- Check Engine Light
- Car died in the middle of the road..
- cruise control switch ?
- Got a problem i ripped the top connector out of the Alternator
- air condition question
- Air Bag light
- How do i remove my door moldings on C5?
- Vibration in blower motor?
- Rear Hatch Buzzing
- A/C keeps changing vents or blowing out the floor when I accelerate
- Quick Question
- Help!! Crank Bolt Keeps Backing Out!!
- Lowered Car Issues
- 1996 Trans Am Gauge Cluster Removal
- Torque for trans. pan ?
- SES light question
- Please Help
- Trouble With Motor
- replacing console pad?
- Problems !!!
- Need help soon
- Anyone ever had a problem with their coolant light and the plastic side tanks?
- coolant low?
- Vibration
- My car is possessed...
- Daytime Running Lamps Question
- Help!!!
- need help with a/c
- clunk, clunk, clunk coming from rear or car
- Weird Window Noise
- o2 sensor problem on 2000 Accord
- seafoam ?
- Engine Service Light / Temp Gage Craziness
- Oil pressure sending unit.................
- battery going dead
- AC blowing out heater and defrost vents only
- Sponsored by Denso!
- Low voltage problem, not your tpical one either. Please help!
- Quick O2's question
- Help with Emissions
- How to adjust headlights?
- Car wanting to die part 2
- My car is not running right
- Coolent Light Came On
- T-Top Flew off! Wtf?!
- Really need help
- $$ Misfire Who Will Figure It Out??? $$$
- Damn T/A power antenna! help
- Strange Parking light problems (not correct sockets?)
- 99 Ls1 overheating problem
- What the F
- Car shuts off?
- question about 02 sensors with headers
- Place to buy 3/4" fuel line?
- Issue after issue
- 2001 Eclipse Shuttering while braking
- vibration when turning wheels
- what is this sound?? VIDEO
- Help! Reinstalling steering wheel - can't get high beams hooked up
- water pump going bad?
- Strange happenings
- Tune Up Questions...
- Popping through exhaust when cold
- quick pwr steering pump question
- Belt ?s
- 2000 Vette Headlight gear/motor..
- My car is starting to worry me!
- Front passenger turn signal socket help
- alt? batt? wat is it??
- Getting codes for both O2 sensors
- water pump replacement?
- What gasket do i need?
- Power steering Reservoir
- Dead coolant gauge?
- leak
- Water in the gas tank?????
- ok diagnosed Misfire...
- DS brake light not working
- tq specs on idler please?
- Spark Plugs/Wires Round One
- Schrader Valve?
- Idle Problems
- Ac compressor issues
- LS1 Water Pump & T-Stat
- Voltage question
- General Maintenance & Repairs FAQ -- PLEASE READ BEFORE STARTING THREAD
- Another Ticking Post.......
- Do Mods put alot of stress on the engine?
- Only 210 miles to a tank?
- Crane wires + champion plugs = fail + misfire
- !!!Help...weird problem!
- Whats this?
- Lower Control Arms/Bushings squeaking?
- Stupid light question
- Odometer Rollback Question
- need help! my key phiscally wont turn forward in the ignition
- Exhaust leak.
- what is this hose for
- whats the best header gaskets
- slp exhaust question
- orifice tube location?
- Driver window won't go up!
- Rattling noise when I turn the car off
- 2k RPM+ Whine- 98 Formula!
- Looking at 85,000 Mile WS6 - Should I worry about mileage
- Problem i dont even know what catagory to put this in
- Step by step instructions on bleeding brakes?
- Gas mileage
- Metal fasteners for the rear plastics??
- top end tick/low oil pressure problem
- Tape on fuel lines.
- rearend creak
- Headlight actuator?
- Loud Beep
- Low Coolant Light
- Windshield ding
- stereo install,brake light bypass?
- 1999 Monte Carlo Z34 (3800 engine) leaking oil...
- a/c idler pulley - How to remove it?
- nice rack!
- turning indicator?
- Basic maintenance....
- Where Is This Coolant Coming From?
- Weird problems with 00 3.8L
- Headlight problem (hdlight control module?)
