View Full Version : General Maintenance & Repairs
  1. How Do You Adjust The Fog Lights On A Firebird
  2. another damn vibration.
  3. GC European Formula???
  4. idling issue stock 01
  5. Vibrations at speed, grinding, light steering, etc.
  6. Thin Oil in the LS1, Test #1...Success!
  7. Could a bad alternator do this?
  8. WTB: Headlight Motor Cover
  9. Changed headlight motor
  10. Dealership Maintenance
  11. Ebay headers. What do you think?
  12. Please help! I'm out of ideas.
  13. I may have broken valve springs... Help please
  14. what is this mysterious vacuum line?
  15. Compressor
  16. how do you adjust the headlights one a firebird
  17. Why cant I find O2 Sims?
  18. 900-950idle
  19. I fixed something and another thing broke
  20. Bad cat
  21. Fan relays/manual fan switch question
  22. Third Light Lens 2002 TA
  23. water pump questions
  24. Car seems down on power.Am getting code 300.
  25. Starter i think? HELP!
  26. Drivebelt problem
  27. Very light tapping sound after fixing exhaust leaks?!
  28. need help on purchasing a new alternator
  29. Strange Noise...i Cant Find The Source.help
  30. car keeps bogging
  31. problems when it rains
  32. can't figure out this problem....help!
  33. quick ?
  34. spraying co2 on intake manifold
  35. Seafoam
  36. Tach Calibration
  37. Help me identify this line
  38. Maf
  39. Recharging AC
  40. Starter problem
  41. corroded fuel pipe
  42. Low Fuel Light = No A/C?
  43. squeal when making tight turns (98 TA)
  44. Security Dash Warning Light
  45. How bad will the oil pan leak with one bolt missing?
  46. my driver window
  47. Charging the AC system
  48. How many times should I have to drain this damn thing before it is empty!?
  49. Bogging
  50. BCM codes help
  51. 95 Z28 not running right when hot.
  52. Side Mirror Installation / Cost
  53. Need help!! 96 T/A flex clutch line needed ASAP!!
  54. Best shocks to use with Hotchkis springs...
  55. Fuel mileage?!?
  56. Help! Rear Seat Screw Specs?
  57. Oil still clean after Seafoam?
  58. Stripped stud, wheel now stuck on car, need ideas!
  59. coolant leak from waterpump pulley
  60. alternator Harness
  61. 1994 Firebird - power loss on warm engine.
  62. What all controls the A/C compressor Clutch?
  63. trying to remove alternator.
  64. I'm an idiot.
  65. Front Windshield Crack
  66. Wifes car throws SES light...help.....!
  67. Low oil problem
  68. a marble in my crankcase?
  69. Engine bay fusebox Question
  70. Gasket part # help
  71. I'm stumped...
  72. Startup issue
  73. oil leak from ac compressor
  74. HELP!!! Water Pump I Think
  75. o2 sensors that rattle
  76. Can't coast for crap
  77. Window motor Q?
  78. sounds like change...
  79. Anyone ever try this?
  80. Little older engine TBI: Starting issue
  81. Moisture in Taillight
  82. windows and radio quit - help!
  83. running hot
  84. running hot
  85. Low Power Steering Fluid
  86. molding around windshield
  87. Uh oh, oil change problem with Castrol Syntec
  88. odd misfire
  89. 100000 mile Tune Up: Need Advice
  90. Flashing SES and weird surging
  91. Problem with 1996 Z28
  92. headlight problem (not motor)
  93. knocking noise
  94. Quick seafoam question..
  95. need a part no. key lock surround (black piece) for a 95 T/A
  96. window motor
  97. Detonation fixed!
  98. rattles coming from front suspension
  99. A/C compressor woes.....
  100. Only use 525 viscosity mineral oil on AC seals, or use an alternative?
  101. Heater Hose Problem
  102. electrical issues
  103. Where am i losing oil?
  104. Security light??
  105. Engine backfires then dies. Bolton 00 z28
  106. Car won't start on the first try
  107. Need Help broken t top lock
  108. Brake lights dim
  109. Squeaks , Squeaks
  110. another weird problem?
  111. Fans not coming on?
  112. major noise after sitting with AC on,,,grinding
  113. throttle cutting out / lagging
  114. Trans Am Headlight motor? Makes noise, Keeps turning?
  115. Knocking sound?
  116. belt noise?
  117. won't start
  118. BCM issues after washing engine compartment.....security light on
  119. Hatch Leak
  120. P1637??
  121. Alignment Question
  122. Alternator
  123. What would you charge?
  124. From BMR Tq ARM to stock? come on in!
  125. Shifting resistance/gears locking
  126. AC Condensor Camaro same as Trans am?
  127. Security Light, Problem with Starting Car
  128. Car just dies/ turns off
  129. Problem w/ ARP stud removal
  130. ac/hvac problem?
