View Full Version : General Maintenance & Repairs
  1. 100k !!
  2. 383 LT1 Engine Problems. Plz Help. Pictures inside.
  3. MPG's Dropped Dramastically! HELP!
  4. Rear hatch shock number
  5. T/A Headlight Stuck, It's NOT a Stripped Gear!
  6. A>C> Fan question
  7. Drivers side window bluntly stopped working?
  8. grinding noise. lets figure it out.
  9. Radiator hose
  10. Removing the hatch 98 camaro, how hard??
  11. Need Help!!!!
  12. Engine noise!
  13. Window regulator maybe??
  14. crank posistion sensor
  15. Oxygen Sensors
  16. Coolant Temp Sensor/ Check engine
  17. AC question
  18. How to replace the bevel by the drivers side door?
  19. AC Doesn't Blow Cold
  20. Door skin is seperating.....what glue?
  21. parking lights/turn signals/brake light help
  22. 98 Trans Am no spark or fuel
  23. drivers window hitting triangular piece
  24. AT IDLE WHEN I HIT GAS TIGHT CAR Knocks and ENGINE STOPS
  25. Got a few issues to work out, need feedback
  26. Clunking and clicking when braking wtf???
  27. Help Asap Nowwww!!!!!!1
  28. Exhaust smells bad, need help!
  29. Radiator Repair
  30. vibration in car
  31. can door panel be removed with window up.
  32. car wont start
  33. Car wont Start need Help please very weird issue
  34. P0100 code problem New Lid?
  35. Alternator Plug Burning Alternators?
  36. 5 Alternators Within 2 Months???
  37. Still having problems...
  38. 30+ Mpg?
  39. Lights dimming while driving down the road?
  40. Need some help from experts. Valves are very noisy and a broken bearing...
  41. Poor mileage, car runs bad with ac.
  42. Coolant Flush question?
  43. Headlight disassembly
  44. Headlight Problem!!!!!!!!!!
  45. convert from auto windows to manual?
  46. Help With Steering Column Movement
  47. Not V8 related but worth a try (weber carb on 2.0 4 cyl)
  48. No start problem. Please help!
  49. replacing head gasket on 1995 3.4 Camaro
  50. Reset Computer B4 Inspection? Help Fast!
  51. No Start, No Spark!
  52. Just changed oil, Huge oil pressure improvement!
  53. Bad gas mileage lately, replace 02's?
  54. Low Oil Indicator/Dipstick smells like gas.
  55. WHAT is this Noise!
  56. HELP!!! car wont turn over
  57. how to replace front turn signal light bulbs?
  58. Starter wont turn.
  59. passenger A pillar and dash separation?
  60. Wheels drive while in neutral? A4
  61. metal in oil
  62. A/C Belt Snapped - Is this the Source of My Problems??
  63. gettin hot!!!! help guys
  64. Engine shaking at idle, misfire or motor mounts?
  65. car shaking at idle, runs shitty down low
  66. AC accumulator very hot
  67. 98 camaro with cracking like sound
  68. turn signals don't work
  69. help !!!!!!!!
  70. Clunking from rear.....
  71. Blinker won't work
  72. Block Drain Plugs?
  73. Loud rattle, front suspension?
  74. throttle cable clip
  75. NEED HELP FAST ticking valvetrain
  76. need the name of this line so I can fix my ac
  77. What is this part called?
  78. Airbag Light Flashes
  79. A/C compressor wont kick on
  80. how do i remove engine oil filler neck?
  81. Cheap Gas Caps
  82. Parking Light Swap
  83. black smoke... help
  84. High Idle after APS and 317 heads install
  85. Driver Window Motor (This cheap??)
  86. 98-02 signal lights?
  87. Need HELP! Still Stuck in NC
  88. Suspected crank position sensor wire problem
  89. key stuck in ignition!!
  90. Battery Cable
  91. Electrical problems
  92. where does this go to??
  93. popping and backfiring
  94. Do you have a fuel gauge that pegs like mine?
  95. Changed oil... wtf is this!?
  96. My CAR DONT GO TIGHT IDLE IS 500RPM OIL PRES 15PSI????
  97. Turn signal pigtail source????
  98. Coolent Sensor
  99. Are the windows tied into the stereo????
  100. Stranded In North Carolina
  101. door lock problem.
  102. Belt/Alternator squeaks only at high rpm's ???
  103. Vaccum hose
  104. PCV hose
  105. voltage low help!!!!!
  106. Symptoms of a bad Fuel Filter ?
  107. Leaking oil and trans fluid...What to replace?
  108. Vacuum Line ???
  109. Different brightness in tail lights.
  110. headlight problem
  111. Clunking noise when i turn the engine off
  112. new spark plug wires
  113. Low idle and car wouldnt stay running at first!!! Help!!
  114. Would you change your plugs and wires at 36k?
  115. Paper stuck in VIN plate location
  116. Water Passenger Side from Rain
  117. brake lights not working???
