View Full Version : General Maintenance & Repairs
  1. Loud Ticking/Clicking Sound
  2. Car stalling
  3. Baffled Oil Pan??
  4. Will a?
  5. My starter keeps cracking!!!! HELP
  6. Motor mount - to - block bolt size?
  7. Service light on, then off?
  8. Questions about my exhaust
  9. NOT LS1, 3800v-6 tranny slipping...
  10. 00-02 dashboard question
  11. ac compressor
  12. Coolant in the Oil Cap!!!
  13. Will the hvac panel from a ls1 vette fit in an fbody?
  14. security light on?!?!
  15. streeing column swap
  16. T-top windnoise question
  17. oil gauge
  18. 0w30 question
  19. window track roller arm broke,,,any ideas for a fix?
  20. What is the thick, black, sticky snot like stuff used to hold weather strip in place
  21. Heater problems on a 95 Z28
  22. Tranny rattling sounds exactly like muffler came loose but its tranny.
  23. Crazy Power Steering Leak
  24. how to adjust passenger door.
  25. Alternator / Electrical help
  26. Top 6 lines of rear defroster don't work!
  27. Replacing torque arm-trans mount
  28. water leak? floor mats soak?
  29. Floorboard flood
  30. electrical problem
  31. No Interior Lights
  32. Low coolent light.
  33. speed sensor question
  34. FNG needs help.
  35. Alternator plug
  36. Power steering
  37. major oil consumpsion?
  38. Oil gauge dancing?
  39. code p0122 but test fine
  40. rattle?
  41. stalling
  42. Cylinder 2 and 5 getting no spark
  43. 1 cylinder low compression
  44. couple issues
  45. Diappearing Coolant
  46. Running like chit...
  47. My Hood is Stuck!
  48. Code P0410 showing up
  49. power door locks wont unlock...either one
  50. Headlight motor gears
  51. alternator help...
  52. loss of power : for about a second
  53. 1999 trans am idles rough when cold
  54. Random Misfire Code PO300??
  55. oil leak ...oil pan gasket ?
  56. left front parking light, 02z28
  57. key problems
  58. I have an issue......
  59. Sevice Engine Light On-Help
  60. Heater Question/ Problem - Elec. W/P
  61. Buzzing Like Bees!
  62. Whats happening
  63. Super Newbie Question!
  64. Knocking at very high rpm?!
  65. weird power steering?
  66. Can you use a gauge cluster from a 2002 in a 1998??
  67. Hmmmm.....enigine probs
  68. Car reacts weird to bumps at highway speed
  69. Tinting Windows??
  70. Removing Seat Belts
  71. 'Thermal mod' for winndow motor question.
  72. Idle hanging
  73. My horn doesn't work?
  74. Power steering fluid?
  75. Another funky noise thread...
  76. frozen T/A headlight wont go up
  77. weird idle
  78. Wierd vibration...
  79. Oil in Cylinder
  80. Starting Issue
  81. How hard to perform a compression test with motor in car?
  82. Major Clutch Problem
  83. high oil pressure and coolant issues
  84. somebody please tell me its totaled!!
  85. somebody please tell me its totaled!!
  86. Won't Start - click click click
  87. Interesting Problem...
  88. belt or pully noise
  89. car not starting (not ls1)
  90. ***starter removal ?'s***
  91. What is this? (wiring harness part)
  92. rear rotor swap kicked my A$$
  93. Exterior front electrical light signal problems....ARGH
  94. Gas Gauge Not Working Properly
  95. New steering column, VATS question
  96. HELP car wont run
  97. humming?
  98. starting problem
  99. Charging Problems????
  100. Strange chatter
  101. big ass oil leak
  102. '00 SS Idle Problem
  103. Pulsating front brakes
  104. SES Light 2001 LS1 Formula
  105. Another misfire thread
  106. Engine Fogging
  107. Thanksgiving day from hell..HELP ME ASAP! Thanks!
  108. Misfire
  109. Oil Leak..Does anyone Know what part this is??
  110. Power Steering...
  111. Ridiculously squeaky tensioner!!
  112. Help needed ASAP
  113. Idle Question
  114. Security Light Flickering
  115. Lights flicker...
  116. Z28 rotors vs C5
  117. Blinker Issues
  118. Map sensor not working
  119. Problems with Red Top
  120. HELP! cooling fans
  121. Turn lights
  122. IAC valve experts...Enter.
  123. Wipers on all the time
  124. Trunk hatch
  125. HELP. Locked keys in car.
  126. Cannot unlock my drivers side door.
  127. bump bump bump.... ???
