View Full Version : General Maintenance & Repairs
  1. What would you charge?
  2. From BMR Tq ARM to stock? come on in!
  3. Shifting resistance/gears locking
  4. AC Condensor Camaro same as Trans am?
  5. Security Light, Problem with Starting Car
  6. Car just dies/ turns off
  7. Problem w/ ARP stud removal
  8. ac/hvac problem?
  9. More than I can chew.. ?
  10. Steering Wheel/ Alignment
  11. 2007 new body style gmc sierra pick up
  12. 6 speed shifter resistance & clicking
  13. Power Steering pump leaking?
  14. A/C Pressure Switch...Which wires to jump to test compressor clutch????
  15. Throttle response issues...lags at inital launch
  16. please help with a/c system problem....
  17. Anyone ever have any problems with their Air conditioning freezing up ?
  18. Help electrical problem
  19. Compressor Oil - Recharge... Another A/C thread..
  20. which oil to use???
  21. Broken DRL/turn signal light
  22. Window Motor
  23. quick and mild missfire when car is hot?
  24. traction control rear end into a non traction control 02 Camaro
  25. help
  26. Stalling and Dying no idea???
  27. Ac Compressor Help.
  28. Lookie What I Got Yesterday :)
  29. Is this idle behavior normal?
  30. pwr steering pump bolt broken in block
  31. AC Blowing out at feet and dash....
  32. Grease removal?
  33. My car won't start!
  34. Exhaust leak type noise
  35. Plastic piece underneath passenger turn signal?
  36. SS Wont Move!!!!!!!!!!!
  37. Probelm
  38. headlight motor....where to buy?
  39. Changing oil filter
  40. blue smoke, HELP!
  41. Air Conditioner Charging
  42. Plugging the PCM back in....
  43. Leak, Rear End? (Pic)
  44. Vibration under acceleration: Driveshaft?
  45. fuel gauge rests on E
  46. some weird noise: please help
  47. Sounds like crickets in my a/c
  48. Blew out muffler baffle? How do I fix this
  49. squeaks from car when hot.
  50. New Carpet
  51. Close to overheating!!!??? Need ideas
  52. How hard to replace fuel pump?
  53. Miniature flat tire...ish sound when braking?
  54. anyone have this happen... brake lights
  55. No high beams??
  56. question about map sensor
  57. air bag replacement
  58. Fuel Gauge help?
  59. squealing after it rains/water
  60. Want passenger side power window.
  61. ls1 compressor same as v6 compressor?
  62. Will hitting a speed bump with long tubes hurt the cylinder heads?
  63. Flushing A\C systems?
  64. headlight motor
  65. AC DELCO 41-985 plug gap question .40 or .50 for bolt on car
  66. Oil Pressure
  67. Water under passenger seat
  68. vibration
  69. Did I switch these two lines????
  70. car wont start
  71. Upper radiator hose collapsed... help?
  72. A/C blows hot
  73. seafoamed today
  74. Down on power + a backfire
  75. 2nd gen heater core HELP!!!!!!!!!!!!!!!
  76. A/C Pressure Gauge
  77. no cats and cut out
  78. Vibration and Clunk
  79. Help ! Abs - Tech2 Diagnostic Tool
  80. 17mpg.. 1/2 HW 1/2 City. Normal?
  81. My MPH gauges dont work, how easy to fix?
  82. NGK TR55 Change Interval
  83. What the heck is it made of?
  84. What is going on?!?
  85. $17.99 synthetic oil change
  86. overheating (cooling fan fuse)
  87. Water pump question???
  88. About to Seafoam...wish me luck.
  89. left blinker stays on...
  90. Flushing and replacing coolant writeup?
  91. Damaging Engine by Not Driving??
  92. Whinning Noise
  93. Exhaust Rattle
  94. Alternator stops charging when turning???
  95. Loose ground cause high voltage? ABS and Fuel harness together?
  96. Some Kind Of Noise When I Turn A/c On?
  97. Ps pumping with no fluid
  98. Gauge Cluster diagram
  99. Fix your leaking t-tops.
  100. Quick HELP AC
  101. HELP.driver side window just sopped going up or down
  102. Clicking noise at High RPM
  103. O2 Sensors, What kind to get?
  104. Gm part number
  105. Headlight weirdness...
  106. I think I blown a Head gaskett. What do you guy's think?
  107. Lights not working: no taillights , dash , or hazard
  108. Advice: Emissons (EVAP)
  109. Wires Touched now no power
  110. Lost engine power
  111. Whats the best way to change the alternator?
  112. Oil leak! But how?
  113. Ignition Problems 2
  114. Driver window does not go down
  115. Need some misfire help
  116. Normal Oil Pressure?
  117. Its RXP compatible with Seafoam?
  118. Click, no start....even w/ full voltage
  119. What the F*&K has happened to my car?
  120. Turn sig / Pk Light / DTRL - burnt sockets
  121. MAF Cleaning
  122. Strange Fuel Pressure Issue...
  123. Does your Firebird have bugs in it's rear?
  124. Overheating w/AC on during summer
  125. headlight problem
  126. Engine Storage Question
  127. Turn Signal Lever Issue
  128. what kinda oil
  129. low oil light???
