View Full Version : General Maintenance & Repairs
  1. Vibration at idle
  2. Black specks on my oil dipstick tube?
  3. 1998 TA - Gasoline gauge a little off?
  4. Burning Oil!
  5. remounting hi-beam switch
  6. Stock LS1 misfire at or around 2000Rpm
  7. P0308
  8. High idle?
  9. What The Hell Is Wrong With My Car
  10. How to adjust fog light on formula?
  11. Coolant Disapeared?
  12. Ticking noise from engine area?
  13. engine died
  14. Buying a Z28
  15. Need new door for my Hawk
  16. Air in slave cylinder??????????
  17. Marble sounds and sparks?
  18. problem with temp gauge and cooling fans
  19. spark plugs?
  20. help
  21. A/C Problem, main vents not working
  22. Car is dead temporarily..
  23. plugs and wires in a V6
  24. Oil Pump going bad?
  25. All the Sercive lights come when hitting a bump?
  26. Window regulator
  27. overheating
  28. rear shudder
  29. Any ideas on diagnosising wheel bearing!
  30. Antifreeze smell
  31. Suggestions for buying new Jack!
  32. My rear end is already FUBAR?
  33. 91 Z-28 5.0 Running rich at idle
  34. wipers stop in the up position?
  35. how to get to my heater core?
  36. ac blows warm air??
  37. Need Help: If i Brake HARD in the LT1 The oil pressure goes wayyy down???
  38. question about ngk plugs
  39. Help..car intermittently pulls hard to the right??
  40. My gf crashes at the local 1/8 mile
  41. Help..noise in dash?
  42. Whirring sound, please help
  43. The Never Ending Belt Squeal.
  44. The TA wont start!
  45. Removing Washer Res. ??
  46. Need Help Quick!
  47. need help with spark plugs
  48. high rpm popping lt1
  49. Normal Spark Plug Wear?
  50. Ok Coolant Question, Somebody Chime In And Help!
  51. starter ear broke and also the outside bolt hole
  52. starter ear broke and bolt hole on block
  53. nasty exhaust exspultion!
  54. Seamfoam Did Nothing For My Car!
  55. Power Steering will only turn left? wtf?
  56. what the hell is this thing?
  57. *SENSOR* Help!!! (TP)
  58. FLuid inside of the car, smoke when running
  59. Leaking Coolant coming from?
  60. Leaking Coolant coming from? (pictures)
  61. Is the gasket for the tube off the manifold that goes to the check valve necessary?
  62. Engine Restore additive
  63. My window died
  64. Stereo lost bass
  65. Lose vacuum connection?
  66. yellowish foam in oil cap....
  67. Rear side markers don't work
  68. Oil leak on front of Engine cover? Help please
  69. Quick question re Starter on LS1
  70. LS1/Camaro Starter - Simple question
  71. Starting problem
  72. Wheres the EGR >.>
  73. Window Roller Felts??
  74. M6 tranny service...
  75. A/C, How much oil does it hold?
  76. My car won't crank half the time, other times it will...
  77. Are these normal things to need to replace?
  78. What spark plugs should i run in my camaro?
  79. no heat now wtf
  80. M1 TDT 5/40 spotted!
  81. Psi To Compression Conversion
  82. door windows rail grease
  83. Shaking/vibration at high rpm.
  84. AT 60k? What to do?
  85. Where is the Idle air motor located on the LS1?
  86. Royal Purple or Mobil 1 synthetic?
  87. Trunk space wet..
  88. pontiac WS6
  89. is this part of the radiator core (leak)? *pic*
  90. Vibration from Rear Under Neutral Throttle
  91. Whp makes the Best paper air filter?
  92. cyl 1 misfire...help please
  93. Hmmm....10W40?
  94. Brake Bleeding
  95. Brake light More Dim than the other???
  96. difficulty of changing serpentine belt?
  97. Window Motor Questions
  98. oil leak?
  99. oh wow...caliper fell off on freeway..
  100. Tailight sticks out how can I fix this?
  101. AC Compressor lines bolt on screw question
  102. untrackable misfire!!
  103. storing tires and wheels
  104. A.I.R. pump noises? 1998 A4 T/A
  105. Absolute manifold pressure...
  106. TA headlight
  107. ASR/Cruise Control Module/Servo WTF!!!!
  108. AC issues!!! Will not change setting....
  109. oo ford ranger turn signal switch...
  110. High idle after mods
  111. '99 Temp Guage - Common Problem?
  112. changing out a bulb and noticed i had a vac line disconnected..
  113. Cleaned / Oiled Filter....Idle Problems???
  114. clunk noise on drivers side shock
  115. Power Steering Leak
  116. tailshaft/driveshaft hitting body?