  118. Check engine light come from a bad plug?
  119. Car lags at WOT.
  120. Ignition cylinder question
  121. Cross Country Drivers??
  122. o2 Sensor Brand
  123. Power seat will not go down. HELP!!
  124. no pwer to compresser
  125. A/C Leak Repair Question
  126. Alternator Power Wire Problems!
  127. Failed PA State Emissions
  128. Engine Stops While Driving???
  129. I need help....
  130. a little info please
  131. What size and type of bolt...
  132. Wiper arm removal
  133. Squeeking in rear driver side wheel well
  134. rear diff has oily residue
  135. Hey guys, please help with my mods gone wrong.....
  136. Hyperlube?
  137. replacing the o2 sensors ?
  138. horn problem
  139. sway bar hit high pressure ac line...wtf???
  140. 79K miles replace 02's?
  141. Just got new A/C hard line, no gaskets?
  142. Maintainance light on
  143. rear rattle
  144. Vibration after changing brakes
  145. Inspection Tomorrow -Coolant Hose Leaking Tonight
  146. lug nut stuck on stud and spins!!!
  147. Oil Pressure--2000 Corvette
  148. security system troubles
  149. What do you think of this True or Not
  150. PS pump or Alt to blame?
  151. SS 8 years old should I flush the Radiator?
  152. Sensor above starter on passenger side?
  153. valve above oil filter?
  154. does this spark plug look bad to you?
  155. bad idle on 3.8
  156. Throttle/idle hanging up
  157. Removing Mastic?
  158. Help Car Won't Idle!!!!
  159. Window track
  160. changing break lights
  161. AC Help QUICK!
  162. noob question?
  163. Powersteering whine and notchy turns
  164. Groaning sound on turns, please help!
  165. pass. fog light problem
  166. Replaced Fuel Filter; Car Won't Start
  167. 3rd gear
  168. Low Oil? Or What?
  169. changed ac compressor and refilled with r134a no cold air
  170. help with noise from back of our 01 corvette, stops when taking tight turns
  171. Another key stuck in ignition story...
  172. Light bulb issue
  173. Anyone want an LS1 only A/C system sticky--nevermind
  174. gas gauge acting funny!
  175. Engine groan at low rpms
  176. Just changed headlight motor...
  177. My lights are really dim
  178. EVAP, Emission Problems
  179. Help with Hissing sound
  180. alternator?
  181. refill AC
  182. 98 ws6 headlamp issues
  183. Repairing a T-top gasket?
  184. car wont start some times
  185. What is the correct level for the coolant tank?
  186. Took my car to Pep Boys to check out my A/C....
  187. HEADLIGHT Probems HELP!!!!
  188. sputtering?
  189. High beam ?????
  190. Help with play in steering
  191. auto/vehicle storage bag
  192. Pop when accelerating. (Suspension)
  193. Small electrical problem
  194. Clunk when hitting slight bump or decelerating
  195. Part number help, already tried the dedicated thread
  196. little part. big problem?
  197. which Brand of window motor to buy from autozone?hr
  198. rough idle
  199. Metal shard on magnetic oil drain plug?????
  200. cammed miss
  201. Anyone help with my problem??
  202. extendind AC lines???
  203. Fuse (Tail Lps) keeps burning up
  204. 10 MPG...Why?
  205. Window motor questions
  206. Headlight issue when unlocking/locking car
  207. running rich
  208. Where is the knock sensor located?
  209. Coolant SPRAYING out!
  210. Where do the Vacuum hoses go that come from vac canister?
  211. hole in back of ac compresser
  212. engine temp out of whack
  213. another AC question
  214. Fan stays one hours after I cut the car off
  215. T/A Even BIGGER Headlight Problem. Help
  216. Alarm Going Off
  217. A little moan...
  218. Not your typical A/C problem...
  219. How hard to replace door window?
  220. car overheats when AC is on
  221. What is the problem
  222. Ugh! Not starting?!
  223. ac hose question
  224. Will the SES light shut off by itself?
  225. Cleaning pistons?
  226. ac compresser problem ...?
  227. A/C Problems in 120 degree weather.
  228. Bad alternator's
  229. Pissed as Hell
  230. How hard to replace rack and pinion?
  231. airbag light blinking
  232. Disconnected power seat NEED HELP RECONNECTING!
  233. How do you remove Coolant sensor
  234. a/c problems
  235. AC Problems
  236. Creaking when shifting
  237. valvoline synthetic 6qts for $9
  238. Need Help ASAP!
  239. Rack and pinion leak
  240. Changed my plugs for the first time
  241. inspection problems. HELP PLEASE!!
  242. Burning out window motor or misaligned window?
  243. Ses P0420
  244. Windshield wiper arm removal
  245. Need helo 00 Camaro SS
  246. Need help starting problem 00 SS
  247. SES light after plug/oil change
  248. wtf is wrong with my headlights
  249. How to open hood without hood latch cable?
  250. DAMN, my A/C just blew up
