- Random question about windows
- True Dual!
- Any way to clear up a cloudy headlight
- Gauge Cluster light out/fuel gauge not working
- Weich Amsoil Should I Buy??
- light bulbs behind radio buttons
- Water Pump Replacement
- power steering
- idling problems
- 02 sensors
- car sputtring and backfiring
- battery to small
- Why my car doesn't get hot??
- pullies installed and car runs great
- Problems: Coolant Leak & Choppy Ride
- P0704 Clutch Switch Input Circuit Malfunction
- small dent in exhaust will it cause problems?
- oil pressure Q?
- Windshield Wiper Probs
- Low Coolant light comes on
- Crazy Space ship noise in warm weather start ups
- Car no starting after put in storage?
- Clean MAF, how-to?
- p1516 p1517 p1518
- What could this be?
- blinker flasher replacement
- hissing noise under floorboard
- cpu hissing noise
- Injector Cleaning/Sea Foam
- Clutch fluid change
- anybody elses oil filler neck loose???
- need help with Window "jump"
- powersteering issues please help!
- I need to charge my AC What is the weight
- symptoms of tranny slippage
- Headlight motor repair
- my car is overheating.
- Anyone successfully repaired a tilt steering column?
- Power Window Problems
- Knock in only in 4th between 30-40mph???!?!
- LT1 wont fire up
- my Long Tubes just got destroyed.
- Key out car still runs?? lol
- Radiator Leaking Time To Up Grade Need Help!!
- Dissapearing Antifreeze, Only Tiny Spot on Floor
- Trans am headlight doesn't always flip up
- Brake Problems
- will a camaro dashpad work on TA
- Radio Steering Wheel Controls
- what is this and how do i fix it???
- Radiator Drain Plug Stuck?
- Changing Brake Pad's Question??
- Which Optima Red Top?
- Rhino Ramps...anyone have a problem w/theirs slideing?
- oil leak rear main seal ?
- A few problems with my LT1. help please!
- knocking sound
- steering wheel lights
- Hatch Not Releasing with Motor Running
- Misfire!!!!!!!
- Odd Blinker Problem, multiple symptoms
- Stumble at 1500-2000 RPM, in 4th, 5th, or 6th gear
- Water Pump Leaking
- hesitating while accelerating
- Tea kettle like whistle.
- Alarm Question
- Oil Light
- Oil change light and change intervals...
- high idle??
- Squeaking and accelerating VERY slow. Whats wrong?
- what the hell is this noise?
- O2 Sensor question & window motor (not related)
- '99 TA Diagnostic Estimate
- Why the bad gas mileage???
- Which Spark Plug/Wire Combo for an ls1?
- Car Not cranking!!!!
- Z06 engine
- Car Not cranking!!!!1
- Headlights dont work
- Supercharger-like sound from Hell!!!
- Is it just me or does the gas pedal kick you back with TCS on
- rocker bearing are all over the place but!!!
- MPG Tracker
- thumping when tapping gas
- Weird clunking/clicking noise when turning on the car
- power steering.........
- Stiff Power Steering
- Non LSX Head Gasket problem
- My Ram Air hood..
- SAI codes (p0410 & p0412) & p0157 o2 low voltage
- Turn the crank to start my car?
- rear end fluid
- PLEASE HELP Headlights and Dash lights blinking??????
- dash light burnt out
- Quick ???
- Need some help!
- power antenna almost goes all the way down -.-
- pass side seat belt
- Battery maintenance
- Proper maintenance schedule for 02 Z28
- Shop Fees
- Oil Pan Info
- Engine knocking
- Factory Fills and oil in general
- irratic idle and fuel pressure
- Plug and Wire Install+Fuel Filter
- Key won't turn in the ignition
- Denali question!
- Rear end squeel when turning
- Security light
- HELP my car suddenly will NOT crank!!
- Is my exhaust leak big enough to cause problems?
- Water Pump/Gasket Needs Replacing, need some guidance
- Need repairs
- Misfire?? Hard Ass Idling; Ses Flashes!!
- fans programmed to come on early but aren't
- Firebird headlight problem
- Fuse for tail-lights keeps blowing.
- radio unmutes when headlights turned on
- Doing a full restor on an 83 TA
- Idle
- Check gauges Light on and Gas Guage is dead!
