- window problem *pics included*
- Car Wont Idle
- Horn Q
- Gut Cats!! Help
- AC line leaking from doing a H/C swap
- Oil Problems and filters, many questions.
- Fixing leaking P/S hose
- need help!!!!!
- Vibration problem?
- Dip stick popped out. Too much pressure?!?!?
- WTF! Please Help!
- weird noise?
- Winter Problem Fixing..
- help with 180 headlight motor gear
- Start up problem
- best replacement window motor?
- Security Light
- Steering Column Interchange
- oil pressure dropped 10lbs
- Power antenna
- Headlight help!!!
- mobil 1 0w 40???
- cruise control?
- High Pitched Whine At Startup
- Engine Temp Gauge
- After changing plugs.....
- Dex cool?
- code p1416
- Help Turn Signal Problem
- WHat is this sound
- Fyi
- erased an OBDII code and it never came back!!
- arcing around coil packs, rough idle, ticking/pinging sounds
- Serpentine Squeaks
- Changing the spark plugs...
- Problem on startup
- semi stripped drain plug
- Only Hi Beams Work?
- Power steering pump and LT's w/ cats
- Plug Gap?
- Headlight Question...not sure if it is the gears or motor
- 2 part number requests!
- OIL CHANGE light?? Comes and goes??
- Help with weird problem involving driving through large water puddles...
- Ran out of gas, please help
- Check Engine light????
- A fun list of, "UH-OH"s...
- storing a used shortblock?
- clutch pedal wont press in
- Low Trac light during hard braking, but not sliding
- Drivers window tint peeling
- Passenger window goes down but not up
- running out of steam at the top of first
- Valvetrain noise and adjusting rockers
- Knocking sound when turning/ ASR Turning off
- misfire after cats are gutted??
- Unexplainable Phenomenon!
- the weirdest thing just happend
- Rough Idle afte warm up
- A little help here please :)
- starting for the first time
- Who says Corvette O2 sensors, #13111, work?
- Front main seal
- Cylinders 2-4-6-8 misfiring all at once??
- My fuel pump is taking a crap help!
- Door panel getting a little loose
- Fuel pump help please!! Strainer issues,99-98 converted. Also more issues help!
- my winter beater 88 century shuts down when going 30mph why??
- would a bad 02 sensor slow my car down?
- broken headlight in a T/A
- Serpentine belt squeal?
- Horrible Gas Mileage, 15.8mpg w/o a led foot
- Cannot remove gauge cluster
- Seems like an electrical problem...
- Heater Core Info
- Instrument cluster light
- Very strange idle coming from car
- tail lights?
- Fans not coming on. P1641 P1642
- Whats the usual price for a windshield for a camaro?
- Y to I welded
- Valve ticks
- Anybody have the PN for the roof? Thats right, the defective b-pillar part
- My ASR light is off when I start the car...
- Aight, i need some Electrical Gurus in here..
- camaro ss running slow
- possible head problem?
- Massivly huge problem
- Replacement length for LS1 pushrods
- Oficcially Aggravated!!!!!
- A/C Question, plz help.
- ASR light wont go off!!!
- A/C problem
- Gear Shifter Button (Automatic Tranny) Gets Stuck
- Trans Service
- Code-Torque Convertor Quad Driver Module?
- Kind of a newb question...
- those with frequent o2/heater codes
- problems after FAST 90/90 install. need help
- AC making a fast chirping noise?
- Cleaning off radiator?
- Door Problem
- security ligh on starting problem
- need help figuring out why I'm lean!
- Emergency Brake No longer works after having car in the shop
- Does anyone else have an insanely hard time pumping gas?
- 99 T/a Check Engine Light Resest
- 94 Z71 TRUCK..tranny problem..help
- Help! Corvette won't start!!
- Stiff brake pedal and ZERO stopping power help!
- Rattle In The Rear
- Oil Leak... Oil in Bellows/Lid/valley cover
- Random/ Multiple Cylinder Misfire
- Does the Air Dam actually help that much?
- Threw this code....
- Window fell off track... WTF
- Lucas Oil Stablizer
- Deleted cats...weird problem!
- Please help me with my ABS light i have the codes:)
- Car tries to start w/o key in ignition
- No Power at the Top of Gear
- Mouse Deterrent
- Weird sound coming from rear passenger wheel
- Rough estimate for AC
- Clutch feels mushy when driving hard
- Tcs,brake,abs Inop
- Piece missing?
