View Full Version : General Maintenance & Repairs
  1. P-0440/0442 - Possible Causes?
  2. PCM won't communicate, gauges don't work
  3. HELP. 3800 V6, how to get to throttle body?
  4. Condensation driver side rear tail light reverse?
  5. Average A/C vent temperature
  6. Fan Fuse issues
  7. what sized torq bit for rear struts
  8. Tranny crossmember bolts
  9. Service engine soon light blinking(weird)
  10. WTF!!! Need help, video inside.
  11. is this normal
  12. could it be a rear pinion seal?
  13. Low Coolant light on but Coolant is full! Why?
  14. Where to hook up ac coolant recharge can?
  15. 05 monte carlo WONT TURN OFF COMPLETELY HELP HELP
  16. Power-steering out?
  17. whats causing my car to sputter?
  18. Killed a o2 sensor, can I.....
  19. Inside a Well Used Fuel Filter (Pics)
  20. Is there a quick and lazy method to changing the brake fluid?
  21. Head or intake gasket
  22. Large Vibration at ONLY 65mph
  23. any write ups to fix slack in cable?
  24. vats
  25. Causes of rough Idle.....
  26. car still sputtering after y pipe install
  27. TA headlight
  28. Keyless entry barely works!!
  29. Cleaning carbon off pistons
  30. Have you Seafoamed?
  31. Problem with the ASR
  32. turn signal problem?>
  33. torque wrench
  34. Stumble at Idle
  35. Idles high
  36. What does this mean?
  37. truck wont start
  38. Quick help with stuck fittings??
  39. Alternator Part Number
  40. hesitation help
  41. weird sound when turning ignition
  42. ac problem
  43. change driverside mirror
  44. Lights wont work for shit!!!
  45. My gas pedal is sticking help!
  46. Car acting up after Longtube Header Install
  47. lets add to the lighting problem
  48. my lt1 is not getting air! any help?
  49. Poor Performance-Check Engine Light
  50. auto headlights please help!!!!!!!!!!!!
  51. water pump,,new opti???
  52. Possible oil leak from front passenger area?
  53. 50k Maintenance
  54. water - a/c problem (help)
  55. only one side fires..
  56. Some newbie questions about fluid changes, etc.
  57. What's wrong with my car?
  58. Offroad: which oil?
  59. tune up
  60. Leak on drivers side
  61. What idler pulley do I use?
  62. Power window experts please
  63. Car won't start...pos Wire problem PLEASE HELP
  64. is my battery dying?
  65. IAC and MAF cleaning
  66. Distilled water in aluminum radiator, yes or no?
  67. 9" E Brake
  68. where's the drl fuse?
  69. noise wen turn n clunk switch gears
  70. driver side back noise helpp
  71. Fan Issues
  72. 2000 Firehawk Still Not Starting...
  73. WS.6 will not start !!
  74. Pulled car out of storage today.
  75. installed ls1 in 94 firebird HELP!!!
  76. Car doesnt want to start..
  77. asr problem
  78. Horn problem?
  79. Car dying on me?
  80. water pump failure
  81. service light after tune up? HELP!!!!
  82. Tick after Plug Install?
  83. differances in factory lower air intakes?
  84. READ if you have the starting problem with full electricity but car wont try to start
  85. SIdeways play in front wheels?
  86. oil & mpg
  87. About how much should this cost me?
  88. Overheating Troubleshooting
  89. Broken Throttle Cable Clip
  90. Best way to reset idle?
  91. where is the IAC?
  92. The endless cranking but no fire.
  93. Need help with repair/arcing coils?!
  94. RPM's dropping at idle.
  95. I need help
  96. sewing machine noise?
  97. does anybody have the link to the sunviser fix mod??
  98. What is the name for this A/C part?
  99. Car won't start
  100. Help!!!!!!!!routine Maint. Now Won"t Start!!!!!
  101. Error code 0305 Misfire on cylinder 5 on 2000 firebird. Any suggestions?
  102. Let's play doctor
  103. Is TIME an issue ref brake fluid?
  104. Squeaking while turning
  105. 1st to 2nd hard shift
  106. 98 Camaro V6 - Intermediate Check Guages Light on/off
  107. Weird miss fire??
  108. check engine code
  109. Question
  110. turning clunk
  111. Bad Vibration!!!!!!!!!!!!!!!
  112. Took out cluster and now car won't start
  113. Searching for grounds P0300
  114. What a day.... Help
  115. Trying to buy GM's rear differential additive...
  116. power steering pump hose won't stay on!!
  117. power steering idea :)
  118. Ticking noise coming from right header?
  119. Issues with Evap system
  120. Worst Day of My Life
  121. 30mph why no power
  122. '99 WS6 rear end sound
  123. Coolant
  124. Stock GM radiator = FAIL.
  125. code p0140,,,,,p0138 why is it on
  126. Ran 14.4@ 100 what should I check to get hp back?
  127. How to port throttle body?
  128. Cooling fan question
  129. free coil
  130. Newbie fuel filter question
  131. ABS INOP... my fault?
  132. HELP!! U-Joint Brand
  133. any body know y this code is on
  134. cruise control servo keeping throttle open
  135. headlights on all the time???