  130. Door Lock/power Window switch light.
  131. Change rear break light?
  132. bad a/c.....
  133. Drivers side turn signal stays lit, not the bulb
  134. motor cluck noise
  135. Rumbling, Shaking, please look. Getting me worried
  136. knock sensor
  137. Vibration and Whistling at high speeds...
  138. power window motor install
  139. trouble code
  140. LT1 is ticking:: Video inside Please help.
  141. I just bought one of those A/C refill kits...Help
  142. Brake Lights Keeps going on and off HELP!!!
  143. A/C Pigtail
  144. What's this wire?
  145. Where did Bob(oil) go?
  146. AC Compessor in '98 Camaro
  147. BRAKE/ABS problem??
  148. Catalytic Converter power loss?
  149. How to install Auto-Trix window fix??
  150. Fuel saver things on ebay?
  151. Replaceing ac compressor and accumulator any tips?
  152. How to remove PWS rack
  153. Question for A4 owners regarding drivetrain noise
  154. Wierd Noise.. Bad engine??
  155. driver's side window stops halfway up???
  156. Oil Pan Bolts
  157. What causes power steering pump whine?
  158. Freon Capacity, need help
  159. tbi flooding badly
  160. Car dies when I turn AC on after startup?
  161. water pump died!!! Now i need a new one please help me out!!
  162. Passenger side Spark Plugs
  163. Differential Fluid
  164. damn clunk noise from right rear
  165. Change oil light on AFTER I changed the oil?
  166. to lean
  167. drivers side 02 not connected to anything??
  168. self-maintenance question
  169. intake gasket
  170. Starter kept cranking motor over after it was turned off
  171. power steering leak?
  172. Finally no more slow passenger side window
  173. a/c evaporator
  174. ignition lock cylinder
  175. Chevy hydro boost Can anyone help?
  176. Where to find weight of my car?
  177. Vibration and clunk
  178. think my water pump went out!!!
  179. Best header gaskets and where to get them!
  180. Missing head bolts?
  181. Cruise control clip
  182. have question about gauges on a 2001 silverado just bought
  183. 93-97 lt1 camaro's
  184. Just saw the new Motorcraft full synthetic oil
  185. Ac Compressor
  186. wiper arm wont come off!!! Help!!!!
  187. Low idle rpm
  188. How to install seat covers
  189. coolant light ??
  190. Antenna
  191. Dirt in AC Evaporator
  192. 210 degree Temp
  193. P0138, P0140, P0160. Header trouble.
  194. Help with 99 Camaro Pistons
  195. Power Steering Flush
  196. Misfire
  197. Girlfriend got a v6 camaro... whistling sound? vents open?
  198. Help!!! Help!!! Help!!!
  199. Axle Bumpstop part # anyone know it??
  200. Door Weatherstrip Name?
  201. I need your expert advice!
  202. wont start some times??
  203. fog light replacement?
  204. coolant problem
  205. rattle noise since mods have been done.
  206. Crazy electrical issues...HELP!
  207. Valveseals replaced, still problems. I dont know??
  208. Car won't start after new starter install. Ignition switch?
  209. Is it octane rattle?
  210. need help with drain on battery
  211. royal purple and oil filter
  212. Bad Rings?
  213. Oil Filter/Oil
  214. what should my oil pressure be? and sway bar ?
  215. Winding sound coming from middle of rear seats?
  216. Better alternative for exhaust bandclamps?
  217. whats wrong?
  218. a/c issues
  219. starter and bell housing help!
  220. Help with 98 Camaro?
  221. dont over oil your k&n air filter
  222. Penzoil Platinum
  223. need help
  224. Car died while driving
  225. Starting issues
  226. Head light problem.......
  227. 98 trans am TCS not turning on
  228. Is there any way to tell what month and year a 7 year AC Delco battery is?
  229. Need help with an A/C problem.
  230. Vibration after LT header install.
  231. A/C and Fan Problems
  232. replacing turn signal lever
  233. How To Replace Front Turn Signal Bulb
  234. AC Smells like Sh*t and Makes Odd Noise
  235. I Need Help!
  236. rough idle with AC on
  237. Volt gauge acting up
  238. Bad Rings?
  239. car wont start??? NEED HELP!!!
  240. AHH my dash!! somone inside now!!!
  241. Help with ABS
  242. Cooling fans not working
  243. Dexcool or the Green Stuff???
  244. stereo lock password?
  245. car runs funny
  246. Help! no idea what the problem is?
  247. Exhaust bandclamps causing exhaust leak?
  248. Turn signal lever is tough to move
  249. Refill tranny - no fill tube - late 1-2 shift?
  250. Door rattle when window down.