  117. ac idle pulley
  118. Lack of power or my imagination?
  119. ABS Inop Light
  120. transmission maintenance
  121. Possible ATF in the Coolant - Power steering cooler is the suspect + hose questions
  122. A/C Pressure Switch Location?
  123. Shaking
  124. Window does not seal. Pics inside
  125. Car Start up Problem?
  126. Electrical/Relay Problem, Need Help?
  127. Help!!
  128. Good jack for lifting my C5?
  129. C5:How to fill+purge brand new power steering pump/rack-Not working
  130. Chirping sound leading to insanity!!!!!
  131. New Belt
  132. Poly Motor Mounts
  133. Engine Blow By.
  134. Serpentine Belt
  135. my car has no balls below 25mph
  136. A/C Diagnostic *HELP*
  137. Right Front VIbration.
  138. Sea Foam worth it???
  139. Rocker Arms ques. please !!
  140. 1990 chevy stepside
  141. Rattle, Clunk between adj. torque arm and y-pipe
  142. Need advice: Cleaned my car's IAC valve. Now it's acting weird.
  143. Fuel pump whine
  144. Oil Leak Questions
  145. Mirror lights will not turn off
  146. 86 auto tpi vette won´t start
  147. Interior lights come on automatically
  148. quick oil filter ?
  149. ignition switch?
  150. oil pressure question
  151. Something is really messed up!
  152. Air Condition Service Help
  153. burning oil????
  154. Rear Defroster Trouble
  155. 98 TA headlight prob
  156. loud grinding when trying to start motor!!!!!!!!
  157. engine getting hot
  158. Windshield Wipers HELP!!!!
  159. Another oil Pressure question
  160. No dash lights please help!
  161. mpg seems to have dropped
  162. oil pressure???
  163. Really need your guys help, Car completely locked up, really nervous
  164. Dome and Map Light Problem
  165. I need some help, Lots of help!! OBD Gurus inside PLEASE!!!
  166. Got a code P0420...
  167. How easy is it to change my valve cover gaskets?
  168. O2 Bank 1 Low Voltage...What the HELL?
  169. O rings on PS rack?
  170. tapping for manifold
  171. Oil Leaking
  172. JB Weld
  173. Trunk wont shut :(
  174. my car keeps dying!!
  175. I think I have bad ball joints :(
  176. Need Help Please having OIL Problems!!!!
  177. dash light help???/??????
  178. replaced alternator
  179. Yeah, um about that spring...
  180. Possible? LT install, No Cats, No Sims, No Tune, NO REAR O2 CODES
  181. window not closing?
  182. c5 parking break
  183. Driving lights OUT, but front blinkers still operative......HOW do I do this???
  184. couple of problems i could use some help with
  185. Engine noise and oil leak
  186. seat belt light
  187. Window Trouble Need Help!!
  188. Headlight Wiring Harness?
  189. UOA/M1 5w-40 TrSUV, 3342mi, 1998 Z28 LS1
  190. High-pitched horn??
  191. A/C Idler pulley, where can i get this? Whys it so hard?
  192. Need help!
  193. oil leak
  194. Low oil level light...
  195. LT1 goes down. HELP!!!
  196. Little help with fogs and parking lights needed
  197. went and test drove today
  198. headlight help
  199. Need Help
  200. Vibration during parked reving, and lil in 5th, 6th
  201. Need some help
  202. Cheap, Easy Way to Keep Your T-Tops From Leaking
  203. LS1's and TPS's
  204. It Died this morning, HELP!
  205. Power steering fluid leak
  206. Help! Motor shot, need suggestions!
  207. My 02 trans am is being a FORD!
  208. Where to purchase window motor and K&n cleaner
  209. Transplanting Engine
  210. Lid
  211. Knocking sound, squeal when driving
  212. Oil in coolant? HELP!!!
  213. Window Motor???
  214. Problems with LS1
  215. Tick after Seafoam
  216. Oil Leak!
  217. headlamp motors shot
  218. O2 Code Question: Do bacnks go left to right or front to back?
  219. How do you change the #8 spark plug?
  220. Thermostat replacement
  221. Where to find weatherstripping?
  222. RTV silicone?
  223. Window Rattle Problem
  224. Rear-end oil change/site suggestion
  225. Emission?
  226. a little help please
  227. horn honks while off
  228. Clacking noise
  229. Alternator Issues!
  230. Dexcool gunk...
  231. figured out why my window doesnt work.. what is it?
  232. o2 sensor
  233. burning smell and smoke i think comin out of exhaust after a race
  234. 1998 Formula Steering Rack/Gear Boot
  235. Help! Can't get the starter out.
  236. PS leaking!!!!
  237. best oil
  238. Smokin
  239. Seafoamed my car tonight!
  240. bulb socket corrosion?
  241. Bank 1 oxygen sensor
  242. Any special method needed to add coolant?
  243. Torque ratings...
  244. High pitched noise.
  245. ?? on o2's
  246. tick under car
  247. throwin codes
  248. Seafoamed the Bird and Truck
  249. all power shuts off!!!
  250. Need help with daily driver!