- Car stumbling! NEED HELP!!!
- AC makes a weird tick+sound when tuned on??
- Engine running rough after plug change no SES light
- Headlight motors on Firebird
- clutch chattering
- BACK FIRES Shifting Gears ?
- Random misfire return
- Car dies on highway any ideas?
- 4.8 cold start issue...
- Car wont start, need quick help...
- crankshaft position code ?
- Aggravating Interior Noise
- Optima Red Top
- Headlamp grinding
- volt meter prob
- drivers side wont lock
- still getting REDUCED ENGINE POWER message
- Headlight prob on 98 z28...
- 01 Trans Am, when use keyfob, lights go up and down?
- The damn thing won't start please help
- rear main seal parts & write-up?
- Oil leak?
- oil drain plug
- Loud clunk on transmission during gear shift(auto)
- starter problem????
- RPM puzzle
- code P0128
- Water in oil help please
- Weird Vibration
- What the hell did I break???
- How to repair fiberglass?
- Window
- When to change fuel filter
- OMGWTFBODY'S issues and repairs thread: Swap advice.
- oil pressure gauge gone nuts
- moisture in taillight
- Window Shudders?
- Mixed Green Coolant and DEX-COOL in my car! HELP!
- P1441 Code troubleshooting?
- Having a pinging sound under hood need help!
- How Far Can an LT1 Go?
- Security light at startup=no igniton
- WTF?? OIL blowing out at startup??
- A/C tensioner/idler pulleys
- Where to get AC Iridiums for a 1998 LS1?
- alternator clip?
- A/C clutch
- REDUCED ENGINE POWER message
- What could cause this starting issue?
- tranny mount
- Please Help. EGR Flow Malfunction P0400
- Steering wheel vibrates at 60+MPH
- odd vibration at 1900-2200 rpm
- Rough idle
- SES after plug/wire change
- SoCal, Longtubes, and Smog Check
- Electric problem! Anyone ever have this problem?
- What can it be???
- 2002 Mustang V-6 exhaust leak
- a few issues
- smoking!!
- can someone help me diagnose this problem??
- HELP- rattle!
- Sounds like popcorn?
- Noticeable vibration when car turns off
- LT1 coolant flush
- What's up with my gas tank?
- Air conditioning evaporator drain hose.....location???
- loose wires under hood?
- Ideas on my power loss
- Not running smooth when warm?
- Oil Pressure Gauge
- Replaced waterpump and thermostat and getting hotter than before!?!?!?
- Shifter vibrates when I accelerate
- Time for a tune up?
- Oil Pump taking a crap???? shaky needle help!!!
- Transmission problems: I could use some help
- Silver Stars Fog Light Bulbs
- Vacume leak?And some other questions
- big problems with the t/a
- Unknown Clunk?
- ripped up PCV system, advice needed
- Need help picking a new horn
- Installing Silverstar fog lights on Trans Am?
- Car vibrates while driving... hard idle... blue smoke
- Misfire? maybe a spark plug?
- ANNOYING SQUEAK!! Please help!!
- new problem can any one help?
- No turn signals...
- OIL seepage
- Pop up and grind. Amusing headlight antics.
- Turn signal works fine but stopped blinking (yes I changed the bulb)
- TQ arm mount????
- loud turn signal
- Car pulls to the left!
- Electrical Problem
- A/C - blows, no cold air, found green liquid, pictures inside
- Headlight adjustment screws trans am
- Checking Grounds...
- Help! Car drops voltage randomly. Its possesed!
- Driver Side DRL
- Help! Overheating Problem on Daughters V6 Camaro
- Strange fuel pump issue
- Rear passenger side exhaust rattle
- Seats arent working and im driving cross country in the morning help please
- ses light question
- Manual Vs Automatic Columns
- Replacing low beam headlights on Trans Am?
- Need some help with a/c leak.
- wont start
- bad road noise
- clunking on slow decel
- lights diming
- having problem with my taillights
- Misfire or something up past 5700rpms, help!
- so i broke my torqe arm mounts
- OEM motor mount for 98 ss!
- TERRIBLE noise!!!
- Fogs on a '97 Camaro
- is it bad to drive with the knock sensors bad?
- Weird problem when key is turned too ACC..
- Where are the knock sensors?
- Headlight Motorrrrrrrrrrrrrrr!
