View Full Version : General Maintenance & Repairs
  1. i have a dashboard wireharness problem
  2. when i downshift
  3. 95 T/a 1500-2000 Rpm The Gauge Goes Down While Engine Is Cold
  4. Oil pressure changes at same rpm
  5. filter brand
  6. A/C Compressor clutch
  7. 90,000 Miles Gcs Any Good
  8. check engine light came on at high speed
  9. Rat chewed on some wires!!!
  10. Steering slack -- shaft through firewall?
  11. A/C trouble and the good ole Orifice Tube
  12. car sputtering
  13. NGK TR55's.
  14. warped belt sound coming from LS6 intake?
  15. o2 sensor problem
  16. cant open hatch with key?
  17. LT-1 - Small Block Chevy Differences
  18. Can't find misfire, details inside
  19. smoke coming from some where
  20. Power Steering Fluid is ORANGE???
  21. oil consumption
  22. adjustable throttle cable?
  23. need new steering column, price?
  24. Fuel Filter
  25. Oil Leak out exhaust tips?
  26. Brakes: Is it supposed to be hard to reattach the caliper?
  27. Airbag question
  28. Changed Fluids, Gained HP?
  29. ls7 water pump?
  30. run regular oil for 100-200 miles?
  31. Help please!My window
  32. what car cover do you use??
  33. Weird knock in the motor...
  34. ?'s about posi traction
  35. Car will not start......Help!
  36. Instrument panel lights fuse keeps blowing?
  37. Brake Light Problem
  38. ac and power steering kills motor
  39. Random Misfire at low RPM
  40. LS6 Intake manfold?
  41. `98 seats into 2001 TA - Now no lumbar!
  42. Oil change question (No, not "how do I do this?") :)
  43. 2001 Trans Am Headlights Question
  44. Multiple engine misfire???
  45. So, I'm buying a 2001 Z28 and he told me this..
  46. Fram oil filters
  47. stuttering/bucking ????
  48. Changing Battery Cables
  49. Which SES scanner to get?
  50. Steering issues
  51. Plugs still good?
  52. Door wont open need help!!!
  53. T Tops Leaking...Where To Buy New Seals?
  54. Hood Bird/Paint Question.
  55. cooling light question
  56. Question bout Air conditioning harness..
  57. Easy way to check the A/C?
  58. squeeking tensioner?
  59. anyone know 3.4 v6s
  60. No oil pressure when I started the car.
  61. sqeaking coming from the back!
  62. anyone know 3.4 v6s
  63. loss of power?
  64. Fuel overfill?
  65. 98' TA, Dead Battery (new Optima)
  66. hesitating, stalling, sputterring,
  67. how to stop the y-pipe from hitting the floor
  68. Starter install, which to buy/ difficulty???
  69. Turn signals not working
  70. Seafoam and spark plugs???
  71. Removing side mirrors
  72. Has anyone ever replaced there door glass. can I get some tips and help with some ?'s
  73. I had wet carpet on the passenger side???
  74. Hi-beam switch is broken, sort of
  75. help please
  76. ses code
  77. traction control stuck
  78. car won't start and everything is going wrong
  79. Relays.... Did GM cut some corners?
  80. Oil leak help!!!!!!!!!!!!
  81. SES light: Evac syetm leak (small). Is this bad?
  82. Changing Fuild
  83. Faulty Fuel Gauge
  84. replace cat or get rid of it?
  85. 50 amp ingnition fuse blowing
  86. Oil FilterMAG
  87. Starter/Relay/Electrical Issues Car is sitting in a parking lot HELP!!!
  88. TA throwing a p0102 code
  89. Need a Water pump
  90. RPM range?
  91. air conditioning question
  92. no oil pressure!?!?
  93. Windshield Wiper issue *highly embarassing while driving*
  94. Bad horn or relay???
  95. rough idle, hesitation when accelerating
  96. Throwing MAF code after header install
  97. alt. help needed
  98. how to get to lifters?
  99. Fuel injector cleaner
  100. p1637, Think I found my gremlin?
  101. SES light, bad exhaust emissions, can O2 sims fix?
  102. Headlight motor
  103. Airbag replacement help
  104. nasty oil leak wtf? lol
  105. Turn signal keeps burnging out
  106. Ten Kinds of messed Up!!!
  107. car making a weird sound
  108. Weird light
  109. driver side window fixed :)
  110. Stupid Question?
  111. daytime running light bulb replacement
  112. water in horn ...
  113. turn signal not working not bulb ?
  114. Replacement wiper motor issue?
  115. MAF reading high?
  116. spark plugs
  117. Ls1 = Corvete Engine???
  118. Car won't start...
  119. Help! car is stranded at autozone
  120. fram, K&n, blackwing air filter
  121. gauge problems
  122. HPC coated stainless headers, how tough?
  123. starting issues
  124. **** WERIDDD sound from my ls1!!!