  136. Water under seat
  137. what does this sound like?
  138. Maf,,code
  139. Car won't start
  140. Power Steering Flush for $125. wtf is that?
  141. Battery Guage Problem
  142. how much for a seatbelt retractor used/new?
  143. How do I change the u joits after pulling drive shaft?
  144. Oil Pressure Problem...
  145. wipers knocking
  146. oil pump
  147. hmmm. how do i connect this two?
  148. Random Misfire
  149. Serious Brake Issue. PLEASE help !!
  150. SLP Spark Plug Socket
  151. Wiper Arm (replacement)
  152. Really Bad Day
  153. Turning signal help
  154. HELP, 00 headers, 02 z28
  155. Can you change the fuel filter without jacking the car up?
  156. is it comon for an a/c controller to go out
  157. L- Terminal?
  158. AC Doesn't Blow Cold
  159. LS1 Body Control Module Problems - The Fix
  160. Headers are leaking and car died?
  161. Car Diead On Me!!!
  162. 95 Aurora misfire woes
  163. i need help asap..
  164. Need a part number
  165. Misfire after ~2 mins after startup, then runs fine a minute later
  166. squeek from drivers side after 12 bolt install???
  167. Motor or tranny messing up or?
  168. A/C Drain?
  169. good and very cheap exhaust places
  170. Please Help!!!! I have the weirdest problem!!
  171. Hot!
  172. Isssues's HELP
  173. Honda ATF fluid??
  174. Strange Sound and Engine Stress when Defrosting?
  175. Grasshopper
  176. Changing DRL/Turn signal housing today
  177. whats causing these 3 error codes
  178. Is it possible to replace rack-pinion seal?
  179. Lost my dash, interior, fog, and tail lights?
  180. Need help..
  181. Is this the fuel pump?
  182. Car bogs no SES
  183. Put a nice oil drain plug in today.
  184. Have a few noises, narrowed them down..
  185. Window Motor - Thanks and tips for others
  186. Low RPMS
  187. How can I tell if my car is overheating?
  188. 2000 Firehawk Not Starting...Help!
  189. power intena?
  190. hard to find pennzoil platinum 10w-30
  191. A.I.R. Check Valves keep failing
  192. Quick question
  193. Heat coming from floor vents
  194. Low Coolant Light
  195. removing corvette radio
  196. need help??
  197. Car is hard to start, then sputters, then runs fine... any ideas
  198. Air System ?'s
  199. Help Please:'(
  200. Cost to fix?
  201. For bird owners.
  202. HELP: Air Pump
  203. What is the GM PN for this hose??
  204. Rouh Idle When Car is Warm....
  205. My engine was built loose so I run 15 - 50W Mobile 1
  206. HELP!!!! My car wont stay running!!
  207. Lights on rear Spoiler
  208. seatbelt not restricting. help
  209. I've got a couple different problems
  210. a compilation of owners manuals??
  211. Whats the best way to clean mass air flow sensor?
  212. Starter shims?
  213. Clogged fuel lines
  214. Pulsing lights--Is this normal???
  215. HELP....Battery dies at idle
  216. fuel pump heating
  217. cold start car dies help!!!
  218. Do i need the drill mod??
  219. Is this a broken window motor
  220. Plugs seized or stuck
  221. turn signal/running light issue
  222. Tachometer stops at 6500.. normal?
  223. car won't start sometimes...
  224. Codes
  225. Temp gauge jumping around?
  226. fuel injectors ticking...
  227. Popping noise?
  228. whats this vibration/whatever it is??? help me out
  229. Gauges jump and trip odometer resets when starting
  230. Noise predictions???
  231. Kinda noobish Fuel Filter Question
  232. High Pitch Sound from Engine
  233. need help driver window is having issues
  234. Left O2 Lean
  235. 70,000 miles.
  236. Turn signals and headlights dont work???Gauges cause problem?
  237. Rear Hatch hinge is driving me nuts!!!!
  238. What fluid do you guys use in the rear end for I think torsen
  239. Seafoam issues
  240. help please, car is having starting problems.....
  241. abs inop and trac wont lights on, tried body scan but says cant communicate with BCM
  242. ignition key is stuck!!!!!!! HELP!!!!!!!!!!!
  243. Semi-Strange Blinker Issue
  244. nay one know if there is a how to on removing axles?
  245. disconecting the battery?
  246. Weird electrical problem. windows don't work and Monsoon shuts off?
  247. Weird electrical problem. windows don't work and Monsoon shuts off?
  248. Slow A/C Leak...
  249. car problems
  250. Brake problem....help!
