View Full Version : General Maintenance & Repairs
  1. o2 sensor
  2. burning smell and smoke i think comin out of exhaust after a race
  3. 1998 Formula Steering Rack/Gear Boot
  4. Help! Can't get the starter out.
  5. PS leaking!!!!
  6. best oil
  7. Smokin
  8. Seafoamed my car tonight!
  9. bulb socket corrosion?
  10. Bank 1 oxygen sensor
  11. Any special method needed to add coolant?
  12. Torque ratings...
  13. High pitched noise.
  14. ?? on o2's
  15. tick under car
  16. throwin codes
  17. Seafoamed the Bird and Truck
  18. all power shuts off!!!
  19. Need help with daily driver!
  20. Small rant
  21. lower ball joint replacement?
  22. Crappy interior plastic popping out
  23. Car idled high and then shifted itself in to 2nd?
  24. sputtering when accelerating rapidly
  25. Voltage Issue
  26. Battery Relocation Help (starts, then doesn't)
  27. Vibration issue tied to temperature??
  28. oil change question
  29. Header Install after results EEK ***VIDEO **
  30. Where to get air lid clamps?
  31. window piece broken
  32. gauges problem please help
  33. wierd prolblem with dash lights???
  34. ear piercing whine or someting ???????
  35. cat killing misfire at low revs
  36. sea foam help
  37. Head unit "SEEK" button...won't light up!
  38. LS1 TA Tail Light bulb # question
  39. Wipers "park" in vertical position.
  40. Help with my DRL/Blinker.
  41. I have stalling, bucking !!! HELP!
  42. Seafoamed my car...
  43. I think I have an electrical short?
  44. Engine Backfire
  45. PCV "Jacket"
  46. Broken bolts in the exhaust manifolds!
  47. wierd idle
  48. How to switch to synthetic?
  49. Start and die?
  50. SES Code.... Need some help please....
  51. emissions
  52. Coil pack not firing
  53. where to buy shift solenoids
  54. SLP Blackwing Air Filter
  55. Cruise control
  56. Turning signals not working!!...help!
  57. Oil Puddle under the car....
  58. Getting an Alignment, anything I should know??
  59. ses codes!!
  60. I'm stumped!!!
  61. OBD I or II
  62. Quick Oil filter queston
  63. surges around 4500 rpms
  64. Front end creaking
  65. Car wont start not dead battery
  66. Running rough and high RPM Ping..HELP
  67. 60mph + role of carpet = worries
  68. racing idle in park & neutral HELP Plz
  69. Clunk from rear of car when turning left
  70. Connector Diagram
  71. Check Engine light!!!
  72. Grinding coming from front of car
  73. Trunk latch
  74. 96 pontiac trans am keeps cutting off
  75. Vacuum Canister
  76. Air-to Oil PS cooler...
  77. Charging the battery with the battery fully connected to the car?
  78. Aux Power Outlet Access?
  79. starting problem
  80. Now it sounds like my brakes are going to fall off.
  81. Emergency - Just locked myself out... 01 z28 what should i do?`
  82. LOUD metallic screech on downshift
  83. I`m RICH and not cash flow
  84. Help removing brake lines?
  85. High startup idle
  86. something draining battery dead
  87. Fender sticking out....NEED HELP ASAP
  88. wierd noise when i turn??
  89. How To Test Iac?
  90. how to check for bad BCM
  91. Need everybodies help on this one
  92. wierd noise when i turn??
  93. Belt question???
  94. Weird squeaking sound
  95. front end alignment- new tires
  96. What do you use for ramps/jacks?
  97. voltage help
  98. Clicking Sound!!!!!!!
  99. Car missing at idle.
  100. my escalade is stumbiling
  101. whats this mean
  102. Battery drained + me stupid = hell 4 me
  103. car runs rough when warmed up
  104. Y-pipe hitting tunnel
  105. PS and Radiator problem
  106. Hit Curb
  107. Need help with idle......
  108. oil pan help...
  109. Wiring Harness under ABS module?
  110. Ebrake dash light
  111. mid graqde gas.
  112. No Start?
  113. Need some HELP with brake problem please!
  114. Installing AC Compressor
  115. Long trip tips
  116. PS or Transmission fluid in coolant?
  117. tranny flush vs. tranny fluid exchange.
  118. whirring under load
  119. tranny fluid.
  120. Center console (upper piece that shows the gears)
  121. lost the cap for my brake fluid???
  122. oil pressure drops like a bat outta he11
  123. oil presure gauge going bad?
  124. Why a seperate a/c belt??
  125. Need some tranny help?
  126. Need some expert advice!
  127. iac counts low
  128. URGENT window motor question
  129. knock sensors and mech overrev
  130. Rear wheel Hub Bearing assembly
  131. Please help Me!!!Gauge resetin
  132. trans oil in the engine?