  125. HELP - I think I got water in gas
  126. Front Plate Screws? WS6
  127. Let see if anybody knows how to do this
  128. Which rack and pinion for WS6? Anyone have a WS6 VIN i can borrow?
  129. Catch can or LS6 Conversion?
  130. Check Gauge light flashes at high rpm..
  131. Putting chrome Lug Nuts On?
  132. car making a sound?
  133. high ideal
  134. Light rattle.
  135. Coolant Pressure Test Help
  136. Windshield wiper nut size?
  137. synthetic oil
  138. A/C Problem
  139. steering issues
  140. Wheel stud part #(yes I searched)
  141. engine about shot
  142. Rear end fluid change
  143. Blew my LS1 UP - NEED ADVICE!!!
  144. Odd Rotational Squeaking
  145. Too much oil...
  146. Oil Consumption, how to really figure it out?
  147. ABS light on????
  148. Pulley Squeaking
  149. How do you guys adjust your stock rocker arms
  150. Help!!!!!!!!!!
  151. Passenger side mirror keeps coming loose
  152. low oil light.And oil level is perfect help.
  153. Headlight Lamp h1, H4 h7 ?
  154. Jolting M6
  155. Fuel Injector question
  156. I keep blowing fuses for the turn signals!
  157. 2 problems
  158. AIR BAG light on?
  159. !AIR and inspection
  160. recommend a good maf please
  161. Fans are always on???
  162. Front Seat Belt Bolts
  163. 98 TA Center Console Part #'s
  164. coolant light on?
  165. Front side marker lights don't work
  166. Driver's Side T-top Rattle:S
  167. O2's got wet. What to do?
  168. Brights Quit Working?
  169. a4 issue
  170. cooling fan not working, fuse relay?
  171. stupid blinkers. help
  172. P1441 on 97 LT1
  173. loud screaching from my motor!!!
  174. Dumb question?
  175. Cruise Control problem....anyone have this wierd issue
  176. Rattle from pass side only when wet?
  177. Lug Nuts?
  178. Outer tie rod noise??
  179. undercarriage cleaning question
  180. Cruise Control ...... what a headache!!
  181. exhaust rattle at start up
  182. trouble starts
  183. Oil Pan Gskt Help.
  184. can you clean 02 sensors
  185. getting leaner??
  186. Something wrong here...0 to limiter video
  187. Front seal leaking, got a new one... still leaking ??
  188. Problem.
  189. Power loss. Not a sudden power loss, but....
  190. Headlight problem on a 02 Trans Am
  191. 2002 Alternator Rebuild
  192. transmission fluid in oil
  193. speedometer is not reading right any suggestions
  194. 100K miles - change the O2 sensors?
  195. Battery tie down
  196. I found 3 needle bearings stuck to my drain plug?
  197. car sat for 10 months now drivers power window won't work
  198. anyone just done away with ps pump?
  199. Interior Lights Won't Shut Off
  200. How to remove clamped exhaust?
  201. Power steering pump options...?
  202. autotrix
  203. Cruise control quit
  204. Vibration
  205. Bad water pump? Water pump gaskets? Something else?
  206. 02 trans am rattling problem from exhaust?
  207. fuel injection flush?
  208. what is this sound after warming up? (have video/audio)
  209. lube it up
  210. A/C Help!!
  211. Ignition Problem
  212. Left Turn Signal's Out
  213. smokin a little...
  214. Turns over, no fire, plenty of fuel pressure
  215. Throwing P0171 Code
  216. valve cover off
  217. vibration around 85, clunk when shifting
  218. cruise control cover....
  219. fuse wire
  220. Radiator Questions
  221. help now
  222. power steering problems
  223. A/C Compressor sensor???????
  224. Ttop Rattling Driving Me Insane!! Help!
  225. P0708 Transmission Range Sensor Circuit High Input
  226. How do you access the steering column?
  227. Water pump pulley
  228. Timing Chain
  229. Newbie Brake????
  230. about to purchase 02 z06......question
  231. Okay to contact previous owner about maintenance?
  232. What to use on door jambs for a quieter door shut?
  233. rear wheel bearings
  234. Coolant Leak From Water Pump...Any Ideas?
  235. Air system....where are the hoses
  236. souns dumb but im curious
  237. GMPartsCheap.com
  238. automatic lights not working
  239. Squeaks!
  240. Got this LT1 with a vibe *only when braking
  241. Bad Squeak!!!
  242. wierd noise when turning?
  243. Radiator hose leading to engine is rubbing on pulleys! Ah!
  244. Restore
  245. clunking noise when stopping
  246. Rear Main Seal
  247. Brake lights say on?!?!?!
  248. Tranny going?
  249. Need Answers plz
  250. Help Car Wont Hold Idle!