- AC Delco Water Pump Thermostat
- Valve Cover Crossover Hose
- Wont turn over
- Check engine light came on today
- Map light bulb replacement
- Tensior and Idley pulley 2nd editon with part numbers
- What the hell is wrong w/my AC!!! PICS
- P0141 and P0161 just came up at the same time
- Some loose wires behind headlight switch question
- trouble shifting out of park...
- oil sending unit location
- why is this O2 sensor really really black???
- knock sensor low voltage?
- Brake problem on my vette
- T-Top lock fell out help
- Car running horrible
- Belt squeaking or something
- Not Just An Ordinary Squeak!
- dealership or local garage!
- SES light, but no codes
- What a fantastic day...(pics)
- rotton egg smell? and no power down low???
- 99' Coolant level sensor removal: How to?
- Vent Problem
- problem in the first 5-10 feet of driving
- Rough idling, misfiring.
- 360 degree electrode sparkplugs i.e. Torquemaster and Halo. Are they any good??
- My first oil change...
- need help with my blinker
- I Need Help Asap!
- sway bar thing not there...
- Time to tear apart the dash!!
- disco lights
- TA headlights going up and down?
- halogen backup lights
- hand brake issues.....
- Oil
- AC compressor questions, interchange, rebuild
- Rare dash color?
- Firebird/TA Replacement Headlight Bolt
- Losing all oil pressure
- power steering drain
- Almost Dead Battery= Alarm Going Off?
- car acting funny
- Pulsing lights
- starting troubles
- SES Light - Small EVAP Leak - Any ideas?
- firebird front license plate filler removal
- P1626....Anti-theft system fuel enable circuit (Passkey error)
- Cold start this morning
- Idiot check on a elec/batt/alternator problem
- alignment issue
- Turn signals don't work
- Need to replace this hose connector, but not sure what it is? Pics attached
- Water Leak?????
- A little expertise needed
- Msd Plug Wires.....help!
- Mysterious clicking noise
- Need Help On Rocker Arm Install
- Idler Pulley BS...
- Just bought my ws6 and having problems
- corrosion on turn signal socket
- How do you reomve targa top
- Weird Squeek noise, need help
- Alternator help needed
- Ticking underhood of 1998 LS1 T/A A4
- RPMS shoot up!
- Horn troubleshooting
- Air Conditioner
- is it over for my motor?
- need help
- When I ONLY turn left A birdie like sound comes from my cars rear?
- lt1 ticking and pinging
- Piston Slap or Pinging!!!
- O2 Sensors
- dash lights went out
- Where to get this Done?
- windshield wipers
- I could turn my car into an Aquarium
- 97 v6 into a 00?
- Help me with this clicking!
- Rattle
- SLP's LM! Catback
- Replacing Windshield Wiper (Entire Unit)
- What am I missing here - Button below gear shift
- LT1 Cooling System help
- quick question bout the window motor
- Water leak thru Hatch Strut Mount?
- Removing Manual Window Crank??
- belt squeak
- knock sound from rear/tranny
- Is your car this bad off ??
- Braking problem
- Power Steering....help
- fuel filter/fuel line leak
- Mysterious rattle
- Elbow At Rear Of Valve Cover
- What is this part?
- Raw Gas coming out of exhaust??
- Fuel Gauge
- wierd problem
- window switch swap Q's???
- Hazards Dont Completely Work
- need some help
- TSC Sensor bolts
- vibration
- window regulator
- Whistling
- Need A Chassis Man
- Leak on passenger rear floor; drivers front floor!!
- Extended crank cycle
- RPM's dropping when coming to a stop or shifting out of park.
- car wont start??
- Castrol Synthetic 5-50 wt Oil
- Is it safe to spray the engine bay in order to celan it?
- Headlight motor R&R
- Question about O2 Sensor's
- Fuel Trim System Lean
- Bad vibration and pulsing when braking
- Header choice confusion
- QQ! Lock operation.
- Water leak fixed, still have a ?
- Plugged in code-reader and fuel pumped started priming
- Front Air Deflector Part#?????
- car won't start
- Removing ass stench from leather seats
- tail light bulbs
- rockauto.com
