View Full Version : General Maintenance & Repairs
  1. Intake manifold gasket help
  2. REAR AXLE BEARINGS & SHAFT REPLACEMENT
  3. Idle problems
  4. Gas mileage disappeared
  5. gauges issue (tach, speedometer)
  6. Alternator Problem, question
  7. Dead spot with varying points?
  8. R12 Oil
  9. Vibration help
  10. help with my metal screeching/ squeaking sound
  11. Is It Possible?
  12. Optima Battery - NG!!!
  13. Whats That Sponsor?
  14. Service Engine Soon
  15. are the front+rear o2 sens the inerchangebol?
  16. Headlight gear motor fix
  17. proper gap
  18. Coolant does not return to radiator
  19. Codes.....P0172 and P0175
  20. loose a/c compressor clutch
  21. Fuel Filter
  22. Low Coolant light
  23. Need a few Torque Specs:
  24. Whats wrong with my car?!?!
  25. oil pressure fluctuating
  26. Misfire???
  27. I have a problem.. Someone help please..
  28. knock sensor codes!
  29. Vacum Leak Test
  30. how often....???
  31. Car Starting
  32. Radio light problems
  33. O2 Sensors and Lean Banks SES
  34. E-brake light staying on?
  35. Optima Red Top vs AC Delco Stock - Weight
  36. F-Body - Temporary window fix?
  37. Surging at mid speeds
  38. Im stupid cruise doesnt work
  39. popped a SES
  40. Have a 03 Silverado's 6.0 motor? What's worth saving for my 00 Z28 and what's $$?
  41. Engine hesitation
  42. The truth behind firebird headlight repair
  43. Gross coolant!
  44. Noise made shifting from rev, drive etc...
  45. Can anybody tell me why my car doesn't want to start?
  46. what is this part called?
  47. Power Steeing went, AGAIN! Help?
  48. Fixing the Oil Pressure Sensor with Intake Manifold still on?
  49. Lt1 Needs Help No Spark
  50. WTB/Rent/Borrow Steering Wheel Puller?
  51. hatch shocks
  52. mixing weights of oil?
  53. blinker stopped blinking
  54. LS1 Oil Leak
  55. bad pilot bearing prob. ?????
  56. 98 z28 Idle Problems
  57. How do I remove my side mirrors?
  58. free mods
  59. fucking headlight motor
  60. broken head off manifold bolt into head
  61. Won some Oil, Okay to use in an ls1? 5w-50 castrol syntec
  62. Temperature gauge high, problems?
  63. oil change
  64. Starter ?
  65. Thudding noise
  66. Headlight Bracket broken
  67. window motor
  68. Can you mix spark plug wires?
  69. Idle Air Control question...
  70. Headlight Motor
  71. Quick Help Please!!!!!!
  72. whistle noise on highway
  73. timing question
  74. AC has 95psi and won't kick on
  75. Transmission shot?
  76. multiple misfire code
  77. Air Bag Light after Sterring Wheel Swap...
  78. accelerating sqeak help!
  79. Rubbing In Front End
  80. car throws out smoke, when shifting at high rpms?
  81. A/C Filter??
  82. HELP! Big problem with my power window and remounting
  83. where to order torque arm bracket
  84. Smoking engine after a/c removal......
  85. Headlight Adjustment?
  86. i wonder what I broke....
  87. Help About Power Steering Noise!!
  88. can i clean my air idel control sensor?
  89. Vats/ security light ?
  90. A/C, Noises, and grinding problems...
  91. Wierd Spark plug fouling
  92. Ground Locations
  93. No spark?
  94. Easy Job Gone Hard, Y Pipe
  95. water pump question
  96. car stumbeling when coasting
  97. Good Jack Stands
  98. The Tempature Gauge
  99. P0101 MAF performance Failure
  100. Whats this plug into?
  101. Idle Air Control
  102. NON OEM spark plug gap?
  103. Strange Overheating Problem
  104. A/C System part numbers
  105. Intermittent click under hood
  106. Car stumbles in drive at idle...help
  107. LT1 engine problems
  108. DS Window, pl and mirror trim piece
  109. drivers side wind noise?????
  110. ses light from air lid
  111. Circuit Location
  112. A big increase in road noise. How do I rid it?
  113. Oil Burnoff?
  114. Loosing power steering fluid. Have pics of problem
  115. Radiator Leak - Please Help
  116. Low Coolant Level sensor
  117. Altenator HELP!!! What am I doing wrong???
  118. Answer/Fix to Chronic Firebird Door Panel Cracking Problem Info!
  119. Car wont crank, need ideas...
  120. TA Headlight problem...
  121. changed shifter and now wont start help me
  122. help, weird noise and shake .