  131. More than I can chew.. ?
  132. Steering Wheel/ Alignment
  133. 2007 new body style gmc sierra pick up
  134. 6 speed shifter resistance & clicking
  135. Power Steering pump leaking?
  136. A/C Pressure Switch...Which wires to jump to test compressor clutch????
  137. Throttle response issues...lags at inital launch
  138. please help with a/c system problem....
  139. Anyone ever have any problems with their Air conditioning freezing up ?
  140. Help electrical problem
  141. Compressor Oil - Recharge... Another A/C thread..
  142. which oil to use???
  143. Broken DRL/turn signal light
  144. Window Motor
  145. quick and mild missfire when car is hot?
  146. traction control rear end into a non traction control 02 Camaro
  147. help
  148. Stalling and Dying no idea???
  149. Ac Compressor Help.
  150. Lookie What I Got Yesterday :)
  151. Is this idle behavior normal?
  152. pwr steering pump bolt broken in block
  153. AC Blowing out at feet and dash....
  154. Grease removal?
  155. My car won't start!
  156. Exhaust leak type noise
  157. Plastic piece underneath passenger turn signal?
  158. SS Wont Move!!!!!!!!!!!
  159. Probelm
  160. headlight motor....where to buy?
  161. Changing oil filter
  162. blue smoke, HELP!
  163. Air Conditioner Charging
  164. Plugging the PCM back in....
  165. Leak, Rear End? (Pic)
  166. Vibration under acceleration: Driveshaft?
  167. fuel gauge rests on E
  168. some weird noise: please help
  169. Sounds like crickets in my a/c
  170. Blew out muffler baffle? How do I fix this
  171. squeaks from car when hot.
  172. New Carpet
  173. Close to overheating!!!??? Need ideas
  174. How hard to replace fuel pump?
  175. Miniature flat tire...ish sound when braking?
  176. anyone have this happen... brake lights
  177. No high beams??
  178. question about map sensor
  179. air bag replacement
  180. Fuel Gauge help?
  181. squealing after it rains/water
  182. Want passenger side power window.
  183. ls1 compressor same as v6 compressor?
  184. Will hitting a speed bump with long tubes hurt the cylinder heads?
  185. Flushing A\C systems?
  186. headlight motor
  187. AC DELCO 41-985 plug gap question .40 or .50 for bolt on car
  188. Oil Pressure
  189. Water under passenger seat
  190. vibration
  191. Did I switch these two lines????
  192. car wont start
  193. Upper radiator hose collapsed... help?
  194. A/C blows hot
  195. seafoamed today
  196. Down on power + a backfire
  197. 2nd gen heater core HELP!!!!!!!!!!!!!!!
  198. A/C Pressure Gauge
  199. no cats and cut out
  200. Vibration and Clunk
  201. Help ! Abs - Tech2 Diagnostic Tool
  202. 17mpg.. 1/2 HW 1/2 City. Normal?
  203. My MPH gauges dont work, how easy to fix?
  204. NGK TR55 Change Interval
  205. What the heck is it made of?
  206. What is going on?!?
  207. $17.99 synthetic oil change
  208. overheating (cooling fan fuse)
  209. Water pump question???
  210. About to Seafoam...wish me luck.
  211. left blinker stays on...
  212. Flushing and replacing coolant writeup?
  213. Damaging Engine by Not Driving??
  214. Whinning Noise
  215. Exhaust Rattle
  216. Alternator stops charging when turning???
  217. Loose ground cause high voltage? ABS and Fuel harness together?
  218. Some Kind Of Noise When I Turn A/c On?
  219. Ps pumping with no fluid
  220. Gauge Cluster diagram
  221. Fix your leaking t-tops.
  222. Quick HELP AC
  223. HELP.driver side window just sopped going up or down
  224. Clicking noise at High RPM
  225. O2 Sensors, What kind to get?
  226. Gm part number
  227. Headlight weirdness...
  228. I think I blown a Head gaskett. What do you guy's think?
  229. Lights not working: no taillights , dash , or hazard
  230. Advice: Emissons (EVAP)
  231. Wires Touched now no power
  232. Lost engine power
  233. Whats the best way to change the alternator?
  234. Oil leak! But how?
  235. Ignition Problems 2
  236. Driver window does not go down
  237. Need some misfire help
  238. Normal Oil Pressure?
  239. Its RXP compatible with Seafoam?
  240. Click, no start....even w/ full voltage
  241. What the F*&K has happened to my car?
  242. Turn sig / Pk Light / DTRL - burnt sockets
  243. MAF Cleaning
  244. Strange Fuel Pressure Issue...
  245. Does your Firebird have bugs in it's rear?
  246. Overheating w/AC on during summer
  247. headlight problem
  248. Engine Storage Question
  249. Turn Signal Lever Issue
  250. what kinda oil
