIl catch can question....oil in the intake question.....
  211. List of pieces that fail easily or weak links
  212. Water Pump Old Gasket Removal
  213. annoying popping
  214. Car won't start!!!!!!
  215. Wierd Squeak
  216. PCV Sludge... need help
  217. Tranny fluid leak by front of car can't find it help!
  218. headlight bumpstops?
  219. car won't start
  220. Ignition Switch Burn
  221. where are heater hoses located?
  222. Head Gaskets
  223. weird/loud whining sound?
  224. Hi for the first time and ....
  225. express window down moduel
  226. Ran out of gas WTF???
  227. K&N air filter how do you clean
  228. P1637C, PO300B codes?
  229. Door *pops* when opened
  230. Quick question
  231. strange noise? any thoughts
  232. Day night sensor
  233. Heater blows cold air
  234. drips of oil under opti?
  235. Turn signal wiring problem
  236. New engine won't idle
  237. help car throw a 0719
  238. Oil Light
  239. Buzzing noise w key in acc. position
  240. Steering rack removal question
  241. gauges dont light up/blinker socket/headlight problems
  242. Need a link!!!
  243. High beam actuator rod
  244. Dash Removal on Grand Prix
  245. ***alternator/battery problem***
  246. Rubber hood bump stop. Part number?
  247. hatch poper
  248. vacuum tube question.
  249. What caused this?
  250. Engine Coolant Low