  123. Help me please( NO lights)
  124. Starting problem
  125. Mechanical Gauge
  126. Can i use just one hood strut?
  127. Interior humming noise?
  128. EVAP system
  129. Low Trac light coming on!
  130. Car Wanted To stall After Track A/C goes To Floor
  131. OBD II Codes
  132. high idle
  133. squealing at full lock
  134. Gas tank cleaning ?
  135. AC always on!!! and I over-heat?
  136. Wiper arm stops.
  137. are o2 sensors covered under warrenty? PO155
  138. rear diff.
  139. deploying and question on storing a ......
  140. Car is missing uphill and idles rough. Code p0102 and p0135..advice needed
  141. Newbie questions on drum brakes! Help!
  142. Repair your broken headlight mount!!
  143. A couple small problems...
  144. 2001 T/A daytime running lights/turn signal wiring harness?
  145. A/C Blower just stops blowing
  146. Foglight alignment
  147. Milestone! What would be good for it?
  148. I believe I can join the "I broke my oil pressure sensor" crowd...
  149. Turn signals not working
  150. Anyone know what the part # is for this? *PIC*
  151. new brakes minor problem? maybe?
  152. A/C Problem
  153. Tempature Gauge
  154. headlight motor
  155. A whistle while moving. HELP!!
  156. Euro headlights
  157. Dirty oil between 1,500k oil change?
  158. Quick Question????
  159. Anyone replace the ac condenser.
  160. engine misfire help
  161. Need some quick help with idler pulley issues
  162. airbox rubbing against hood?
  163. Battery/Alternator Question
  164. Replacement Power Window Motor Question
  165. LS6 - Where to get PCV valve cover grommet?
  166. someone help me please!!!!!!!!
  167. catch can with no oil?????????? wtf
  168. hard to reach wire...
  169. F-Body - How to remove turn signal lever?
  170. Squeak/squeel on start up
  171. rattle sound?
  172. WTF is wrong with my headlights???
  173. rly hard banging underneath car
  174. stock 02, auto, idle???
  175. Alternator problems
  176. pcv valve
  177. cracking sound from drivers side steering components
  178. rear end fluid
  179. 01Z doesnt start up on first try
  180. LS6 - PCV line leaking, causing problems?
  181. severe RPM drops when coming to a stop... mostly with A/C on
  182. Tranny rebuild, what do I need?
  183. Bogging..feels like no fuel is getting to the engine
  184. I got a light on my dash
  185. Upgrading tail lights
  186. 3rd brake light wiring
  187. Throwing serpentine belt
  188. question about a idler pulley
  189. Oil contamination in coolant?
  190. Drove in a puddle, turn signal problem
  191. HELP 150 miles from home!! ASAP
  192. anyone know where to get new power window bezel clips?
  193. What is going on??!!
  194. check engine light
  195. How much smoke on start up is normal?
  196. A-Pillar gauge pod light wiring
  197. Codes
  198. Over heated
  199. Coolant light pop
  200. how to remove drivers side window...search is out(need info asap)
  201. Weird problem
  202. Leaks, leaks, and more oil leaks...
  203. life of battery
  204. Turn signal / brake light problem
  205. car running hot 1999 ss camaro
  206. Airbag light ?
  207. odd problem after shutting off car
  208. Curse these headlights.
  209. drive side head light and slow window problem
  210. question about park lights blowing up??
  211. P0704 part number
  212. Lumbar and Power Seat Problem!?!?!?
  213. Boiling Coolant problems.
  214. Driverside Window Not Raising Up???
  215. z06 rear suspension real squeaky
  216. saftey belt loop??
  217. ticking noise
  218. A/C Help
  219. help on miss fire!!!!!!! PO300
  220. tach & speedo not working??
  221. car dollys
  222. I forgot to lock my t-top!!
  223. Traking down a water leak??
  224. my car is worse than baby girl
  225. attempting passenger window motor
  226. still poping
  227. Tube on Torque Arm
  228. no dash lights or ODO
  229. Tach can't keep up with the motor... missing shifts..
  230. Vibration under acceleration
  231. Cooling Fans Questions
  232. Driver Side Headlight
  233. mastercylinder cap
  234. EGR, block off
  235. bad noise runs fine
  236. Help Diagnosing Electrical Problem
  237. Need Help... Bad Vibration
  238. reverse lights wont work!
  239. Sucking oil like crazy, ford taurus.
  240. Mobil1 0w-40?
  241. Squeak after car has been sitting
  242. A/C compressor problems
  243. Clunking noise at Deceleration
  244. Gas in the oil 13qts?????
  245. what to do after a flood? please read
  246. New WP, New Thermostat, New Radiator, Still overheating!!!
  247. P0102???? In A Pickle
  248. RVT Gasket maker ?
  249. Distrubutor wont go in all the way. Help!
  250. Strange Turn Signal Problem