- Powersteering Problems
- Rotella T
- 120 MPH car cuts out, Speed Limiter? M6 car
- Firebird headlight motor fix
- Help!! --a/c
- Quick Air Conditioning/Fluids Questions
- Head Gasket Leak?
- Wipers Won't Go Down All the Way
- Ticking/rattling coming from the valvetrain *Video
- Wtf Is Wrong!?!?!? Idle Problem!
- Throttle Body Colant Bypass PROBLEM
- Oil change light keeps coming on.
- Power Steering Leak!
- alternator issue??
- Coolant is going somewhere, but not outside. Help!
- Whinning
- Coolant leak, cant find it
- electrical gurus in here!!!
- AC belt squeaking, nothing helps
- Seriously does it really matter what oil we use?
- Fans stay ON after I shut the car off
- I need some help
- Day Time Running Light And Pass Blinker Help
- Have a Brake Issue
- engine bay cleaning woes
- 2001 f-body O2 sensor
- rocker arm noise???
- major oil leak but can't see source?
- 3 bad alternators in a row?
- Oil is Always Black
- Sunvisor?
- AC/compressor causes fluxes in voltage/rpm
- Driver window
- metal on metal grind on hard braking or engine brakin
- couple of stupid questions
- need a little help
- Headlight motor on the TAs
- Weird Panhard Bar Noise..
- 50,000 Miles LS1 Maintenance? (Firehawk)
- check engine light
- Got 2 3800 V6 Questions, Injector Tick and Replacing the 2 Piece Drive Shaft
- Stock MAF replacement
- Header install = broken sensor & Exhaust bolt
- Help re-wiring crank sensor connector
- Security light stays on!
- Need help with window sag!
- A/C problems HELP before it gets hot.
- Name that hose!
- How difficult- Compressor?
- Rear stock wheels from 2001 don't fit on 1995??
- roaring coming from the front.
- Quick help MAF cleaning
- Any GM workers? Need help finding EURO spec part number
- noob pinging/knocking?
- white smoke question fuel pump?
- Car randomly turned ooff
- problem code PO161 on a 98 TransAm
- high voltage when i rev the motor
- Repair Manual
- Suspension Squeak!!! ... I Think
- Squeak/thump from rear end
- Odd Blinker Issue, and a Headlight question
- can't find windows motor write ups
- Motor Oil in throttle body
- check engine light ...help
- Serpentine Belt killed my AC hose
- Car starting problem.
- window squeaks
- alternator wont charge! please help!
- **Power Options**
- Anyone had or is having a problem with their front turn signals working sometimes?
- water pump leaking
- Instructions on installing new brake lines?
- Idle?
- Strange A/C moment
- A/C Issues-nothing from front vents
- Low voltage at idle
- Need a new A/C compressor (thoughts?)
- RPM Not Steady
- Help-speedo, tach, odometer, radio do not work
- Two Engine codes, confused.
- Fuel Pump?
- Help!!
- Trying to figure out why both cigerette outlets are dead.
- Starter wire diagram
- help!how do i remove scratches in the window?
- Throw codes, once reset they do not appear again
- Tail light works but not brake light?
- Help Please!
- went to change the headlight and found a problem
- A/C ticking??
- Rear 'Brake' Lights not functioning
- Exhaust smell...
- ABS INOP and AIR BAG lights came on today
- Low charging voltage
- Power sterring leak
- SES light flashing after Seafoam......
- Need Help quick!!
- Radiator hose replacement help plz
- car wont idle after hooking pcm back up
- Air Bag Light on after Turn Signal Repair
- Belt?
- Thinking I'm f*ed
- whining noise
- Oil pressure = zero
- Coolant and power steering fluid MIX
- bad maf
- fog lights on
- Whining from rear end passenger side
- Flat nitto DR
- LT1 Car cannot be restarted once warmed up.
- Guys with steering problem experience...please help!!!
- QTP cutout repair
- Light problem
- Help! Chronic Cat Problems
- would it be dumb to......
- Oil Problem??
- Horn got wet, sounds weak now
- Fast Idle??
- replacing oil pan gasket
- Wet o2's????
- power to manual windows
- question for interceptor owners
- pcv tubing for ls6 intake?
- how do you clean the IAC