  133. Getting window all the way up
  134. Locked T-Top Cant unlock it now
  135. head gaskets
  136. feeling a vibration
  137. Vacuum Leak
  138. broke spark plug in motor...need advice
  139. Big Water Puddle, Under Back Seat..
  140. ac comp clutch low press switch ?
  141. Car running lean in bank 1 and bank 2
  142. Door Unlock problem
  143. Key Cylinder Problem
  144. Car won't start, possibly battery connections
  145. stripped out tranny cross member bolts
  146. Part number for fog light replcement?
  147. Exhaust banging
  148. heating and air conditioning
  149. GC in Winter
  150. AC Controls Stopped Working
  151. Toy Drum up Front
  152. Oil Pan Gasket ??
  153. question!!!
  154. Backfire?
  155. wierd noise discovered
  156. Oil in knock sensor hole
  157. whining speaker
  158. 2000ss Window Motor problem?
  159. Starting problems
  160. 1999 Camaro Headlights not working?
  161. Rear Hatch Trim Plastic
  162. part number
  163. new here need help PLEASE!!!!!!!!
  164. Oil Change w/Lucas & Seafoam Question
  165. MSD wires?
  166. failed inspection, need help with high beams
  167. My car shakes when I stop..
  168. O2 sensor problem...
  169. Unknown issues....
  170. Instructions for changing 4th gen window motor
  171. Will a bad ac condenser cause clear water leaking?
  172. im gettin alot of surging. ???
  173. Jumpy acceleration??
  174. weird noise from engine
  175. Car runs like a$$ when cold
  176. oil pump died?????!!!!!!!!!!
  177. What is this tube for?????
  178. High Beams turn signal stalk assembly help *****LARGE PICS WARNING*****
  179. Torque specs?????
  180. Hears a good 1 for ya.....
  181. Headlight are flickering
  182. TA radio knobs
  183. How often should the brake fluid be changed in our 4th gen F-bodies?
  184. Help, lost all power, no lights, won't start, nothing
  185. How do I zero out the TPS sensor?
  186. O2 Sensor Replacement
  187. What does milky oil looks like?
  188. Bogging engine
  189. Impala Air pressure light
  190. LS1 TA Foglight replacement.
  191. sponge or mitt!
  192. best place to get new window motors
  193. Air Intakes
  194. car will not start.....battery is good
  195. Knock Sensor/Header Hit Problem
  196. DS power mirror problem
  197. Jerky acceleration and service engine light
  198. Coolant reservoir cracked.
  199. 4L60E - Replacing shift light on console?
  200. How to clean IAC valve and throttle body?
  201. Hood Wont Stay Shut Tight (2000 Ta)
  202. Conv. Top???
  203. CODES: PO140, PO154, and PO160
  204. Removing wire on alt
  205. need a new car battery
  206. need a new car battery
  207. Water In Tail Lights !!
  208. Random idle behavior..
  209. Where are y'all getting factory replacement parts from?
  210. Oil pan and Rear main seal leaking?
  211. A/C Service question
  212. Can you add DRL's to '96 Z28???
  213. what's the best type of plugwires?
  214. Removing torx bolt by kickpanels for seatbelts...
  215. daytime runing light and blinker issue
  216. Seafoam Q.
  217. Performance Transmission Mount...
  218. Car keeps dying!
  219. I'll try again - IDLE PROBLEMS WITH 98 A4 LS1 CAM
  220. Interior Door Panels
  221. Window motor questions before repairing
  222. Shaking
  223. Need help ?!?!
  224. Sqeeking around the pulley wheels
  225. big backfire
  226. Need a little help
  227. Need Help!!! Oil Question????
  228. MOBIL1 is a blend now!?
  229. Throttle body swap, bad idle, need retune?
  230. temp going nuts
  231. Need help with my ford taurus, plugged cat?
  232. Pos bat cable wiring
  233. camaro foglight bulb replacement
  234. some weird electrical problems
  235. How do you know you really getting 91+ gas?
  236. losing voltage???
  237. Ebay knock sensors
  238. Replacing Waterpump
  239. replacing weatherstripping yourself.
  240. What's wrong with my front suspension???
  241. E-brake adjustment???
  242. Headers And Ory Installed... Major Problems!!!
  243. Mobil 1 Turbo Diesel Truck 5W-40
  244. Low Voltage
  245. engine build problem
  246. does anybody have a third brakelight for a 98-02 SS?
  247. slipping somewhere?
  248. is it comon for waterpumps to go bad?
  249. I dont think its the Power Steering but..
  250. Clutch!!