  128. low power and bad idle
  129. camaro security light
  130. Alternator Relocation?
  131. Tranny swap problems.... 91 rx7
  132. Windshield wipers won't turn off.
  133. Losing tune....
  134. Revs go up.. speedo don't.!!!
  135. Leaking fuel between fuel filter and fuel line help.
  136. Seafoam question.
  137. A/C question / Wiring
  138. Removing battery for storage
  139. granny mode!
  140. Trip odometer resetting?!!
  141. Any help with these codes? P0171 P0174
  142. Air bag light - WTF?
  143. Heat/Ac Blower shooting air into the engine bay???
  144. Someone that should die in a fire.
  145. Breaking up....
  146. Headlights/wipers at same time
  147. Wierd misfire, but no code?
  148. Engine cooling fans shut off???
  149. Passanger window won't go up?
  150. very hard ticking on driver side head
  151. SES Light on after Seafoam....
  152. ASR/TCS off problem
  153. Car won't start.
  154. Window Guide
  155. ls1 missing.
  156. motor mount bolts loosening
  157. Windshield wiper issues.
  158. 4th-Gen Trans Am (floppy head rests) How to Guide
  159. Intermittent stalling problem....
  160. GM 10 Bolt pumpkin is always wet...?
  161. 4th-Gen Trans Am (floppy head rests)
  162. Best price on 1998-2002 LS1 Magnaflow quad tip system?
  163. Sarter mount broke
  164. alternator problems
  165. Seat Belt Holder
  166. Still throwing codes
  167. Power Steering making a LOUD whine
  168. LT1 startup Q's...ideas please.
  169. Glove Box Light Stays On??
  170. rack & pinion
  171. Brake issues....
  172. hose leak dealer order only?
  173. vats bypass question
  174. 89 Iroc
  175. rear main seal leaking
  176. popping sound from 1st to second gear and sometimes reverse!!??
  177. guys with trans and water temp gauges come in
  178. Relay question
  179. Exhaust leak
  180. Change oil soon signal HELP
  181. I found my battery draw/Now I need help
  182. ABS light popped on after some donuts and hard braking
  183. Weird "pulse?"
  184. Sloppy jerk in the driveline
  185. Part number for starter/fan relays?
  186. Hesitation Frustation!
  187. ses engine code question
  188. Motor Mounts. You be the judge.
  189. Winter Tips
  190. questions about o2 sensors
  191. Fog lights
  192. Broken tooth?
  193. Help My only key broke!cant start car!!
  194. Fog light
  195. Fuel pump went out on my friends 3rd gen
  196. Bad Springs?
  197. 98 z28 weird prob.
  198. Any recommedations on some good o2 sensors
  199. Gunk...
  200. Hole in floorpan
  201. Power steering Delete
  202. Power steering fluid is milky
  203. Summit MAF
  204. Did a sea foam top end cleaning but not alot of smoke.
  205. No HVAC fan
  206. HELP Security light. No start.
  207. tcs light
  208. Primary and secondary fans dont turn on
  209. Can I tap into one of these?
  210. Head lights pop up, but no lights!
  211. "Service Engine Soon" light?
  212. car ran great now wont crank...help
  213. Airbag light
  214. help with wierd vibration!!!
  215. Problem getting key out
  216. Whats the name of this?
  217. wierd intermittent running problems...clueless
  218. cap and rotor help
  219. Ideling akward
  220. Interior Lights Killing Battery
  221. Wiring Pop! Need Help!
  222. Best mod for under $10...
  223. Squeal from hell
  224. How to install a fuel pump??
  225. A/C Condenser removal question
  226. Major Oil Consumption-Rings?
  227. steering column
  228. hood struts for lightweight hoods
  229. Interesting: Electrical/Check Gages
  230. No Cluster lights?
  231. My car killed another WalMart Battery
  232. Help Please............
  233. A/C blower problem!
  234. Does LS1 waterpump have a weephole?
  235. Random "Something to Check" of the day
  236. Spark plug gaps after 15K miles
  237. practically stock 02 ws6 won't idle when cold.
  238. burnt oil smell?
  239. Tranny
  240. New tie rod ends
  241. Poppy exhaust when foot is taken off throttle? Normal? On a search for shitty low mpg
  242. Power Steering Pump Leak
  243. preventive maintenance
  244. hissing noise from rear
  245. EGR Wiring Diagram
  246. Ignition control module testing ?
  247. No heat and it's getting cold
  248. Wheel Hop
  249. How to remove the fan assembly on 99TA
  250. seafoam Q
